Tires, tires, tires
17273757778149
  • sandman46sandman46 Member Posts: 1,798
    I use the emergency brake every time I exit my car, as I've always done since the middle '70's. Living in South Florida with no hills, is this practice a safe one or will it hurt the rear drum brakes on the car? Someone had mentioned to me that this could cause drum brake rotor warpage. Is this something that could happen and should I stop this use of the emergency brake? It's become as automatic as putting on my seat belt whenever I move the gear selector.
    TIA for any responce on this matter. I looked through all the messege boards and wasn't quite sure where to post this question.
    The Sandman :-)
    Do you have disc brakes in the rear? If so, the drum brakes and drum pads are actually for emergency brake functions and are intergrated in the rear rotor; i.e., rotor surface for disc brake pads and inner drum surfaces for emergency brakes (drum brake shoes).
    I only have disc brakes in the front of the car, the rears are the old drum style. The car is a '03 Sentra, your basic transportation appliance. But, the price was right and it gets me to where I need to be. If and when I win the Florida Lottery, then I will buy what I really want, and not what I need.
    The Sandman :-)
    Ummm, I'm going to have a VERY difficult time believing that using a parking brake can lead to a warped drum, so much so that I'm going to say, "Horse Hockey!"
    Regarding usage, according to my Owner's Manual (which pretty much lines up with every Owner's Manual I've ever had) you should use it wherever and whenever needed. Specifically it says:
    Vehicles with manual transmission:
    Always engage the parking brake when parking on hills and inclined surfaces, as first gear or reverse may not provide adequate resistance to rolling.
    You can help prevent corrosion and avoid uneven braking response by gently engaging the parking brake from time to time when coasting to a stop at traffic lights (ensure that you will not pose a hazard to other road users).
    I hope this helps.
    Best Regards,
    Shipo
    OK, then practically the only way you can mess up your brake system rear brakes anyway is to overheat them and ratchet them up right away. But normall brake fade will kick in :(:)
    So unless you are doing that then it is just normal wear and tear. Keep using your parking emergency brakes, it is truly scary how many folks do not use their parking/emergency brakes when they park.
  • kyfdxkyfdx Moderator Posts: 273,936
    In any vehicle, regardless of transmission type, the parking brake should be set at any time you are not behind the wheel.
    In commercial vehicles, it is the law.
    regards,
    kyfdx
    I will continue to use the emergency brake as my sop when i turn the car off.
    That's what I truly love about Edmunds.com...we all don't know each other, but our passion for cars and trucks makes it seem like 1 big family here.
    Edmunds rocks!!!!!
    The Sandman :-)
  • edhedh Member Posts: 246
    They will only install the tire speed rating that came on the car.
    My 4 cyl 94 Toyota camry came with H rated tires - amazing but true.
    So Costco will only put back on an H. They will not put on a T even.
    Most other tire places tell you what came on it originally , but will put on whatever you want.
    What's Costco's policy based on?
    Costco wants to cut down the reasons for being sued.
  • driftracerdriftracer Member Posts: 2,448
    most other chain stores are the same way. Makes perfect legal sense to me.
    There are a few issues about tire speed ratings that seem to get lost.
    The first is that the speed rating is based on a lab test. Operating conditions may alter the actual speed capablity of a tire.
    For example, using lower inflation pressures lowers the speed capability. Another is driving on a surface that is less than glass smooth.
    One way to look at this is what percent of the tire's capability are you using. With an H rated tire, you are using less, and therefore safer, than using an S or a T.
    As a general rule, vehicle manufacturers have been caught up the pursuit of handling - trying to make their vehicles responsive to steering inputs - kind of a safety / PR issue. That usually means a higher speed rating.
    Hope this helps.
    maybe thats it--- cause a 4 cyl Camry really does not NEED a H rated tire.
    My cousin is also a slow driver he had the same Costco problem with his 4 year old Infiniti Q 45, it had a v rated tire or some other real high rating.
    we both bought other places than costco.
  • ashutoshsmashutoshsm Member Posts: 1,007
    ... I will defer to the excellent explanation from capriracer.
    To reiterate - yes, you may never approach the upper speed limit of an H rated tire, but that is NOT the issue. H-rated tires are constructed to have better high-speed stability, and possibly more grip (varies with manufacturer, but true when comparing different ratings in the same line of tires from ONE manuf.).
