http://www.car-videos.com/articles/horsepower_torque.asp
I'm neither scientist nor engineer, but my lay understanding is that horsepower is the measure of the amount of available force and torque is the measure of that force in action. In autombile engines, the ratio between HP and torque helps describe relative efficency, but it can depend on where (engine or drive wheel) you measure it.
Because HP and torque measurements can be a little slippery, if you're interested in comparative numbers, compare also the displacement (cubic inches or liters) to horsepower, and the horsepower to weight ratio, across different types of cars. Heavy cars need big horsepower and torque numbers just to move. Lightweight cars with lesser engines can perform very well.
Personally, I had thought that given the option levels on the CTS, that most people would probably get the luxury version anyway. To me, it has a nice mid-range of features without getting completely stupid on price. But my dealer corrected me by pointing out that half of their sales are for base CTS's, not luxury models. She said that more likely than not, their buyers want to get out of the dealership not paying more than $32K. And that means a base car. And the base car does not come with a sunroof, nor can one be ordered. Heated seats can be ordered with the base car though.
The current CTS engine has a peak torque of 218 ft-lbs and makes 220 hp @6000 RPMs. The torque @6000 rpm's is 192.5 ft-lbs (about 88% of peak). The new 3.6 liter V6 is supposed to have 90% from 1600 to 5800 RPMs. The peak torque 250 ft-lbs@2500 RPMs and 260 hp @6500 RPMs. At 5800 RPM's this new engine will have 248 HP and at 6500 RPM's it will have 210 ft-lbs of torque. It will have 225 ft-lbs of torque @1600 RPM's. I would guess that the current CTS engine has less than 90% of its peak torque below 2000 RPM's.
I would hope that it doesn't cost them only 1-3K less to build a base car.
Hmmm. Wonder what "2K" means. 2000 doesn't make sense.
The CTS is the vehicle that will be used in what is supposed to be the mother of all car chase scenes.
Most of the pics and clips I've seen show the CTS all shot to hell.
At any rate, this should be very nice publicity for Cadillac and GM for that matter.
The movie is still five months away... can't wait!
It is like an accessory coming on - and is worse/more frequent if the A/C is on. My idle speed is 650 and varies only slightly when this occurs.
Any ideas? Is 650 rpm (by dash tach) correct?
I was disappointed that monitor didn't start telling me (nav display) that I had 10% oil life left.
Cost ($32). I asked if there were any service specials and the service consultant said, "no". When I got home the dealers monthly flyer was in the mail without an oil change coupon. The service consultant was correct. They usually have a special for $24.95.
As usual, they were prompt and courteous (an hour for the oil change and rotation of the tires) and they test drove the car then washed it. I'm pleased with this dealer and they treat me right.
They were down to 6 CTS's on the lot. One customer was buying as I walked into the showroom and a second customer took his son for a test drive (looking for a stick). The sales man I talked to said, that they've been selling very well.
Drove on light snow (very slick and icy)yesterday. Bad news!! But I would have had the problem with any car. They don't do well on ice. I slid through one intersection and the traction and stability systems turned on. Needless to say, I slowed down.
Rich
There is a cool picture of Bryan Adams taking a picture of Robert Plant in front of an XLR. I take it this will be used for the XLR or a general Cadillac print ad at some point.
Year 37976
All pics:
http://www.autonews.com/files/2003_detroit/03detroitshowart/
Just go to GM and then Cadillac to find the SRX & XLR.
http://msnbc.com/news/854650.asp?0bl=-0
http://www.wieck.com/public/*2PV_046892
I got to see the article . Great news. I guess that I might wait to see the CTS V and/or the 2005 CTS before doing a trade.
I wonder if all that got a 3.2L will trade away. It will make for a good used market. Is this a good way to get more used CTS cars into the marketplace ? Seems that maybe it will encourage the younger crowd to take notice.
But will this make for a greater depreciation and less on a trade in?
On the other hand, the huge glass sunroof looks very nice.
Hmmmm....
Vehicle type luxury utility - 5 passenger; third row seat available (7 passenger)
Model year 2004; launch: second quarter 2003
Layout front engine, rear-wheel-drive luxury utility (AWD available)
Engine 4.6 L Northstar V8 VVT DOHC, 4 valves per cylinder, 4-cam variable valve timing, 10.5:1 compression ratio
Horsepower 315 hp @ 6400 rpm
Torque 310 lbs.-ft. @ 4400 rpm
Transmission Hydra-Matic 5L50-E five-speed electronically controlled automatic with driver shift control
Final drive ratio 3.23:1
Curb weight RWD: 4295 lbs (V8); AWD: 4430 lbs (V8)
Overall length 194.9 inches
Wheelbase 116.4 inches
Height 65.8 base; 67.8 with roof rack
Width 72.6 inches
Towing 1000 lbs (base); 3500 lbs (optional)
Wheels 18 x 8-inch cast aluminum
Tires - V8 Michelin All-Season Radial P235/60R18 (front)
Michelin All Season Radial P255/55R18 (rear)
Just drove my new CTS in snowy conditions for the first time. I must say it handled very well and I wasn't in the "winter" mode either. Traction was very good.
I don't like leaving work and having a brand new car in the lot with snow and a little ice all over it. I'm glad to have my garage which is great for melting any remaining snow over a 6-12 hour period.
Still burning premium unleaded...even though the current price here in Connecticut is $1.87.
Car runs great. Can't wait for spring.
I will be going in for an oil change next week and plan to report this problem. The second problem is valve train noise, sounds like a Singer sewing machine while mildly accellerating.
I will post the response.
"....But GM had already committed $4 billion to reviving the Cadillac lineup with an edgy new look. Lutz hated it. He even went public with his dislike of the knife-edged styling of the new $30,000 Cadillac CTS. Lutz’s aversion to the stealth-fighter look didn’t play well. “I told Bob, ‘You’re wrong on this’,” says Gary Cowger, GM’s North American president...."
Man, the M5 may for once loose a comparison.
bingoman - Congrats on your digital camera. I hardly ever use my 35 mm camera anymore. I'm a procrastinator at finishing a roll of film and then getting it in for developing (one roll sitting on my desk for two months right now). I bought my wife a digital for her birthday last year and it's been great. You can take as many pictures as you want and just delete any you don't like. I'm looking forward to pictures of your CTS.
It's been a great year for Cadillac. The CTS is selling at record numbers and we still get looks wherever we go. My wife is always telling me about someone staring at the CTS. I guess that's what it's all about. The CTS may not be perfect, but it's been a wonderful experience for us. I only hope Cadillac listens and improves the car, based on owner suggestions.
Rich
I have not yet gotten mine to the dealer. I will keep you posted.
I did have a call from Cadillac (some survey person). They were asking how I liked the car and if there were any problems. They also asked specific questions ("have you noticed any water leaks") that tell me they are listening to feedback, making fixes, and then checking with new owners (1.5 months).
That makes great sense!
The STS-V really will take on the 500hp V10 M5, the STS-V is probally going to get a 500hp+ V12.
The M5 weighs every bit of 4000 lbs.
The M5 costs 35K more.
If I own a CTS V and get slightly beat by a M5 I am not going to worry about it or get my feelings hurt.
It will be interesting to see how many CTSv's GM offers. Vette owners who want a sedan could easily cause demand to far outstrip supply.
