Hunting
Fishing
Doing anything in it with my Father (he is a slob)
Using it for business travel
She now claims that if the decision were hers, she would have rather have purchased a Land Cruiser/LX-470 (too small/can’t afford) or a Range Rover (scared of its reliability and can’t afford). I don’t really believe this as she was the first to notice the Sequoia and has stopped countless moms in shopping center parking lots to get their take on their Sequoias (all have raved about them) over the past couple of years.
It has become apparent to me that I will be keeping the old F250 4x4 for all of my recreational purposes until the newness of the Sequoia wears off.
BTW: My wife has also begun to worry that with the slew of new technology that the competitors are pouring into their SUVs, the Sequoia will be due for an overhaul within a year or so, and she will be forced to wish she had a new one. She really wanted the factory Navigation system and the flat folding rear seats. Based on my read of this site and Toyota in general, I am not expecting a design overhaul before mid-year ’05. Even then, it will probably not be terribly drastic. Even if we knew this for certain, I doubt she would have wanted to wait the extra year and a half to pay the premium for this new design.
If you wish to do something like this on a regular basis, you can simply hook a toggle switch between either wire going to the connector. When driving down the road simply hit the switch and it'll disable traction control, and then restart your engine when you wish to re-enable it.
Can you lock the center diff on a newer than '01 Sequoia without putting it into 4WD Low and in 1st gear? I know you can't do it on a '01 unless you are in 4WD Low with the tranny in first gear. At that point you won't be going 45mph.
Maybe you're confusing TRACS with VSC. Locking the center diff will disable TRACS not VSC. I believe what you experienced was VSC kicking in because it sensed your rearend jumping around after hitting the bump. That caused it to dethrottle.
What's cliffy's take on this situation?
Sounds like any more off is unobtainable unless I am doing this the wrong way....... can anyone confirm...............
"The other part of this system is the VSC or vehicle skid control. VSC will selectively apply brakes and throttle to prevent understeer or oversteer. It works in both 2 and 4 wheel drive. This is a rather amazing system and does an incredible job of giving the driver control of the vehicle. Understeer is responsible for a large number of SUV rollovers and oversteer is very common on icy surfaces. The Sequoia will allow you to turn off the VSC but only when you are in 4WD. The only reason to turn this off is if you are off road and want to be able to slide sideways. On the Runner and Land Cruiser, the VSC and TRACS are disabled when you lock the center differential."
You can find the rest of this post on the Toyota 4WE Systems Explained board. Go to the beginning.
The scenerio you describe should only occur if someone persists on mashing the footfeed down after the vehicle has clearly lost traction. In the absence of a human doing it cruise certainly would.
Some car will automatically disable cruise the instant VSC or Trac "trips" but I don't know about the Sequoia.
Open center differential with brake modulation for torque apportioning as needed. Torque delivered evenly to all for 4 wheels when equal traction is available.
I honestly don't know what to make of your situation.
Also, Edmunds.com suggests changing diff fluid every 5k, but Toyota manual has it being done at 30k. Is the diff fluid part of the 4WD system? I only use 4WD sparingly. Any comments?
Thanks to all the Sequoia owners on this board, I've learned alot.
I love my Sequoia.
Rich
Dealers buy oil in bulk and put the same stuff in every rig; I don't think any of them particularly care what the factory manual recommends so long as they can take the cheap way out :-)
Heaven help you if you d-i-y with the recommended grade and have an engine problem though; the dealers will scream that you didn't follow the oil change intervals recommended by the manual and deny warranty coverage.
So lesson learned, Always read the owners manual!!! (and not at 1 AM like I did when I first bought the truck).
So Cliffy you are correct it probably was the A-Trac and not VSC (I wasn't sure which one caused the issue since I thought only 2 wheels were on the bumps and maybe it sensed the slight wheel turn and one side with less traction).
wwest- definitely no cruise on, crazy not insane!
So the question is Can the TRAC system be turned off? The 2WD models have a TRAC OFF button but it automatically re-engages over 19 mph anyway. The 4WD models don't have this option though locking the center diff does turn off the VSC as it says in manual.
I just am not happy with the traction control. I want full throttle when I want it!!! My cousin wrecked her ML320 and Land Rover Discovery in her driveway due to the traction control on both. (granted most people don't have a driveway 1.5 miles long with turns and and hills up to 45 degree angles, they live on top of a mountain in the Berkshires) From what she described the power just kept cutting on both until the wheels just stopped turning. Only thing the dealers and everybody could come up with was that the "extreme" conditions combined seriously confused the computers on both. She's now driving an older Toyota pick-up. They had too many reliability issues with the chevys and fords the business owned and refuse to buy any more (granted the older/regular 4WD worked great but they had other mechanical/electrical issues a lot)
My 00 GS300 would apply the brakes but give me a few hundred milliseconds to react and get off the gas before dethrottling.
The GS Trac being a great improvement IMMHO.
It seems strange that Toyota would go back to the earlier system. Is your Sequoia e-throttle and the ecu "thought" you were still applying throttle?
Were I you I would take it to the dealer and have them check it out.
With no pumpmotor to replenished brake fluid pressure none of this, VSC, Trac, will work and you're stuck. I would also suspect that once the pumpmotor goes offline the engine may become dethrottled more quickly in a wheel slippage situation, and may remain there until the next restart.
no separate optional traction control system on ours ..Chevy-GM calls it Stabilitrack.. not needed.. also the Autoride.. not needed.. both are good ways to add $750 + $1120 to gain nada.. ... not too much ice/snow down this way along the coast anyway.. I'll kick it in AWD if it's rainy ... both have 'posi' rears.. oops.. I'm dating myself..now called 'locking rear differential'..
