Visitor Agreement.
If you are saying that the clutch burned itself down to the rivets after 1,000 miles, and if you didn't abuse it in any way (rocking back and forth in snow, stop light burn-outs, etc.), then I'd say it was not properly installed or again, the parts are defective.
Dealer says that the computer codes say engine misfire, but nothing to do with tranny. Tranny fluid was low, and smells burnt. Dealer says that truck caused tranny problems, so won't take care of it. They want me to replace it to the tune of 3K. NO TRANNMISSION failure code on the computer diagnosis. Could this be something other than the tranny or am I S.O.L.?
With your fluid being low, that's not a good thing for you in your argument for compensation.
I'd say that if you scream loudly enough, and if the dealer offers some kind of 50-50 split on the rebuild, I'd take that offer and try to remember that over the course of the next few years, the cost of this misfortune won't be so bad on a year to year basis.
The transmission isn't leaking. The fluid was just gone. I had the fluid checked about 5k ago, and was low then too. Where's the fluid going, I wonder.
I was told that the Torque Converter may have locked up,as a result of the engine misfire. Does this sound like a reasonable explanation? If so, what can be done about it? New torque converter?
No hope with the dealer - they wont do anything, as they are saying that the truck (engine misfire) caused Tranny problems - not their fault.
Thanks, Shirley
I have read about a place you can send the computer and get it re programmed/fixed, but would like to know if there is some way I can check anything prior to doing that. The code tells me it is the trans range sensor input, is there anything other than the computer that can fix this? The RPM gauge has dropped to "0" and bounced back many times, does this have to do with my current problem?
Does the tranny on my car have a filter and if it does where is it located? This tranny isn't like others that have a pan you can drop. I have previously changed the fluid. I have been thinking of installing a cooler for the tranny is this advisable?
Is there some place a person can go to figure out when you get a code exactly what might fix the problem. I have been thinking of purchasing a manual but not sure if it would contain possible solutions for different codes. I would appreciate any genuine advice you can supply.
Whidbey Rep
any info you can give would be greatly appreciated! thanks :
If you plan on reading out the sensor you will need to read between pins 1 and 7 in drive you should read around 321 to 442 ohms. Drive is the mark you see with a "D" you will need to turn the plastic piece to where the small notch lines up with the line for "D" I marked all my positions prior to removing. Park will line up with the grooved line. You can read this from the computer located in the center console area, but if you want to locate it the range sensor is under your air cleaner.
I also bought a tranny cooler and will install tomorrow.
If any one wants more info the other readings let me know and i will post them.
I ordered the part and will install Wednesday and will let you know how it turns out.
You might very well consider plugging in a good used one. It'll cost half the price or less and if you buy from a good wrecker, who bench tests his units, you're probably fine. The transmission itself is a sturdy one.
So if I were in your shoes, I'd opt for a warrantied used unit if your car were close to mint condition, or if it's got some other cosmetic or mechanical issues, I'd just junk it and go buy another 735iL for $3,500--$4,000 bucks and work from there. You should be able to find a nice one for that. These cars are plentiful (at least where I live) and very reasonably priced.
The trouble is, if the poster were to junk it and buy another one for 4000.00, who's to say it too wouldn't dump a transmission in short order?
Also, I wonder how many miles that 7 has on it. I wouldn't chance a used one in a high miler. Those are money pits to be sure!
Be careful!
Now why is the trans. unique to that model? That doesn't make sense to me. I could see why the driveshaft might be...or perhaps the tailshaft housings are different?
Well on a used transmission, they can be a) inspected b) bench tested with air pressure and c) warrantied.
You can minimize your risk.
Get familiar with your states lemon laws. It should be in your owners manual packet. Try another dealership, or put some heat on Nissan Versa to fix it properly while providing you with a comparable loaner car.
The district manager for the franchise is refusing to work with me on repairing the transmsision, stating that the work order says the additive was install even though I know it wasn't.
My honda dealer doesn't want to give an opinion on what caused the failure and also doesn't want to "get in the Middle".
Can others with more knowledge than me please inform me of the failure mode of this transmission with the wrong tranmission fluid installed as described. I have been told that 2-3 weeks is an appropriate time frame for the Dexron III to cause a failure. Direction to any web sites that will address this situation would also be appreciated.
Thank You
Hondas have a reputation for transmissions. I find it hard to believe it was caused by lack of a small additive that adjusted it to Honda's requirements. I find the concepts that certain cars require special fluids only available from their manufacturers' special shelves a little tough to belive -- with a little background in chemistry.
I hear more speculation about the flush method rather than drop, drain, new filter, refill method that takes more than 5 minutes and $199.
