Visitor Agreement.
My next question is...what is the difference in terms of handling and tread wear between the 60-16 and the 50-17? My car (2001 Monte Carlo) currently has 60-16s on it, and I'm thinking of getting some new wheels that are 70-17.
http://www.tirerack.com/tires/tiretech/general/sidewall.htm
And, if you're looking to change the size of the tires on your car, use this handy tool I found on the net (you guys are gonna love this):
http://www.paspeedo.com/calculator.htm
I used this second link quite a bit while looking to replace the Bridgestone Potenza RE92s that came stock on my 2000 Mazda Protege ES.
Plugging in those two tire sizes you're asking about, you'll find there's quite a difference -- about 3/4 inch in diameter and almost 2 mph at 60.
tntitan: You'd do well to do some research of customer comments at tirerack.com. I wound up purchasing a set of four Dunlop SP Sport A2s, which are more highly rated than the Michelins and cost less! I used tirerack.com and am completely satisfied with my purchase. The tires are everything I read they would be. And I even changed sizes, from 195/55/15s to 205/50/15s in the process.
Have fun shopping!
Meade
regarding: "Plugging in those two tire sizes you're asking about, you'll find there's quite a difference -- about 3/4 inch in diameter and almost 2 mph at 60."
2 mph doesn't really matter as much when most people drive 10 to 20 mph over the limit anyhow! The 3/4 inch might be more important, though for clearance purposes.
Meade
You can go with an All Terrain type tread which is a good "all around" tire, or throw a set of dedicated snow tires for the winter and keep the AWs for the highway/summer use.
If you decide to go all terrain get something with a lot of siping this helps tremendously in winter driving! BFG ATKOs, Yokohama Geolander ATs, Pirelli Scorpion ATs, Mickey Thompson MTX, Cooper Discoverer ATs, General Grabber(AT, ST, AP), Dunlop Radial Rovers, Goodyear ATS...to name a few good ones. There are tons...check out www.tirerack.com for a lot of great reading and some good tire prices. HTH!
I was going to put a Powertraxx No Slip locker in my Wrangler this year for snow, but we never got any snow! I might do it in the Spring for off road use.
I think your best bet would be to pick up some real knobby snow tires or mud/snow tires (Wildcat comes to mind) or even some retread snows.
What you say goes contrary to everything I've read. I thought you want to put traction to as many tires as possible.
They probably sell lockers for people who live in snowy areas because people generally don't understand basic physics
I think the key here is to understand that traction is not limited by diffs but by rubber to ground contact.
Open-diffs and LSD's are better for snow and ice than lockers IMO. Whether or not an LSD is better than an open-diff I will leave up for each person to decide on there own
Any help will be appreciated....
anyways...get good tires and some chains and you won't have to worry about your diffs
And sure if one wheel is on ice and one is on pavement, that's just great to have an LSD or locker. I just think that turning on snow/ice happens more than one wheel on ice and one on pavement. It's a bigger concern, and not many people understand basic vehicle dynamics.
I hope you can explain to your friend why full time locked is not good!!! on ice and on pavement!!!
Open
LSD
Locker
But then the conditions where you have the diff locked, it becomes a choice of making headway with some tail wag or just sitting in the road going nowhere.
A previous statement that an open diff provides some torque to the non-slipping tire is an academic exercise (not reality) since I've seen many pickup trucks sitting perfectly still on flat ice covered roadways smoking one rear tire.
As for the "cluck-cluck" sound, it's clear to me that you have a chicken stuck in your front suspension. Better get him outta there.
Shaving tires reduces tread squirm, which is when the rubber tread blocks shift during hard cornering, making the car's handling less stable and consistent.
With street cars, you need deep grooves to disperse water, many tread edges so a tire can bite into dirt and snow, and a soft tread compound to provide high grip for braking and steering as well as provide a quiet smooth ride. Most of what I just described are unimportant in racing.
With long lasting tires, however, by the time you reach a sufficiently low tread depth that should give you better dry traction, the rubber compound will be so hard that it will give you terrible traction under all conditions.
Some places will sipe old tires for you which can help some snow/ice traction but without a good sticky compound you can't do anything to improve dry traction.
Deep grooves in tires help to reduce hydroplaning. A properly inflated tire at reasonable speeds will remain in contact with the road when going through a puddle of less depth than its tread depth. Some tread patterns are designed to evacuate water so as to reduce hydroplaning in water that is deeper than the remaining tread depth and/or while traveling at a speed which doesn't allow water to get out of the way fast enough just from the weight of the vehicle.
Sounds like something desirable to me.
"With street cars, you need deep grooves to disperse water..."
or just drive slower in the rain
"..., many tread edges so a tire can bite into dirt and snow..."
I have snow tires for that.
"..., and a soft tread compound to provide high grip for braking and steering as well as provide a quiet smooth ride. Most of what I just described are unimportant in racing."
Don't the people who shave their tires desire those traits?
How about a good 15" tire?
http://www.off-road.com/ford/tech/pressure.html
Michelins for sure!!
Some other fairly similar tires would be the Michelin Cross-Terrain, Bridgestone Dueler H/L, and the new Goodyear Fortera HL. All compete directly for the SUV/light truck owner who wants a smooth ride and good handling from a light truck tire.
In car tires the direct competitors to the Eagle LS are the Michelin Energy MXV4 Plus, Bridgestone Turanza Revo, Yokohama Avid, and a few others. Your challenge is going to be finding a tire comparable to the Eagle LS in that 245/70-16 size. That's a truck size and very few car tires are made in that size. So you may be forced into a truck tire like I described above simply by a lack of choices.
BTW, that Eagle LS in your size is only $82 each at Tire Rack. http://www.tirerack.com
http://www.tirerack.com/tires/dunlop/du_sp_a2.jsp
Do any of you have these tires? Any comments are welcome.
Lee
