Waxes And Polishes
1121315171820
  • StillwaterStillwater Member Posts: 44
    A while back, we talked about going to car washes, especially in the wintertime to get salt off.
    Today's (5/9) NY Times's auto section had an article about them.
    The so-called "touch-free" car washes are noted as being less effective at removing grime because, obviously, no brushes contact the car. However, the article notes that SOME, in order to be more competitive, apply a "pre-soak" of hydroflouric acid, to remove road tar and the like.
    I CERTAINLY don't want that on my car!
    I haven't used Rain-X for several years, but I remember that, once applied, my wipers would often clatter across the windshield. As effective as the Rain-X was, I still needed to use the wipers (though less often).
  • spyderturbospyderturbo Member Posts: 31
    My friend says the Rain-X wax just came out (as far as he knows) and this is a completely different product from the windshield/window treatment. I may purchase some and check it out. I'll share my thoughts once I've tried some.
    -Spyderturbo
  • DarknessDarkness Member Posts: 24
    Pbveline, (sp)
    Are you talking about on the actual WINDOWS, or on the window moldings? The moldings is what I was speaking of... if you are speaking of the actual windows.. then the best way to solve ANY problems is with newspaper... it is extremely time consuling, and personally I've only done it once. I see no need to go THAT overboard, I mean I think a toothbrush on the tires is enough for me. :P
    -Herr Darkness
  • ruskiruski Member Posts: 1,566
    I would try Rain-X but I have no more cars available for the trial. They have all been Zaino-ed.
  • pblevinepblevine Member Posts: 858
    Yep, I tried Z6 on my windows, and guess what, it actually worked! The results were better than Windex or Glass Plus (which I also tried).
    #716
    I am glad it worked for you also. In practical terms, it is nice to have one product that really works and also to do more than one thing.
    It also goes to prove how optically clear it is. One can try putting carnuba based wax on the windshield, but it is more than obvious what will happen.
  • binubinu Member Posts: 81
    Everyone ,,
    I watched the Prolong Paint sealant infomercial for the 3rd time today on TV ..
    Looks like a great product( if an ad can be believed) ..
    The ad goes to the extent of spraying a can of paint on a car which was treated with Prolong paint sealant and then the demonstrator just wipes the paint off clean with a towel ..
    another scenario ...shows another guy spraying sand at a high pressure onto the paint and the paint is still undamaged ...
    I have seen this product in Target or somewhere but havent used it yet ... will probably wait till my pile of meguiar's run out ..
    has anyone else used this product ..?
  • buddhaseedbuddhaseed Member Posts: 26
    I'd like to learn how to remove the blotchy hard water stains caused by unwiped morning dew or rain drops. Most of them are left on the hood and can be felt by sliding your fingers across the hood. The dried water traces are so stubborn that repeated car washes just can't get rid of them. I have tried polishing, too, but with little help. Please suggest any name brand product that can magically remove them, or any effective procedure that will do the job. Thanks!
  • guitarzanguitarzan Member Posts: 873
    Try claying them off.
    How? I'm new to car care business and please kindly tell me which product to buy and how to apply it. I'd appreciate it very much!
  • joecarojoecaro Member Posts: 44
    If you are new to this it would probably worth your time to go back over these posts. Claying is discussed in great detail in several places, as well as much other advice.
    Clay may be a bit harsh, eh? I mean you'd be taking off chunks of wax with it, and then be forced to rewax. Seems a little too much to go through for morning dew.
    Buddaseed,
    I'd suggest getting a better wax on the car, (which woiuld require claying first, and then you can most likely wipe it off with Z-6 (for Zaino) or that Meguirs comes with a surface cleaner similar to Z-6 as well..
  • shomanshoman Member Posts: 97
    There was a post a little while back about protecting the car, and of course good inside storage is the best, but they also mentioned car covers whether inside or out.
    It is NOT a good idea to use a car cover, no matter how soft it says it is, or how water repellant, or how much it says water will go only one way through it. The reason is that no soft cover can stay perfectly still on a car in the wind. Also, no matter how soft, it's still going to wear throught the paint and in a LOT less time than you might think. I know cars that have been ruined in just a couple months time.
    NEVER use a car cover outside. I don't even like to use them overnight at car shows when it's calm. If the car is that important and fragile, then buy an enclosed car hauler. Otherwise, vandals can get through any cover and they usually just draw attention to YOUR car, and again, they will all hold moisture and deteriorate your paint.
