A ground breaking design would be GM's OHV dual cam in the crankcase engine with double VVT. But you turkeys would never understand that would actually be ground breaking.
If they are different things, could you give us a word?
Thanx!
The advantages are less "pumping" losses - this is what Cadillac was trying to do with the 8-6-4 engine. This is the same principle that makes the diesel efficient - no throttle.
The Vibe engine has a variable valve lift - but this is the cheap version - where at high speed you get more lift and more power (like at 8000 rpms) and at low speed, there is less lift for better (smoother) engine operation.
Some of you need to catch up on what the latest techology is.
I like it!
But I do know that variable valve timing does NOT require electronic throttle control. Lots of cars have VVT but don't have ETC. The LS VCT (variable cam timing) changes based on engine speed, not throttle input. It will work with or without ETC.
Also interesting to see CTS parts finding their way into other GM products. I wasn't aware of that. Exciting that in just a little while we'll get some definitive specifications on the SRX, XLR, and see the ESV hit the market.
fjk57702,
"A ground breaking design would be GM's OHV dual cam in the crankcase engine with double
VVT. But you turkeys would never understand that would actually be ground breaking."
Huh, you'll have to explain that one to this "turkey".
M
GM has a show engine with ohv's (24 - 2 intake; 1 exhaust) that are controlled by two camshafts in the crankcase. This means that there are pushrods which probably limit the top engine speed, but the timing chains are short which means that the chains don't stretch as much as OHC chains. Plus the friction is 30% less. This 4.3 liter V8 puts out 300 hp.
Production is scheduled to start in late '03.
Aaaargh!
I don't have Stabilitrac so I don't know how that would handle. I guess that I was impressed at how the car handled in the snow. I went to a shopping center that had plowed most of the snow and looked for a parking space that was more snow covered than others. I found one that had slighly iced over and parked there. Once again I had to back up to get out and the car just went. No wheel spin or hop or anything.I kept waiting to see if Traction would kick in but it didn't indicate that it had on the panel. Parked again on slight icy patch and this time had to drive out from the front and the CTS just went.
I am going out later to see if I can find an unplowed parking lot to have some fun.
In addition to what was mentioned in earlier posts the new engine also has:
1. A new ECU that is 1/2 the size and weight that can be mounted onto the engine instead of in the cabin. This is a big advantage for packaging, assembly and weight reduction. Shorter wire runs also lead to more reliability. The 32 bit system is not surpassed by any engine.
2. A truly simple continuosly variable cam phasing system that is compact, simple and cheap. Some competitor cam phasing systems add significant length or cost.
3. A dual resonance intake plenum that fattens the torque curve.
4. Despite what was said earlier piston cooling jets are the exception, not the norm for most engines. The jets reduce noise and allow lighter pistons. Lighter pistons lead to even more reduced NVH, more power and fuel efficiency and reduced emmissions.
5. Roller finger cam followers are also rare due to their expense. However, they do provide for high efficiency.
6. Polymer coated pistons. Just like Nissan/Infiniti loves to brag about in all of their literature.
I am looking forward to testing one of these engines.
thottle control allows the elimination of the cable between the t/b and go pedal; there is a motor attached to the t/b that controls the opening and closing of the t/b...the go pedal is attached to a sensor and all that "stuff" is integrated into the ecu to better control emmissions and improve fuel economy...cam phasing is the relationship between the exhaust cam and the intake cam relative to their timing. jackg
The biggest problem is finding your own personal seating position. Once you find it you can drive all day. Wind and rain are no problem. The car hardly moves in high side winds, and I've had some pretty high winds crossing the desert to Las Vegas.
Good luck on your CTS.
Bingoman
This past summer, we made two single day round trips to southern Illinois (600 miles with local driving). Again, the CTS was up to the job. It's our car of choice for road driving.
However, I had the same problem bingoman mentioned. My right leg got really sore on a few long drives, until I found the seat adjustment that supported my leg properly. I prefer not to use cruise control, so the gas pedal leg gets a workout. I have the same problem on any other car, so it's not just the CTS.
If you want a car that will make you smile after a long drive, the CTS is the car for you.
Rich
Passenger: Good
Driver: Good
Side Impact Front: Good
Side Impact Rear: Excellent
Crash Offset: Not Tested
Bumper Bash: Not Tested
Rollover Rating: Good
2003 Cadillac CTS 4-DR. w/SAB
Heavy Pasenger Car
Frontal Star Rating
Driver 4 Stars
Passenger 4 Stars
Side Star Rating
Front Seat 4 Stars
Rear Seat 5 Stars
Rollover Resistance Rating
4 Stars
What options did you get? What color is it? Which transmission?
Why did you choose a CTS? I and the others ,I'm sure, would like your impressions and observations and opinions.
I have had the opportunity to play on I-15 on short trips to California, and when traffic allows it will hold and handle at 125 mph with realative ease and power to spear. This is going to be great on the Autobaun. Cadillac has hit the mark!!! Thanks for asking mannytranny
For the rest of you, here's the url to Bob Lutz's speech to the Cadillac/Lasalle club.
http://www.media.gm.com/news/speeches/081002_lutz_cad.html
He has some interesting things to say about Cadillac's future and the part the CTS plays.
Rich
Thanx
Thanks anyway
From AZ it's necessary to either drive to Las Vegas or Utah to get to the Virgin River Gorge. I used to run it regularly in a truck, so I know what's being discussed. BTW, there was a huge dispute over which state(s) should pay for this stretch, back in the '70's, given that it's impossible to access directly from Arizona.
With the car I've got now I tend to favor two-lane roads in Nevada for my high-speed runs, but to each their own.
the bug
the bug
the bug
Our CTS doesn't seem to burn any oil. I check the dipstick regularly and it's just starting to get dark, but no loss on measurement. The oil life display shows about 11% oil life left, so next week she'll go in for an oil change (7200 miles).
I'll mention the cold starting noise to the service consultant.
A black CTS with Indiana plates passed me on Route 64 in Carol Stream, IL the other day. Wondered if it could be someone from the board, probably not. I see at least one CTS a day and Black seems to be the most common color, with Sterling or Diamond White in second place.
thebug - We looked at homes in Lake Havasu, about two years ago, but then the grandson was born. He changed our plans. I'd rather suffer in the snow and cold than miss seeing my little buddy grow up.
Still we fly to Vegas at least once a year.
There's a rumor, out on the net, that Cadillac has moved production of the CTS-V out about a month (September or October of next year). They want to make sure that the car meets all the performance and quality expectations of the buyers. I hope so, just give us some new pictures to drool on.
Rich
