Visitor Agreement.
With the front driveshaft getting power, it is going to make more noise than when it is not getting any. How much I'm not sure. I find that mine makes more noise under power. If I'm just coasting or not on the pedal there is no sound. After a while I get used to it, because by feel of the road I know it's really working well. We had some snow a couple days ago and what a difference.
If it is a problem, the possibilities are front differential and gears, U-joints (which may have been lubed at 3000mi), front drive shaft, and of course the transfer case. I've heard of seals and bearings causing noise in the transfercase.
I too have that slight whine noise. I just hit 77K miles on my Jeep and plan to check everything and change all fluids. As I recently purchased this Jeep only weeks ago, I don't know for sure what maintentance has been done.
I've had a slight hesitation in startups, so I started with the ignition system by changing the plugs, wires, distributer cap and rotor. Seems to start and run much better now. There was normal wear on the plugs, cap and rotor. I also checked all engine fluids. They look fine.
http://www.off-road.com/jeep/cherokee/
Jeepin.com - a good site by Jason West
http://www.jeepin.com/
Go Jeep - a good Aussie site
http://www.gojeep.rockcrawler.com/Introduction.htm
Jeeps Unlimited
http://jeepsunlimited.com/xj/features.htm
I have more but I can't remember them off the top of my head.
I'm actually surprised mine have lasted this long considering I tow alot. I had a Sebring that went through pads/rotors every 10K miles and once I quit using Mopar or cheap autozone parts I had no problems. I've never had pad or rotor problems on my Toyotas, so I don't think it's really my driving as much as just cheaper parts. Not sure why one Cherokee has more problems than another though. I know another guy that put 50K miles on his and never had any rotor warpage.
One final note, there is plenty of information both online and in print on how to choose a good used car. Good Luck!
They have forums dealing with stock machines and highly-modified off-roaders, along with some product reviews.
Has anyone ever seen a 2001 Jeep Cherokee "FREEDOM" ? It was a Limited-Edition package for Californai ONLY I am told, It was in Bright Yellow, and allthough a SPORT, it wore the Limited's chrome grille and tailgate 'eyebrow' and 16" Limited wheels & tires - but had the Sport's cloth interior. Anyone ever see one? I read 500 were made & numbered???!!
Sandy
I obtained this info from Mother-Mopar - but they could NOT tell me how many Early Limiteds (May 29-July1) were made, except to say "around 2,500 units" .......
p.s. at 42,000 miles on our 2000 and still love it. Just put my first set of brake pads on, rotor looked good and a 'snap' to replace.
Rock Rails: $69
Gas Tank Skid Plate: $6
Trans Case Skid Plate: $35
Front Grille Guard with Lights: $129
Front Grille Guard w/o Lights: $89? (I don't remember, but it was cheap)
Running boards were real cheap, too.
etc.
I was looking at the 2001 parts for an XJ Sport 4dr 4x4 with a zip code from the Buffalo area. I don't know if other model years will work or not. I've heard of some dealerships honouring these prices and some claiming to not know what is going on. The prices on the reduced items are acutally the dealership cost for them so don't let them tell you something different.
BTW, if anyone is living in North Dakota or Minnesota and would like to perhaps arrange to purchase a Grill Guard with Lights that I could come and pick up, let me know. Unfortunately, the Canadian dealerships, at least the 7 in my area, have no idea about this clearance and don't care enough to match prices.
Re: warped rotors...
If you get a vibration through the brake pedal while braking, there's a good chance your rotors are warped.
Bob
RE: MPG I'm averaging between 18-22mpg as well. Depends on how I'm driving as I have a bit of a lead foot. Coming up on 30K miles and 1 year. Couple minor complaints, but I'd buy another one over anything else out there. Too bad I can't, thanks DC!
1) I have a 2000 Sport that just came back from the shop following its yearly inspection and check for engine light "on". The results were good...with the inspection I had the tires rotated, 4 wheel allignment, etc.... and I was initially informed that the engine light "may" have come on to indicate a vacuum leak. This happens sometimes after a GAS fill up with a gas cap "too tight".
