Visitor Agreement.
on the 2006 Sedona easy to change? And,
where is it located?
along with all the other problems. So, I had to get a lemon law lawyer. Its the best and only way I can see to get Kia to do anything.
Kia Sedona Brake Problems
Kia Sedona Stalling/Idling Problems
Good troubleshooting!
Here is the history:
Obnoxiously squeaky back/side window since it was new, but only in the cold. Once the car warms up it quieted down some. I brought it in three times for this, but of course the car was adequately warm once I drove there and it wasn't squeaking. The dealer would not replace the window for me unless they heard the squeak so I live with this one. Nice for a new car!
The the front end started with some "jiggling" type of noise. Brought it to the dealer who said nothing was wrong. Brought it another because it was so bad I was worried about safety. Was told it was normal "wear" of the struts and Kia said NOT to replace them because it will happen again. It's an obvious noise to eveyone who drives in the car (including my half deaf mother-in-law)and very embarrassing to have an almost new van that sounds like that.
Next was the alternator that went at 20,000, had to get towed. Apparently this goes in almost all of them at some point between 20 and 30k miles.
Next was the engine light intermittently going on. Ended up being a broken fuel sensor in the fuel tank. This was determined when the car didn't pass Massachusetts state emissions testing. Had to be ordered, so two trips for that problem also.
Next was the engine started sounding like a Mack truck on start-up until it warmed up. Coincidentially this started the morning after the alternator was replaced, but they said it was unrelated and don't have an answer as to why my van sounds like a diesel dump trunk until it's warm.
Presently the power steering is failing, the dealership is calling Kia to find out whether to replace the pump or just start by flushing the system.
Let's see, next present problem is the driver's side door lever (outside) broke. Pin fell out. Went in and they don't stock the pins. Need to order a whole new door lever mechanism. Made a second appointment for this problem today.
In general the engine has "pinged" on acceleration since day one despite using high octane gas and using dry gas from time to time.
Positive notes on the car are good transmission, great seats (although these older model seats are a killer to pull out of the back), convenient controls, homelink and many other options that come cheap (although that's probably not a positive aspect since the car is not worth the cheap price!)
I'm going back to Honda or Nissan....drive it and be able to forget where the dealership ever was is a better way to live!
Also, in the spring when I first took it in to have the "ping or tap" noise looked at, I also asked them to change the gas filter, as the van was running rough. They couldn't change the filter, because it had rusted right to the gas tank, and they had to replace the whole tank, under warranty of course. The guy behind the counter all but wagged his finger at me saying that had I changed the filter at 50,000 ks as the service manual recommends, this wouldn't have happened. It wasn't until I got home and checked my book that I saw that the gas filter was being replaced at the exact mileage that is recommended in the book.
We've decided to get the three present issues addressed, contacting and involving the regional service manager if necessary, then we're unloading the van, and replacing it with a Honda, which is what we should have bought in the first place. I used to be the unfortunate owner of a Hyundai Stellar, and this is all starting to smell similar. It's not the issues with the van that has turned us off KIA, it's their service and obvious reluctant to address known issues, that has destroyed their image in my mind. I don't care what they sell their vehicles for, they're as disposable and cheap as a bic lighter.
We will never buy KIA or any Korean car again , as long as it's associated with Hyundai, and we will certainly be as vocal as possible with our dissatisfaction to friends, family and colleagues.
I would say it appears your airbags operated exactly as designed, by not deploying. The front airbags are designed to deploy in more direct "head-on" collisions. The side and curtain airbags are designed to deploy in more direct side impact collisions.
It sounds like your collision didn't meet either of those requirements. For the front airbags to deploy the front bumper would have to have been hit. The sensors are behind the bumper area.
The front airbags deploy with a great amount of force. They are designed to "catch" you when your body is moving forward with a great amount of force due to a "head-on" collision. In the accident you describe, the airbags probably would have caused more injury than they would have prevented.
What is your opinion of how the Sedona protected you and your passengers? Is it going to be repairable? If you have a picture of the damage, maybe you could post it.
The dealer "couldn't reproduce the problem", but it appears as though at least one other person is experiencing the same problem (they've posted a video on youtube).
Is anyone else experiencing this problem?
I suggest that you research the Lemon law in your state.
Has your dealer provided you with a vehicle to drive while he has yours?
P0441 - Evap. Emission System Incorrect Purge Flow
P0128 - Coolant Thermostat (Coolant Temp. below Thermostat Regulating Temp.)
This may be related to your Sedona's problem.
Clicking "Track This Group" will make sure that you don't miss any new posts or discussions. When you come back the next time, just click on "Read New Posts" and you'll be able to click through all new posts and topics in this board.
