jimbob7216@hotmail.com.
Jim
First, I put it into 4WD high. From a standing start, I mashed the pedal to the floor. The terms "shot out of a cannon" and "like a bat out of hell" are how I would describe it. It was like I was on dry pavement. The TRACS light came on and the brakes did their job at moving power from wheel to wheel. The rev limiter never kicked in.
I then tried it again with the center differential locked. You can't do this in the high gear range in the Sequoia but it also simulated what a conventional 4WD would do. In this mode, the TRACS and VSC are off. I still moved but could really feel the wheels spinning. Control was not great and I had a fair amount of side slipping. I did it again without mashing the pedal. This worked much better.
Next, I put it into 2WD and mashed the pedal. Now here is where it got interesting. The TRACS system quickly took over with both the brakes and the throttle. My RPMs were reduced to between 1500 and 2500. The brakes were clicking constantly but I was moving steadily forward. The throttle would cut in and out with my forward progress. If I eased up on the pedal, control improved even more but even with the pedal on the floor, I was able to move forward and turn with ease.
This was a stunning display of the TRACS/VSC. Even I was amazed at how well this 2WD vehicle was handling extremely slippery conditions. Obviously, the 4WD worked much better but the 2WD got me moving and in control.
I had the problem with the VSC OFF and VSC TRAC lights that would not turn off.
They said they only had to reset the computer. There were no error codes, so reseting the system was all they needed to do. I mentioned that this was not a satisfactory explanation, because something had to trip the error condition. And if it was not fixed, how do I know that it won't happen again, or that something is in fact damaged.
Their reply was always, if we don't know the error code, we don't know where to look.
I did get the center differential to lock in L4 and L gear.
I got to drive it on the freeway yesterday, and noticed that around 60 MPH the car has a slight vibration. Nothing major just a slight vibration. Accelerating past 60 or slowing less than 60, the vibration appears to go away.
Has anyone else experienced this?
Any ideas and suggestions.
I had to face the same choice 2 month ago. I tested both and settled on MDX. The MDX gives me all the toys standard including 4WD full time, 5sp automatic transmission, sunroof, Alloy wheels, fog lights, 7 seats, etc. and still about $2500 less than a Sequoia (SR5 4WD) with less features. I don't go offroad and don't tow a lot of stuff so my choice was easy.
BTW, Sequoia has a better roof rack in my opinion.
Lets get to picing and options. Please tell me if I got a bad,good or great deal.
We purchased our Toyota SR5 4WD with the following options -Alloy wheel package -Convenience package-power tilt moonroof-roof rack-dual control AC-Daytime running lights-power adjustable front and pass.seats.
MSRP price $39,120 add tax, plates and title I dont know if destination was included with MSRP.
We got ours for out the door price for $39,800 this price included tax, plates, title, destination and he also included floor mats and put a hood protector on.
Im not a Ford basher Im going to buy a Ford Escape next year for myself The seq is my wifes suv.
Last thing the only con so far with the seq. GAS MILEAGE SUCKS!!!!!
I agree that they're both completely different animals.The Sequoia is significantly larger than the MDX overall, so it's not just a matter of having one extra seat. The MDX is a good vehicle for people who need the occasional 3rd row for kids. However, the Sequoia's 3rd row is actually usable for adults for fairly long trips. It has a fair amount of cargo room behind the 3rd row to boot. I'm only 5' 9" and I could not sit on the driver's side portion of the MDX's 3rd row seat. I just barely fit on the passenger side of the 3rd row seat, but that's with the 2nd row 40% section moved forward. The 60% portion cannot do this. In addition to this, entry and exit to the MDX's 3rd row is extremely difficult.
In addition to the above, the Sequoia has selectable full-time 4WD - 50/50 split - whereas MDX has auto AWD with a low speed (below 6mph - full-time mode). The Sequoia also has stability control/traction control whereas the MDX does not. The extra weight of the Toyota which hurts the fuel economy gives it an advantage over the MDX in accidents.
Drew
Vans and Aftermarket & Accessories message boards
My question is, are the dealer 'Simonize 5 Year Wax and Upholstry Guarantee' ($389) and the 'Straight from Toyota 6 year 75,000 mile bumper to bumper warranty ($1,487) even worth considering?
This is my first SUV (I/m starting at the top!) and with 4WD and all those computer gadgets, I'm thinking about the extended warranty.
Opinions -preferably laced with fact- please.
Thanks for any feedback.
Tony K
Also, I beleive the MDX could keep up with the Seq off roading with the exception of ground clearence limiting events so I would not place too much weight off roading between these two.
Lastly, I looked at both of these as well at a time when I couldnt really decide what they were intended for but they are really two different SUV's. If you dont need the extra towing, extra space and are usually using the 4wd/awd for snow and ice then I would give the edge to the MDX. Its cheaper, gets better milage and probably will be equal in quality although I hate to bet against toyota here.
Drew
Sorry about the confusion.
I have calculated our gas mileage to be 13.1 mpg.
The overhead console computer has calculated that I'm getting
15.2 mpg.
The difference is $18 more in gas based on 1.70/gal. WOW!
At 100,000, it would cost approximately $1800 more driving at 13.1
than it would if we got 15.2.