    So you WILL benefit from having a higher speed rated tire even when cruising at 60mph and turning sharply at 40mph. Like you may have to do to avoid a potential collision. Buy a lower speed rated tire at your own risk - only if saving approx. $5-10 a tire is worth it :)
    FYI - I upgraded from S rated tires to Z rated tires on my last car. On my current car, I'm on the verge of a move from H rated tires to W rated tires. But that's just me! If you shop around, and follow the reviews, you will not ecessarily pay much more.
    A higher speed rated tire will provide a harder ride quality than a softer lower speed rated tire.
    -mike
    the suspension on a car with H or V rated tires has spring and strut ratings that depend on that type of tire, not a wimpy, soft sidewall tire.
    Cars with more agressive spring and strut rates tend to load the tires more and rely on more aggressive tires to make the car handle correctly -
    If you use cheaper S or T rated tires, they will wash out and scrub, giving more understeer.
    To use a radical example, think of a Corvette's aggressive suspension - the engineers coupled that suspension with 40-45 series, stiff sidewall tires to minimize tire deflection so the car's strong springs and struts could "plant" the tire harder. If you COULD get an S rated 275/40-18 tire (you can't for this very reason, because some cheapskate would put them on his Vette) and put it on instead of a Z or W rated tire, the winpmy sidewall would fold hard under cornering, and you'd lose control. Manke that comparison a little less dramatic, and you have the difference in putting S rated tires on a car that needs H rated tires...
    in their tire tests noted that some UN RATED tires performed better than h t or s rated tires.
    buyer beware
  • ryokenryoken Member Posts: 291
    I just noticed that the door plaque for my '01 Ford Expedition (275/60R17) states the proper inflation pressure for my tires is 26psi front, 33psi rear. I've always thought tires should be 32-35psi, and never below 30. Wouldn't 26psi cause the tire to wear unevenly on the outer edges and affect gas mileage?
    The placard inflation pressure is the proper inflation pressure if you want to maintain the vehicle the way Ford designed it.
    However, it sounds like you are desiring something more - better tread wear, better fuel economy. So to improve those properties, it is advantageous to use a higher inflation pressure. What you sacrifice is ride harshness.
    FYI, Ford has for years used just enough inflation pressure to carry the maximum load of the vehicle, and nothing more. They do this in order to get a soft ride. IMHO, this is not good engineering.
    3 to 5 psi over the placard is what I recommend as a general rule.
    Hope this helps.
    is generally what I suggest as well.
    -mike
    "I just noticed that the door plaque for my '01 Ford Expedition (275/60R17) states the proper inflation pressure for my tires is 26psi front, 33psi rear. I've always thought tires should be 32-35psi, and never below 30. Wouldn't 26psi cause the tire to wear unevenly on the outer edges and affect gas mileage? "
    Actually what you wrote just made me cringe. When the Explorer tire blow out situation happened I followed this closely, for my 87 Toyota Landcruiser had the EXACT SAME tire size! So for 18 years I had been running 32-35 psi in my tires while others with the same tire size and I am sure same tire specs run 26 psi ? or 6-9 psi less? or from 19-26% UNDER INFLATED???
    So to get you in the ball park if you run 85% of the max side wall tire pressure it will be a good departure point and you can adjust for being too hard or too soft from there. So for example I have been running Michelin LTX's (275-70-16)for over 660k miles. It has a max sidewall rating of 44 psi. So 85% =37/38. I find this too hard so I run it at 35 psi and look to air it up when it hits 32 psi.If I let it go to 26 psi, it would make my heart sink! As another data point the Toyota Dealer that I have been going to for the last 16 years says 32/35 is just fine.
    Consumer Reports' Editors have been reviewed by people in their right frame of mind, and purportedly reported to have been under the influence of intoxicating substances of varying legality.
    They should stick to reviewing knitting needles and refrigerators.
    Consumer Reports' Believer Beware, especially if said Believer is a car enthusiast.
  • kenm8kenm8 Member Posts: 71
    Perhaps one should look at the methodologies that are used by Consumer Reports to determine whether or not they are capable of testing tires and autos. I think that their procedures are above reproach and have confidence in their reports. Also, as a reader, I do not have to wonder whether or not their testing methods might be compromised and test data skewed. They do not accept advertising.