    Don M.
    Just in case someone might mis-read my above post, the comments are about using any cover outside. Covers in good inside storage (where wind doesn't blow through) are OK, but you have to keep them clean. Otherwise, dust can and will work it's way through the fabric and get to your paint as you take the covers on and off. For inside storage, I find old bed sheets work really well, are easy to wash, free, and while they take a bit more work, they protect from light dust just fine.
    Don M
    Thanks so much for your inputs. It seems clay should be the last resort. Now I am wondering how to prevent the clearcoat from hard water stains after claying. I polished and waxed my car every month but it seemed no way to stop such stains.
    #724
    Used to be indecisive , but now you are not so sure.
    Give a try to Zaino polish. So far I have been able to wash off water stains from my Zaino-ed surfaces.
  • tomcat1tomcat1 Member Posts: 8
    I just received 2 sheepskin wash mitts from Autotoys.com, but there were no care instructions.
    Do any of you know the best way to clean and care for them? Specifically, can they be washed in a washing machine? Thanks in advance for any advice.
    Tomcat
    Shoman,
    I have used my car cover for about four months or so now, and I have had no problems with it scratching the surface. I did fork out $150 for it, and the moisture seems to be correct, I do take it off and let it breath on nice days and when it IS on, I bunjee cord it to the underside of the car (Making sure the hooks do not touch the exterior, nor under any circumstances would they). No scratches, the car has stayed cleaner and brighter than ever for a certainly noticeable longer period of time. I looked around when shopping for them, and this seems to be the best there is.. and was worth forking the $ over for. Not to argue the point, but I just wanted the other side shown.
    -Herr Darkness
  • mdbaker1mdbaker1 Member Posts: 17
    Has anyone ever used Finish First Polish? I found it while surfing the Web recently (www.finishfirstpolish.com) on this message board (http://client.ibboards.com/cgi-bin/hondaacura/Ultimate.cgi). They appear to be mail-order only.
    It's a cool message board if you have a Honda/Acura even though it's a blatant advertisement for the polish. However, I have to hand it to them, customer testimonials are the best advertisements. Check it out...
    M
  • drscopemdrscopem Member Posts: 83
    Hi:
    I have used Finish First. It is a polymer sealant product similar to Klasse and Zaino. The prep cleaner does a good job of removing wax, etc. prior to applying the sealant.
    I found the end result to be slightly less glossy after 2 coats vs. Klasse or Zaino. It is definitely easy to apply and remove. I have nothing negative to say about it. It is less expensive than Zaino. The car wash is excellent and seems equal to Zaino but again less expensive.
    The May issue of Corvette Fever ranked Finish First and Zaino as their recommended paint finish products.
    Good stuff but doesn't smell as good as Zaino!
    Thanks for the recommendation. I found my hard water stains have left holes on the clearcoat surface (could be seen by running some water over it) and I believe after claying I must fill in some liquid to make the clearcoat surface even again.
    Do you recommend any product that is made of the same materials that the clearcoat is made of? Or simply straight, where can I buy the clearcoat liquid to fill up the holes? It is strange that nobody has ever talked about such liquid in this board though I think it is essential. Is it never available, requiring professional skills to apply, or is there any better replacement (like polymer sealants, etc.) that people think better to use?
    My focus on #734 was, how do people usually make smooth the uneven clearcoat surface that is full of poked holes, especially after applying the clay? Thanks for any advice..
    Hey all, check out #208 in the maintenance section. I'm really surprised there has been no response. With all of the polish and wax fanatics out there, I thought there would be some truly amazing stories told.... Please sound off!
    -Spyderturbo
    buddhaseed,
    Have you tried using Z5 to polish out those water marks?
  • wc3georgewc3george Member Posts: 23
    I got my free sample of Meguiars Endurance (tire care).
    I was less than impressed: it's a gel that is mixed with some sort of pink liquid. Maybe the two didn't combine properly because of the small sample bottle. It left a nice shine at first, but it has gotten streaky over the past few days.
