Visitor Agreement.
from MOPAR, either installed by yourself or a Jeep dealer?
I try to stay away from the dealer in most cases because of high prices but some things have to be purchased there.
Mrq3883, I don't know much about heaters but I know that my heat is evident as soon as I have engine temperature. Maybe its a heater core thing?
you might want to check thermostat or heater core for plug
The on-highway ride is much better. Large potholes and pavement irregularities are less harsh than with the stock shocks. If you off-road often, then there are better options, but the Bilsteins are fine for trail riding.
On the lighter note, what a honor it is for me to own this truck. It has been everything I thought it would be. It's classic body style is still one of the toughest and sexiest looking compared to its competetors. I finally took it for a road trip recently and it was a great ride. It handles the road great and I felt very safe in it. Haven't taken it off roading, but I plan on it and I know that this truck will be capable of letting me expierience it's true performance.
My only gripe on the truck is the gas milage. WOW!!!it's loves the stuff!! Any sugesstions on keeping better fuel economy? And also give me some pointers on what I need to do to keep my truck running a long time.
thanks everyone
She has just 10,000 miles (it's a 2001) and the only problem I have had is the element of the driver's side heated seat broke. I am now waiting for a replacement since December 16th and no sign of it yet! 7 weeks. Otherwise I personally have had good luck with it.
Wow, it sure has been "busy" while I haven't been posting here. Well, just to let you guys know, I still love the Cherokee, but sometimes, I don't know what comes upon me. It's just hard to find one near me, for sale, anywhere. I guess people seem to be quite happy with the one they already have, so they don't sell them. Nothing is going to change by the summer anyway, so I may end up buying something else. But just know, that I will always love a Jeep.
Which leads me to this question: The Cherokee is a unibody design, right? Now, is that a complete unibody, or is there a frame, welded, instead of bolted, to the shell of the Jeep? Please explain...
The following list shows what parts have been replaced:
-Lever and pin assembly
-Torque shaft
-4x4 bushings
-Center exhaust isolator
All this was done under warranty.
The people at this dealership are very nice-Bannerman in Toronto.
I have sent an e-mail describing the problem a couple of days before.
Two people called, the service manager and a service advisor (he owns a '98 Cherokee Classic).
The service advisor mentioned recent similar issues with two other Cherokees, so I guess all this work was done based on that experience.
I noticed on the work order that after replacing all these parts a road test followed.
The noise was still there.
What seemed to fix the problem was:
"Found tailpipe hanger pulling to one side. Adjusted to straight down position.
Noise not present"
Now it just purrs like a big cat.
What's so dreaded about the 60K? I spent about $400 which included them unsuccessfully diagnosing an intermittant check engine light, tranny flush, transaxle fluid, diff fluids, brake inspection, spark plugs, and oil/filter. You want dreaded, take in an Lexus RX300 and tell them to do the 60k service. But you get a crappy ES300 to drive around while they service it, whoopee.
Thanks for the tip on the transmission service. I'll try to find a shop that will suck it all out.
Most of the fluid services take very little time. I've changed the plugs once on my own and it barely took 1/2 hour. One thing I've found they beat you up on is airfilter. They did mine during a LOF change and charged me $17. It's a $4 part at autozone and takes all of five minutes.
The other thing is I don't think the book calls for anything different at 60K than the 30K service. You might want to look at it but I think it's an identical service. I know that's all I had them do. I'm not exactly a maitenance freak but I do what needs done. I've got several 150K miles cars under my belt. IMHO a lot of what shops sell is bunk.
I have finally settled on a '96 Jeep XJ (Cherokee) Sport 4x4. I would like power options, but I could go without them (But hey, if you're going without power options, may as well get an SE). 4.0L High Output, color doesn't matter, as long as it isn't red. Automatic Transmission, and Air Conditioning. Now, as for the ABS, um, well, I drove a car with it, and I didn't see much benefit of the costly option. I would like a low mileage Jeep, but I know I'll probably never find one. Around 120,000 miles is fine for me. The 4.0L and the AW4 (Automatic Transmission) seem to run forever.
I think that the '96s have enough improvements, and seem to be the most reliable. Good year, I guess. I'm still a bit worried about those falling doors, but maybe I can get a dealer to fix them. Was there ever a recall for those doors? It seems to only affect the 2-Door, but I "think" I heard someone with a 4-Door have the same problem.
Now, I think I have caught the offroading bug. These people at the other Jeep forums have gotten me knowing a Jeep like the back of my hand.
Why not a '97 you ask? Well, '97s tend to have the higher resale value, and I'm not looking to spend much money (I have to pay for insurance).
This will be my main and only vehicle, and hopefully, it will get me through college without much trouble.
This seems a little early to change the fluids [especially at $125 plus] however, we have not had good luck with this vehicle over the last year and a half [at least 12 visits to the service department for a variety of issues] and I want to keep it in good shape.
Any advice?
Check your owners manual if you need further proof. It's a bit less biased than the guys selling the service.
I've got 65k miles on my '01 and had the diffs, tranny, and transaxle fluids changed at 30k and 60k miles. I would probably do a complete tranny flush at the first 30k miles service, but drain and fill is adequate after that IMHO. A tranny flush will run you $100 by itself.
