Pontiac GTO
Thing to remember is, by the time the 05 Mustang GT is out, so will the 05 GTO. And that will be faster and likely gain even more of a luxury edge over the Mustang.
The GTO will sell, not like hotcakes but it will make money for GM.
Brian
I’m interested in both the GTO and Mustang (see my bulleted comparison on page 43, post #841). I think both cars have strengths, so I am looking at each in an unbiased way to ensure that I buy the best car for my tastes. Your comments, however, are mostly based on brand loyalty and are riddled with holes.
Consider some of your complaints:
• Gas tank location: The GTO’s reinforced gas tank is mounted far forward in the trunk to ensure that it doesn’t rupture in a collision. Check blueovalnews.com if you want to learn how unsafe the current Mustang is – in a rear-end collision, the rear-mounted tank can easily rupture and roast occupants, even in low-speed collisions.
• A six-speed transmission has nothing to do with torque and everything to do with fuel mileage. The GTO is rated at 29 hwy, which exceeds the 25 hwy figure for the ‘Stang. (And the Goat has a liter more displacement!)
• You state that an OHC engine is better than a pushrod engine. Based on what? Although I have not been a GM fan in the past, the 5.7 has rock-solid reliability, tremendous horsepower, and a willingness to rev. So an OHC engine is better in what way? From what I’ve seen on blueovalnews, the Ford 4.6 has had quite a number of problems in various model years, including head gaskets, warped heads (Cobra), valve ticking and other problems.
You make good points with regard to the Mustangs use of regular grade fuel (about a 12% price difference, though, not 20%), and the price difference. The rest of your statements are opinions which you present as fact, and even at that, they are extremely uninformed.
I'm still undecided on which car to buy ('05 Mustang or '05 GTO), but at least TRY to keep things factual.
At 18,000 copies/year for the next 3 years it wont have to sell like "hotcakes". My guess is they will all sell and no incentives will be required to move 'em.
The automatic 2004 GTO has a guzzler tax (freeway).
The 2004 Mustang Mach1 automatic ( but flashy) has no guzzler tax, MSRP is $30,575, no IRS (only $2k less than GTO, $32,495).
The GM and Ford engines are both basically pretty good, although they put a cast crank in the DOHC Mach1 automatic car.
The 2004 Mach1 is about 300 pounds lighter & six inches shorter than the 2004 GTO.
The new 2005 Mustang looks much nicer than the 2004 mustang.
The mustang gas tank is on the bottom, between the bumper and rear axle, not real safe, if the bumper hits the tank. The 2004 GTO gas tank is more isolated for crashes. The mustang gas tank is in the same location area as part of the IRS trailing arms on the 2004 GTO.
you DO know. I just told you. Its in the trunk.
But I am curious. If it was not in the trunk in the '68, then just where did the fuel filler neck run? Its in the same location as the '65-67, which was in the center of the rear panel under the trunk lid. The fuel filler neck ran right down into the gas tank, which was right there under the trunk. So where did it run in '68? You mean to tell me that the neck ran down from the rear panel through the trunk, made a 90 degree turn, ran all the way under the trunk to in front of the rear axle? I find that odd. I'm not saying its not true. Just making an observation.
I'm glad to see some of the reactions to the GTO. It is confronting to get an import with a revered local name but judge it for what it is a great car.
Re Exploding gas tanks. I haven't heard of any Monaros catching on fire from rear shunts (ours have the fuel tank under the trunk). We have only seemed to have had any fires when people started spiking our fuel with ethanol. Otherwise it is rare to hear of fires in anything other than catastrophic crashes. Now that the ethanol problem has been solved no more fires (think flashpoints).
Hope this info is what you were after
Cheers
Two quick points:
1) with premium gas at $1.80/gal here and going higher the GTO will be a very expensive everyday driver
2) I also saw it at the St Louis auto show. The styling just did not grab me. I know many like the "low key" look but the car just has no character of its own. Maybe the '05 will be an improvement. The interior was very nice except for the lack of full instrumentation.
I understand what MidWestTrader is saying, though. When I saw the Mustang at the Detroit auto show a few weeks ago, its styling REALLY grabbed me. It's a really neat car.
I'm sure I'll be happy with either car, which puts my mind at ease.
EZRAPON, I too looked at the 300C, at the urging of a friend of mine from Chrysler. It looks like a really good value for the money, although the tank-like look is just not me. Anyway, I want a COUPE with a MANUAL transmission. C'mon Chrysler! Get with the program!
