Hyundai Azera Lighting
Right now, it's known that Sylvania makes an H11B, but only as the regular halogens, not the upgraded, Cool Blues, Silverstars or Ultras. I would gather to believe that none of the other makers have jumped on to start making aftermarket upgrades for H11B's yet.
I agree with you about the whole idea of removing the headlight housing to change the bulb. I did it once and I was only able to remove one headlight housing successfully, the other one didn't want to come out and I didn't feel like breaking anything in doing so. At any rate...with the housing out...bulb replacement was a snap, but...you have the extra step of removing and replacing the housing.
If you're looking for a good price on the HID's, contact Supreme Power. The guy there offered me an HID set up for mine for $200, he said he also had one for the fog lights as well...package deal, he offered both sets to me for $350. If I wasn't working on some of these home improvement projects, I would have jumped on that deal!!!
I've previously described my inability to get my Ultras installed. I could not get the entire light assembly out. I tried to understand the process and only remove the bulbs directly. Still, no luck. I look at the lights with the screw in cap removed (upside down of course) and still not figure out how to remove the bulbs. The lights look like those in Picture B in the manual where it describes bulb replacement. A thorough process description of bulb replacement would greatly be appreciated. Thanks in advance!!
Steve
Once you get the bulb in place, the tricky part of working the clip back into place becomes a little test of patience. I say this because the wires for the harness tend to get in the way. So...be patient and work the wires around so you can put the clip back in place to hold the bulb in place and once you're done, screw the dust cap in place and you're done.
BTW If your low beam looks like the one in picture B (in the manual where its explaining replacement process) its the H11b.
Steve
Daniel Stern states that there are 3 different configurations - but what I have is H11b low beams, H7 high beams and H8 fog lamps. I put the "OSRAM Rallye" 2100 lumen H9 burner on H7 base bulbs in my high beams - otherwise, I'm good.
Ummmmmmmmmmmm...how did you put an H9 bulb where an H7 bulb should go?
As far as the bulbs go, I'm starting to think that the '06 Azeras were the only ones that use the H7 bulb as the low-beam bulb.
The Phillips Xtreme are supposed to be 80 % brighter. I didn't do a test , but I do see the sides of the highway better in the dark. YOu can find them online, best to get the size you need and google shopping will help you search.
Good luck to all
It's a 2100 lumen lamp mounted on the H7 base. You may well be right about the H7 low beams being only in '06 models, but I seem to remember somebody saying it was "slipstreamed" in mid-'07 models...
Do you really need four bulbs (low & high)?
Do you really have to remove the whole headlight?
Thanks - much appreciated.
I'm not sure about the new bulbs, I'm still riding with my Sylvania Silverstar Ultras in the low beams. The high beams are still OEM bulbs as I don't really use them much and my fog lights I switched to Nokya Hyper Yellow bulbs.
I can answer...there are 4 bulbs 2 for low & 2 for high, but you don't necessarily have to replace all 4. Also, you don't necessarily have to remove the whole headlight to replace the bulbs either. The 1st time you try replacing a bulb with the headlight in place, it takes some patience, but after you've done it a couple times...it becomes rather easy.
Way back when I had a 71 Dodge Challenger, I installed driving lights. Too bad we can't get bulbs to change the fog lights to driving lights. In the last 30 years, I have never driven in fog at night, even when I was travelling throughout the South for 20,000 miles per year.
Believe it or not, changing the fog light bulbs is quite easy. What you have to do is make sure whichever side you're replacing, turn the steering wheel all the way to the other side to give you room to work. Then...using a flat blade screw driver or putty knive, pop the wheel well liner out so you can work your hand inside of the fender. It takes a little work, but once you figure it out...it's easy. You then have access to the back side of the fog lights. Reach in, grasp it and twist gently to see which way you need to turn it to remove it. The wire is long enough that you can pull it back towards you, unplug the old bulb and put in the new one. Then...it's just a matter of putting it back in place.
thanks, bob
Don't expect much of a change is the actual light output replacing your OEM H7 bulbs with PIAA bulbs. They will look different (i.e. 'blue-er') and the higher the color temp (i.e. 4000K is the bulb's color temperature); the more blue-looking they will be. The best replacement bulbs I've found for the stock/OEM H7 bulbs are the OSRAM "Rallye" 65watt bulbs: from the way they are marketed they are likely NOT street-legal, but I always drive my Azera off-road after dark, anyway.
The problem with the PIAA bulbs (I've used a LOT of different bulbs in my '03 Infiniti I-35 and my '08 Azera) is that they have very limited life (maybe 150-200 hours vs. standard bulbs which are 400-500 hour rated), tend to actually have LESS usable light due to the blue-colored coating on the bulbs and - at least for the H7-based Azeras, you need MORE light on the road - not less.
