Visitor Agreement.
I believe that this problem is caused by
(1) Driving frequent short distances
(2) Driving under extremely cold or high temperatures
(3) High Idling
Any help will be greatly appreciated on how to correct this without buring my pocket.
They kept my car for 4 days with no work being done when we inquired to see if the work was complete. We found out no work had been started, because parts were on order. We took our car home and returned it when the parts came in 4 days later. With repairs made the noise was improved but that is when we noticed that you the gear shift could move from reverse, neutral, drive, and low by just touching the gear shift, and not by pushing the button. We returned the car to service and they stated that they could not duplicate the problem, and it was normal to go from drive to neutral
The clincher came when we saw an accident and was trying to lend assistance our car was parked on a hill and began to roll down the hill and off the side of the road into an embankment.
After speaking to the dealers General Manger he wanted to trade us into another car, which would put us further into debt.
Chrysler's position on this matter is that they "respectfully decline responsibility".
If anyone else has a similar problem with their Stratus please let us know
Never again burned Chrysler / Dodge owner times 4 but not again!!! :mad:
Jake Williams
Huntsville, AL
did you find out what went wrong/ happened after you replaced the transmission fluid of your 99 Escort? I am experiencing a similar problem. Please let me know if you did find out what went wrong/ happened.
The_Kat
(baraka_28@yahoo.com)
For the last 2 days, it's giving me a strange problem. At times, when in neutral, the RPMs run high, around 2,000. The acceleration is good and it corresponds with the rpm, i.e., the clutch should be transferring the torgue properly. I can quickly speed up to 60 - as usual. However, at other times, the idling is rough, the car shakes, and the acceleration is very slow, even when I press the padle to the floor. There is a fluttering noise coming from the engine when this happens. There is no trend that I could observe when I shut the car off and start it again.
Could this be bad spark plugs? If not, any suggestions?
Car has about 90,000 miles and the plugs were change 4 year (=17,000 miles) ago.
Thank you,
SS
The first couple days the transmission and engine ran flawlessly. The last couple days, when the engine is fully warm, I've noticed that when I am about to stop, as I go from any gear to the middle (neutral), the engine will do one of three things:
1. Idle at 1000 rpm until I am fully stopped, then it will go down to about 700 rpm.
2. Go down to between 250 and 400 rpm, then spring back up to normal idle range at about 700.
3. Go down to between 250 and 400 rpm, then cut out, causing me to have to start the car again.
I talked with some people at school, and I get a bunch of different answers. One has told me it could either be the battery, alternator, or ____ice convertor (something that controls emmissions?).
Another said it might be spark plugs.
Please let me know of what might be wrong and how much it may cost to fix. Thanks,
Parker Woodruff
(who is hoping not to spend much more on his first car).
You need to have the codes read first off. Try Autozone, they will often read the codes for you for free.
Then come back here with the codes and we geniuses can do some "educated" guessing rather than shot in the dark stuff which really doens't make a lot of sense.
Once you have the codes, repost in "Technical Questions" not here, and be sure to give us, once again, year make model engine size and symptoms.
Idle Speed Control ----> ISC
If it is a motor the drive system can go bad on some vehicles, mine did one time. Mine was sporatic, till one day it stuck holding the throttle open. RPM's way up there 4000 or so. On the newer cars this takes over the function of what the old dashpot used to do, among other things.
Anyone had a similar problem?
Another way, some people try auto-rx (look on the web) in their tranny with good results.
Do you or anyone know what function the lock-up solenoid valve and the shift control solenoid valve do on the Accord Auto/Trans.?
It just that I am worried when I am going to get the problems back.
The ONLY other thing I can think of is that your clutch disk is stuck to the flywheel, due to the car being inoperative for a while. There is a way to free it up but it's a bit adventurous. Basically you start the car up in gear, chug away in first, and then apply and release the gas pedal in the hope that you can free up the clutch disk. Be really careful where you do this.
Here's the problem. It has been working fine for the last 7 months I've had it. About every two weeks I will make a 300 mile round trip. About 3 weeks ago, I noticed that it was taking slightly longer to shift to 2nd gear. Then a few days later it took even longer, but once it shifted to 2nd it shifted to all other gears fine. Now, it red lines (or close to it) before shifting to 2nd and 3rd is slow to shift too but not as bad as first, not yet at least. Overdirve has quit working all together.
It downshifts fine. If I step OFF the pedal at 60 (not in overdirve of course) it DOES NOT stick in that gear and the engine RPM quckly goes down without affecting the ride--just like you would expect with any properly functioning automatic transmission/vehicle.
I heard from a friend of mine that if you drop the tranny fluid in an old truck I will start to have problems...well, I am having problems anyway. I did pump out through (transmission) dip stick 1 quart of fluid and replaced with Lucas transmission conditioner. I have been running it for 2 days and no change.
