Visitor Agreement.
I saw it at Ames. This is their regular price, not a sale price. Hopefully it won't go up.
-cr
I am not so sure that it is as good as Mobil.
It is probably not if we are splitting hairs, but rest assured it does meet those all important specifications. (SJCC,API, etc, etc,)
Thanks in advance
good luck... post and tell us what the dealer says.
By way of info; If you have access to a BJ's they have synthetic Castroil in a 5qt container for $14.49
If the engine thermostat is the only thing governing engine temperature, you might want to try this with DISASTEROUS results; Try emptying the engine oil and run your engine. Care to wager what happens to your engine? Clue, most likely, the thermostat would not be defective
Far easier would be to buy that Castrol syn oil @14.49 a 5 qt container, and see what happens on your temperature gauge.
I fully agree with you that such lubrication improvements, assuming the thermostat is functioning normally, would not be seen as a reduction in the coolant temperature.
Yes it is app 50 degrees cooler. Not startling by any means.
Perhaps you are attibuting synthetic oil magical powers it doesnt have. Yes, on a side by side comparison to the conventional oil the syn runs app 50 degrees cooler. It has no magical effect or affect on the functioning of the cooling system, i.e. the thermostat functioning. Like I have said if you think that the only thing that affects heat dissapation in the system is theromstatic control, try running it with disastrous results without engine oil. By your theory the thermostat should regulate the heat in the 190 degree range. RIGHT from that side of the system. MUCH engine damage on the other!! Don't believe it? or afraid to try it?
I agree with you that everything you can do to keep it in a "normal operating range" is what you want to do.
I guess I assumed wrong when I thought we were talking about normal operation.
#525
I have used syn oil only in the winter in my last three cars and all ran at the same temp as they did with DD oil.
Many things effect engine temperature but the final result -- what you see on the dash board -- is determined by the thermostat.
Well structurally you must decide whether or not the app 50 degree so difference is worth the switch to synthetic. While results can and do vary, who cares for example; if you trade new every two? Actually, the funny part is that on a theoretic basis, the lower temperature is more critical for conventional oils rather than for synthetic oils.
Thanks, John
With the exception of heavy towing, driving up Pikes Peak in summer with the A/C running or stop and go traffic in 100 degree plus days your engine should always be running at the normal temp range and this is entirely regulated by your thermostat. There is NO WAY that an normal functioning engine that is running in less than extreme conditions will have the engine temp drop by 50 degrees because of synthetic oil. If you really understand how the thermostat works in your cooling system you would see that what you are saying would mean that the thermostat never even opened. Which, like I said before, gives you an air cooled engine.
I am a believer in the enhanced properties of synthetic oil but claiming engine temp drops of 50 degrees belongs in a Duralube infomercial.
My postings are not meant to expound on the function of a thermostat but to express my doubt that running synthetic oil will drop oil temp by 50 degrees.
I have never seen this benefit, I have not heard anyone else claim this benefit and I am skeptical.
John
Yes, in your manual you will probably see the range and it is probably 5-10W -30w.
John CG,
I agree with you about engine reduction and have wondered about the several posts that claim a noticeable reduction.
Although the thermostat is not the *only* thing that controls temperature (e.g., a partially plugged radiator will allow the temp to rise above the thermostat set point) it is the main thing in a engine in good condition. Any changes in the oil would be *mostly* compensated for by the thermostat (it is a feedback system).
And, synthetic oil has the same nominal viscosity as mineral oil. Since there is no or minimal metal-to-metal contact, the viscosity is what determines the fluid friction. Since synthetic is supposed to be about the same, where's the difference.
Lastly, engine heat is determined by many factors, such as load, weather, which would swamp out small differences in the oil viscosity friction, even if there was any, and even if there was no thermostat to level things out.
Also due to the higher viscosity index and also flash point of syn oil, there is a tendency not to consume as much syn oil as conventional oil, all thing s being equal. If your engine is running hotter all things being equal, over a baseline time/miles frame it will show up as say; using a quart more as opposed to not needing to add oil.
My real life example is; my truck tends to use one quart of syn oil at the 14,000 mile mark.
anyways please let me know as should I go to fully synthetic or blend, or keep using the regular oil.
Thanks for your comments
Re. synthetic vs. oil cooler-I cannot imagine the cooling benefit of sythetic vs. dino would be as substantial as running an oil cooler. Seems to be apples and oranges. Why not have both benefits? I also don't think a trans cooler is cooling sooooo much that the oil would never reach proper operating temps and thus sludge up. I think coolers are meant to assist in heavy duty requirements such as consistent heavy loads or towing.
http://www.geocities.com/MotorCity/2195/engineoil_bible.html
What??? Oh yeah, run that thick 20W50--what
manufacturer recommends that? Hell, change it
every 20,000 miles! Godalmighty.
the reasons why they are pushing it out farther are multiple...
#1) i think that jiffy lube (and others) are primarily responsible for the feeling that most people have that they have to change their oil every 3k.
#2) better tolerances
#3) advances in oil add packs
#4) dealers offering free service at recommended intervals.
the 3k number isn't some kind of magic number... if you do nothing but drive around town 2 miles at a time... then i'd change it every 2k... if (like me) you drive it 70 mi on the turnpike one way to work every day, you aren't exactly overstressing your engine and are safe going past the 3k number. i personally change mine every 5-6k with mobil 1.
live it up. change it every 100 miles if you like. it's not gonna hurt.
ymmv. my opinions, for what they are worth.
it really take for the "rings to seat". In other words when would it be most effective to start using syn. oil?
Steve
Upon hearing the shaft failure I inspected the engine and found I had been about 1 to 1.5 quarts low on oil....
Is the oil consumption due to failure of this part or is there a unnoticed leak somewhere? This little car has been very good only work done in the last year was timing belt, valve job, resurfacing head, water pump, and new radiator. When I did remove distributor assy I found small leak around housing that met the block, seemed to be caused by worn o-ring.It was nothing major. I was told by mechanic that the viscosity oil I was using was too light (10w30) for a rebuilt head, high mileage, and driving conditions (80mph about 90miles a day mostly highway) that I should switch to 20w-50 or straight 30 due to excessive mileage.
Is this a correct evaluation? Is a car with 115000 miles and excessive mileage supposed to use more oil than normal? or do I have bigger problems?
Any info is greatly appreciated