Stabil trac... not needed... ok I would have agreed with you until I lived with such a system i.e. Toyota VSC. It is very very cool. Dry pavement, squirt around corners in town, full throttle... no problem just MOVES! Gravel road, wet road, snowy, icy, no problem... just feels like driving on dry roads. Amazing. Should be required on all vehicles... I think it is at least as important as anti-lock brakes and is essential safety equipment for all drivers esp. less experienced or savvy ones.
In my opinion, four wheel drive systems are the most mis understood part of the automotive world. There are only a very few companies who will spend the extra money and put a true, full time, mechanical center differential four wheel drive system in their vehicles. Toyota, Mercedes and Rover, for example.
A full time system is infinitely easier to use than a part time system. For the Sequoia pilot, there is really only one simple choice; do I want to use 2 or 4 wheel drive? Set and forget. On a Suburban (and other part time systems) for example, there are many more buttons to push and choices to make. Auto 4WD, 2WD, 4WD 4LOW. Indiscriminately pushing these buttons without knowing when how and why can result, best case, expensive drive train damage, or worst case, an accident.
Take a chance, take your wife and check out a Sequoia, you might be surprised. Be sure to engage 4WD.
Signed... a happy, 2.5 year long Sequoia owner.
Once the system detects the driven wheels slipping it will begin to apply the brakes, lightly somewhat. Then if you do not release the throttle it will begin to dethrottle the engine.
Supposedly the latter to prevent over-heating of the brakes.
On my 92 LS I learned that the longer I stayed on the gas in order to get the car up and going the longer it would take to recover once I got off the gas.
As I said earlier the 00 GS300 seemed to give me a few hundred milliseconds to react and get off the gas myself before beginning the dethrottling procedure.
I don't drive my so-called giant truck screeching tires and going around turns full throttle.. never have never will.. it's a truck not one of my previously owned sports cars like my '69 Vette, '75 280Z..83 RX7..or even my old '65 Goat.. been there.. done that... a truck is a truck.. ain't for jackrabbit starts or burning rubber.. for me anyway.. what they could do for the majority of the larger SUV's is develop better brakes that will actually stop the truck..
I used to live on Long Island.. 4wd hi is the way to go driving in the snow.. never heard of anyone having trouble with theirs.. drive mine on the beach at Hatteras in 4wd Hi all the time....no snow down this way along the coast near Myrtle it's the recommended way to go for the beach..
sounds like you really like your Sequoia.. I'm sure after having owned a number of Toyotas and Infinitis in the past they are a lot better quality-wise than the Chevys.. I can almost bet on that...
the last time we were at the Point at Hatteras on the beach, a brand new Sequoia was buried up to it's floorboards...stuck dead.. we all gave him the tip of the week..he kept on saying he had 4wd
(AWD).. we told him, 'yeah, air-down'..
It seems to me that one could easily get into a situation that requires almost continuous torque apportioning and/or virtual LSD(Trac??) via the brakes and I have little doubt that the brakes would quickly overheat and probably warp the rotors.
To be sure of what I'm saying I am referring to FULL-TIME AWD mode, not the part-time 4WD mode.
AND.
In part-time mode there is no non-driven wheels for Trac "reference" so it is very unlikely Trac would ever activate in that mode.
And no, I'm not 100% sure the throttle kill doesn't operate in 4WD. I am 99.9% sure and have actually tested it on icy roads, but perhaps there is more going on than I am aware of.
Perhaps the term "feathering" the gas pedal is a more appropriate way to describe a good method for controlling the throttle kill.
I can't think of any reason for a delay in going in and out of the AWD/4WD drive modes except entering or leaving 4WD part-time mode as described above.
The way most vehicles lock the center diff'l is with the use of a "dog-clutch", a splined shaft engaging with a matching sleeve. If you're trying to engage 4WD the splines must line up and then slip into engagement. That generally requires them to be rotating slowly and at approximately equal speeds. Larger, or more worn tires on one end vs the other will almost always interfere with the "match" and delay the dis/engagement.
To disengage 4WD the dog-clutch must not be under stess, no engine drive nor lagging torque factor.
In AWD (full-time 4WD) "H" or "L4" the center diff'l is NOT LOCKED and the brakes are used to apportion torque equally as/if required. My guess would be that it is in this mode that the Trac system would be most likely to dethrottle the engine if the operator is into "lively" gas application and the brakes have been in continuous use for torque apportionment. Whipping around in a snow and ice covered empty parking lot for instance.
There could, of course, be some sort of mechanical delay in engaging AWD from 2WD or vice versa. There are some CAUTION notes in the manual regarding this.
The Toyota Sequoia has an AWD system using an open diff'l and using individual wheel(s) braking to apportion engine torque. Brake apportioned toque basically operates the same way as Trac on your FWD Prius.
On the Sequoia when a wheel spins the brakes are applied, lightly, to that wheel to force torque to the wheel(s) with traction. If no wheels has enough traction to move forward and the driver attempts to spin the wheels to get unstuck the engine will be quickly dethrottled.
On the Sequoia if the above condition exists for more than 45 seconds the ABS pump/motor is automatically disabled so the driver will not persist and thereby damage the brakes, rotors, or even the driveline, worse case.
But then the Sequoia, unlike your Prius, has a backup 4WD system wherein the center diff'l is locked and Trac is disabled.
And please remember that snowchains on a FWD vehicle can quickly become extremely hazardous.
My answer would be to leave the Prius, or any FWD vehicle, at home in a nice safe garage if the roads outside are slippery.
Just relax and enjoy technology. Cars are a lot more interesting now than they were 15 years ago.
Just curious, what did you do with all that food you had left over from Y2K ?
2HD.
There are some things going a step beyond, but in general all of these things are going to a great improvement in our lives.
