Tires, tires, tires
1130131133135136149
    So you should replace the tires every six years, just to be on the safe side.
    I heard it was every 5 years... and no I don't work for Firestone. :surprise:
    Just happened across this article and thought it may be of interest:
    Wet weather braking tests show budget tires don’t pay
    200 days of rain a year on average in the UK. That sounds worse than Seattle. We get ~230 sunny days annually here in Boise, so maybe I can buy cheap?
    Steve, visiting host
    It might be scary to think tire standards in the US might be greater, especially when continental Europe has its own countries autobahn, i.e. from 80 mph to unlimited speed limits. Or the corollary is.... it really doesnt matter that much ! :confuse:
    Since there isn't a US standard for traction, it would be hard for the US standard to be higher!
    I think what Steve posted would be applicable in the US as well.
    Well, sort of. Tires are rated for traction and temperature. The issue with traction is the rating is only based on wet braking . Oh, and the tire makers do the test themselves and "self-report" the results. Just like treadwear.
    In light of Steve's post, and my response and yours, I would have to agree with lilengineerboy's take. For me in the process of selecting tires I do give some weigh/priority to the UTOG/UTQG and the AA AA (traction) ratings. etc.
    ..."Traction Grades
    UTQG Traction Grades are based on the tire's straight line wet coefficient of traction as the tire skids across the specified test surfaces. The UTQG traction test does not evaluate dry braking, dry cornering, wet cornering, or high speed hydro planing resistance.
    The Traction Grade is determined by installing properly inflated test tires on the instrumented axle of a "skid trailer." The skid trailer is pulled behind a truck at a constant 40 mph over wet asphalt and wet concrete test surfaces. Its brakes are momentarily locked and the axle sensors measure the tire's coefficient of friction (braking g forces) as it slides. Since this test evaluates a sliding tire at a constant 40 mph, it places more emphasis on the tire's tread compound and less emphasis on its tread design.
    In 1997, the UTQG Traction Grades were revised to provide a new category of AA for the highest performing tires in addition to the earlier A, B and C grades. Previously the A grade had been the highest available and was awarded to tires that offered wet coefficients of traction above 0.47 g on asphalt and 0.35 g on concrete. Today the grades and their traction coefficients are as follows:
    Traction
    Grades Asphalt
    g force Concrete
    g force
    AA Above 0.54 0.41
    A Above 0.47 0.35
    B Above 0.38 0.26
    C Less Than 0.38 0.26
    Unfortunately the immediate value of this change to tire buyers will be limited. Use of the AA grade will first be seen on new tires that are introduced after the standard was enacted and will then appear later on tires that have had the required wet traction all along, but were introduced when the single A was the highest available grade."....
    link title
    In light of the above and referenced information but especially:
    ..."The UTQG traction test does not evaluate dry braking, dry cornering, wet cornering, or high speed hydro planing resistance.
    It would appear that one of the services/added value a place like www.tirerack.com offers is the real world testing after the app 1/2 G min standards for AA ratings. So indeed the standards are there, albeit INCREDIBLY LOW. :lemon: Besides I would swag every car geek had/has a fantasy of testing whatever tires he/she wanted to the hearts content and usually on someone elses nickel. A lot of folks test tires on their own nickels ;)
    Upshot: Indeed you are not saying just because one pays more (to incredibly more) for a set of tires that premium is a guarantee of the best WW traction?.
    Testing of course not only disproves that ( upshot) notion , but actually indicates more variance.
  • okko1okko1 Member Posts: 327
    your over thinking this :)
    ..."Or the corollary is.... it really doesnt matter that much ! "...
    "(you are-my sic) your over thinking this"...
    Hardy!?
    Perhaps we ALL could be more careful in the wording.
    In this case, there is no minimum level of traction performance required in the US. There is, however, a rating system - and the lowest rating is open ended downwards - meaning a tire could have a coefficient of friction of Zero and still be legal to sell in the US. I'm sure such a tire would not sell well, not to mention all the lawsuits that would be generated.
    Nevertheless, the issue highlighted by Steve's post applies to the US as well!
