2014 Porsche 911 Lease Questions
1235»
  • ctm14ctm14 Member Posts: 4
    Hello, Can someone direct me to the most accurate lease calculator/spreadsheet. I have been trying a few online including Edmunds and they seem to produce a lower monthly than Porsche dealers calculate. I would love something where you don't have to manually calculate residuals off MSRP.
  • MichaellMichaell Moderator Posts: 269,468
    I built my own spreadsheet to calculate lease payments. The formulas aren't terribly complicated - 4th grade math.
  • ROBRTM5ROBRTM5 Member Posts: 81
    Hi Kyfdx - Can you please share the MF and residual for a 2014 and 2015 911 Turbo S Coupe. 36 and 48 Months with 7,500 and 10,000 miles.
    Thank you in advance.
    RM
  • kyfdxkyfdx Moderator Posts: 273,250
    RM
    .0020 MF
    2014: 54%/53% residual for 36mo, 45%/44% residual for 48 mo.
    2015: 54%/53% residual for 36mo, 48%/47% residual for 48 mo.
  • dave328dave328 Member Posts: 30
    I'm looking to lease a c2s. Would anyone like to comment on the deals they are getting? '14 or '15. I'm in so cal. Thanks!
  • carnut97carnut97 Member Posts: 1
    What is the MF and Residual % for 2014 911 Coupe and Cab for 27 months? TIA
    C2 Coupe: .00177 MF and 68% residual for 15K/yr
    C2 Cab: .00105 MF and 65% residual
  • dalemadalema Member Posts: 93
    Hi there! Looking for an update on the 2014 C2S cab residual and MF (did I see above a 0.00080 MF??).
    24 and 27 months, 7.5K and 10K miles, PDK
    .00128 and 69% for 24/10 and 67% for 27/10.
    Add 1% for 7.5K
    Add 1% for 7.5K
    Thanks - so the 0.00080 is no longer available or just nit on this model?
    If I could trouble you for the residuals for 5,000 miles also - just add 1%?
    And to confirm, this is with PDK.
    Add 1% for 7.5K
    Yes... .00080 is not available on that model.
    Yes, add 1% for 5K/yr, but also deduct 1% for PDK (that wasn't calculated into the numbers above)
    Super - thanks again for the info!
    What model is the 0.00080 applicable for?
    C4 Cab and C4 Cab S
    Targa 4 and Targa 4S
    Add 1% for 7.5K
    Hi - thanks for all the info as usual. I just received a quote that is way off from these numbers though - if I could confirm with you:
    2014 C2S cabriolet with pdk - 27 months / 7,500 miles
    Should be a residual of 67%?
    They are telling me 64%.
    I haven't discussed the MF with them yet, however, they are at .00225 - so way off from the .00128. But I'll get that sorted out.
    Add 1% for 7.5K
    Base (15K/yr) residual for 27 months is 63%. Add 4% for 7.5K/yr. Subtract 1% for PDK.
    That makes it 66% for 27mo, 7.5K/yr PDK on a 2014 C2 S Cab.
  • finwizfinwiz Member Posts: 7
    What are the MRM, residuals, and MF's for a 2015 911 Turbo Coupe (not a S):
    -12K per Year & 24 Months
    -12K per Year & 36 Months
    -15K per year & 24 Months
    -15K per Year & 36 Months
    Thanks Again!!!
    Thanks Again!!!
    .0020 MF and $174,900 MRM
    Residuals:
    62%
    55%
    60%
    53%
    Add 1% for 7.5K
    And that would be:
    - 67% for 27mo, 5K/yr PDK on 2014 C2 S Cab
    - 69% for 24mo, 5K/yr PDK
    - 66% for 29mo, 5K/yr PDK
    All at MF of 0.00128.
    Interestingly, I just had a dealer tell me that on a 2914 C2S Cab - 5K miles / 29 months that the MF is 0.00078. True?
    I don't show that.. we see .00128, but Porsche only changes numbers quarterly, so out information came out in July. If they have put through a mid-quarter incentive or change, we likely won't get that information.
    Upon further clarification I've been told this is a loyalty rate.
    With the new quarter any update on the MF and residual for a 2014 CS2 Cab with PDK - 5K miles, 29 months?
