2015 Subaru Legacy Lease Questions
13
  • MichaellMichaell Moderator Posts: 267,696
    edited May 2015
    ptr1nyc said:
    ptr1nyc said:
    Would you happen to have May's numbers? Looking for a 2.5 limited with eyesight 12k 36 months.
    57% and .00021 for 36/12
    Are the money factor and residuals the same for the 3.6R?
    Yes they are.
    EDIT - except I mis-typed the number the first time around. MF in May for the Limited (2.5 or 3.6) is .00031, not .00021.
  • spidpooyspidpooy Member Posts: 182
    Yes they are.
    Would you please confirm MF .00021 and RV %57 for Premium Trim in 36/12K lease term ? 24/12K term is not competitive ?
    spidpooy said:
    Yes they are.
    2.5i Premium is .00040 and 59%. 24 month MF is .00264 for all Legacy trim levels.
  • jkipsterjkipster Member Posts: 272
    Does Suburu charge a bank fee for leases?
    2001 Passat
    2010 G37S Sedan
    2013 G37xS Sedan
    2014 QX60
    2015 Q40
    2016 QX60
    2016 E350 Sedan
    2017 QX60
    2019 E450 Wagon
    2021 Sienna XSE AWD
    2022 Lexus RX350
    2022 Chrysler Pacifica Hybrid Limited
    2023 Nissan Pathfinder Platinum 4WD
  • kyfdxkyfdx Moderator Posts: 271,099
    $595
  • vamin24vamin24 Member Posts: 4
    edited May 2015
    Could you please confirm the May numbers for the 2.5i base model for a 36/10k lease term?
    61% and .00072
    Hey. can you confirm current #s for a premium, non-roof? Dealer gave me 57% and .00040 for a 36/12K. In NJ.
    Also, and lease/bonus cash known?
    follow-up concept question. If I wait until the 16s come out, normally the residual at the beginning of the MY will be higher, but likely with a higher MF, right? If there isn't any bonus cash, since I can get the VIP pricing, unless there is a major price increase, I may not have to worry about waiting too long and running out of cars in the next month!
    The 36/12 residual is 59%. 57% is the 36/15 residual. And, that's the same for all Premium models, regardless of options.
    There might be $250 of dealer lease cash.
    It's hard to say what might happen with the new model year. Every time you think you see a trend, something changes. It seems doubtful you could get the same monthly payment on a 2016, but the Legacy isn't a big seller, so you never know.
    thanks. 2% better residual will help a little.
    still, these never seem to lease well. Going to be hard to justify so much higher a payment over a comparable price Camry! Though my daughter might be crushed.
    I wouldn't pick one over a Camry, unless I was stuck on the AWD. Subaru drivetrains always seem a little thrashy to me. Unless, it's a turbo, of course.. ;)
    well, I made the mistake of taking my daughter looking at all the options. Should have known she would pick the most expensive! But, remains to be seen what I can get the dealer down to.
    the Legacy is a nicer car overall. at the same price, easy decision. For $75/mo difference comparably equipped, not so easy!
    edited May 2015
    Would you please post current RV and MF for 2.5i Legacy Limited in Wisconsin. 36 months and 10K miles ? Any lease cash ?
    58% and .00021. No lease cash.
  • borafsarborafsar Member Posts: 54
    Can I have the 36/15k numbers for Premium and Limited in Colorado?
    Premium - 57% and .00040
    Limited - 55% and .00021
  • orangefig1orangefig1 Member Posts: 14
    Can I have the money factor and RV on a Limited Legacy with nav. 3 years/36,000 and 3 years 30,000 in Massachusetts?
    .00021 MF and 57%/58% residual.
    That's if your dealer uses Subaru Motors Finance. Some Northeast dealers don't..
  • milwaukeeguymilwaukeeguy Member Posts: 9
    Hi, can you provide MF and Residual on 36/36k and 36/45k for Legacy Premium w/Moonroof Pkg+NAV+ EyeSight ($2,890 pkg) in WI? Is the whole package residualized? I'm putting this up against an Accord EX - from past posts, sounds like Subaru can't touch Toyota/Honda on lease terms. Thoughts? Thanks!
    .00059 MF and 58%/60% residual.
    Full MSRP (bottom line of the Monroney sticker) is what residual percentage is applied to.
    Can you give me the MF and RV of a 3 yr/ 30,000 mile lease for both the premium and limited this month?  We are in MA
    .00059 MF and 61% residual.
    .00040 MF and 59% residual
  • abendageabendage Member Posts: 1
    Hi, do you have the current figures for premium and limited 36/15k in Colorado? Thanks!
    Premium - .00059 MF and 58% residual.
    Limited - .00040 MF and 56% residual
  • wghummelwghummel Member Posts: 1
    Hello!
