Engine Oil--A slippery subject
"You can start using Mobil 1 in new vehicles at any time. In fact, Mobil 1 is the factory fill in Corvette LS1, LT-1 and LT-5 engines. And Mobil and Porsche just announced a new partnership that will also have all Porsche cars manufactured at the Zuffenhausen plant lubricated with Mobil 1. One of the myths that persists about Mobil 1 is that new engines require a break-in period with conventional oil. Current engine
manufacturing technology does not require this break-in period. As the decisions by the engineers who design the Corvette and Porsche engines indicate, Mobil 1 can be used in an engine from the day you drive the car off the show room floor.
The “30” designation identifies that all three grades (0W-30, 5W-30 and 10W-30) will exhibit the same oil viscosity at normal engine operating
temperatures. The “W” designation identifies the low temperature viscosity. A smaller number indicates an ability to flow at lower temperatures. In summary, Mobil 1 0W-30 will provide the correct viscosity protection at normal engine operating temperatures, and BETTER
protection at low temperature extremes for any vehicle that calls for a 5W-30 or 10W-30 engine oil.
If you have any additional questions, you may contact us at our E-mail address: lubes@ffx.mobil.com or by phone at 1-800-ASKMOBIL."
Can I come into your house for a minute. . .
I used Amsoil and was very dissatisfied. It foamed on me. Thought I had a gasket leak. Changed back to Mobil 1 and it went away. Tried Amsoil a few years lates, and same thing.
I think it's a paraffin-based synthetic rather than Mobil 1's olefin-base, which as I read it, is preferable according to the literature.
I miss those Amway parties, and the Moonies at the airports. Man, I'm teary-eyed when I think of those great 70s. Jimmy Carter. Prime Rate of 19.5%. Hostages in Iran. But I digress. . .
Keep your door locked.
-psycho
that people are changing their oil at 3000 miles.
Now I know why filter and oil manufacturers
encourage this. I also know why garages and quick
lubes encourage this. (Money, money, money)
I have always (the last 23 years) followed the
manufacturer's recommendations and have never
changed oil more often than 6000 mile intervals. I
recall that Consumer Reports did a test on New York taxi cabs that proved no measurable difference in engine wear with more frequent oil changes than those recommended by the manufacturer. Do folks just like buying lots of oil, or am I missing something?
everyone talks about 3000 mile oil changes, whereas my car owners manual specifies 5000 miles or 5 months. after a lot of pondering, i decided to go with synthetic oil and follow the manufactures recommendation of 5000 miles.
my dealer said that was ok.
1) sell diet products
2) belive and take in ginko shcmalbowa
now have "amsoil" dealerships.
Amsoil is sponsoring a MX racer for the 2000 series (my passion is motorcycles), so what the hell, I might give 'em a try.
PS My Silverado asks for an oil change every 3 to 4 thousand miles. It doesn't say, "oh, you are running synthetic, you can go further". I still believe in oil change every 2 to 3 months.
Hell, we change our wet clutch off road race 4stroke's oil every time we ride, and many of us use $5/qt synthetic.
The dealer daid I have use 10W-40
At 2000 miles I changed to Castrol 10W-40
However I read article said that 10W-40 is not a good oil.
At 4000 miles I changed again Castrol 10w-40
At 6000 miles I changed to Mobil 1 5w-30
At 12000 miles I changed to Mobile 1 10w-30 (summer)
At 17000 miles I chnaged to Mobile 1 5w-30 for comming winter..
Should I use 0w-30 other than 5w-30 any disadvantage?
Among these oil I feel Castrol provide best mileage 19 to 20 highway. then Mobil 1 5w-30 18-19 then Mobil 1 10w-30 18. So better mileage means better oil? I will keep useing synthetic oil. Just need some connection between mileage vs systhetic oil.
any comment is welcome
the standard comeback line to this test has always been "but new york taxis don't do the same number of starts as a regular, non-commercial vehicle." Start-ups put quite a bit of wear on the engine, and when oil breaks down (as it does when it gets old) even more wear occurs. This point about start-ups seems valid and important. Whether or not the cabs really do as many starts as a non-commercial car is up for debate.
I'd look at that test as just that--a test. I wouldn't accept it as the last word on oil changes, though.
What they should have done was test out to 100,000 miles or beyond. Then they should have been able to really see the differences in wear between different oils.
Dave
Jiffy Lube has no third party data to support a change at 3000 miles, so their recommendation is based on "marketing" thats scary.
Garages say "it works" - I guess it does, changing at 2000 miles will work too, and so will changing every 500 miles.
I liked consumer reports testing (NYC cabs about 95 % of them shut off and cool down at night), so I switched to 5000 miles change frequency. The local mercedes dealer tells me many of their computers say change at 10,000.
Your respondant quoting Mobil Corporation opinion may be well be right. But there is obviously not agreement about this subject. Since VW has a 100,000 mile/10 year drive train warranty, which we don't want to cast doubts on about proper treatment of the engine, my inclination would be to follow their (VW) advice and take the minimal wear of the first 10,000 miles of using conventional oil.
You may be better off following the recommendation of those who are warranting your vehicle.
Many people regard a 3000 mile oil change as a "safe" period. The oil probably hasn't broken down that much, but why let it. 5000 miles for an oil change is not bad either, although you're more likely to be "pushing the envelope" in terms of oil break-down. 10,000 miles seems a bit much. Maybe a MBZ engine can take it, but I'd tend to doubt it.
