Visitor Agreement.
On the highway or interstaes, I try to keep in below 75 MPH or 2,200 RPM in OD. Off the intersate I try to run at 55-60 and not use cruise so it does not sown shift on hills. I live in the mountains ...
As far as BF Goodrich tires...The Rugged Trails on mine are NOT low rolling resistant. I think when I get new tires and go with a highway ribb type tead it my increase the MPG....I DO NOT LIKE the Rugged Trails on mine...they are too soft and won't get the mileage I am used to...I'll be lucky to get 40K on these tires. I do about 50% highwy driving so I am dissapointed in these tires. The ride and handling is good but the tire is to soft for highway driving, resulting in less mileage. I run the MAX tire pressure on these too. That can affect your MPG as well. an underinflated tire will use 10% more fuel than a properly inflated one.
OK Hope this helps...
Car stats: Extended Cab. Automatic Trans.
Note: To get the high mileage I just have to slow down to 60 m.p.h. and drive at a steady pace. No fast starts or stops. It makes my trip about 5 minutes longer. At 65-70 mph I get about 28 m.p.g. highway.
If anybody does better I'd like to know, and how.
My 07 2WD off road TRD Pre-Runner with 4.0L double cab normally gets 20-21 hwy and 19-20 around home...as of late I have seen a 15% decrease in MPG....I found out that Texco locally is adding over 10% Methanol to the 87 octane gas...so far Shell is not doing that here but I suspect all the majors will be before long, if they can get away with it....using shell I still get the 20-21 Hwy and 19-20 around home....not bad for almost 6,000 lbs of Truck and it sets as high off the ground as a 4WD....
I have BF Goodrich OEM's now but next year will put a highway rib type tire on...maybe a Continental Conti Trac tire and should improve MPG a little more as The BFG's add some drag. Good Luck!
I have now about 40,000 miles and nothing has changed from day one. I am thinking of selling it for just this reason. I love the truck otherwise but bad gas milage for a 6 banger. I had a Plymouth Voyager van with a 6 banger that got close to 30 MPGs. With the Toyota, I can literly watch the gas gauge go down from stop to stop!!!
What gives???? Any help out there
I can be contacted at 310-227-6860 or email at mecone@aol.com
Martin<a href="
I get 14 MPGs with my 2x4 Toy Tac TRD
May have a cure
Martin 310-227-6860
email: mecone@aol.com
21, 19.5, 20.5, 20.5 and 20 mpg. Mostly driving back and forth to work, no long trips yet.
Mick
Do Taco's (and other trucks) get 2WD-like gas mileage when they are operating in 2wd mode?
My questions are,
How much gas can you get in the same vehicle?
What is the vapor recovery capacity that this extra gas is going into?
A two liter diesel getting 140hp and 230 ft/lbs would likely push the Taco to 25/35 mpg. It would make a nice little stump puller too.
This is all fantasy of course. I guess its back to the real world.
Great truck, debating getting the same one as a replacement. Or going to the Access Cab 2.7L for a little more fuel savings. My guess is if my driving habits kept me on the high end for the Dbl Cab V6, then on the Access Cab base, I'll be in the 26-27mpg. Hopefully... comments?
The only pickup I've had that got better mileage was my 99 2.4 5 speed (not a Prerunner) which I got 28 highway with once. I think there's a penalty in aerodynamics with the Prerunner because it sits higher off the ground. I'd love to have a new Prerunner Access Cab with a 4.0 5 speed automatic and a scangauge to play with for awhile to see how good I could get out of the new V6 auto combination. I never got better than 22.5 out of the 3.4 4 speed auto Prerunner.
I'm with avalon02wh in msg #338. If Toyota engineers just swapped a few parts around, they could make MUCH BETTER PRODUCTS... and bring us the diesel from the HiLux that they build in the rest of the world. And if they built one the size of my 1986 Xtracab, I'd be even happier !!!
Amazing how many times I've whined to Toyota and GM about the stupid products they build... and all I ever get back is "We're sorry you don't like our product." So let them lose money and go bankrupt... why should I care?
Ever notice that a Prius has little skinny tires and it isn't jacked up 3' in the air? It's called "less rolling resistance" and aerodynamics. Been there, done that. Big tires cost me 2 MPG. K&N and Flowmasters cost me torque, and no improvement in MPG. Jacking it up changes the aerodynamics so that 60 MPH is now like trying to move through the wind at 90 MPH.