    As an auto enthusiast, I do read other magazines such as Road and Track and Car and Driver and appreciate their objective test data and subjective comments about autos. These magazines do not test tires as frequently as does Consumer Reports.
    I would also agree. Outside of testing the tires under a quasi if not scientific methodology, ie repeatable and verifiable; they also take polls of their mailing list. It is pretty rare when the general test results differ widely.
    This of course does not prevent something that tests well new to not live up to reliability or durability parameters over time. Truthfully despite a so call black eye, Consumer Reports does report when that happens. They just dont run around practicing self flagellation or are seen in sack cloth and ashen bodied. :)
    An example. I bought a 1985 Toyota Camry based on very favorable testing. I also had had an earlier year Honda Accord stick shift and knew that the automatic Toyota would eat brakes and probably struts in comparison. Again I bought the Honda Accord based on favorable CR tests. For a time owning the Camry was very nice but then it started to become a maintenance nightmare. 1. Gas mileage started to drop, they could fine nothing wrong 2. struts needed changing 3.premature brake pad wear 4 rotor warping
    One day I saw some smoke in the headlights while driving at night. I thought it was the car ahead. I stopped when it looked like it might be my smoke. Sure enough as I opened the hood engine oil was firing out of a hole where the metal had failed. So I powered it down and checked the oil an sure enough it was about a quart low so I added and then drove all of 1/2 mile to the Toyota dealership. The next day they said I needed a new manifold, the head gasket was gone, the valves were warped etc etc they estimated 2200. They called back hours later and said well it looks more like 2500. Then when the service advisor called the third time I was almost beside myself. He said you need to tell me you have been having brakes and suspension problems. (Seems there was a secret warranty.) So I said hmmmmmmm and he said, we will take care of it, so he changed the rotors, brake pads, struts, axles. So what should have been close to 3100 in repairs was capped at 2500 and all this under 75,000 miles. :(
    CR later reports that this model year had more than its share of brake rotor suspension problems. :(
  • imidazol97imidazol97 Member Posts: 27,818
    >These magazines do not test tires as frequently >as does Consumer Reports.
    How many times has consumer report tested tires???
    I'm sorry, but I completely disagree with the methodology employed to determine the proper inflation pressure in message # 3837.
    First, it does not take into account the actual load on the vehicle. This is the MOST important thing to be considered about inflation pressure.
    Second, the methodology can lead to a situation where the tire is underinflated. Example: some vehicles require 35 psi to carry the load, and the tires might be marked 35 psi, or they might be marked 44 psi, or even 51 psi. Yet all these tires would have the same maximum load capacity.
    The placard, as flawed as it may be, ALWAYS takes the vehicle loading into consideration.
    Per index info in the back of Consumer Reports, tire tests over the last 3 years: Jan 04, Nov 03, Dec 02, Nov 02, Nov 01.
    Regarding auto testing, Consumer Reports states that they drive each vehicle for several months and 6000 to 8000 miles. Another factor regarding the things they test is that they “buy” all of their products. This assures that a manufacturer does not get a chance to have a “ringer” put in their test loop. There are no such assurances for car magazines that accept vehicles for testing from manufacturers.
    "I'm sorry, but I completely disagree with the methodology employed to determine the proper inflation pressure in message # 3837.
    The placard, as flawed as it may be, ALWAYS takes the vehicle loading into consideration."
    First of all I have no problems with your disagreement. I have run 32/35 psi for over 660k miles and basically other than taking in 9-12 nails one year on one set of tires have had no problems and in fact have had 55-90k of treadwear. So clearly if I was running a less than optimum condition, one would not expect those kinds of even wear patterns. While I do not have any direct experience with Ford Explorer tire blow outs (thank God) most of the indications were the tires were so called "under inflated" So for example, all one needs to do is look at the specs for the particular tire it is easy to figure given max tire pressure and max load. Again 85% of that should yield X max load.