My '08 has the H11b bulbs - I haven't had any problem with "over-driving" the headlights complaints many H7-equipped Azeras have mentioned. Having both H7 in the high and low beams means you can swap those bulbs out for the special OSRAM Rallye part and have 50% more light on the road all the time. There is no significant difference in the amount of heat generated by these higher-output bulbs. You should be able to find them for about $20-25 each online. I know "candlepower.com" sells them, but (just checked) they are out of stock. :sick:
Putting 4 of those bulbs in your '06 Azzy should give you 4200 lumens (vs. 2800 lumens for the stock bulbs) with low beams and 8400 lumens (vs. 5600) with high beams on. :shades: Total about $80-100 for a 50% boost in usable light, which is not much more than you'll pay for a pair of PIAA bulbs (depending on the specific bulbs, maybe less) - and you'll be replacing all 4 instead of just the low beams.
thanks, boblaw
I'm currently running on stock bulbs on my 07 Azzy. However, I'm itching to get the Silverstars on my car. The place where we live is unlighted at night & brighter lights would definitely help.
What I am worried about is the rumor that these replacements don't last as long as the OEMs. I have heard that they go out almost once every 1-2 years. Is that the case? If so, why can't Sylvania make reliable ones as OEMs?
I want brighter light but I want them to last as long as the OEMs. Can you guys help me? I don't want the lights to konk out when my wife is driving as she's not at all mechanically inclined. (Her idea of changing a tire is calling me to do it, lol!!)
In reality, a bulb never goes out at an opportune time and about the only thing you can do is maybe by 2 sets at one time to have spare bulbs on hand in the event one should go out. A light bulb lasting 1-2 years is really, really good (especially halogens). However, according to the lighting experts, we aren't supposed to be waiting for the bubls to blow before replacing them as the bulb naturally grows dimmer over time (which makes sense). You can get a set of Silverstar Ultras for between $35-40/pr. and lasting 1-2 years...that's not a bad return actually.
are adjusted does this affect the high beams?
thanks boblaw
If you adjust the low beams...the high beams adjust with it as each adjustment affects the entire headlight housing.
Mike
If possible, can you take as many pictures as possible of the process? It would be of great help to those of us who are more visual learners
looks good Are the led strips inside the light cover??? Where did you get the strips??Are they wired separately for independent operation???
I did, however, remove the headlight housings, cleaned that lip area really good for best adhesion and applied the strips end to end so it looks like one continuous strip. Then I ran the wires for the ones on the passenger side to the ones on the driver's side (I had to splice wire in between using butt connectors). I then ran the wire through the firewall (piggy-backing on my amp power wire) to the fuse box and I'm using a 10 amp source that is only on when the car is running. The negative lead is connected directly to the battery negative terminal.
I had to cut a small notch in the lip at the inside corner of the lip to allow for the strip to lay straight and the wire end would have a place to go. I laid the 2nd strip down by butting the open end against the open end of the first one so it looks like one long continuous strip. The wired end ends up where the turn signal light is. (approx).
For good adhesion, make sure you clean the lip off really well. Install on a fairly warm day (above 70 degrees for best results) and press each strip into place with firm pressure for about 20-30 seconds. Being warmer allows you to shape the strip to the curve of the lip much more easily.
Just how long did the whole shebang take you?
While I'm thinking, has anyone tried putting in a real horn that replaces the wimpy OEM bleet?
Considering I had to wrestle with getting the headlights out...the total job took me about 1.5 hours. However, now that I know where everything is and how to do it...I can see it taking me between 30-45 mins. if I did it again.
Sorry to hear your horn is rather whimpy...mine is fine. However, replacing it shouldn't be hard...once you locate it.
As a side note, after 4 years I finally found out how to adjust the headlights. I feel so silly...especially after seeing how easy it is! LOL
watch our for an '06 black on black flying low and fast under the radar thru Columbia on 26 to 77 on the 30th in the late afternoon.....blacked out chrome and a candy apple red "RS" badge on the grill and yellow euro driving light lenses....traveling from Tampa to VA......as Jeremy says on Top Gear..."Out of the way Germans!!!"
Do you know how to adjust the high-beam headlights? In my '06 Azera,
the high beams are aimed too low. My dealer said there is no adjustment.
I do not believe him.
Thanks for any information!
At any rate, to adjust your headlights...there's a neat little piece you can find on the back side of the housing between the low & high beam caps. I have taken a pic of the driver's side headlight so you can get an understanding of where to look (see in yellow circle).
Using a phillips head screw driver, slide the tip of it into the "cuff" and turn it to adjust as needed.