    I actually was careful in the wording. But I really just consider my self a tire consumer. I would actually go to someone like you for the REAL skinny !! (Broad to narrow to expert view)
    I think it is routinely seen on "brand new" oem tires. To use two as an example, but Indeed this might be an almost universal oem practice., Honda Civic and VW Jetta TDI come with oem tires (rated on www.tirerack.com) that were consistently at the LOWER rungs of the ratings system, aka 23/24 (thank heavens for # 24,) which is now rated 19/21, and 17/29. In both cases you can get radically better rated tires (same category, even across categories) at actually CHEAPER prices than the very low rated oem tires !!!
    On the other hand, I got 74,300 miles and 113,000 miles from the oem tires. Can I get that from the now better after market selections? If I did my research and, and ,and, and..... time will tell !
    Not that this is a trend or anything, ;) but the new 2009 VW Jetta TDI comes oem with a tire that is rated 26/29, again thank heavens for #'s 27 to 29.
    Interesting that some of the top rated "after markets" tires are actually cheaper (by -3 to -5 per tire) !!!
    "Interesting that some of the top rated "after markets" tires are actually cheaper (by -3 to -5 per tire) !!! "
    And some of these tires could easily be defined as "budget" tires....... Until someone defines "budget tires" (i.e. brand names) , I don't see how this article applies to the US market.
    Well a good example is Michelin. By most accounts, they are very good to excellent tires, in the categories they compete. While they try to have a Jack Welsh, old time GE mentality of having the BEST or near best" tire" in each category, they do not always hit the mark.
    Indeed some would say the "Asian" tires are the budget tires, but in fact Michelin has maintained rubber plantations in VIETNAM since before Vietnam kicked France out !!!! (aka LONG time ago . If so, using the logic, they are GROSSLY overpriced for what you really get. Again that can also depend on how it is measured, but I use cost per mile driven.
    How this applies to the US market is that many of these tires are for sale in the US.
    Never heard or seen any of these tires in the US until....
    I did do a search on Linglong tires. I did find a dealer in nebraska that sells them. Found some reviews on Wanli and Nankang tires. They seem to be either truck or performance tires.
    An example that seems to be good in the categories it competes. Kumho, a South Korean vendor?
  • ex_tdierex_tdier Member Posts: 277
    Anyone have any feedback on these tires? I'm thinking of getting them and also using them for winter as they're rated as a winter tire too: http://www.nokiantyres.com/tyre?id=10360796&group=1.01&name=Nokian+WR+G2
    EVERYONE that I have heard that has these tires, almost all RAVE about them. They are one of the first go to tires if you live in perpetual purgatorial weather. Those at the edge of or in center of that kind of perpetual weather have dealers that sell the Nokian brand. In the age of internet tire sales that may or may not be a disadvantage to you. I do hear that 40-60k is about the most you can expect of these tires. They are also expensive relative to other tires.
  • altair4altair4 Member Posts: 1,469
    I am running a set right now that I purchased in October for our '03 Passat wagon. They replaced a set of the Nokian WR's.
    In my opinion, these tires excel in these areas:
    Wet weather.
    Cold, wet weather.
    Moderate snow (I'm sure a more aggressive "snow" tire would beat it).
    I run them all year around. They are absolutely terrific in wet weather, as were the WR's before them. They okay in warm weather. Again, a dedicated tire would beat them.
    But taken in the context of an "all-weather" tire, I don't think anything would beat them. The compromises that Nokian made on this tire just fit too well with the way I run them in the weather that I face, on the roads I drive. They're just very impressive to me. They are what all-season tires should have always been.
    To my knowledge, it is the only "snowflake-in-mountain" tire that comes with a wear warranty. In my experience, they'll last as long as a Michelin all-season tire like the MXV-4 that Michelin had.
    And look for a local dealer - I was very much surprised how well I did buying locally compared to buying online and then paying separately for a mount/balance.
    I doubt that I'll buy any other tire for my car in the future.
    Can I ask what size and price per tire for the Nokian's?
  • kyfdxkyfdx Moderator Posts: 270,951
    I didn't get them..