    Anyone else had any experience with this?
    pblevine:
    No, but I tried Car Kit Scratch Out, recommended by a Kragen staff. These products do not harm clearcoat, nor fill in the etched areas of clearcoat. It is non-abrasive so its scratch removing function is not obvious, either. Anyone please help #734 and #735?
    wc3george:
    How long does Endurance last? I've tried No Touch and it lasted just for a week or so. No Touch looks like a spray gel which does not require rinsing. Just spray on and it will dry and shine.
    I got two samples: one was light pink cream, the other contained liguid and clear gel.
    I used the first package on my Grand Prix, the second (just the gel because liquid just poored out) on my 300M. So far they both look good. It has been a week.
    I also just received the Endurance sample... It is my understanding that one should not use silicone based compounds on tires (leads to drying and cracking); anyone know if Endurance does or does not fall into the Armor All pitfall?
    Hi:
    I learned a lot about tires from Larry Reynolds at carcareonline.com. Two things destroy tires - UV light and ozone. Rubber is clear/translucent. Tires are black because they contain carbon black which absorbs the UV and converts it to heat. With time it becomes white to gray. Ozone will eat up the rubber so even if the tire is locked away in the garage it will decay, i.e. dry rot. To fight the ozone, wax is added to the tires and as you drive the wax gets oozed out to fight the ozone. Tires that aren't driven eventually have all of the wax broken down by ozone and rot. Silicone dissolves the wax and so allows dry rot.
    I clean my tires with Westley's Bleche-White from the Auto Zone. I then use one of the white liquids like Zaino for tires, Black Again, etc. This makes the tires really black. I then use Tire Treat. This is clear rubber in a can which fills in the cracks in the tire and coats it with rubber. It allows the tires to stay black longer. It is made by W.M. Barr & Co. in Memphis, TN. I got mine from the Herrington catalog at 2 cans for $15.00 plus shipping. One coating is supposed to last up to 30 car washes. I did my tires in January and they still look good.
  • josephkjosephk Member Posts: 7
    I have seen a several posting inquiring about the quality of Prolong products advertized on TV. I don't remember seeing too many responses. Could someone who have tried using it or have seen cars with it tell us how the product is? I am a devout Zaino fan, and don't expect Prolong to provide the shine and the glitter that Zaino gives a car or a truck, but the supposed protective ability of this unique product intrigues me.
    I would greatly appreciate some responses.
    I just put on the Endurance last weekend; it's lasted this long :)
    I'll be interested to see how long it lasts. I've used another gel -- something like Tire Wet -- that worked okay, but the applicator was junk. Very hard to get the stuff out of the bottle and on the tire.
  • cindy288cindy288 Member Posts: 13
    Has anyone ever used RACE GLAZE? How is it?
    Thanks for keeping us posted. Let's see if it is as good as it advertised.. "lasts months, not days or weeks!" :-)
    Oops, it's "lasts weeks.." as I checked the store shelf yesterday..
  • KThomp100KThomp100 Member Posts: 62
    Hello...
    Am deciding on a color for my new Lexus and am being told that on their black cars they do not put a clear coat over it. Can you please explain the advantages and disadvantages if any for this. Also, what are the best products in your opinion for black cars for waxing/polishing. This would be my 3rd black car (it's been about 6 yrs tho since I owned one) and I think the others had a clear coat on them.
    Any and all replies ASAP would be appreciated.
    Why doesn't ANYONE respond to any posts relating to Prolong? Has no one used it? My post number is 743, and there were many other inquries about the product earlier. If you know anything about it, please us know. Thank you!
    Just checked out a brand new black Lexus that had been detailed by their prep staff. Already there were light scratches all over the car. None of these could be seen unless you got real close to the car but this one was parked right under a bright floodlight so it was easy to check out. With the proper "after prep" by the new owner, are these surface scratches able to be removed?> I wonder if the dealers will just remove the plastic on the cars and let the new owner prep the exterior.
  • orange606orange606 Member Posts: 32
    I have been using Zaino since January, and I thought I would post an update on how it's worked out. I applied Zaino to three cars. Two of them, a 10-year car, and a 1-year car were clayed first. The other only a few months old was not clayed. The shine was better than Meguiar's, and a single coat lasts much longer than Meguiar's. I would say you could go two months between polishing, if you push it. Meguires lasted a month at best. However, just this week I found my self claying two of the cars. The 1 year old car, and the newest one. I know the newest one had debris on the paint because of over-spray from painting a gate. The Zaino polish preserved the surface, and after a claying it was in better than new condition. The other car just had a ruff surface. The oldest car, strangely enough, did not need to be clayed. Most likely the build up on the other cars was related to were they traveled over the past months. The Zaino products did an excellent job of keeping the contaminants from bonding with the surface. The following is a list of pro, and con qualities of the Zaino products.