You can find some information here.
http://www.theautochannel.com/articles/2001/01/08/012401.html
Priced between $23.5K and $26.5K. It's not much more than a midsize sedan.
It sounds like TRACS works really well in high range on a level but slippery road. That's certainly where it will be used in the majority of cases. I wonder how TRACS would do in low-range Drive (i.e., with TRACs still enabled) on a slippery (e.g., sand covered) 30 degree rocky upslope that you need to climb at 1 mph. That's a case I am interested in, but would have trouble testing here in the midwest. That's a case where a locking center diff in low/low would do well until you got opposite diagonal wheels unweighted or losing traction on a slippery surface.
I once watched a 4Runner try and power his way up a rocky slope. He got a rear wheel off the ground, and it promptly spun up a storm, and when it hit the ground again, the instant deceleration snapped the axle like a twig. That's probably a key reason why TRACs has rev-limiting capability, and is also why I want to go only 1 mph under those conditions.
The 2WD case sure does sound like what happened in the infamous "accelerated into highway is slippery conditions and lost power" case. Rule-of-thumb, always keep it in 4WD except in dry summer highway driving.
Question: When you select 2WD mode, does it disconnect in the transfer case (like the older manual transfer cases), or does it just unlock the front wheel hubs. If it does just the latter, then you aren't saving any wear and tear on the drivetrain in 2WD mode, and the mileage may barely differ.
Re: "I had the problem with the VSC OFF and VSC TRAC lights that would not turn off. They said they only had to reset the computer." Is this something the owner's manual tells you how to do, or must you take it to a dealer (ugh). Would the service manual tell you? Would it also tell you some of the computer options that can be set, like the rear window unlocking sequence? Maybe there's an optional setting to enable TRACs in low/low ;-).
This is something users need to know how to do. Computers are everywhere, and the code in them is generally not bulletproof and can get lost in hyperspace should an unusual condition (or timing of conditions) occur. Just this past week, for example, I've had to reset my dishwasher (by switching the breaker), my cable modem (by pulling the power cord), and my computer (by pulling the plug - cycling the power switch had no effect) twice.
I was under the impression that the Sequ engine was basically the same as the Lexus engines.
People are complaining, however, about tapping, clicking, valve problems, etc. with the Sequ engine.
Is this a different engine?
Also, what type of gas mileage are you guys getting?
FYI: I earlier posted that we got $3,000 off MSRP in Atlanta - Sandy Springs Toyota - which still appears to be a good deal.
1200 miles and no complaints. I am driving in 4WD all the time now and have had no problems with VSC/TRACS cutting in at inopportune times. I think this is the way that the truck was intended to be driven.
I'm trying not to get used to the bass problems with the radio. It sounds better at higher volumes and is not all that bad, but I am still hopeful that there will be a fix for this.
Handling in the ice and snow has been exceptional!
As the salesman walked to the desk, I heard the customer say in a loud voice "Oh great. Here we go again." Then, pointing to me he asked, "Are you a salesman? Can you please help us?"
I greeted him and asked for a minute to call off the other guy. I had overheard what the guy wanted and knew it was going to take some professional level help to meet his needs. After a brief... discussion... with said rookie, I came back and proceed to figure out what the customer needed.
The couple was very nice and well informed. We figured out exactly what they needed and quickly came to a mutually acceptable price for the order. All went very smoothly.
Here's the part that bothers me. They are active lurkers on this board. They relied on information posted here by all of you and myself is coming to a decision. They didn't realize that I am a salesman in their back yard.
So... for all of you in the DC area, my name is Steve Clifford and I sell Toyota at Springfield Toyota. The number here is 703-451-0300 and my e-mail address is sclifford@kjtoyota.com. Don't put yourself through the headache of dealing with inexperienced and unimformed salesmen if you don't have to.
http://www.fisherprice.com/US/products/product.asp?id=621
So did they retrain or fire the "rookie" salesman? Seems like a worthless individual if you ask me.....
WHATSSSSSSSSSSSSSSSSS UP?????????????
Hey you should come back to the tundra topic it has cooled off alot recently.
Post #538 way to toot your own horn.
Ryan
The neighborhood isnt going anywhere just wanted to say hi
Ryan
Ok can you get a factory hitch on the limited tundras??? What about the SR5's?
Ryan
Ryan
Can you please clarify this recurring question to me? Can we actually include the convenience package, fog lights, and rear spoiler in a build-to-order for an SR5? I am still confused by the mixed information that the dealers in "my neighborhood" are giving me. I am trying to order an SR5 with these and other options.
What's frustrating is that the dealers giving me the "better offers" are telling me that I cannot have these options on an SR5. The ones that charge more, said I can. I just want a straight answer because I know you've had a lot more built-to-orders.
Thanks for the info.
Just curious.
I've followed this forum for quite some time. Have always appreciated your opinion. It seems a bit out of character for you to slam your fellow employee. Why not share your knowledge with him. I guess it just rubbed me the wrong way - and I'm sure others too - that you would publicly "dis" him like that. It gives the impression that the sales people at your business are sharks, and would eat their young to get that sale. Were you a big shot car dealer from the start, or were you a "rookie" once? Just a thought.
also referencing #541. I have that particular seat for my son, and it is a good seat. I currently have it in a 96 Blazer I have but will be transferring it to the Seq. once I get one.
NL