    But, recent quote for 205/55-16 (times 4), was about $660 on the car (+ tax).
    Not cheap!
    195/65-15, stock size, was about $500, including tax, disposal fees, mount, balance and warranty at my local dealer. Comparable to Michelins in the same size.
    Actually a better buy, given the Michelins are clearly not a snow tire. . Did you take an mpg hit off the Michelins?
    No mileage hit that I noticed (and I'm on the OCD side) with either the WRs or WRG2s.
    I didn't get them..
    Not cheap!
    These are the sizes I need and I agree, they're not cheap. For that reason, I've decided against them. I may buy a separate set of winter tires as well as these have been rated 1 snow flake recently (barely achieving a severe winter rating).
  • Randy_74Randy_74 Member Posts: 2
    Don't know if this is the right place to ask this question, but here goes. I had my front end aligned and my tires rotated about three weeks ago. A few days ago I had a rhythmic noise coming from the rear left side. It turns out the lug nuts were loose (on ALL the wheels) and the left rear had damaged both the lug studs and the wheel itself (two elongated mounting holes). The shop that did the work said that they will do nothing since it was several weeks later. Should I take them to court? The lug stud replacement was not very expensive but the wheel is about $300 plus shipping and the mount and balance of the tire. Anyone have prior experience with this and/or work in a tire shop and have any advice?
    Thanks much,
    Randy
    2004Ford Explorer Limited with 17" Chrome/Alloy Wheels
    I am in no position to comment on the legal aspect, although my first reaction would be to hold them accountable.
    However it is commonly known that some tires/rim/lug nuts after tire work/change/rotation, etc DO work loose their lug nuts. I have seen in some owners manuals to check for this after the initial work has been done. So jumping over the liability issue the real question to ask the tire shop is what is the best time/miles after the initial work is done for them to RE check it?
    For me this is serious enough to have bought the applicable torque wrenches AND sockets and extensions and just recently an impact gun for "gorilla applied" and speedy removal.
  • toronado455toronado455 Member Posts: 83
    Consumer Reports rates the Hankook H725 slightly above the Yokohama AVID TRZ, yet in every category, the Yokohama scored either equal or better. So why does the Hankook get an overall score of 73 vs. 71 for the Yokohama???
    I'm getting 4 new tires for my 2002 Dodge Grand Caravan and I'm trying to decide what to get. Currently it has Yokohama Aegis LS4 which I paid $65 per tire (plus installation). I've gotten over 50,000 miles out of them which is perfectly satisfactory to me. I chose them because Consumer Reports tested them and liked them. Now I'm looking to replace them and the prices of the tires I'm looking at are much higher. The Yokohama AVID TRZ is $109 and the Hankook H725 is $100. I've never paid that much for tires in my entire life (no pun). ;) I wish I could find something closer to the price I paid for the Aegis LS4.
    I asked my tire guy about the #1 rated Goodyear Assurance TripleTred and he told me I should avoid those because they are unidirectional. I asked him if I should also avoid the AVID TRZ since it is an asymmetrical tire and he said that was different from unidirectional and not a problem. It just needs to be mounted correctly.
    I'd like to know why "unidirectional" is different from "asymmetrical" since they both need to be mounted a certain way. I don't see what the difference is!
    Essentially both are optimized for directionality. Asymmetricals are further tread TASK optimized.
    You can scan tire rack.com for probably the more technical article, but here is one source.
    link title
    Does the width of a tire have an affect on how a car drives in a straight line? For example, does a wider or narrower tire make it more or less difficult to keep a car going in a straight line on the freeway? Or does tread width have no affect on that? :confuse:
    All things being equal, a wider tire will be more subject to "tram lining" where it catches the grooves in the road and tracks off those. They are also more prone to "wander."
    However all things are not equal, and a lot of it depends on the tire design, the tread design and the materials used to make the tire. The 205/55R16 Bridgestone RE940AS Pole Position seems to be more susceptible to this then the Bridgestone RE92 OEM tires we had previously in the exact same size.
    Thanks. That's kinda what I figured. All things are definitely not equal.
