tnneedhelp... my keys are stuck and nothing works. did you get it figured out? windows down and rain on the way!!!! i have a 99 jimmy too.. please help
I wiggled the wire on the possitive side and poof.... all is fine! My bf was doing everything and thinking the worst last night... thanks to hours of reading on here, I fixed it myself! Thanks to all!
I have a 2001 2D GMC Jimmy. It has 13,500 miles on it. I get excessive vibration at 65+ mph in the floor and seat but was getting some vibration at speeds greater than 45 mph. After three set of tires I took it to the GMC Dealership. They found the transmission support was collapsed. Once they replaced the transmission support the vibration from 45 mph to 65 decreased greatly. They decided it was the drive shaft. After replacing it they found no change. The Dealership said they give up on finding the problem. I contacted GM and they sent in the Area Business Manager. He drove the Jimmy and decided that it was the Uniroyal tires. Michelin tires would solve the issue. I put a set of Michelin's on it and there is no change. I'm very unhappy that I have a mint condition SUV with low mileage and it is basically undriveable at speeds greater than 65 mph. They have advised me to file a complain with BBB. :mad:
They love to blame it on the tire issue, easy way out for them...It is not tires there are issues with the Jimmy's and they for some reason will not admit it...I feel they are just hoping to mask it with easy solutions and once most peoples warranties are over and major problems arise with the Jimmy's then it's out of their hands.....
Very Poor acceleration, stutters lots, almost as if its flooding but the exhaust isnt rich? Brand new Cat on it last week. Pedal more so sets where the truck will stop acceleratin. Pushing the pedal down wont change the acceleration. As soon at it hits bout 2500 pulls like it should. Mixtures maybe? Looking for new Throttle body~ Any help is much appreciated~
my 1985 jimmy has a 305 c.i. engine. 90,000 mi. 2 mechanics have gone through it without success.sometimes it runs fine, then will sputter and die or have no power. all suspect parts have been replaced, i think, except carb(rebuilt twice) and distributor. problem happens more after warmup and hot weather. any help or ideas are appreciated. :confuse:
We'll theyhave road force tested 12 "set's" of tires till they found a perfect set of good-year. Still had the vibration. District service manager takes it for a drive. Yep its tires try Michelin tires. Cost me 150 bucks for my brand new jimmy. Still vibrating even worse now. They are going to put back the "Perfect" Tires and have the service manager drive it again on the 18th of this month then he is going to likely tell me that they all have a vibration. Wrong!!!!!!!!!!!! I took a total of seven other Jimmy's out and found three that were as smooth as glass!
I have been cruising the Toyota dealers ! oh My Dad has sold his 2000 chev Silverado and has purchased a Toyota Tundra. He has been through three trucks with countless problems compared to my mothers Camry Let youknow what he the district service manager has to say!
I have a 86 s15 jimmy with 2.8 V6.I changed spark control module,pickup coil,ignition module,coil,dist cap,rotor.I'm getting fire to coil but nothing from coil to dist.
I recently purchased a 1996 S-10 Blazer. It will not pass inspection here in lovely NY. I tried the other day and it was giving the following Not Ready messages:
Evaorator unit: Not Ready Oxygen Sensor Heater: Not Ready EGR something: Not Ready
Today, it had 2 more Not Ready messages for a total of five!
Has anyone else had a similar problem? If yes, PLEASE give me some ideas on how to stop the nightmare. Ive had the truck for 3 weeks now and havent been able to drive it. SOMEONE PLEASE HELP!
I agree it is not a tire issue 4 sets have been put on mine all force balanced and still the same results...The dealership here has 15 now and 3 more on the lot that vibrate..I have driven one that hasn't but no thx no more for me, I am out of it now going after GM for a full refund and into a 2005 Canyon, man it's like nite and day there is a reason why the Jimmy's and Blazers were being blown out so cheap.GM knows the reason is avoiding it and it is going to come back and haunt them as they need to look after and resolve this now and not blame it on tires.... :mad:
Thanks!!! - that did the trick - please note that when I removed the bolts on the crossarm support on the passenger side (I only loosen the bolts on the drivers side - good tip) the crossarm was allowed to drop, which also dropped the transmission a few inches. Next time I will shore up the transmission
Even though my Blazer is a 95, it has OBD-2 (it must be a mid-year model). My problem started last year when I lost my 4WD. It is the push-button system(NP-233). The 1st thing I checked was the switch. It checked out ok. Next I checked for trouble codes. The only code was for an erratic speed sensor. I came to find out that I had a bad wheel hub on the front left wheel. I replaced that. After that, I replaced the ECM for the transfer case. Still nothing. So I break down and take it to the dealer to have it diagnosed. After a $100 bill, I was told that the mechanic replaced a fuse and tested and returned it to me. That night when I was comming home from work, the fuse blew, the lighted switch for the 4WD went out, as well as the dash lights and the tail lights. I looked in the fuse block and replaced the bad fuse, all seemed OK. Since I hardly ever drive the Blazer after dark, I had no further problem. When my son started his 1st job, I was required to pick him up as he had not gotten his drivers license. I started blowing that fuse almost nightly. Tonight it happened twice. It seemed to happen when I put on the brakes. After thinking back to other repairs I had done that could have been related, I remembered that I did replace the brake booster about a year or so ago. I'm not sure if this might have anything to do with it, but I thought I shoould mention it. Thanks for any help you have, Don Solomon Durango, CO
Ok, here is the problem. Occasionally all the lights in the console light up like a christmas tree up (kinda like when the car starts up), then guages all go to zero and do not work and then when you accelerate you have to press the pedal down considerably to accelerate. Any ideas?