Never heard of this before and wanted to pass this on.
They did find that my problem however came from a #5 cylinder not firing properly. Plug replaced and a computer reprogram to correct a rough idle and the Jeep is running much better.
2) This is my second Jeep and besides my wife feeling very safe since it has served her through several difficult weather situations, I too have found it to be a very enjoyable vehicle.
Anyone out there with gas mileage info though? I have found that around town it gets very low mileage(possible do in part to the # 5 cylinder,huh), but on the road it turns in 18-22 MPG depending on conditions and driver. It is an automatic. How does this compare?
Christmas trip produced 21.7mpg.
Very pleased so far with Jeep service and vehicles!
The 4.0 is a great engine for towing something small (up to 5000lbs). I'm considering picking up a little fishing boat soon and should have no problems towing it behind the jeep. If you only plan on towing and no off-road stuff you might want to not get one with the Up-Country Suspension package. This package has the rear sway bar removed which apparently helps with towing. However I've also heard many others who say it makes no difference. As soon as I put on a lift kit and get some beefier shocks, it's coming out.
My Jeep has the automatic transmission and I had the dealer add the towing package when I bought it. The towing package comes with an auxillary transmission cooler, the hitch and the wiring. If you're looking at a jeep, look through the front grill and if you see a small radiator in front of the larger radiator just above the bumper, that's the transmission cooler. Apparently it's a big help and will increase the life of the transmission. I think you can also buy them aftermarket.
I guess that I'm getting the right mileage for this vehicle. Nice to know. Feedback appreciated.
I am trying to change the front brakes on a 2001 Cherokee Sport and am having a bit of a problem. The piston won't retract far enough so that I can get the brake unit over the rotor. I have tried to "C" clamp. There is a little Bleed valve but turning it counter clockwise won't release it. I am afraid to put to much force for fear of breaking it. Any help or ideas?
I know there is an up-country option that uses different shocks and was wondering if anybody has them on there truck and if so do they like them.
Personally, I'm probably going to go with Doetsch Tech shocks once I get a slight lift. Eventually (ie once I have enough money) I'll go with a whole Old Man Emu suspension package. I've only heard excellent things about both. We have most major companies like Rancho, Munroe, Edlebrock, Doetsch Tech, etc but prices vary alot up here. Now if only I had that kind of selection on other aftermarket stuff...
Are you upgrading to performance rotors/pads?
The rotors are fine. We have 30K on the jeep and they are not worn. This is the first brake replacement. I am not intending to put performance pads or rotors on at this point.
Thanks in advance for any input. Much Appreciated!
S A N D Y
S A N D Y
I've got an '01 with 30K miles. I've gone through mud deeper than the wheels and snow being pushed by the bumper. It does a helluva job. I've had two problems: oil pressure sending unit (tells the oil pressure guage what's going on, no big deal) has been acting weird since about 15K. Going in for warranty replacement tomorrow. The rotors have acted like they are a bit warped, but here lately feel fine so maybe they fixed themselves, dunno. As peshleman1 said above, these are some of the last real 4X4's besides maybe the Wrangler. The 4.0L is much stonger than the high-reving low-torque motors everybody is going to. Try and pull a trailer with a 3.7L V6 in the Libery and you'll feel the difference.
S A N D Y
Was the build number/date on the inside of the door? If so, I want to check mine out because even though I picked it up in May '01 I think it may have been there for a while.
Best regards
The tranny cooler only comes with the tow package from the factory. Dealer cost was $310.00 which added class III hitch, wiring, 7-wire adapter, heavy-duty engine cooling, aux tranny cooler, synthetic differential fluid, and a full-size spare tire with matching alloy wheel. $100 less if you don't have the alloy wheel package. I was surprised that there weren't many available with the tow package as I'd want it regardless for only a couple hundred bucks. If you ever decided you wanted to tow something, you be hard pressed to get just a hitch installed for less.