There are usually 2 maintenance schedules in the owner's manual. One is for "severe" duty (which is what most people actually do) and one is for strictly highway driving. I'm guessing the 10,000 mile figure is based on the highway-only schedule. The other schedule probably recommends oil changes at half the mileage.
I listen to a local radio show hosted by a well-respected automotive specialist. He recommends changing to synthetic oil on a new car between 4,000 and 40,000 miles. Sounds reasonable to me.
Dave
Part of the deal at VW is *they* (VW) change the oil for the first 24,000 miles. So they are in control of what goes into it until we give them Mobil1 to put in. He is saying wait until the second oil change at 10,000 miles to start M1.
INKY
The point is, synthetics still retain their protective properties at those low viscosities, so you should always use the lowest Synth viscosity allowed by your owner's manual.
Most syth oil manuf recommend that you NOT use their product until at least after 10K miles because the synth is too slippery and does not allow the rings to seat properly. i've never understood the Corvette's use of Mob 1 from the beginning. There's nothing special about the break-in oil, since about 1975. It's just that you need enough friction (and wear) to set things right before you use synth.oil and slow things down.
I use synth and I change it every 5000-6000 miles, despite claims of longevity. Click and Clack, the Tappet Bros, from CAR TALK, used to adamently recommend an oil change on all cars at 3K. They've changed their tune to 5K based on the superior quality of oil since about the SG and SH grades.
Relax. Forget about the car. Go outside tonight and check out the Leonid meteor shower, perhaps the best showing in 33 years, with an estimated 1000 falling stars per hour (one every 3 seconds?)
More later, gents.
-psycho.
INKY check out tests at acdelco.com
INKY
my manual recommends 5w30 in the winter and 10w30 otherwise.
if you use synthetic, manufacturers recommend against using any oil additives (check out the faq section on the castrol website www.castrol.com)
http://minimopar.simplenet.com/oilfilterstudy.html
they don't like Fram, or Champion.
I agree about the size, I have heard that below 25 microns it does not hurt anything. There are differences in the filters tho and in some cases u get what u pay 4.
Suggest read the site.
Note that "extra filtration" and large capacity filtration is not necessarily a bad thing at all, kinda like "insurance", and may provide some benefit. But, I don't put 200K+ on my engine befor the rest of it is likely to be in a state of disrepair (& sale). Good quality oils and filters will get a good life from the average vehicle.
My personal opinion, based on looking inside some filters, is that some of the internal construction of the $2 filters of some national brands may not be as good as i'd prefer (especially paper endcaps, and poor anti-drainback valves). I'm assuming most do a decent job filtering, and the bigger risk is failure or wear from oil drainback at start.
I can't really watch "everything" that the outside mechanic does and I don't want to / can't change the oil myself.
1. Does the benefits from switching to synthetics outweigh the potential that the outside mechanic will mess around with something on the car?
2. How honest / dishonest are the average mechanics out there? Do I have unfounded worries or has someone experienced those very same problems? Your feedback is much appreciated.
Ed
edandty@msn.com
Ed
edandty@msn.com
The Owners Manual indicates that it is not necessary to warm the engine up for longer than 2 minutes, even in cold weather. The manual goes so far as to say that the car will warm up faster if you simply drive it shortly after ignition.
This seems to contradict everything I have been taught over the years about letting an engine warm up, ESPECIALLY in the winter, so that the oil can thin out and reach the top of the cylinders. I thought this was necessary to prevent excessive engine wear.
Have I been misinformed all these years? Am I doing my little 4 cylinder engine harm by ignoring what the manual says, and allowing it a good 5 minutes or more of warm-up time in the cold winter morning? I like to see that temperature gauge start to move before I go racing off to work.
I formerly owned a 91 Mercury Tracer with a 1.9 liter 4 cylinder engine that went 156,000 miles with no engine trouble, so I don't think this method is too bad. I sold it to my brother in law, and it's still going near 200,000 miles and not using any oil.
Dave
God Bless You! I have 1 too. No drips,
no leaks so far. I hope I don't jinx myself.
The newer engines come up to operating temp.
much faster than earlier models. My 99 is in the
normal range within a 1/2 mile. Newer cars are
also more sensitive to operating temperature.
The old days of taking out a 195 degree thermostat and putting in a 180 degree one
will screw up all the sensors being monitored by
the onboard computers.
Your advice is good...most car experts say to
drive slowly until reaching operating temp.
But below 0 it is wise to let it sit for a short
time.
it certainly doesn't sound like it's psyched to journey forth even at a slow speed. it sounds like it's telling me to hang out and wait!
so the question remains: even if it is for my own conscience, am I harming my vehicle in any way by letting it warm up for a few minutes before take off?
Igloomaster, if you think your engine sounds louder at 30 degrees, just wait until you start it at -20. You'd swear it was a diesel! No, you are not harming your engine by letting it warm for a few minutes. It will just cost you a bit ao gas mileage and time, but give you a little peace of mind. You may also be contaminating the oil a bit more, but if your commute is long enough to warm the oil to operating temperature, this shouldn't be a problem.
Dave
Just remember to unplug it before you drive off.
Dave
Another related suggestion: Avoid, as much as is practical, starting a cold engine and then stopping it before it reaches operating temperature. The "classic" error is moving the cold-engined car from the driveway into the garage late each evening. Such a practice accentuates the accumulation of condensed products of combustion in the crankcase.