Sorry about your bad luck. Mine needed an oil-pressure sending unit and front rotors at 20k miles. Otherwise no problems in 65k miles.
As far as reliability, I don't understand why we are having so many problems with our unit. I have been monitoring this forum for some time no one seems to be going to the shop like us. It's a shame when the guys at the desk no longer ask your name. My wife and I like the Cherokee and hope we can get the bugs worked out. It sure is nice to have with all the snow around here this winter. With the new Michelin tires I bought last October [the stock Goodyears lasted a little over 12,000 miles], the Jeep went anywhere in the worst conditions. It's been over a month with no problems and we are keeping our fingers crossed.
I also have a number of friends with Cherokees and all they swear by them. Oh well, perhaps we have one that was made on a Friday - does that old wives tale still apply?
Thanks for the input.
I used to own Toyotas and their dealers are even worse. "Toyota recommends a throttle-body cleaning every 15k miles, it's only $50". That's $1 worth of cleaner and something I can do at home in less than five minutes. Bunch of crooks. I put oil in the things, tranny fluid at 50k mile intervals, and drive them for 200k miles with no problems. I suppose if I wanted to keep the thing for a million miles over-servicing might help, but I get sick of a car after a few years.
I stopped into our local Jeep dealer to buy a set of front pads awhile back and I overheard a guy on a phone call to a customer. He was trying to convince the guy he needed a tranny flush (he might have needed it) but when he hung up he was bragging to the other part-guy that he sold a tranny flush to some guy that brought his car in for a warranty item. They must be on commission at that dealership, and I imagine many are.
I switched to Michelin LTX-A/T's around 20k miles. My factory goodyears still had well over 1/2 tread left but they were over-all junk IMHO. Wet/snow traction was bad after 10k miles, they were noisey, and refused to stay balanced. The Michelins have around 40k miles on them and look to be within about 75% of new.
By the way, I bought the Michelin M&S's and love them.
Yesterday we got a fresh layer of snow in Toronto.
In some spots just a little over 1 foot deep.
As I came home and tried to get from the street into the driveway, I found the driveway blocked by a bank of snow, I got stuck, so I had shifted into 4X4 full time.
After clearing the snow bank I shifted back into 2 wheel drive mode.
The driveway is about 40 to 50 feet in length, and after that I have to make a sharp turn to get to the underground parking.
However, when making the turns to get underground and into my parking spot, I have noticed that the font wheels turn and feel funny, like going over bricks or bumps in the road.
I have the Select Track system and I have to go through 4X4 part time before getting into two wheel drive mode.
My first thought was that I was still in 4x4 mode, and not in full time but part time (because the funny feel of the front wheels).
That got me thinking to a couple of posts seen here about tapping the acceleration twice to make sure the transmission gets back into 2 wheel drive mode.
I only have 50 feet at the most and then I have to turn, and once I go down the slope there is no way back but to keep going and turning.
My question is: how far you have to roll before the 4X4 mode will disengage?
The answer is: it depends. Going from part-time to 2wd typically you can hear the front hubs "click" when they connect/disconnect. Doesn't usually take more than 15' or so if you're changing throttle input (which helps it shift). Going from full-time all the way to 2wd though sometimes can take longer. Usually between full-time and part-time is where it hangs up. Usually I've found the best way to get it to connect/disconnect is by changing the throttle. Either giving it gas or letting off.
Best bet for these types of condtions is to be in full-time. It's essentially the same as running in 2wd until you have slippage. Eliminates the lag-time between switching systems and you don't have to think about it when you come upon dry concrete.
Part-time is better for severe conditions, but it's a lot easier to shift from full-time to part-time if necessary.
Basically the Select-trac is similar to most any 4X4 system in the front-end. The hubs are locked which in itself does not cause binding because the front diff is open. When in full-time mode, the center differential only kicks in when slippage occurs in the rear. There is no change in driving style with full-time engaged assuming you don't drive like a knucklehead. It's just like running in 2wd until the rear wheels spin. If you like to do burn-outs or "fish-tail" around turns, then you'd have to change your driving style:)
When in part-time mode, the center differntial is locked and sends power evenly to the front and rear. This will cause binding on dry surfaces which is why it's not to be used unless the roads are completely slippery. The full-time is great for typical light snow days when some areas are snowy, some are cleared roads, etc. No thinking required. Part-time is a little better when the roads are very slippery and there aren't any cleared roads in sight.
I have driven a Cherokee over a short distance and I confess that, in part-time 4WD mode, turning was a hair-raising experience. I didn't feel that in a Subaru. I was wondering if a selc-trac system is much better than the part-time 4WD in urban daily driving, especially in slush of the winter.
The answer would be yes. The part-time system can get "hairy" when turning, particularly if it's not real slippery. Sometimes slush isn't slippery enough and you can bind it up. Very bad for the internals when that happens.
The Subaru system and jeep full-time are similar in their basic functions. It's when you have the front and rear axles locked together (like the part-time system) that funky stuff happens.
The selec-trac is usually more than adquate for the average urban junkie. Having the part-time system available is just an added plus, although it seems to confuse a lot of folks as to which system they should be driving in.
both of them, only work about a maximum of 5 feet from the vehicle and sometimes not at all. Can the dealer fix this without to much hassle, I'm still under warranty.