I have a 1997 Chevy Blazer. The auto will intermitintly stall (turn off)and all dash lights come on. The engine restarts easily but the problem repeats in a few seconds although sometimes it will run for hours with no problems
Had similar problem with my 1999. Change the electrical relay. Mine is under the hood against the fire wall. There are 2 small black boxes, one controls the running lights and one the headlights.
Now my 99 has a blown seal on my bad wheel bearings. Went to change them but need to know if there is a pin in the 'pumpkin' or if i need a press to put it back on? Anyone know? We tried to replace last night but couldn't get the hub to come out. I was told may have a pin in the pumpkin or may need a press. Help Please.. This thing has Got To Go!
I have a 1998 blazer 4wd, I bought it in Feb. We noticed in May that the breaks squeal and recently have started to making a grinding type of noise. I have taken in back to the dealer where I bought it at and he told me that the Breaks are brand new on it and they checked it 4 times the day i was there. I dont have trouble stopping and going. The squealing and grinding noise start when you first move from a stopped posistion and tapping the brakes lets the noise go. Also they do squeak a bit when i stop. I have heard on the radio that several GM trucks have been recalled due to the braking system. I can't find if my blazer has been one of them. I am thinking about going to a GM place and having them check it out next week. It was getting a bit loud and kinda scary driving in the high graded hills over vacation.
Also I would like to know what damage could have been done becuase when I bought the Blazer they had the tranny fluid in the differental and the differental in the tranny. I since have replaced ALL fluids and the dealer ship has reimbursed me for doing that. I dont know how long it was in there as far as we can tell there isnt any signs of damage showing up now.
I have a 2001 blazer.The check engine light is on. I took it to a local shop, only to find they could not fix it because it is the PCM. I was told it has to be repaired at a GM dealership. Can anyone help me?
98 Chevy S10 Blazer with intermittent A/C and airbag light. When the A/C problem began, the air would get hot for a few minutes, then cool back down (52 degrees). Vehicle has electronic climate control. At this time, it is mostly blowing hot air. The compressor is running and we've changed the blend motor without any success. Also, the airbag light comes on from time to time. Sometimes it's on steady, sometimes blinking, quite often it doesn't come on at all. I'm suspicious of a computer or ecm problem. Anyone familiar with this vehicle and any module that could affect both systems?
I have a 2000 Blazer with a similiar problem. All the console lights will come on and I loss most of the gauges. No rhyme or reason when it might occur or go away.
Can't find any loose wires or connections. If anyone has an idea, please let me know.
Not sure what a "pumpkin" is but here's the procedure for replacing axle seals/bearings. Requires opening up the differential housing and removing the axle shaft C lock:
Axle Shaft, Bearing and Seal GM S-Series Pick-ups and SUV's 1994-1999 Repair Guide
1. Raise and support the rear of the vehicle safely using jackstands. 2. Remove the rear wheel and brake drum. 3. Using a wire brush, clean the dirt/rust from around the rear axle cover. This should be done to help prevent foreign material from entering the rear axle and possibly damaging the differential. 4. Place a catch pan under the differential, then unscrew the retaining bolts and remove the rear cover. When removing the cover, a small prytool may be used at the base of the cover to gently pry it back from the axle housing, breaking the gasket seal and allowing the lubricant to drain out into the container. Be careful not to use excessive force and damage the cover or housing. 5. Remove the rear pinion shaft lockbolt and the pinion shaft from the differential.
7. Remove the axle shaft from the axle housing by pulling straight back on the shaft hub, be careful not to damage the oil seal with the shaft splines. 8. If the bearing and/or oil seal is being replaced, use a medium pry bar to carefully pry the old oil seal from the end of the rear axle housing. DO NOT score or damage the housing oil seal surface. 9. If the wheel bearing is being removed, use the GM slide hammer tool No. J-2619, along with adapter No. J-2619-4 and the axle bearing puller No. J-22813-01, or the equivalent tools to pull the bearing from the tube. Be sure to install the tool assembly so that the tangs engage the outer race of the bearing, then use the action of the slide hammer to withdraw the wheel bearing from the axle housing.