    Just wondering what the MF and residual is as of October on a 27 month with 12K miles for the C2 coupe & C2S coupe
    We don't have the 4th Quarter numbers for Porsche, yet.. hopefully, by next week.
  • eg991eg991 Member Posts: 4
    Hi - can you please advise if the 12-month pull-ahead program that PFS was running in the third quarter on 2013 Carreras has been extended into the fourth quarter?  Also, please advise if there are current residuals and money factors for a 2015 911 Turbo. Thanks!
    We don't have the 4th Quarter numbers for Porsche, yet.... hopefully, soon.
    Thanks very much in advance. Just to clarify, when the October numbers do become available, I'd like to get the numbers on a 2015 Turbo coupe for 36 and 39 months, 7,500 and 10,000 miles/ year, respectively. And, of course, confirmation that the 12 month pull-ahead program is still in effect for the 4th quarter.
    In addition to above question on 2014 Cab S - any insight on the just announced 911 GTS Cab and coupe - 5K miles, 29 months with PDK - residual and MF?
  • Hi Car_Man: When the Q4 number become available, can you please provide MF and residual for a 2015 base Carrera and Carrera 4 ... for 36/10. Thanks in advance.
  • cap20cap20 Member Posts: 2
    Trying to get input on the following deal that has been offered:
    2014 911 Cab S
    10% off MSRP
    30 month lease
    MF .00145
    Residual 62%
    Any thoughts?????
    I heard through the grapevine that the 12 month pull-ahead program on 2013 Carreras has been extended thru 1/2 and that the rates and residuals on the Carreras and 911 Turbo are unchanged from the third quarter. Would appreciate any input or confirmation you have on that. Thanks!
    I don't have any confirmation on the rates and residuals, except I "heard" the same thing... nothing in print.
    Okay, thanks so much for the guidance. Please let us know when you do see the program in print, and thanks for all of the help!
  • miamiadjustermiamiadjuster Member Posts: 12
    Was wondering what the interest rate for a 60-month loan was with Porsche Financial. This is for a 2015 GT3. Thanks.
    We don't have the current program, but last quarter, the rate for new cars was 2.49% APR for terms up to 60 months. That isn't likely to have changed, but it might.
    Thanks Kyfdx!
  • justin12justin12 Member Posts: 23
    edited November 2014
    I was offered a 30 mo. 7.5K lease on a '15 C4S manual (MSRP at $115,365), 3% discount, MF .00225 with $1647/mo payment. Residual is 66%. Can I do better? What figures should I be considering at 12.5K miles per year?
  • ygbsm1ygbsm1 Member Posts: 12
    Hi- wondering what residual and money factor is for a lease on a 2015 Carrera GTS. 5K year mileage for 24, 27, or 36 months. Thanks!!!
    We don't have any Q4 numbers from Porsche.
    We've not seen any numbers from Porsche this quarter.
  • govnagovna Member Posts: 6
    Ive been quoted 70% residual, .0022 MF on 27/7500 for a 2015 C2 PDK.
    Also a 6.25% off MSRP.
    Thoughts?
    Thoughts?
    The standard MF from Porsche has been .00200 for a while - though we don't have any current numbers, I see no reason for them to change it.
    Meaning, your MF may be marked up on you.
  • Car_Man: do you have the residual and MF for a 2015 base carrera PDK - 36/10K. Thanks
    No Porsche numbers this quarter - sorry
  • sjl225sjl225 Member Posts: 29
    Hi
    I'm looking for the November lease numbers for the C2S manual
    MF's and residuals
    24
    27
    30 months
    7.5k, 10k, and 12k m/y
    Thank you very much!
    sjl225 said:
    Hi
    MF's and residuals
    24
    27
    30 months
    2015? .0020 MF
    Residuals are 69%/67%/65% for 12K/yr.
    Add 1% for 10K/yr or 2% for 7.5K/yr
    Thanks....I forgot to ask for the 2014"s as well. Can you please provide them as well.
    Happy Thanksgiving!
    Happy Thanksgiving!
    2014 C2S - .00153 MF
    Happy Holidays!
  • For current leasing information, go to 2015 Porsche 911 Lease Questions
