2014 Audi Q5 Lease Questions
245678
  • kyfdxkyfdx Moderator Posts: 276,075
    @john_a11 said:
    Can you please give me the December Money Factor and Residual for a 2014 Audi Q5 TDI lease for 3 years/45k miles.
    2014 Q5 TDI Premium Plus 36mo, 15K/yr lease
    .00166 MF and 57% residual
    kyfdx
  • asolare1asolare1 Member Posts: 31
    Are the money factor and residual the same for the prestige as they are for the premium plus? If not, what are the MF and residual for 36 and 42 mos/ 10k per year on a prestige? Thanks.
    Residuals for the Prestige line are 4% lower on the diesel
    2014 Audi Q5 TDI Prestige 36mo, 10K/yr lease
    .00166 MF and 55% residual... 42 month residual is 51%
    Those are December numbers that have been extended to January 7th.
  • auditaasssauditaasss Member Posts: 21
    Hi All,
    I'm picking up my car on the 10th and going in today to lock the finances, do December's rates still apply?
    2014 Q5 TDI Premium Plus 36mo, 12K/yr lease .00166 MF and 60% residual
    Ben
    December numbers have been extended to January 7th..
  • dcenterdcenter Member Posts: 6
    edited January 2014
    Can you please provide current MF and residual for
    2014 Q5 3.0T TFSI Premium Plus
    36 mo / 10k,
    39 mo / 10k,
    42 mo / 10k,
    edited January 2014
    2014 Q5 3.0T Premium Plus 36mo, 10K/yr lease
    .00163 MF and 59% residual. 39mo. residual is 57%
    42 month: .00183 Mf and 55% residual
    Those numbers are good through Tuesday, January 7th
  • hercules00hercules00 Member Posts: 134
    kyfdx - Are the numbers still the same for the 2.0 TFSI P+? TIA.
    2014 Q5 2.0T Premium Plus 36mo, 10K/yr lease
    .00159 MF and 57% residual
    3.0T Premium Plus
    .00159 MF and 58% residual
  • extrabitterextrabitter Member Posts: 3
    What is the SQ5 MF & residual for January? (36 mo, 12K/yr). Thanks!
    2014 SQ5 Premium Plus 36mo, 12K/yr lease
    .00154 MF and 57% residual
    The Prestige trim residual is 4% lower
  • amup225amup225 Member Posts: 5
    First time doing a lease so I need some help here.
    2014 Q5 3.0T Premium Plus. MSRP $54,195, talked them down to $51,000.
    Lease is for 15k/year for 36mo. They're giving me a rate of
    $723.36/month with $2255 inception fees (does not include taxes)
    edited January 2014
    If the CAP cost is the same as the selling price, then with base money factor of .00159 and residual of 55%, the payment would be about $717/mo.
    That's a lot with $2255 upfront
  • ryangadryangad Member Posts: 13
    Can anyone help me with the January 2014 MF and residual for the Q5 2.0T Premium Plus (3 year lease / 10k miles per year)?
    .00159 MF and 57% residual.
  • cargrl2cargrl2 Member Posts: 6
    Can you help with Jan 2014 MF and residual on the Q5 2.0 Premium Plus 42 month/10k? Thanks.
    .00179 MF and 53% residual
  • matty44matty44 Member Posts: 1
    looking for Jan 2014 MF/residual for Q5 2.0 Premium Plus 36 month/15k miles and 42 month/15k miles, both with Audi Care. thanks
    .00159 MF and 54% residual
    .00179 MF and 50% residual
    Add 1% to residual for AudiCare
  • bmacchiobmacchio Member Posts: 30
    Just got a lease quote for a 2014 SQ5.
    MSRP of $60,490.00.
    Options: Phantom Black Premium Plus with audi side assist, audi connect, MMI, Nappa seats, Bang & Olufsen, and some other small dealer accessories added on.
    Residual: 55% (36 month, 15k/year, '14 SQ5 premium plus)
    Rate: .00214 (5.16%)
    Monthly payment comes out to $955.37 plus tax.
    I don't want to put anything down, just first month payment. The quote says $1673.23 due at signing.
    Fees...
    Capped Fees (W): $695.00
    Lic/Reg (upfront): $491.00
    Upfront Fees: $117
    Working Cash: $900.00
    My Questions:
    1) Can I not finance those fees above? Do they always have to paid upfront? I don't remember doing this on my previous leases.
    2) Is that residual correct? Looks like it is to me.
    3) That rate is much higher than the standard .00154/3.696% that I have seen on this discussion. Is that just dealer markup?
    4) I'm trying to get the payment to $900/month with nothing down. Is that reasonable for this car?
    4) What is the residual for 36 month, 15k/year prestige SQ5? I saw that they are usually 4% lower, so would it be 51% for these same lease terms?
    Thanks for you help!
    edited February 2014
    1) Looks like the acquisition fee ($695) has been rolled in. It's possible they don't roll in the other fees because they are government fees, and untaxed.. It may cause them to be taxed, if you roll them into the payment. That doesn't mean you can't do it.
