2016 Subaru Legacy Lease Questions
                    Ask your 2016 Subaru Legacy lease questions here!
Term: 36 months/12k miles
36 - 59% and .00090
39 - 56% and .00100
42 - 54% and .00100
Add 2% for 12K
36 month/ 12k miles
39/15 - 56% and .00065
42/15 - 53% and .00060
Add 2% for 12K
could I get september numbers for legacy 2.5i limited? 10k/12k 36 months thank you!
ODAT
.10/mile charge if you want more. No indication of what the limit might be.
Try other Subaru dealers - only takes one to make a deal.
thank you for all the help and information you provide on this forum!
We already placed an order for 2016 3.6R Legacy Limited, but not sure if the car will get to the dealer by the end of the month or it will be in October, so I might inquire about MF and residual numbers again next month
Could I please get the lease info (MF and residual) for a 2016 3.6R Legacy Limited with the Pkg#23(Eyesight) and PP#5 - 36/12k and 36/15k miles in Colorado?
Could you please provide me with the October lease info (MF and residual) for a 2016 3.6R Legacy Limited with the Pkg#23(Eyesight) and PP#5 - 36/12k and 36/15k miles in Colorado?
So, the money factor got worse on 0.6% but residuals slightly improved.. Interesting... I wish Subaru would keep rate at 1.32% with the new residuals
Thanks again!
May I please have the MF and Residual values for
2016 Legacy 2.5i PREMIUM and LIMITED also
3.6R LIMITED with AUTO and Eyesight pkg for 36/15K in NJ? And if there are any incentives this month.
2.5i Limited - 56% and .00025
3.6R Limited - 57% and .00055
Would you be able to provide me with MF and Residual for 2016 Subaru Legacy 3.6r Limited w/ Moonroof/Nav/Keyless Access & Eyesight w PP #5.
12,000/36 & 15,000/36. in Pennsylvania Thank you very much.
could you please confirm the October lease info (MF and residual) for a 2016 3.6R Legacy Limited with the Moonroof/Nav/Keyless Access & Eyesight (Pkg#23) and PP#5 - 36/12k and 36/15k miles in Colorado? Because as you could see below, on October 1st KYFDX gave me different rates then what was given to people here couple days ago for seems like the same configuration (see below). Thank you!
kyfdx Posts: 37,608
October 1
comradsuhov said:
Thank you KYFDX for providing September rates! Unfortunately the car didn't arrive yet and I'm now looking at mid-October for this.
.00080 MF and 60%/58% residual
Must have read off the Outback line, the first time.
Add 1% for 10K
Also, do the dealers have discretion to charge even more on the interest factors? I've never encountered that before, but this one says you have to add 0.5....which is just a ridiculous number that I don't think he fully understands or means. Aren't the numbers set by Chase/Subaru Finance?
Thank you so much for your help!
Dealers are permitted to mark up the money factor by .00050, for extra profit. They aren't required to, naturally.
Some dealers in New England do not use SMF.
No incentives or special lease terms from Subaru. 36 months is generally the sweet spot for them.