Is there a sensor or something that I could change? Change fluid/filter?...I do not have many tools or much money right now (about $100-$130) Please advise if you can. Thank you!!!! Jerry L
1992 chevy truck transmission vibrates at idle. vibration goes away when i hit the gas, or come to a complete stop. engine is fine. runs very smooth. problem is worse in reverse. it seems to "chug" until i tap the accelerator. could it be the transmission bands or something? i know engines very well, not trannys.
also... it only does this after warming up. not cold.
thanks all
The shop replaced the transmission cooling system with one of their own and put new transmission fluid in. For first day there was no problem except that the revs seemed to be higher than before when changing up between 20-30 mph, and the move from a standing start seemed to need more revs to get going than before.
But today there has been a heavy vibration and delay when moving with medium to high revs from a standing start, and some kind of transmission slippage can be heard. I was worried that my high revs when the fluid leaked may have screwed the transmission - but reading this site suggests that there is a lot to understand about fluid, pressure, sensors, etc that could be my problem due to the shop fitting their own kit and fluid. Any diagnosis of this would be appreciated - and advice on what to do about it.
I think most of the fluid was lost on the road - but it looked pretty clean (light purple) to me as is trickled away! I didn't smell anything afterwards but I did see a little oil 'smoke' when I revved the engine - though I think this was the leaking fluid burning on the radiator, where it was dripping down.
Is there any chance that it can't be the disks, given that it operated OK for a day without slippage? Assuming it is the disks, is this a major repair and is there any pointers I can give the shop to checking it out? They are specialists in automatic transmissions, and so I would hope they know about typical problems.
Is it ok for me to continue drifving the car or is this likely to cause further damage?
A transmission shop won't need any pointers. They can tell by driving it around the block. Maybe they can find a good used one to save some dollars since an expensive rebuild could exceed the value of that Neon if it's rough/high miles.
And no, I wouldn't drive the car anymore if I were you.
Generally an automatic transmission is "overhauled" rather than rebuilt---that is, the parts that are undamaged (still in factory spec) are re-used and the damaged parts replaced. The variables include whether your pump is damaged and how much debris there is in the torque converter. With a rebuilt transmission, everything is replaced with new whether it is good or not---most shops don't do that, nor do you have to.
I have had my '97 Bonneville for about 4 months. Bought it used with no warrenty (of course). Had a complete check done before purchase and everything panned out clean. Here's the trouble.... about 3-4 weeks ago, we noticed a hesitation when going into reverse. Really didn't think much of it at the time. Then we started feeling it bog down while in OD, going up hill. We started putting it manually into D. I only use the OD on the highway anyway, and D around town or on windy back roads. (Lots of those where I live....)
Anyway, two days ago, when starting from a stop sign the front end shuddered really bad, had no acceleration and just sounded awful. After the shudder stopped, we got full acceleration and went on. Soon after, I noticed it slipping out of gear. Yesterday, we babied it around town but had some scarry moments when I couldn't get it to shift into any gear while going up a hill. Thats when I decided to PARK it!! My husband put some fluid in to see if maybe that was the cause. We just had it flushed about 6 weeks ago..... We took it for a short drive after that to see if that was the problem. Once again, it wouldn't go into gear so it got towed home. Luckily that was only about a mile.
Anyone have any suggestions? We live about 30 miles from nowhere here and I have to have a car. So the quicker I can get back on the road, the better!!
Becky
I'm sixteen, and I just recently purchased my first car
Thanks very much,
--Boom
Oh, ps.. I have noticed that lately it kind of sticks going into fifth gear, and the gears are sometimes a tad noisy downshifting into 1st, but other than that, just the unusually loose clutch pedal.
Your thoughts would be appreciated. I don't know of the fluid or filter has EVER been changed either!!!
Or did you mean 68,000 miles? I have heard of Hondas racking up some tremendous miles so I guess it's possible.
Your description points to a bad clutch. Learning how to drive a stick on that car may have contributed to this.
If that car really does have that many miles, the price of the clutch probably exceeds the value of the car.
My car recently lost its ability to operate in reverse. I have an automatic car and the reverse seems now to be neutral, neutral seems to be drive and drive is still drive. I'm wondering what might be wrong and how much it might cost.
I'm just looking for some information to help guide me along the way. I feel I've been taken advantage of because I'm a woman and I don't know really anything about cars.
Thanks so much for any advice.
Personally I think you're going to have to probably suck it up on this one but I hope maybe it's something electronic- or even linkage related--newer transmissions can sometimes do that.
Could somebody give me a hint?
Thanks for your time!
Manual Transaxle
FLUID RECOMMENDATIONS
1988-94 5-speed manual transaxles use Synchromesh® transmission fluid, GM part no. 12345349.
The filler/dipstick should be here:
http://www.autozone.com/images/cds/jpg/small/0900823d800eec44.jpg
The drain plug is located on the bottom of the transaxle case.
Did it this afternoon, everything went fine.