To install:
10. Clean and inspect the axle tube housing. 11. If the bearing was removed, thoroughly clean the wheel bearing using solvent, then blow dry with compressed air. DO NOT spin the bearing with the compressed air or damage may occur. Inspect the wheel bearing for excessive wear or damage. If it feels rough, replace it. 12. With a new or the reused bearing, place a blob of heavy grease in the palm of your hand, then work the bearing into the grease until it is thoroughly lubricated. Using an axle shaft bearing installer such as No. J-34974, J-23765 or equivalents, drive the bearing into the axle housing until it bottoms against the seat. 13. If the bearing and/or seal was removed, use an axle shaft seal installer tool such as No. J-33782, J-23771 or equivalents to drive the new seal into the housing until it is flush with the axle tube. If a seal installer is not available, a suitably sized driver or socket may be used, just make sure the surface in contact with the seal is smooth so that it won't damage the seal. 14. Using gear oil, lubricate the new seal lips. 15. Using a putty knife, clean the gasket mounting surfaces on the housing and cover. Take care to keep material out of the differential housing. If necessary, place a rag or paper towels over the differential while cleaning the housing flange.
When installing the axle shaft(s), be careful not to cut the oil seal lips.
16. Slide the axle shaft into the rear axle housing, taking care not to damage the seal, then engage the splines of the axle shaft with the splines of the rear axle side gear. 17. Install the C-lock retainer on the axle shaft button end. After the C-lock is installed, pull the axle shaft outward to seat the C-lock retainer in the counterbore of the side gears. 18. Install the pinion shaft through the case and the pinions, then install a new pinion shaft lockbolt. Tighten the new lockbolt to 27 ft. lbs. (36 Nm).
When adding oil to the rear axle, be aware that some locking differentials require the use of a special gear lubricant additive.
19. Install the rear cover using a new gasket and sealant. Tighten the retaining bolts using a crosswise pattern to 20 ft. lbs. (27 Nm). 20. Refill the rear axle housing using the proper grade and quantity of lubricant as detailed in Routine Maintenance of this repair guide. Install the filler plug, operate the vehicle and check for any leaks.
I have a 97 blazer i purchased used recently. While driving down the road you all of sudden lose power. At the same time the air bag light flickers on and off with the engine trying to run. I usally pull to the side of the road. The blazer never cuts off but runs just enough to keep the motor going. This will clear up after a minute. When the engine starts running ok again and you pull back on the road the transmisson shifts hard. If you cut the blazer off and then restart it the transmisson shifts smooth until it has another spell where it won't run right again. Has anyone had this problem or might know what is causing this. Thanks for the Help
I'm hoping I don't have a bigger problem. I ran my Blazer out of gas - then put 2 gallons in it - turned it over and it wouldn't start. The starter was cranking and the electrical seems fine. Any suggestions? Is this one of those cars that needs to be put on an incline or decline to get the gas to have a little head start after running out? Thanks.
Have the wiring harnesses off the computer checked. I had a similar problem with the gauges and lights, but the truck would also shut-off. It turned out that 3 wires on the harness were exposed and causing a short-circuit. This may be the case with your truck too.
While driving the other day my 98 jimmy lost power and i coasted to the side of the road where it then died. I wasn't able to get the truck to start after that. after getting it home I replaced the fuel filter and check the fuel pump all seemed good. When i tried to start the car would turn over and unsteadily idle for about 30 sec or so and when the accelerator was pressed it would die. After finding the locations of the ignition control I decided to disconnect the module and attempt a start. it acted the same just cranked and no turn over. With this what should I replace first the ignition module or the coil? Or would it be something else? I don't have access to a diagnostic reader so if any one knows how to jumper the connector to get a reading through the display let me know.
Is the check engine light on? What's the fuel pressure reading? Is there a hot, blue spark when using a spark tester? Guessing and throwing parts at it gets expensive in a hurry.
"I don't have access to a diagnostic reader so if any one knows how to jumper the connector to get a reading through the display let me know"
Jeff, I checked all the fuses under the dash and under the hood.......all are fine. You can hear the lock working...actuator and sylenoid seem to be going good....replaced batter in key module just in case...didn't work. it is as if the glass part is just jammed for some reason. You can not take the back pannel off without opening the gate......am I just out of luck??
