https://books.google.com/books?id=6uEDAAAAMBAJ&pg=PA110&lpg=PA110&dq=granada+twindow&source=bl&ots=JQh2nt9-E2&sig=fZPYD62hSbldKzec9CTJYmv0zOE&hl=en&sa=X&ei=TjEGVavLKsvEggSf14DYCw&ved=0CCcQ6AEwAQ#v=onepage&q=granada twindow&f=false
vancouver.craigslist.ca/van/cto/4915838160.html
That green interior, however, might take a bit getting used to.
**Edit: just found a color chart. I think that color is called "Dark Jade Poly"
Granada/Monarch, the downsized 1980 T-Bird/Cougar, and even the 1st-gen Panther cars, all suffered from Ford's fat-hipped look in those days. The body at the rear axle was too wide for the rear tread it seemed. The slab of a rear bumper on the Fords didn't help the look either. Last days of Gene Bordinat design language I guess.
Is there any real advantage to drawing in the relatively cooler air from outside the engine bay? I know the theory is that colder air is more dense, and has more oxygen. But do those things really work, in real life?
According to Wikipedia, auto makers started going to those longer cold air intakes so that the crude emissions controls of the time could regulate engine temperature better, drawing in cooler air when the engine was too hot, and hotter air when the engine was too cool.
With something like that Monarch, or my New Yorkers, if that piece fell off, I wonder how much it would really hamper performance? Or, more likely, driveability and fuel economy?
The 302 was a weird engine in those days. I recall one year, 1979 I think, where it had something like four different horsepower ratings. But oddly, it went down as the cars went upscale. IIRC it had 140 hp in the Fairmont, a bit less in the Granada, a bit less still in the LTD-II, and 129 in the Panther LTD.
I would think it would be just the opposite, where a smaller car with a tighter engine bay may have a more restrictive intake and exhaust. For instance, when GM upped the HP on the 305 to 165 for 1985, they only did so in the full-sized cars and trucks. In midsized cars like the Monte Carlo, Bonneville-G, and Grand Prix, it stayed at 150. I think with the midsized cars, it was the exhaust that was the choke point. At one point, it actually goes sideways , as the muffler is parallel to the rear axle, just in front of the gas tank, so that puts in a couple of 90 degree angles. Yet, both the catalytic converter and exhaust tip are on the right side of the car, so that would mean at some point, the exhaust had to cross over to the left side to go into the muffler, to come out on the left.
I've heard that putting a dual exhaust on the '78-88 GM intermediates is a bit tricky because of the tight clearances. But, it can be done. After all, we had the Monte SS, Olds 4-4-2, and the Regal T-type/Grand National.
We have a guy in the neighborhood who has a black Accord in that generation that ended in 1997 and is frequently cited as the best Accord made. I'd take it.
I remember either C&D or MT being a bit unimpressed with the '94-97 style of Accord when it first came out. In the past, whenever a new Accord came out, it always seemed like they totally threw away the old design and started with a clean sheet of paper, and created the right product at the right time. But the '94, they said, seemed more like it was just change for the sake of change. Perhaps all new, but nothing really ground-breaking.
They may have also been nonplussed with the Accord because by that time, the '92-96 Camry seemed to be everybody's darling. And I guess the Altima seemed like a pretty big deal at the time.
Funny, I drove by a Ford dealer today that had a row of new Mustangs with their back to the road. They all appeared to have wide hips.
Saw two oddities today. A blue 63 Imperial 4 dr HT and a VW pick up truck. Not real familiar with those, but it appeared from the Microbus it was built from to be a 60's. I think like the Corvair Rampside of that era, the VW pick up didn't hang around real long either.
Now for a drag car with 800 HP, and using ice to cool the fuel charge, you might gain 5%, so that's 40 horses practically for "free".
Saw an immaculate red E30 sedan - with working turn signal!
My total experience in a Corsica was renting one for a week in Florida. Were there ever a perfectly generic car this would have been it. It did everything OK without anything that you'd notice as being really clever and had the oddest knobs and such. That said the little sucker got me a speeding ticket on Route 98 in the panhandle. I tried to convince the cop that I mistaken the route number for the speed limit sign but he wasn't buying it.
I remember we had a Corsica rental once, I was maybe 19, got to drive it a bit. I recall it was dark red on dark red, reasonably equipped, I think it had the 3.1 - actually relatively quick, in that 0-40 way GM seemed to focus on back then.
My parents had a new '90 Corsica V6. It had column shift which my Dad preferred for some reason, even with bucket seats. I can't think of any other car in that class that could be had with a column shift. My Dad ended up putting his own aftermarket storage thingy in the middle. Theirs was the ubiquitous maroon over silver two-tone, but it did have the blood-red cloth interior which I found more elegant than the same interior in mousy gray that ours had.