But it sure looks cool :shades:
I just drove a new Honda Fit the other day, which has a fuel economy gauge on the dash right in front of the driver. I think EVERY car sold in the US should be required to have one !!!
Very pleased with results. Great truck. The bed cover didn't change MPG.
TSB installed to cover load/handling. (new shocks and 4 rear springs).
Mick
I was just going to go with what I had in the past; a base 4cyl. As I checked out the specs I noticed the base 4cyl Prerunner is about the same money. The EPA MPG estimates CLAIM to be the same for both of these 2wd models but I'm not convinced.
Even if you don't take the higher resistance caused by the larger mud and snow tires or by the higher profile of the Prerunner into account, I can't see how the Prerunner could even come close to the regular Base 2wd for MPG.
According to 2 different published sources, the gear ratios inside the 5sp manual tranny are the same for both models. The only published difference being the Base 2wd has a 3.307 rear diff and the Prerunner has the 4.10 rear.
I ran calculations for the 2 different rear diff ratios ( taking into account the difference in tire diameters) and I show that the Prerunner mill will turn approx. 200 rpm higher at (my) average highway speeds.
Am I missing something? Did EPA miss something? Did Toyota find a loophole in reporting MPG specs for the Prerunner?
As I said, I'm really spoiled by the 25 mpg I'm getting with the Rav4. When I priced the 2 models equipped as I want, there is almost no difference in price. The Prerunner comes equiped with options that I already want on the Base model and the extra payload capacity of the Prerunner sounds good for when I haul camping gear.
Like most people I want to have my cake and eat it too but am not wanting to have a rude awakening if the MPG for the Prerunner in reality is significantly lower than advertised. I'm on a very fixed income and the MPG makes a big difference in my daily driving.
I am a very conservative driver and am willing consider changing tires on a Prerunner to a compound that would improve highway mileage.
So... I'm turning to you in hopes of getting some real world numbers for a Regular Cab - 4cyl - 5sd - Prerunner.
A shorter (numerically larger) ratio will increase mechanical advantage-increase low speed torque, but will cause the engine to rev at a higher RPM while cruising. A taller (numerically smaller) ratio will decrease mechanical advantage-decrease low speed torque, but will cause the engine to rev at a lower RPM while cruising.
This can easily be demonstrated on a bicycle with multiple speeds/gears. Put the chain on the largest gear on the cassette on the rear wheel and on the smallest gear on the crankset. The result is all torque, no speed. You, as the engine, won't have to apply much force to get rolling, but will have to pedal at high rate to maintain any speed. Conversely. Put the chain on the smallest gear on the cassette on the rear wheel and on the largest gear on the crankset. The result is no torque,all speed. You, as the engine, will have to apply tremendous force just to get rolling. But once rolling, you can pedal at a slower rate.
Changing tires will affect MPG to a degree. A taller tire will help to make the R&P ratio seem taller, slowing RPMs. But as tires increase in height, they also increase in width which will lower fuel efficiency. The contact patch will be larger creating more rolling resistance. Also a larger tire is heavier and more expensive. Additionally, the more aggressive the tread pattern, the more rolling resistance, noise, vibration present.
Will the money saved on fuel offset the cost of five new tires(spare must be same size)?
If you drive in more stop&go traffic, the taller ratio will require more throttle to get up to speed, decreasing MPG. If you drive on the highway, the higher engine RPM will decrease your MPG.
I've tried to find the magic bullet for the same issues with my Jeep and have just given up. The Jeep fills the bill for me in terms of wants/needs, so I just accept it.
Hope this helps.
Thanks for the info.
Greg
I'm interested in finding out whether you went ahead with a purchase of a 4cyl 5spd Prerunner. If so, what type of MPG have you been experiencing? I've been thinking along the same lines, as I'm looking for a daily driver for commuting and wonder about the MPG of this model. Don't need 4wd for this application as I have another truck that meets that need. Any feedback is appreciated.
I already had more problems with my new Toyota then with my12 year old, 200,000 mile Jeep. It seems nobody makes quality vehicles anymore.
Joseph
Thinking about trading for Dbl Cab V6 4wd with auto trans. long box. What kind of fuel mileage is everyone getting.
I hope once the Tacoma is broken in, I'll get some better fuel economy, though I doubt it based on the #s I get already.