    I looked up the specs on the Bridgestone RE92 tires in size 205/55/16. I couldn't find any info on the RE940AS.
    http://www.bridgestonetire.com/tireselector/SizeSpecs_BS_EN.aspx?Product_ID=8
    Apparently they make two different versions of that tire in that size - a V-rated version and an H-rated version. The V-rated version (for the Lexus IS300) has a wider tread width of 6.8" vs. the H-rated version's 6.2" which is shown as OE on the Subaru Legacy.
    The tires I'm considering, the Hankook H725 with a tread width of 6.3" and the Yokohama Avid TRZ with a tread width of 6.9" have a difference in tread width of 0.6". I don't know that I really should be all that concerned about that small of a difference. There are probably more important factors in the tread design to consider. Like the fact that the Avid TRZ is an asymmetrical design, for example.
    But the current tires on my car, the Yokohama Aegis LS4, have a 6.9" tread width (same as the Avid TRZ) and just look a little bit wide on the 6.5" wide stock rims visually. So I like the idea of getting something a little narrower. And my 2002 Grand Caravan has always had a tendency to drift a little bit when going straight on the highway, so if the narrower tire might help to curtail that then I'm all for that.
    But, unfortunately, there probably is no way to know for sure without actually trying something.
    Sorry, early morning type-o, RE960 A/S
    That's what we are dealing with here :)
    As long as the tire is approved for use on a given rim, I wouldn't worry about the tire width relative to others. A narrower tire *may* provide better MPG and rain driving at the expense of dry traction and braking of the wider tire.
    Have you looked at other culprits? Worn suspension components and improper alignment can produce the same results at a much faster rate.
    Ah, OK. :) 205/55/16 in the Bridgestone Potenza RE960A/S Pole Position with UNI-T has a tread width of 6.8" which is an 0.6" increase over your OEM tires. So I suppose we could make the argument that the wider tread on your replacement tires is contributing to the "wander" effect. But, of course, that is only a guess.
    The car was like this from brand new. An initial re-alignment by the dealer helped but never fully cured it. (My previous car, a 1989 Caravan, never had this problem.) And the tires are wearing perfectly evenly so I don't want to touch the alignment now.
    I'm tempted to try the Hankooks just to see if the slightly narrower tread width design helps any.
    "I'd like to know why "unidirectional" is different from "asymmetrical" since they both need to be mounted a certain way. I don't see what the difference is! "
    Assymetrical tires have outside and inside but they can rotate in either direction.
    Directional tires must rotate in one direction (except backing up ;-) but they can be mounted on either side.
    Tires that are assymetrical and directional (yes, there are such animals) have right and left flavours.
    So assymetrical tires might be rotated left to right and rear to front; directional tires can be rotated front to rear.
    Krzys
    Thanks, I think I understand now. Once a directional tire has been mounted on a rim, it must always remain on the same side of the vehicle it was originally placed so that it will always rotate in the correct direction. Whereas an assyemtrical tire just needs to be mounted with the correct sidewall outwards but can be moved to the opposite side of the vehicle at a later time. In order to move a directional tire to the opposite side of the car it would need to be broken down and taken off the rim and then remounted the other way around. Is that right?
    You've got it exactly... :)
  • oregonboyoregonboy Member Posts: 1,650
    The most extreme case would be asymmetrical, directional, staggered tires. Each tire would work only on one specific corner of the vehicle. :sick:
  • ny540i6ny540i6 Member Posts: 518
    Yeah... I live with this with the summer tires on my car - front/rear diff sizes, and Michelin's PS2s mean that there is no tire rotation for me!
    Actually this might be a tad hard to visualize.
    On an asymmetrical tire, you can rotate left to right and right to left . This was done on a (example: GY Eagle F1 Supercar)
    On a directional tire, you have to dismount and remount to be able to rotate left to right and right to left. (example: Toyo T1R)
  • oldfarmer50oldfarmer50 Member Posts: 24,531
    I was at the tire store yesterday and saw a sign that left me a little confused.
    It said that the store recommended putting snow tires on the rear wheels if you were buying only two tires. The applied to FWD cars as well as RWD.