On the other hand, I have read that the Aussies have built the GTO to be a very sturdy car. This is appealing to me, since years of pothole abuse in my Northern climate has a way of beating up a car's chassis. (My Avenger has new ball joints, new rear struts, new front wheel bearings, etc...)
If the reason for the GTO's substantial weight is because they used beefy parts, then I am okay with that. Just wanted to share that...
Let's end the personal comments here. Any further posts along this line will be deleted. Thanks.
kirstie_h
MODERATOR /ADMINISTRATOR
Review your vehicle
MrShiftright
I just noticed that the new 2005 Mustang will be using DBW, yuck.
Audi has been using DBW for several years now. Their throttle has a nasty habit of waiting 1-2 seconds, before actually applying the throttle, but only sometimes, usually, when the delay will cause driver errors.
I hope GM & Ford makes the DBW response quicker and predictable. The Audi system is terrible, especially on the Tiptronic (Automatic cars).
Don
Here's an idea: DRIVER SELECTABLE throttle response. You could have Normal, Sport and Winter driving modes. I think one of the European car makers does this, although maybe I'm just thinking of the transmission shift points.
BenJorden: As far as the hosts go, they were correct to delete the offending posts. Although I pride myself on being eloquent (even when I rip someone apart), I really shouldn't have descended to the other person's level. Apologies to all.
Trunk - I understand the reasons for moving the tank into the front of the trunk. But...the Monaro trunk, I understand, is far bigger, while I believe the tank to be of similar size (anyone know for sure?). When they moved the tank to the GTO's location, what did they do with the space where the tank is in the Monaro? Could they not have expanded the GTO trunk into that area?
thank you
LOL.
I have yet to see a GTO on the roads or a dealer's lot, but I checked it out on the Pontiac website and sampled the audio clip of the engine running. SWEET!!! Nothing like the burble of a big, American V8 engine. If I could afford them both(along with the gas and the insurance) a black GTO(with the red interior) sure would nicely compliment my Lincoln LS V8.
Saw a black/red/6M Friday.
I liked the car a lot.
At 6'8" I can fit in it!
Interior is a 3-400% improvement over a Camaro.
Much better materials and design.
The car is not palin at all. Just very stealthy.
It has an incredible stance to it.
Very little void over the tires.
I would probably remove the spoiler and have the wheels polished if I bought 1.
Problem is the dealer has a 38K sticker on it.
They must like it a lot.
When I can buy one under 30K I might bite.
I hope it is very successful and that dealer's greed does not cause slow sales.
I felt out 2 dealers to see where they were on price - no surprise that both were firm at MSRP. The kicker was on the trade. An AWD 2000 Safari SLE with 39,000 as equipped TMV'd here for $9500 (Trade-In). One dealer gave me $7500 and the other was $8500. Both had a "take it or leave it" attitude. I left it.
As far as your trade, your best bet is to run it by Terry on the REal-World Trade-in Values board here on Edmunds. But I can tell you that Edmunds trade-in TMV is usually wrong. Of course, if I was paying MSRP for a vehicle, I'd want more for my trade, too.
good luck in your search.
Somehow I don't think that's what Lutz and GM had in mind for a $30k sport coupe.
The GTO may not set the world on fire with its looks, but to ME, it's attractive in a very understated way. I believe that a car's most important attribute is its construction and drivetrain, and from that standpoint, the Goat is a terrific car.
To draw a parallel: My '97 Avenger never set any styling trends, but seven years after purchasing it, I still like the looks a lot (and it's been a reliable car). So it was a good choice for me.
So, while some feel that the GTO has a similar shape to a Cavalier, you could also allege that a Hyundai Sonato looks like a Mercedes C-Class. Does that mean that a C320 isn't worth the extra money? Of course not! The Merc is a far better car, so the comparison is silly.
Styling is definitely important, but I believe vehicle engineering is even more important, and the GTO seems to have solid credentials in that department.
P.S. Hey Pontiac: Could you please put a smoother, short-throw shifter in it?
This particular dealer is not marking the car up, and is selling it at sticker ($33,495 plus tax, title & license). My only regrets are that the salesman wouldn't let me sit in it, and the hood was locked, so I couldn't see that su-wheeet 5.7 Litre. Dang!
Since this dealer seems to be so overprotective about people wanting to check the car out (but not overprotective when it comes to the weather, apparently), he may not be getting too many test drives or sales if the cars are being treated as museum pieces.