I sure hope you have a pint jar of the fluid that came out of the transmission to give to an analyzing lab. And you probably need to find a transmission specializing mechanic who testifies after analyzing the results--he's the one who may want the pint of tranny fluid.
They were happy to flush away evidence...
Highway miles would be better than cold short trip city miles IMHO. I'd rather have seen fluid drains at 50K + or earlier. I don't like long life recommendations on any fluids. But you changed earlier than the recommendation, that's good.
A local radio talk program mechanic does arbitration and forensic mechanical work. That's the type of person you need to have look at the failure mode of tranny. He's extremely knowledgeable. Probably costs$$$.
So it failed within a 1000 miles!!!! Who has the transmission now. Make sure evidence doesn't disappear again.
I thought that was surprising.
I am just wondering if it could be something else or maybe something that does not require another trans, or maybe there is something else that can be tested or checked on the truck before buying another trans, and if the need be that I must buy a new trans, if there is any suggestions, advice or any helpful hints, tips.
Any suggestions will be greatly appreciated.
I have a 1999 Ford Expedition Eddie Bauer, 5.4 liter Triton V-8 with 165,000 miles. It is clean with NO problems of ANY kind since I bought 2 months ago, as a matter of fact the car was driven from Boston to washington d.c with no problem. However, yesterday I noticed some little resistance in its movement and today the truck refuses to advance or reverse and people says it is the transmission. I checked the transmission fluid and there was a fluid in it, however the engine oil level was very low, so I immediately added some engine oil and trans fluid but the truck still will not move forward or backward. In order not to cause further damage, I had the truck towed to my mechanic and who also says that since the truck will not moves, it must be a trans problem.
I would really appreciate if you can assist me in determining whether I have identical problem as the one you describe by telling me the followings:
1. Exactly what and where to look for
2. Exactly what did you do to find out that the car only has a minor problem.
Any other suggestions will be greatly appreciated. As stated earlier, the mechanic is scheduled to begin working on the truck tomorrow, however I will ask them to hold on just in case something magical might happen, God knows that I really do not have the money for transmission due to my current financial situation.
I do recall the owner keeping a Louisville Slugger baseball bat in the corner of his office... and for some reason they would only accept cash. I sure wasn't going to argue.
Anyhow, good luck. Hope it's a simple repair.
I have the same EXCACT symptoms.
I have a question regarding manual transmissions and the clutch. It is my first time driving a manual transmission and I learned on the vehicle. The car was purchased new and has 10000 miles on it now, but again, I learned how to drive a manual transmission on the vehicle. The clutch feels absolutely fine when driving the vehicle, but when on a hill, if I put the car into first and turn it off, then take my foot off the brake, I can feel the car lock into first, but then after a second, it seems the clutch slips and the car rolls forward a bit. Then the clutch seems to catch again and the car stops. Then it slips and rolls an inch. Etc, etc. I've always used the emergency brake whenever I park on hills so never noticed this before. Is this a bad sign that I have already worn out the clutch and it is slipping? Or is this common for a manual transmission on a hill? I was under the impression you could park on a hill simply by putting the car in gear and turning the car off.
Use your parking brake and turn the wheels into the curb.
The true test of a clutch is whether it will slip "under load", that is, in a high gear (like 4th or 5th) going up a hill. If it doesn't slip doing that, it's as good as gold.
Then, just recently it began becoming more difficult to even get into reverse without grinding, and now shifting into any gear is almost impossible... I fear the clutch is done for, but are the two problems related? The car is essentially up for sale, but if the clutch is cooked I expect I'll need to fix this first.. how much will I be paying, and could it be as simple as replacing the cable?
I don't have any trouble from a standing start or from a dead stop, I have no problems (yet) accelerating. And most frustrating, it doesn't do it all the time. Every now and then from a stop light it will take longer to shift into second. But again, it's not everyday.
Last weekend we got a break from the rain, and it seemed OK. This week the rains came again, and the problems started again.
This morning as I was getting an oil change, my service attendant said my trans fluid was low and topped it up. He said it looked as if it had been leaking at some point. However, I've never noticed any puddles.
My question is, could any of this weirdness be weather-related? And, since the fluid has now been topped up, should I see an improvement in its behavior? My service man told me to take it to a transmission specialist soon to have it checked out, but I don't trust people who are in the business of selling you a transmission! In the meantime, I'd like to get a feel for what could be the problem.
Thanks in advance!
Do you think it's possible for it to leak and not see anything on the ground or floor? I'm going to take it out tonight to see if it's acting better.
Thanks for answering me. It's frustrating, even if I do have myself to blame by not paying closer attention.