    Can I get the current figures for the 2.5i Premium, 2.5i Limited and 3.6R Limited for a 36-month/10k per year and 36-month/15k per year lease in Ohio?
    Thank you! :)
    wghummel said:
    Hello!
    Thank you! :)
    .00045 MF and 56% residual
    Add 3% for 10K/yr
  • drmrhsdrmrhs Member Posts: 10
    I am getting a 2.5i premium 2016 with eyesight. do they know the residual on it yet for 36, 42, 48 month 10k per year? Not sure if they offer those longer terms. Thanks.
    No 2016 information for the Legacy just yet.
    Yes, terms out to 48 months are available from Subaru - but, the residuals and MF are not to your advantage. 36 months is the sweet spot.
    Thanks very much for the response. Do you expect that the payments on a 2016 will be less because of the stronger residual? If you wouldn't mind, could you please tell me the 36, 42, and 48 month 10k for 2015 premium + eyesight in Ohio anyway. Thanks!
    36/10 - 61% and .00059
    42/10 - 56% and .00098
    48/10 - 51% and .00190
    Thanks! Wow-- you weren't kidding about it being worse.
  • erikaw1erikaw1 Member Posts: 1
    Could I please get the lease info for a 2015 3.6R Limited + moonroof/keyless/nav for a 36-month/10k per year and 36-month/15k per year lease in Washington state?
    54% and .00021 for 36/15. Add 3% for 10k
  • ctal1234ctal1234 Member Posts: 20
    I have a leased 2012 Legacy that is getting close to the end of it's milage (almost 33k out of 36k allowed) with about 6 months left. I was thinking about trying to turn it in early and lease a new Legacy (or maybe an Outback). Is that a good idea? What would be the pitfalls and shortcomings in that scenario? Thanks! I'm in Florida, if that matters.
    You'll still owe the remaining 6 payments. Call Subaru Motor Finance and see what the payoff is, then check on the trade value. You might not be as upside down if you trade it in as opposed to terminating the lease early.
  • comradsuhovcomradsuhov Member Posts: 12
    Hi Could I get the lease info (MF and residual) please for a 2016 Legacy Limited 2.5 and 3.6 with the Pkg#23(Eyesight) and PP#5 - 36/12k and 36/15k miles in Colorado? Thank you!
    No 2016 Legacy numbers are available to us yet .. perhaps in August.
    Thank you Michaell, I will ask again next week then :)
    Hi there. Is there any new info on leases for 2016 Legacy?
    No 2016 Legacy lease numbers available, yet. August numbers expected later this week; perhaps 2016 will be included then.
    Lets try one more time and thank you again for providing this info!
    Could I get the lease info (MF and residual) please for a 2016 Legacy Limited 2.5 and 3.6, both with the Pkg#23(Eyesight) and PP#5 - 36/12k and 36/15k miles in Colorado? Thank you!
    A leasing expert is looking for a new car shopper in the Seattle area who needs help navigating the leasing process. The expert will help you go through the leasing process from start to finish for free in exchange for taking a few pictures and/or video of the experience with leasing a new car using an iPhone app. If interested, please send an email to stever@edmunds.com.
    36/15 numbers
    2.5i Limited - 58% and .00060
    3.6R Limited - 59% and .00090
    Add 2% for 12K
    Thank you Michaell!
    Hi Michaell,
    thank you again for all your help and advises!
    Could you please give me your opinion on the pricing for 2016 Legacy. Here is what I got quoted from one of the local CO dealers:
    2016 2.5 Limited with Pkg#23 and PP#5 = $26,948 + $499.95 (dealer handling) + my taxes
    2016 6.6 Limited with Pkg#23 and PP#5 = $29,998 + $499.95 (dealer handling) + my taxes
    What do you think about these prices?
    Also, when I inquired about MF and residual couple days ago from the dealer, I was given same residuals as you just gave me, but MF for 2.5 was .0011 and for 3.6 I was given .0014. Is it possible that I was given wrong/old rates? Do you know if there is any hidden lease cash incentive or purchase cash incentive?
    Thank you for your help!
    Hi Michaell,
    36/15 lease numbers for 2016 Legacy:
    Maximum mark up on the MF is .00050, so do the math.
    I don't track selling prices, so can't help you there.
    No lease cash that I see; use the "Car Research" tab at the top of the page to link to current customer incentives.
    Which dealer is this? We bought our Outback from Groove in Denver back in February and found them to be a pretty up front dealership.
  • jurizarjurizar Member Posts: 23
    Live in Los Angeles, CA. Considering leasing legacy premium. Can I get the MF and residual value for 36 months/15k miles. Thanks in advance
    58% and .00059
