Did anyone have a reply for your question?
-Mike
My 95 Blazer just started to do the same thing. did you ever figure out what is wrong.
Josh
The speedo + directional keeps going off, sometimes for days at a time? but
everything else is ok, gas/temp/oil/battery displays etc,How can i trace the fault,or do i have to replace/repair the whole dash ? If so, do any of you guys know anyone in the states where i can get a replacement, used parts dealers/breakers or repairers
etc.Thanks up front for any help
Mike
Mike
Took in to the dealer at 15,000 miles for pulsating brakes
Dealer said Rusty and dirty cleaned them up.
Brakes still pulsated but we figured it was due to Anti-Lock
Now 30,000 miles.
Brakes pulsating and squeaking on start up.
Took to repair shop.
Mechanic said we had to replace all four brakes and rotors.
Called dealer,
Dealer said probably weather related, not covered by warranty.
Told mechanic to replace the brakes.
This is what they told us.
Pads would not slide on caliper brackets.
The Sliders and caliper brackets were NEVER LUBED!
This caused, rusted rotors and warped rotors.
Repair shop gave me the old parts.
Question: At 15,000 miles we took it to dealer.
I wonder what the dealer told GM and or charged warranty service?
Could the dealer have charged GM and not done anything?
If so how can I find out?
I have a 98 Blazer and recently my engine started hesitating slightly. Initially it was just a slight hesitation, and could really only be felt at slow speeds or at a stop. Lately it's gotten worse, getting to the point where if feels like it could die. Have noticed it doesn't start hesitating until the engine warms up. Changed the fuel filter, no change. Today, after returning from a drive, popped the hood and looked around. Heard what sounded like a clicking sound coming from the area around the distributor cap (can't quite pinpoint source of sound). The clicking seems to preceed the hesitation, then stop as the hesitation ceases. I have no "check engine" light. Additionally, and not sure if this is relevant, I removed the are intake from the throttle body and the engine died. Probably normal, but not sure. Any thoughts?
Here's a link that may help you figure this thing out:
Link to page
Thx
Jim
Do a google search using "P0441", and/or "no flow during purge cycle" and you should come across some possible causes, or other people's experience with this fault code.
"Mine did the same thing. Caused a SES light for 1.5 years until I figured out the problem. More than likely, it's a bad evaporative emmissions vaccuum switch. It is located below the coil packs on the back side of the engine if you are standing in front of the car. There is a bracket that is held onto the same studs as the coil assembly, and the part you want is on the left hand side of that bracket. The purge solenoid, is on the right. You want the the switch, not the solenoid. Of course, check your vaccuum lines around there and make sure none are disconnected which would give you the same error, but chances are, it is that part. Cost me like 25 bucks at a parts distributor. Once you have checked all your connections to make sure you don't have a leak, or loose hose, try that part. You may also want to take the car to an Autozone or something and have them clear the codes for you. Otherwise, there are some certain criteria that have to be met before the computer will realize that the system is working properly with the new switch installed and the SES light won't go out right away. Let me know if it works for you."
O2 sensors. Vehicle still is running rich and is getting about 8 mile/gals
Check engine light stays on
Any suggestions would be appreciated
Just got back from a NYS inspection station and my 95 jimmy pasted
LJM
He has a 89 blazer and he is looking for a back window for in the tailgate...this is the second one he has broke so we are looking to find a cheap used one or new somewhere cheap.....he also had a question about modifing it too...does anyone know of another make and model where he can switch the tailgate for one or two of the swing out tailgates? Any help would be great!!!!!!!