At the same time I had a red Beretta GT, but with the beige interior instead of gray like every other one did. I actually thought the Corsica was better-styled. I never liked how they cantilevered (is that the right word?) the taillights on the '91 and later Corsicas, and I never liked that '91-and-later instrument panel either.
The Corsica/Beretta was considered one line of car and I'm pretty sure that they reached best-selling car in the U.S. status at some point, perhaps briefly.
My Dad was a big fan of the open compartment in the instrument panel to the left of the steering column, that you could pretty much stick your arm in halfways to your elbow.
As mentioned, getting them to high speed was certainly not a problem. The instrument panel had that look of earlry 90s GMs that was kind of unfortunate. The whole dash was a touch quirky but overall it did everything it was supposed to do. Not what I'd have run to in a showroom but a competent car,
They're built very well, and they're a perfect size for more, very airy with their large greenhouse, and since mine were both the EXR models, they had all the options for the years including sunroofs, a/c, and power windows and locks.
Funny thing too my wagon had factory keyless entry which used same technology as Mercedes at the time. You had to point the fob at the door like a TV remote control to unlock it as it was an infrared type system.
In its defense though, the Camry wagon had more cargo volume than the Accord. Here are some EPA specs from back in the day...
1990-93 Accord wagon: 34 cubic feet
1994-96 Accord wagon: 26 cubic feet
1987-91 Camry wagon: 34 cubic feet
1992-96 Camry wagon: 40 cubic feet
1982-94 Cavalier et al wagon: 34 cubic feet
1982-96 Century/et al wagon: 41 cubic feet
These will differ from the published brochure specs, because the EPA rates them with the back seat up, while other sources rate them with the back seat folded down.
The '96-whatever Taurus wagons looked goofy to my eyes too, not that the sedans looked much greater.
The Camry wagons that did the Rambler thing with the third side-window looked goofy to me, andre.
The A-body just became sort of obsolete once the Taurus hit the scene, though. Although in retrospect, I wonder if in the long run, something like a late 80's Celebrity would have been a better car than a late 80's Taurus? The Taurus got a lot of praise when it first came out, but the transmissions were troublesome, and the 3.8 V-6es would blow head gaskets. As I recall, they were rated pretty bad by CR.
In contrast by the late 80's, I don't think the A-bodies were too bad. I know the 2.8 and later 3.1 V-6es would develop head gasket issues of their own, but it seemed like when the Chevy V-6 blew a head gasket, it was repairable, but when the Ford blew it, you needed to replace the engine. At least, that's from my limited database of anecdotes. I knew two people with Windstars and someone with a T-bird with the 3.8, and when they blew, the engine was shot. I also knew two people with Chevy 2.8's...'87 and '89 Cavalier Z-24's. When the '87 blew, my friend's Dad, who was a metro bus mechanic, replaced the head gasket. When my college buddy's '89 blew, though, the car was about 8 or 9 years old, pushing 100,000 miles, had other issues, and they just didn't want to bother with fixing it.
I thought the '96+ Taurus wagon (and sedan) was a bit too weird for my tastes, as well, although the Mercury Sable didn't bother me as much. I thought they both cleaned up quite nicely for their 2000 restyle, though. I remember taking my Granddad shopping for new cars. He had a '94 Taurus, and was normally used to trading every 3-4 years, so by the time the '00 Taurus was out, he thought his car was "old". But, he didn't like the new Taurus at all. The salesman had to literally beg him to sit in it, and he refused to drive it.
Now, not many wagons left, but MB, BMW, and Audi will put you in one for a price.
Sorry, the link will not post here when I hit "Save Comment".
Speaking of Volvos, I saw an Amazon/122 wagon today - completely different from the one I recently spotted. Also saw a nice 61-63 T-Bird convertible, silver blue with white top, factory/period correct looking wire wheels, parked in downtown Bellevue. A BMW E32 rounded out the spotting.
had trouble finding pictures in google which are like flash images or
something and won't copy. I click on the flash image which often takes
me to a real picture of the same thing which one I can copy for a link.
The '91-96 aero/suppository style B-body wagons had 55 cubic feet. But, I don't think that rounded style has aged very well, especially since styles have reverted in more recent years to angular, blocky styles.
The EPA's tables only go back to 1978 on their website, which is a shame...wish they went back just a few more years, to see how the older cars compared. Didn't the EPA start doing their testing in 1976?
Anyway, going back to '78, the wagon with the most cargo volume was the Country Squire/Colony Park, the last of the pre-downsized mastodons. They're rated at 56 cubic feet. In '78, the B-body wagons were rated at 51 cubic feet, so they lost a foot, somehow, between then and '89, which was where I found the 50 figure.
I'd be curious to see how the old Mopar Town & Country et al wagons, and especially GM's clamshell wagons compared. I know in sales brochure specs at least, they were both pretty big in comparison to the Fords. I want to say the Clamshells were around 107 cubic feet, 104 for the Mopars and around 92 for the Fords? That would be with the back seat down though, and might include under-floor storage.
