Visitor Agreement.
My 2003 Impala (100K Miles) has begun to have transmission issues; it is having trouble shifting gears. While driving, it will still eventually get to the right gear, it just hesitates when shifting up or down. And if I am doing in town driving, it doesn't seem to shift down to first. Another odd issue I have is that while driving without cruise control on, at times when I take my foot off of the accelerator, the car seems to maintain the same RPM and at times seems to accelerate. As an example, I turned the cruise control function off, accelerated to 70 mph, then took my foot off of the accelerator and coasted. It took nearly 40 seconds to drop from 70 to 60 mph on flat interstate highway. I decided to turn the car off and restart it and it seemed to correct the problem for about 45 miles and then started shifting irregularly again as it was doing prior to turning the car off. I have read many of the posts here and I think I have a decent understanding of what issues I am facing, I just wanted to present the other symptoms I was having being that they had not been addressed within this forum. Thanks for anyone taking time to read and respond!
Aaron
All in the mean while the Tranny kept slipping every once in a while. UP TO DATE NOW.. Two weeks ago took car in Tranny codes running p1811, p 1819. Dealer said valve solenoid and valve body bad. Had them replace it. Found cat was bad in test drive replaced that also. Still did not check out vibration in wheels. Went and replaced passanger rim due to it was bent. Helped...took off driver wheel donut on vibration stopped. Replaced rim vibration still there. Was told the cv joints are bad both sides. Others say its the alignment. Who knows tired of getting jerked around. Wish one person would say this is whats wrong this is what you need to do.
Is anyone else having the same problem? If so what can be done?
We recently had to get a new transmission on our 2001 Impala with 64,000 miles for all the same reasons as these other Impalas with problems postings. We were not offered any compensation from our chevy dealership/service.
Randy
I just went in to the shop w mine. sounds the same but mine has to get warmed up "driven for while". I was told by dealer that my High pressure solenoid was sticking. and to corect the thing I would need the solenoid replaced + the valve body. 9 hrs labor $1550.00 :sick:
Oldude
Good luck
Has any been successful in getting money back from GM with regards to the pressure solenoid issue? I’ve had this issue twice now, once while it was still under extended warranty back in 2002, and the second time just this weekend. Realistically, if they have not been able to engineer a better replacement part, why the heck should we have to pay to get this fixed over and over again?
Since the car would only be worth that much as a trade in operating condition, I passed. The service manager said they might take it as a trade in its current condition. Again I passed...not interested in buying another Chevy. A local shade-tree mechanic quoted me $1,200 to $1,500 to put in a used trans. I ended up selling it as-is for $1,200 to a guy who had a totalled Grand Prix with a trans that would fit my Impala.
The transmission always seemed to have problems in cold weather. It tended to clunk from one gear to another and occasionally would whine.
The longer I owned that car the less I liked it. After 20 years of buying Chevies (usually pick-ups), I won't buy another. This morning I bought a '08 VW Jetta.
I have to say, I really love the Chevy dealership in my town. The service has always been top-notch and their prices have always been best in our area. Wish they sold something other than Chevy!
Clark
As for my Impala (just to keep things on topic), other than replacing a pressure solenoid at one point early on, and having the fluid replaced, I haven't had any trouble out of mine. I'm at 114k miles now, and just bought a new vehicle, so I should sell it...thought I posted an ad in the local paper via their website, but it hasn't shown up in print yet. I have a daughter that turns 15 next month though, so I'm seriously contemplating keeping it around for her to drive when she turns 16.
Is anyone else having these kind of problems since the mechanic said to her that the transmision problem is comon for this car?
That stated, I've never heard of "laminant" coming loose. I called my nephew who works on transmissions for a living and he has no idea what that could be. If you could verify the diagnosis, that would be helpful.
Do you know if she has had regular maintenance performed on her car? The transmission is recommended to be flushed at 40K if the car is under heavy service (in her case, maybe lots of hills or heavy loads) or stop and go traffic in temperatures that regularly exceed 90 degrees. However, even if she does fall into the heavy service category, skipping that service wouldn't guarantee a problem would crop up.
Depending on what that diagnosis was, it sounds a little fishy. She might want to consider a different shop for her service but write back with a confirmation of the problem and we'll go from there.
My Impala is a 3.5L LT which has 63000km,I bought it when it had 24,000km and it has made that noise(which has not gotten any worse) ever since. If anyone has this problem or has heard about it I would like to thank you in advance for any ideas or suggestions...cause this thursday i gotta spend $700 on my exhaust that is gone on my Impala. Trying to keep the costs down!
a couple of months ago I noticed my transmission having a hard shifting when around 20 mph and then around 30-35-40 mph . it would feel like something holding the car and then letting it go. . but today on my way home back from work in heavy traffic it started doing it driving slow and having to speed up to keep up with traffic any time I would reach around 20 mph and then around 30 before 40 mph it will do it. problem goes aways onces i am driving over 40 mph
I drove the car almost 10 miles in traffic with the same issue.
does anyone know what could be wrong.
I had the trans serviced just last year.
any advise would be appreciate. thanks :confuse:
at least it didn't cost me a penny cause' my wife works at the dealer ship. where I took it. I guess I am gonna have to check on the warranty for the cat converter
anyway. for the las 3 days the cars is been working fine. sometimes I feel a little misfire when driving but nothing big . like you said maybe the cat converter is clogged. or the cheap gas im putting in.