    2) The residual is correct. If you add AudiCare ($880 on this model), it will add 1% to your residual, giving you an effective cost of $275 for the maintenance program.
    3) The rate is marked up, unless you are not A-tier. Audi allows a massive .00125 markup to their base money factors. That money factor markup is adding $55/mo. pre-tax to your payment.
    4) With your MSRP and a selling price of 6% off, you should be around $815/mo, plus tax, with the $600 of fees and 1st payment due at signing..
    The Prestige model residual is 4% lower... If you leased a Prestige model with the same MSRP, the payment would be about $70/mo. higher.
    Thanks Kyfdx for the help!
  • jd1992jd1992 Member Posts: 1
    looking for current MF/residual for Q5 3.0 TDI Premium Plus 36 month/10k miles
    .00155 MF and 59% residual
  • nickel4490nickel4490 Member Posts: 1
    Hey! I'm looking for Feb 2014 MF & Residual for a Q5 2.0 Premium Plus 42 month lease @ 10K miles/year - with and without nav
    .00179 MF and 53% residual. NAV has no effect on those numbers.
  • audy1audy1 Member Posts: 2
    I am looking for a Q5 TDI - premium plus with MMI and B&O , what is the current MF and residual for 10k 4 years..i was offered $590p.m incl tax $500 down ..current Q5 owner in FL
    .00155 MF and 55% for 42 month, 10K/yr lease
    The 48 month residual is 49%, but I'm not certain of the money factor. AFS only subsidizes the money factor on terms of 42 months or less.
    Thank you kyfdx@Edmunds for the info
  • pvillipvilli Member Posts: 9
    I am looking for the most recent MF and Residuals on a Q5 2.0 Premium. Debating between a 3/12,000 vs 3/15,000.
    .00159 MF and 54% for 36mo, 15K/yr lease. Add 2% for 12K/yr.
  • jackinatormajackinatorma Member Posts: 5
    2014 Audi Q5 Premium Plus with Nav 15K/year, 42 month ....what is the MF, Residual, what % or $ over invoice should I be paying, and what kind of incentives are there currently?
    .00179 MF and 51% residual for the 3.0T model.
    Thanks for the info! To confirm, this would be 2.0T model? Any recommendation of "fair price" over invoice?
    The 2.0T residual is 1% lower than the 3.0T model.
    We get a few outliers, but usually the best price I see on a Q5 is about 6% off of MSRP. Leasing a Q5 isn't cheap. They must not have any trouble moving them.
    Thanks for the info! :)
  • lednameledname Member Posts: 112
    Can you please provide MF and Residual for Q5 3.0T Premium Plus and also Prestige for 36 months & 15k Miles (assume add 2% for 12K miles).
    Thanks in advance.
    .00156 MF and 55% residual for the Premium Plus
    .00164 MF and 51% residual for the Prestige.
    Yes... add 2% for 12K/yr.
  • ursamajorursamajor Member Posts: 127
    Please provide MF and residual % for 36month lease of Q5 2.0T for 10,000 miles/year. As an alternative, are there any promotions for purchases instead of a lease? Thank you
    Sorry, I omitted "Premium" from the prior request.
    The only promotion I see on a purchase is 1.9% APR financing for up to 66 months.
  • janton79janton79 Member Posts: 3
    Do you have March numbers? Can you please provide MF and residual for an SQ5, 36 months and 15,000 miles/year? Thanks.
    The current lease program runs through April 1st, unless they make unscheduled changes.
    .00154 MF and 55% for the Premium Plus model. 51% for Prestige.
    Please provide March MF and residual for a 2014 Q5 2.0 Premium Plus, 10,000 annual miles, 3-yr. lease.
    I know that the 2014 Q5 is in demand, but what can I expect as a reduction from MSRP dealing with the Internet sales dept. for the previous vehicle ?
  • MichaellMichaell Moderator Posts: 270,975
    From previous posts, I understand that the best discount that seems possible is 6% off MSRP. Various employee purchase programs offer than discount.
    .00130 MF and 57% residual
  • black91stealthblack91stealth Member Posts: 3
    Just got quoted the following lease offer, how does it look?
    Q5 2.0T Premium Plus w/ Navigation, Bang & Olufson and a few other options.
    MSRP $47,415 (46,520 + $895 destination charge)
    Negotiated Price $44,250
    42 month lease @ 12K/year
    $24,645 price to purchase at end of lease
    .00179 MF
    $602/month
    $3000 drive off (includes 1st month payment, tax, and acquisition fee $595)
  • vtech22avtech22a Member Posts: 2
    Looking to order a Q5 3.0T Premium Plus w/Nav, SLine Plus, Sport Int, and Side Assist. I was able to negotiate for a 7% off of MSRP but need to make sure the money factor isn't inflated. Acquisition fee for Audi is $695 right? What's the current buy rate and residual on a 36 months, 12K/Yr lease? Thank you so much for the info. The car won't be here until end of April, so I will need to check back in for April rates.
    .00179 MF
    $602/month
    The base money factor on that model is .00150, so that looks to be marked up... That's about a $20/mo. addition..
