Visitor Agreement.
And you don't seem like the lease type to me.
Get a base golf stick shift. Pretty cheap, drives great, and do a few tweaks. A budget sleeper mini-GTI!
As for budgets, well, they are more important with a used car than a new one I think. With a new one, if things go wrong, you have a warranty as well as a clearly defined degree of depreciation. With something like a used Porsche, I could incur a total loss in the snap of the fingers. (if engine grenaded, for instance).
You're right, I'm probably not a leasing type but if a great deal came along, I could adapt.
But, not worth it, if I just need to swap out rubber. In my experience, BMWs stay within alignment specs for a long, long time.
My 2010 Forester received one alignment thus far, and that was when I replaced the shocks and struts. Had I only replaced the struts, I may not have taken it in because it's pretty easy to set the car's camber exactly as it was upon removal, but since I put in the HD springs, it completely changed the dynamics of the suspension and an alignment was more than warranted!
If it's all good, no reason to let someone mess with it.
By that time (another year) I should probably be thinking struts and suspension work so an alignment would be necessary.
And, the wife's Outback is throwing a TPMS code that I couldn't clear by adding air at the local gas station. Goes into the tire shop later today for a look-see.
And, I suspect the MINI is going to need tires soon, as well - thank goodness I'm not in charge of buying them, just dealing with the installation.
No point in buying new, the tires will rot off the rims before I wear them out!
The Sandman
I'm starting to see more & more Legacys on the road. I do like the way the wheels look on the Limited model. They are 18s instead of my car's 17s. My car's 17s have a nice, meaty sidewall that absorbs lots of bumps and I'm not scared if I accidentally hit a pothole.
The Sandman
Left the house about 8:15 and after a quick bite, hit horrendous traffic in North Broward county taking the turnpike. More traffic in Dade county once I got to the turnpike's end. Took 163rd Street to Biscayne Blvd.(U S 1) and went south a few blocks to the court house. Crazy with people but my wait was less than 10 minutes. Got to the window and after a bit,they asked about the driving school certificate which naturally was at home. Told me to come back after i got it but I protested. Turns out they found it in their computer...they had never linked it to my ticket number!! I stayed calm and the guy said he'd fix it all right then and there and I would not have to then go to the DMV afterwards. he did it and I thanked him but really, their office screwed up big time! Hopefully, all is kosher now with my drivers license.
A shame that the government screws up things like this because it makes we the people jump through hoops to correct their mistakes. Not acceptable!!! Just glad it's done and just cost me gas, a few tolls and my time. But again, just glad this chapter is over!!
The Sandman
A 205/55-16 is almost identical to what you have now, total diameter. A 205/55-17 might fit, but is off by more than 3%. 215s more than 5%
Search for the Miata.net tire calculator and can play around. Tire rack probably has something similar.
What could go wrong with a 505hp Alfa, Right??
[ Count me in for a buck ]
The Sandman
2017 Alfa Romeo Giulia Quadrifoglio Bound for Dealerships Next Summer
Wonder if the real kickstarter campaigns will start once these are out of warranty?
It probably uses the block from their 4.3 V-8 and it's chopped down to a V-6. Using a true Ferrari engine would raise the cost dramatically.
http://forums.edmunds.com/discussion/38080/subaru/legacy/2016-subaru-legacy-prices-paid#latest
But, you gotta sift through a lot of crap to find the diamond in the rough!
The second process is the test drive...a good long test drive...and that's often the deal breaker. Even if the car runs out really well, it sometimes doesn't shape up as "the car for me". For instance, I have no idea what it feels like to drive a CX7--never did---so the test drive might result in a perfectly good car being rejected. Or I might hear or feel some seriously bad things---pinging, transmission or diff noises, severe brake shudder, failing electronics.
The third process is the PPI--pre-purchase inspection. Only a few cars make it this far, because it gets expensive to run cars through a PPI....$150 to $350, depending on what it is (Mini, $150, Porsche $350).
I guess if I were shopping Camrys, I'd skip the PPI.
or just disconnect the rear shaft. No need for an angle gear!
Edit: tht CX-7 seems to be gone. don't see it listed any longer.
they do have this. other than the aftermarket wheels, I oddly really like this. wonder how good the price is?
http://www.fiatusaofsouthjersey.com/used/Toyota/2001-Toyota-MR2+Spyder-cf467e730a0e0a6b5144145c7530a738.htm
This looks nice. have to be a little brave. And in the listing, they lie about the tranny (it is a slushbox)
http://www.turnersvilleautomall.com/detail-2005-bmw-x5-3_0i-used-14416147.html
Missed on miles. But if you want big, this is big!
http://www.turnersvilleautomall.com/detail-2008-buick-enclave-awd_4dr_cxl-used-14378871.html
these are actually very nice. and no complicated AWD to worry about. Just serviced, new brakes and tires. Hmmm, I really do like this one.
http://www.turnersvilleautomall.com/detail-2008-hyundai-veracruz-fwd_4dr_gls-used-14231375.html
actually, though, 80k miles is about my limit.
i do want to check out an SRX, so I may try to do that first.
SUVs do seem to be priced much higher than comparable cars though.
This one is low 51K. V6 AWD.
http://www.msmazda.com/vehicle-details/2005-mazda-tribute-s-maple-shade-nj-id-11391861
If you can double your miles and feel lucky, AWD for $1,400! Does not actually look that bad. I know you like these.
https://southjersey.craigslist.org/cto/5325363936.html
Close to you. Definitely a dealer posing as owner, but actually fits the criteria (well, 81K, close enough). Though that pesky brave factor comes in again!
https://southjersey.craigslist.org/cto/5308671156.html
looks like C&D agreed once upon a time:
http://m.caranddriver.com/comparisons/bmw-x5-vs-acura-mdx-cadillac-srx-m-b-ml350-lexus-gx470-volvo-xc90-vw-touareg-land-rover-lr3-comparison-tests
Here is the closest one I may like to go see today:
http://m.cars.com/vehicledetail/#vdp?listingId=651679260
I'm sure something in a lower class like a CX7 or Venza would be the smarter choice, but we are attracted to luxo brands, so it is tough to look away. Besides, when you look at the numbers, something like a 2007 CX7 and 2005 luxo ute with similar miles are similarly priced. Just the upkeep that may kill me in the end.