    Now, putting two snows on the rear of a RWD vehicle is a no-brainer but why would you put two snows on the rear wheels of a FWD car? That makes no sense to me. :confuse:
    My .02 cents is only through experience and is not the most up to date techno opinion.
    1. 4 snows (all around) is the best.
    2. So if you are only getting two, putting them on the rears makes sense for you have to deal with the (loose) steering. .ie. more careful.
    3. fronts break aways are easier to correct and you feel it faster than the rears.
    For some reason, your post made me recalled this vehicle which was a HOOT in the deep snow!!!
    MB4 Coleman
    link title
    link title
    It's a liability thing. If the front tires slide, you continue to go straight. If the rears slide, you will probably spin.
    Most tire stores now insist that you mount 4 snow tires. It's not only safer, but they get to sell more tires. ;)
    I can't imagine putting two snows on a FWD car... that seems like a recipe for disaster, no matter which end..
    I wouldn't do it on a RWD car, either... but, I can see being able to control it, somewhat..
    The thinking is FAR different now a days. I can recall a 1970 VW Beetle, with two (24/7 live-in '74/'75) winters.
    I had been used to using a pair of "cable" chains, as most times you only NEEDED it at altitude in the mountains (6,500 ft) and only if they TOLD you to chain up.
    Since I was going to now "live in" 24/7 snow, I decided to get so called a set (1 axle=2 tires) of dedicated "snow tires." They made this thing run like the proverbial tank- all good. Except they were a real pain when you wanted to increase the speed as the whine would drive you crazy. The next winter I didn't even put them on and did just fine. This was in upstate NY if folks know the scenario. This was before the Global Warming bru ha ha. At the time we were waiting for the Global ICE AGE.
  • mz6greyghostmz6greyghost Member Posts: 1,230
    Driving in Upstate NY for my entire life, I can say from experience that you go with FOUR snow tires, or NONE at all. This goes for FWD, RWD, and AWD/4WD.
    Indeed, I would defer to your lifetime vs my 2 (live-in) winters !!!
    I RE read my post and yours, I would recommend to all, but the most skilled, don't try what worked real well for me (4 normal tires) ... at home !! ;)
    The store I saw this sign in did recommend 4 snows due to the possible effect on steering/handling dynamics (and the desire to sell 2 more tires).
    I guess it has been a long time since I've used anything but all-season tires. It never crossed my mind about how many dedicated winter tires you would use. In fact the last car I had snow tires for was a 1982 RWD Oldsmobile which I drove with snows just on the back. None of my FWD cars ever needed snows.
    And I, like a few of you have driven in upstate NY all my life. Ahh, the memories of my youth, driving on bald snow tires because it was so much easier to light them up that the tread was gone long before the snow fell. :blush:
    I was stuck on all-seasons for a while myself, until I got out of college, and realized I needed to get to work whether or not school closes. ;)
    Rather than get a set of 17" winter tires to swap on my wheels twice per year, I downsized to 16" on steelies (the base model wheel/tire size for my car). The extra set of wheels allows me to swap them myself in my garage using a jack and jackstands, saves me from $30-$60 every time I swap the tires, as well as less wear-and-tear on my 17" rims. After 2-3 seasons, the wheels pay for themselves, and the tires are usually much less expensive.
    After my first winter with true winter tires, I'll NEVER (and I can't stress that enough! :) ) go through another winter without them. I have sets of wheels/tires for both my and my wife's car, which are both FWD sedans. We don't want AWD for the 10-15 days per year that we'd actually "need" it, no gas-guzzling SUV or glorified station wagon they call a "crossover" these days. We both do just fine with only winter tires.
    I agree.... for me "all seasons" are just "all compromise" - not great dry weather, not great wet weather, and most definitely, not great snow weather handling.
    I use a dedicated set of 16" alloys for winter, with snows on them, swap them myself, get to hand torque the lugs, inspect my brakes etc etc, and use those darn expensive (but pretty) low profile, all aluminum jacks I bought a few years ago LOL ;)
    I drive a RWD vehicle, and this setup is the best for me.