    So for example mine are 275 70-16 Michelin LTX with max tp of 44 and max load of 2601 .85= 37 psi and max load of 2211 #'s at that pressure. My door also says 32 psi F/R. If I tow a trailer they recommend 35 psi in the rear. As I have stated 37 is too bouncy and rough and I adjusted down to 35 psi and let it sink if I am lazy to 32. Again I would be horrified to run it at 26 psi. Keep in mind that is 32-26= 19% under inflation. So that cuts to the issue of what is considered "under inflation"
    What is at issue with Ford (explorer) which is being settled in the courts is whether or not the recommended TP 26 psi was set lower than what the tire manufacturers recommends. I think we will not get a definitive answer from FORD or the sued oem tire vendors for usually part of any settlement is a clause of non disclosure of terms, including technical data such as tp recommendations and procedures and whether or not the prevailing party followed those instructions or not.
  • ghuletghulet Member Posts: 2,564
    I have a 96 Chevy Blazer LS 4x4 four door that desperately needs new tires (size 235/75 15). It currently has four Goodyear Wrangler AT/S, which have been OK, but I'd rather not spend $600-800 this time, especially since the vehicle itself is pretty marginal at this point. Can anyone recommend either a less expensive tire, or less expensive method of obtaining tires? My driving is mainly city, a bit of lower-speed highway and at least the past few years, only mildly snowy (I live in Chicago). Any experiences with buying on-line? I've noticed some sites offer free shipping, and I'm fairly confident I can have them installed at a small indy shop around here cheaply. Thoughts?
  • corvettecorvette Member Posts: 11,826
    If the Wranglers have been acceptable, Tire Rack has them for $78 each plus shipping. Searching for your size and sorting by price displays a Kumho passenger tire at $42 and a Kumho truck tire at $52. Yokohama Avid Touring, a very highly rated, long-wearing passenger car tire is available for $56. If I had to buy tires for my Altima right now, I'd probably get the Yokohamas.
    I think the point was missed as to WHY I object to the methodology.
    Any inflation pressure recommendation has to be directly linked to the actual weight of the vehicle.
    Let me point out a couple of flaws:
    "275 70-16 Michelin LTX with max tp of 44 and max load of 2601 .85= 37 psi and max load of 2211 #'s at that pressure"
    I'm afraid that isn't correct. The maximum load capacity for a P275/70R16 is indeed 2601 #, but it occurs at 35 psi. Increasing the inflation pressure beyond 35 psi is for special circumstances, like high speed driving, which is why the sidewall says 44 psi is the maximum.
    Besides, the capacity needs to be derated 10% because it is being used on an SUV.
    Not to discount one's experiences, but the experience with one set of tires on one vehicle is not enough to justify a generalization covering all vehicles. Let me site an example:
    I obtained access to the actual curb weights, load carrying capacity, and the dimensions of a Ford Super Duty pickup, which had LT235/85R16 load range E tires specified at 80 psi. Regardless of the manufacturer, the maximum load carrying capacity of an LT235/85R16 LR E is 3042 # at 80 psi (single). It turned out that at the worst case, the rear tires needed ALL 80 psi to carry the payload as specified by Ford.
    I agree that Ford's spec of 26 psi is horrifyingly low, but my rationale is that the load carrying capacity of a tire at 26 psi is "X" and there ought to be some reserve capacity, and there isn't. This is exactly Firestone's argument.
    IMHO, it is generally accepted practice that if you specify a component, it ought to be specified with a larger capacity than is needed. This reduces the probability of overload types of failures. Given that inflation pressures are not well maintained, it just makes sense.
    NHTSA did a study shortly after the Ford / Firestone thing. Their survey indicated that 1/3 of all pickups SUV's and vans were 8 psi or more below the placard. I think what people are talking about when they discuss "Underinflation" is this aspect, not what is spec'ed by the vehicle manufacturer.
    I guess what I am trying to say is that the vehicle manufacturer goes through some rationale in determining what inflation pressure they put on the placard and they always include the actual weights involved in their calculation. Any pressure recommendation should take this into account, since the source data (the actual axle loading) is not available.
    Hope this helps clarify things.
    Thanks for your two posts, but perhaps you missed in each post what the fellow was really asking you. In his case, shall he put 26#'s, if NOT, what is a good psi to put? I gave a very direct answer. If I read your rational I am still left with the question aint I? He was NOT asking you for the specs on a Ford 250 Super Duty or did I miss a few posts? I used mine as a example for the vehicles are fairly close.
    And so do you really expect the typical driver to even attempt to go through the calculations you have just outlined or is what is really missing in the market place a computer program to which you can run thes very "complex" calculations? I know that Ford and Firestone and whoever is on the wrong end of the liability suit would love to get the monkey off their backs BUT....
    "NHTSA did a study shortly after the Ford / Firestone thing. Their survey indicated that 1/3 of all pickups SUV's and vans were 8 psi or more below the placard. I think what people are talking about when they discuss "Underinflation" is this aspect, not what is spec'ed by the vehicle manufacturer."
    Again if what the NHTSA studies are true then the results totally backs up what I am saying. Keep in mind I mention 19% underinflated. You are mentioning "31%" I know what underinflation I can/want to tolerate and I have stated as such, but again what is really under inflation??? How much is too much. So what did the other 2/3rds run their psi at ? And also as you have indicated 18 psi is do able if I am running on sand!?? Or even on rocks? So I understand what you are saying, but your formula does not answer the fellows question.
    So for example the Fords and the OEM tire folks probably dont want to come out with a tire inflation program, again because if someone says they followed the program and here is the print out and it popped anyway again, case closed????
    First I think you need to go back and reread all the posts:
    Summary:
    Ryoken: What should I use?
    CapriRacer: 3 to 5 psi above the placard.
    Ruking: 85% of what is written on the SW and adjust from there.
    CapriRacer: I don't like the 85% rule, here's why....
    Ruking: Well, it works for my situation.
    CapriRacer: But it doesn't work for them all.
    Case closed!
    Cool,
    3/5 above placard 26 being placard= 29/31 So 3/5 because you say so???
    vs 32/35.
    Lets move on.
    lets move on
  • df2000df2000 Member Posts: 60
    I also have a truck (Isuzu) with placard=26psi.
    And I ruined my first set of Goodyear 245/70r16 by having uneven wear from underinflation (more on outside area of the tread), plus they were really noisy on every turn. Than truck was needed aliment, I got in "old school"(very good) aliment shop and guy told 26 is to low, you have to run from 35 to 40, it will be a little harsh ride but hay you bought a truck. I am now on my second set, I have Michelin LTX 245/70r16 at 35psi for about 40k mi and I got even wear and no noise at all.
    On my another car I run Michelin MXV-4 205/60R15 at 38psi(placard front=32,rear=28) for last 90k mi, I get even wear, better MPG, longer tire life. Well, I am not sure if you can do this with some no-brand tires, but with good brand name, like Michelin, I see no problem run +5/7 psi.
    Also if you follow their testing...
    Rollovers: Why do they shoot from behind, and not show how hard the driver is yanking the wheel, etc. Their testing is marginal at best!
    As for advertising... Hello Enron Under the Table deals....
    Tires and cars: They test them, and then take the lowest common denominator as their car/tire of choice. Never a real good car or real bad one, but an average one that would go well with their toasters and blenders. :) Nothing "exciting" just boring cars that win their choices.
    -mike
    To me CR when it comes to cars is another data point. The real utility is it looks at a major purchase like a CAR (or washer;)) from a non enthusiast's point of view, or more importantly the average consumers point of view. The reliability data is another data point, or, of value also.
    You both provided good info, thank you.
    I get the impression that 26 is safe, but is the absolute bottom with no margine of safety, so make sure it never goes under, not even a little bit. I'll run it in the low 30's for a bit and see if the ride comfort is acceptable.
    Going above 35 definately makes it a bumpy ride. The only time I do that is for autocross days with the other car. :)
    I think you have it exactly right!
    And you ought to maintain the front / rear pressure split. That way the handling doesn't change significantly.
    I may be showing my age, but the first few times CR tested tires, they did a terrible job of testing them. Being an expert in tires, I wondered about the other product testing they did - especially those that I had little expertise in and wouldn't know if the testing was proper or not.
    I concluded I couldn't trust their testing and cancelled my subscription.
    I have recently become aware that the folks at CR that do tire testing are former Pirelli - Armstrong engineers. They arrived many years after I cancelled my subscription. Hopefully their knowledge and experience has resulted in meaningful, "apple to apple" tests.
    I have tried to research the actual tire testing that CR performs, but have run into road blocks - in particular, a lack of a subscription.
    Before I write a check, does anyone know if CR supplies any details about the actual tests they perform?
    Thanks in advance.
    helpful but not done often enough, the manufactureres also side step the results by bringing out new models all the time making the results useless .Goodyear i think has been reinventing their rain tire since the mid 60s, every few years.
    -and the box store tires wal mart costco etc are unknown names.Whats a goodyear arriva relate to? - you do not know what regular tire they relate to..
    I trust CR more than tire rack surveys. cr will test like 20 brands in one category on one car over a number of days and I really think that give you a good stackup of their COMPARITIVE stopping handling etc. It does not tell you if the tires wear well or if they stay round. many complaints about tires like Dunlops are they are great for 10k miles then get noisy.
    the tire rack surveys are not useful to me - one person a tire is great and the next says they suck???????
    Whats the answer ?I don't know.
    the tire people have you where they want you - dependant on advertising. Oh Buy Michelin you say? - most of those I have owned ride hard.
    1) At least CR is attempting to test tires and make the results available to the public. I have no questions about their honesty or independence from outside interference.
    2) Tirerack does test tires, in addition to the survey results. Their tests are skewed towards performance tires, generally. But, that also seems to be their customer base. The performance tires were tested on a BMW 330i. There is a lot of good information from the tests, much more so than the surveys.
    regards,
    kyfdx
    Yes, the tire rack consumer survey is an unstatistically adjusted survey to in effect, attempt to mirror the CR reliability reports. The difference being the CR reports are statistically adjusted. While I like the Tire Rack's testing, they do not give you a long term feel for the tire and how it compares with what other folks drive and their take on things. So for example using these 4 sources: 1. TR testing 2. TR unadjusted consumer survey 3 CR testing 4 CR statistically adjusted survey it will help one to "triangulate" the information you are seeking.
    cr stst adj survey - never hear of that one. cr does tests - what cr surveys are you speaking of?
  • sequoiasoonsequoiasoon Member Posts: 223
    I always liked CR and 98% of their recommendations have worked well for me with one exception. I bought a set of Dunlop Rovers (to replace my crappy Firestone ATX before the recall) when they were the top pick from CR and they had a great price. From the testing standpoint the tires worked exactly as they stated much better then the stones in dry, wet, cornering, noise etc. Only problem they NEVER balanced right. Dealer replaced all 4 and I still had to get them re balanced every 6 months (thank god for lifetime balance). Next test they rated the BFG Long Trails the top pick. For 3-4 tire tests including both of those the Michelin LTX M/S and A/T were second and third with the only complaint being price. I splurged and went with Michelin LTX M/S and it was better than brand new. SMOOTH riding, NO vibration ever, great all around and still had a lot of tread 3 years later when I sold the Exploder.
    For other CR auto/tire testing. I do a TSD/scavenger hunt type of road rally 4 times per year. One member shows up with a different brand new car every time (I started noticing this 6 years ago)turns out he works for CR. These are test vehicles and they have to drive them like they would their own car. The rally are LOW SPEED about 30 mph mostly) but go down some REAL bumpy roads at times. I just thought it was awesome to talk to him and often think hmmmmm that would be a great job. I always chuckle some when I read the auto testing and see pictures of the cars they drove and then read the good and bad points.
    The survey with the colored dots!?? :) That is a compulation of real folks "rating" each car.
    Those are surveys of CR subscribers which may or may not be a representative sampling of all owners.
    They are a sampling of CR subscribers which may or may not chose to respond to a car they may own.
    What I am really interested in is what ARE the tests the CR uses to do the rankings.
    I can understand the results you get of of Tire rack and similar surveys. And my past experiences with CR are just that - past!
    Since I get asked about these ratings on a regular basis, I think it would be nice if I knew how they get them. The last time I looked, they didn't supply any details - only the results.
  • depotbobdepotbob Member Posts: 2
    I'm considering a very clean 01 Accord LX with 44M miles that was running Runway Enduro tires. Never heard of the brand. A Google search turned up nothing on ratings for Runway Enduros. The dealer says the car came in with the tires, so he won't change them in order to make the deal. I'd prefer to run Kumho's or Toyo's, but if the Runway Enduro's are legit, then I'll go with them.