    Pros
    Z-1
    Easy to apply
    Is not removed
    Z-2
    Easy to remove
    Long lasting
    Good smell
    Z-16
    Long lasting
    Z-6
    Easy to use
    Good smell
    Z-7
    Cleans well
    Smells good
    Cons
    Z-1
    Not to great of a smell.
    It's very hard to tell how much to use when applying to a white care.
    Z-2
    Easy to use too much on a white car leaving streaks which are very hard to remove.
    Z-6
    Cheap spayer.
    Z-7
    none
    Z-16
    Not easy to apply.
    Doesn't leave a good finish.
    There are few general negative aspects of the Zainos products. Their botles are not great. They crack very easily. Some of the labels are made with an inkjet printer. This means the ink will bleed if the label gets wet.
  • dsomersdsomers Member Posts: 20
    You're in the wrong place. This forum is for Zaino only and is quite inappropriately named "Waxes and Polishes". It is acutally sort of an all Zaino all the time kind of thing. It's a Zaino user's self-congratulatory, mutual admiration society. In here Zaino user's compare the quality of their shine per number of coats against others! You will find occasional references to clay or other non-wax products, but if you are not a believer and you intend to get any type of non-biased information about products other than Zaino, you really need to try the anti-Zaino group.
    Hi:
    You can tell it's summer because the TV is full of auto appearance products.
    I have NOT used Prolong. I did see the TV infomercial and read the information on the box at WalMart. It appears to be yet another polymer sealant. Their applicator looks like one from One Grand. Their warranty only covers the "shine", not peeling or chipping. You must apply it at least yearly and save your receipts. They do not say how you get the "shine" back if their product isn't effective. The box says you must remove oxidation before application but doesn't tell you how (i.e., 3M Imperial Hand Glaze, etc.). It contains AFMT which is also in their oil products.
    The infomercial shows mineral spirits, etc. unable to remove it but this is true for all sealants as they bond to the paint. The sand blasting segment is interesting in that they did not treat only part of the hood and then show the difference between treated and untreated. Besides if this is true then why does the warranty exclude chipped paint. They say "It looks good" not "It's not damaged".
    My guess is at $20.00 for 10 ounces it is equal to what's out there, not a true "Summer Wonder". Does anyone remember other "ultimate" products to replace all others such as Touchless or Autofom with Fomblin A from Blue Coral?
  • swiftmswiftm Member Posts: 68
    josephk: Try room #89
  • alvinalvin Member Posts: 8
    I have a 99 Jeep Grand Cherokee, Platinum Metallic, took delivery 3 weeks ago. I don't wash myself because I always get the white water spots so I take it to a "hand wash" car wash that uses distilled water for the final rinse. I don't have time to clay (anyways I don't know how and don't want to learn). I'm thinking of applying Zaino Z1 and Z2 after the hand wash without clay and without Dawn. Would I still get the great wet look I've been reading about here?
    #755
    Absolutely.
    #755,
    Only if you drive off road at least one day per month. But it won't be as good as it could be. The claying step is there for a reason. You SUV already has junk, dust, etc. all over it. Claying is very easy and it pays great dividends and is highly recommended prior to applying Zaino.
  • kewldudekewldude Member Posts: 20
    Swiftm.... I hope that was sarcasm about this being a "all Zaino all the time" group. I have to say that it was pretty funny...
  • joefridayjoefriday Member Posts: 17
    I know there's a separate topic on leather care, but this is a question specifically for the Zaino experts.
    I'm going to be doing the leather seats in my car with Z-9 leather cleaner and Z-10 leather conditioner. The Zaino literature says that Z-9 and Z-10 are also good for vinyl. Do they really do a good job on vinyl? I'd like to use them on my dashboard, too.
    joefriday,
    I tried the Z-9 cleaner on my vinyl. It did no harm but was not magic. The Z-9 did a good job on my dash's vinyl. But it was not as effective on that patch of vinyl at the lower foot of my doors where I normally step while getting into the car. The dirt and scuff marks on that vinyl were really embedded and I guess I'll have find an additional product.