I also have a similar problem with my 2001 blazer. I was changing oil a few months ago and the transfer case suddenly shifted into 4LO. After several attempts I got it to shift only back into AUTO4x4 (trans in neutral). Once in AUTO4x4 pushing 2HI sends it directly back to 4LO. 4HI button has no response. Finally I removed the battery cable for 5min or so and 2HI was then entered with no button pushing. I made this problem go away for awhile by removing the red + positive battery cable and cleaning all the corrosion on the cable end. I scraped the corrosion off with a flat blade screw driver and a steel brush until I saw bright copper cable end. Then I drove for 5min and the service 4x4 light didnt come on, so I tried all the 4x4 modes and they all worked perfectly. But this problem today came back to haunt me. I wish I could tell you more about a perminent repair without going to an expensive dealership. Unless you have found a repair since your problem has occured. ">link title
Could anyone one tell me where the egr valve is located on My 94 S10 Blazer. I am having problems with it stalling out and dieing so I replaced the fuel fiter and the PCV plug. But now the car wont even start. So I am going to try to clean the EGR valve and put in the Tomco screen. Thanks so much for the help.
I own a 1999 GMC Jimmy 4x4, 4 dr. 4.3 and last week the overheat warning came on while I was driving on I-95. The vehicle over heated and died before I could pull over. I had it towed home and replaced the water pump, thermostat, flushed the radiator, changed the oil and spark plugs. After all of that my vehicle will not start. It cranks but will not start. There was no radiator fluid in the oil and no oil in the cooling system. The Hayes repair manual does not seem to help much so can anyone please assist me in this major problem?
not out of Luck. you've got to go inside and pry back the plastic panel. Be careful you might break the lift handle like i did. Then you can use a flat tip screwdriver to get the back glass open, be careful. When you get it open you can pry the panel back a little more and get your hand down inside. find the plunger thing. there a piece of plastic that hold the batting arm next to the plunger. if its broke . rig it with a metal clothes hanger. Once you get the door open and unscrew the panel you will be able to figure all of that out. Just remember. Metal Clothes Hangers and Duck Tape can fix almost anything. for awhile anyway.
check your primary ingnition wire going from the coil to the distributor...I have found the wire to rub on the heater hose eventually arcing out and short circuting. Remove the plastic air intake cover and try to strat your engine (have someone else crank it) you'll see the spark arcing across to the heater hose. Put a new wire on and insulate it by covering it with a 3/8" dia rubber hose where it contacts the heater hose. It's arcing out to the water in the hose.
started fine, driving along, came to a stop, while making a lh turn it began to spit and sputter, then died and rolled off to side of road! Turned ignition and just won't turn over to start (recent new battery, ac compressor). Took spark plug wire off a spark plug, stuck a screw driver in end if spark plug wire and held next to engine block, turned ignition and spark is orange, very low and weak. It just won't catch! What's do you think? Ignition coil? Any ideas...
Just curious if you ever found a solution to this problem. My 98 Blazer is having this issue now after having the alternator replaced last week. I've carried it back to the shop and the mechanic replaced the blend motor, but the problem still exists. I suspect something under the hood because we didn't have this problem BEFORE the alternator was replaced. The climate control appears to be working to the degree of changing the fan motor speed based on changing the settings, but regardless of the environment and settings, the air is always HOT now and the compressor is still running and the refrigerant lines are cold.
check your primary ignition coil wire to see if it is rubbing against the heater hose...this will cause a significant problem as the wire has a tendancy to ground out and screw up your ignition .
I have the same situation as you with the tank fuel pump running even with the car turned off. I changed relay and the problem still exists, any suggestions as to what may be the problem? I have a 95 Blazer. Please help
Hey Kevin, My 1998 Chevy Blazer has been doing this for the last 5 days. Man, I have been to several auto-electrical shops and have replaced the flasher twice. Your explanation has been the best and makes the most sense of all. Just when I had reached the end of my rope. Thanks for the knot. I'll get back with you to let you know how it worked out. Peace out. Ebs57
Anyway, I did replace the motor, and so far, so good. Keeping my fingers crossed still though....
Linda
I have managed to take the panel loose from the dash and it seems to be comming from the center of the unit.
Something electrical is burning I just can't get it tore apart far enough to find it.
Is there any links to disasembly instructs on this.
And / Or has anyone else had this problem.
Thanx
Dave :confuse:
Don Solomon
Durango, CO
http://www.autozone.com/images/cds/gif/medium/0900823d8018c464.gif
6. Push the axle shaft inward, then remove the C-lock from the button end of the axle shaft.
http://www.autozone.com/images/cds/gif/medium/0900823d8018c466.gif
To install:
Thanks for the Help
Nope. A code reader or scanner is required.
Heather
http://www.autozone.com/images/cds/gif/medium/0900823d8018b80a.gif
Thanks :sick:
