Don aka Loboy --- I averaged about 20 mpg on the trip back to California. Unfortunately, now that I'm a 50/50 mix I'm getting about 17. Of course it's a bit confusing because I always forget to convert the km to miles!
About the K&N filter, check out their web site: www.knfilters.com and do a dealer search. I just tried it for my zip and several dealers came up close to me. I may consider changing the stock filter with one after my next oil change.
i think the rule of thumb is that there is a 25% loss of power through the drivetrain. there is a dyno printout of an Xterra on the web somewhere that followed this rule pretty closely.
It seems like that I fell off the face of the earth, but I'm still here. I've been buried at work--- you got to love those end of the year pushes to boost the final revenue numbers. Oh well, the holidays are close by and I will look forward to taking the PF to Santa Barbara for the holidays. The weather predictions call for 70-72, so I will really get to enjoy the sunroof!
Hope the holidays are great for you --- Jerry
Thank you for any info.
Mark.
I picked up the filter at a local Pep Boys. The parts counter said they couldn't get them for the new engine, so I went over, checked the boxes, and there it was.
Pathfinder V6/3.5L K&N Air Filter 33-2031-2
It was $44.95.
Brian60-Yup, sorry I misread it and was mistaken. Here is what it says:
"The amount of performance gain varies from vehicle to vehicle. A small displacement four cylinder engine may only realize a two or three horsepower gain while it isn't uncommon for a 350 cubic inch V-8 to gain 10 horsepower or more."
So maybe 5?
FYI-Premium gas here in Denver is running from $1.52-$1.78/gallon depending on what part of town you're in.
I know some of you have replaced the fog light and worry about making scratches on the black rubber parts. I am wondering have any of you try to get the black pieces out by pushing the back parts of the black pieces out if your hands are small enough to go around the bumper's holes.
LE 4x4
Heated Seats
Tow Bar
Power Sunroof Bose Stereo with CD and Power antenna
Overhead compass/outside temp display
auto climate control
dual power seats
It is white with grey leather
26K miles
Sticker in 1999 was just over $34k I paid $28,600
The dealer initially offered $18500 for trade and went up tp $19,500 now they wont budge. They say this is a heck of a deal and the trade offer is very generous.
Any advice or input would be greatly appreciated. I dont know if I ab being taken for a ride. Are KBB, Edmunds, and NADA values over inflated??
own3nissans: Have fun on your trip!
http://www.gadgetonline.com
So, if anyone has any opinions for me, please send them my way.
Thanks a bunch,
Travis
pyrenus@hotmail.com
I've probably read the same article you refer to. The guy said the K&N destroyed his vehicle in 80,000 miles. I have a '93 Altima with over 120,000 miles. At least 75,000 of those miles have been with a K&N filter in the airbox and that car still runs better than my '98 Accord with 23,000 miles (funny, my '99.5 Pathy has 23,000 miles, too!).
thanks,
nismo
I have never tried the Amsoil but it is similar to the HKS foam filter (in description) and I have heard very bad things about those (foam being injested into the engine)!
YMMV
Cheers!
It was 9 weeks ago that I sent in my refund forms.
rated the K&N filter the worst in filter life and the worst in dirt removal even compared to
a low quality paper filter. I have amsoil filters in my other 2 Nissns and have had no trouble.
You might he to replace them in 10 or 15 years. Should use amsoil filter oil,use very little
some may weep on the filter housing. Amsoil filters are the best.
Mine has Dunlop. I run 36 psi in the front and 32 in the rear. The shocks
could be alittle stiff to control the sway. The ride seems fine.
Glad to hear you got the Canadian ST refund. I also had waited nine weeks. For those of you going to Canada to save the money on buying - you will get your tax back, it just takes a while.
Have a great holiday everyone.
-on
-Jon
babble: no whistling wind noise on my 01 LE but I do notice excessive road noise through the rear wheel well on the freeway. More pronounced on the passenger side and especially when raining. Anyone else have a similar situation?
(the second part of the message is of particular interest). This seems more credible than Amsoil's test (SAEJ726C), which is the only widely cited evidence for the supposedly ineffective filtration abilities of K&Ns. The evidence for the contrary can be found on K&N's website (www.knfilters.com) and in various anecdotal testimonies from automotive enthusiastts.
One of the main contentions of the anti-K&N crowd seems to be that the K&N allows greater air flow due to larger pores in the filter and thereby allows larger particles to pass by unfiltered, ultimately causing increased engine wear. While this may be true, from a fluid mechanics point of view, it would also be possible to increase air flow by changing the geometry, material, placement, etc. of the filter itself - which is what K&N claims to have done.
Questions to be answered:
1. What are the specifics of SAE J726C? (does anyone have a copy?)
2. Are Amsoil's results verifiable and conclusive?
3. If K&Ns do in fact offer less filtration capability than competitors - is there a noticeable increase in engine wear?
4. If K&Ns kill engines prematurely, how is it that they continue to run a successful business and command legions of supporters within the ranks of automotive enthusiasts?
Happy holidays.
P.S. Copy your message (highlight text, hit CTRL-C) before you post if you have a feeling the new software is gonna eat it.
I can't say how accurate it is. Steve
Anyway, When I took my PF over to have the tires rotated, the local tire guy stated "firestone strongly recommends 35 psi for these tires". This was in the wake of the Firestone Wilderness recall. The ride was better at 26 psi, but I have decided to stick with 35psi.
-Hope this helps
I'll be purchasing my PF here in about 2 weeks out of state (in Maryland). I'm an Illinois resident but I'll be living in Mississippi. I want to register/title the PF in Illinois and I have questions about the tax laws.
I know the sales tax rate is 6.25%, but I also have seen mention of a USE TAX of $1,500 for vehicles over $30,000 value. I can't seem to find any references for this anywhere on the net (including the Illinois DMV web site), and silly me..I just started doing research on how much sales tax, etc. that I'll be needing to pay after my purchase.
Does anyone know if I'll have to pay both the sales tax and USE tax in Illinois? I'm hoping that the USE tax doesn't apply and that I am way out to lunch, so can anyone confirm or deny this for me?
Also: When purchasing out of state, I assume I would not pay any taxes to Maryland and that the dealer should supply me with suffecient paperwork to show the Illinois DMV.
Can't wait to buy my 01' LE...less than 2 weeks to go now (hopefully!)
Happy Holidays to everyone!
Appreciate any and all help!
I'm pretty sure that this offer is regional (Northeast, I'm in NY) and unfortunately doesn't show up on Edmund's site. Edmund's site, along with other car rebate info sites, is flawed and never really fully up to date.
Happy shopping!
TC
But I can say that you got taken to the cleaners.... undercoating, rust proofing and paint sealant are the 3 biggest dealer scams today. Almost all car manufacturers' present production techniques eliminate the need for these after-market items.
The Pathfinder is a quality product that doesn't need these gimmicks. Sorry to hear that you paid for them.
TC
