Waxes and Polishes, Part II
1246711
  • coffeebizcoffeebiz Member Posts: 13
    Hi. I'm ready to purchase my Zaino products but I don't know whether to buy Z2 or Z5 or both? I have a '97 black 4Runner and I have never waxed my car before. Any suggestions? Thanks.
    Lee
  • drscopemdrscopem Member Posts: 83
    Hi:
    Rather than repeat previously posted information, suggest you refer to posts #153 and #155 above and click on Zaino and Chris Parrish sites.
    Hi:
    Sorry. Edmund's won't take the above site on one line so you'll have to enter it by hand.
  • pat455pat455 Member Posts: 603
    Or just go to www.ls1.com and click on the Showcars and Detailing section.
    To answer your question, the consensus seems to be that Z2 on top of Z5 (however many coats of each you desire to apply) provides the optimum depth of shine, particularly on a black car. On my four month old (light colored) TL, I had applied several coats of z2 before I thought to try a couple of coats of z5, followed with one more z2.
    This was just to see if I could improve on what I already believed to be perfection, and it DID make a difference.
    Also, you will get the best results if you follow the dawn wash and clay routines recommended by the sites referenced in the posts drscopem referred you to, and use the towels discussed.
  • codakcodak Member Posts: 10
    I just used the Z1 followed by Z2 for the first time today, and I didn't think I put either of them on really thick but it took a LONG time for the Z2 to dry. It's not humid here today, and I let it dry for over three hours and it still smeared when I tried to take it off. Also, even when it did dry it seemed to take a lot of effort to get it off. Can anybody tell me if I did something wrong or what could have happened?
  • fastdriverfastdriver Member Posts: 2,273
    codak-
    Not really sure what happened. Was the Z-1 DRY before you put on the Z-2? To test it, you run your finger over the Z-1 or 2- if it smears, it's not dry yet. Could be that you used too much or it was more humid then you thought.
    At any rate, just take a damp towel and wipe the car down. This should remove any smears. Then, use the Z-6. Again, use very little- applying it in small areas and immediately wiping it off.
    Let us know what happens.
    fastdriver
    Hi:
    If the Zaino smears then it wasn't dry. The main cause is putting it on too thick. Everyone is used to putting a thick coat of other waxes on until the surface is obliterated. For Zaino that is way too much.
    Check out post #155 for Chris Parrish's site. He is the guru and has excellent tips. If you can leave it in your garage overnight to dry you will probably be better off - that's what I do.
  • erazererazer Member Posts: 21
    JC Whitney Dura Gloss Clay has been around for a while. It comes in a black tub, and the two 4 ounce bars are also black in color. The product is very abrasive and will leave a sticky black residue on the paint finish, not to mention that you will get black gunk stuck to your hands. Their formula is outdated and is not used by professionals in the industry, that is one reason why JC Whitney discounts it through their catalog. It is very cheap at $13 for the two 4 ounce bars, however, you get what you pay for. This product will simply create more problems and will make the cleaning process more difficult. For information on a top quality "clay-like" cleaning product visit our site at www.erazer.com and feel free to email me with any questions.
    John
  • hgileshgiles Member Posts: 66
    Codak - I have applied Zaino many times in the hot, humid southern weather and I'm not having your problem. I put on an extremely thin layer of the product. Remember that any wax or polymer will be micron thick anyway after you buff it off. I usually wait forty-five minutes and literally wipe it off with a heavy, quality bath towel. One of the main reasons I like Zaino is that if applied thinly it wipes off without the need for tedious buffing. Oh yeah, I am also getting good results as well. Good luck.
    # 167, #170
    I have been using Zaino for 1.5 yrs. now and have consistent drying times of 20 to 30 min. I have done it in very dry to very humid conditions. I believe the key is use VERY thin coats. As you have stated most folks are used to the way heavier waxes/polishes/polymers.
  • chevy05chevy05 Member Posts: 5
    Is it true that putting polymers on vehicle paint can cause spider webbing and other paint damage due to the innability for the paint to breath and expand and contract? I read this on www.waxdepot.com I am up in the air between using Zaino and a product called Super Glaze by The Wax Shop which I have used for years. I am looking for a wax for my new Honda Civic that will shine well, and last a couple months.
  • pblevinepblevine Member Posts: 858
    drscopem,
    I had thought that Z5 should be applied prior to Z2. Maybe I should also try Z5 in the manner you stated above. But doesn't Z5 have to operate at the bottom layer level?
    And to Chevy05, NO Zaino will not damage car paint. I just looked at that waxdepot site's polymer related content. And I can say that they got it wrong. They are lumping all 'plastics' together. Polymers are just one branch of plastics and Zaino doesn't contain silicone. By the way, the paint and clearcoast on your car is a plastic based chemical too. Zaino will not stop your paint from 'breathing' - that's just nonsense. Once dry, your paint doesn't have to breath. Just expand and contract with outside temperature conditions. Polymers like Zaino WILL expand and contract at the same rate. Many of the harder waxes will not. They will break apart at the microscopic level and leave little gaps which allow outside dirt to get to the clearcoat.
    Much mis-information on that site.
  • SporinSporin Member Posts: 1,066
    Is it "Much mis-information" or is "contradictory information" from what you read on the Zaino Bros. site?
    To be objective, you should take information that is provided by the same source that is selling the product with a grain of salt, whether it is Wax Depot, Meguiar's, Zymol, Griot's, or Zaino.
    Very little "Independant" information is available about waxes. Everyone must rely on personal experience and recommendations from trusted friends on what products to use.
    sporin,
    You DO have a point. However, that site made a point lumping acrilic and polymer based chemicals together as 'plastics'. And the better wax manufactures (Meguiar's) have explained how their products break down over time. The high end waxes ARE good products but like all such products (including Zaino), time and environmental conditions will wear them down. According to some of the wax literature, when harder waxes break down, they will split at the microscopic but multi-molecule level. Using larger polymer molecules, products like Zaino will tend to break down too, but from the outside inwards. They will last longer before their lateral bonds spilt. Thus, they will tend to last longer. We can debate how long it takes and how much protection they afford. And even how good a shine is produced. But to label all polymers as 'plastics' and then declare that plastics are bad for a car finish is just nonsense.
    Point taken.
    Hi:
    #173 - Z2 on Z5 or Z5 on Z2?
    Although it was pat455 in post #165 that mentioned putting Z5 on Z2 I will take a stab at it if you wish.
    Swirl marks represent grooves or scratches in the finish. You can either wear them down with a polish, fill them in, or both. Z5 was developed to fill them in. Sal says the optical properties of Z5 are not as great as Z2 so he recommends always finishing with Z2. Since they are compatible you can mix back and forth from one to the other without problem until you achieve the finish you desire but should finish with Z2 to assure maximum reflectivity.
    Your goal is to have the surface as flat and glossy as possible with no defects above the surface (dirt, embedded rail dust, etc. which could be removed by washing, claying, and polishing) or below the surface (spider webbing, scratches, swirl marks, etc. which must be polished or filled). The fewer the surface defects the greater the directed reflection of light (and the less the scatter of light) so your finish more closely resembles a mirror.
    Hope this helps.
  • brendafrankbrendafrank Member Posts: 1
    Does anyone know anything about TST 5000, a teflon-based paint protector? My father had his car done ten years ago, and swears that he never has waxed it, it still looks very shiny, and water beads up on it like a new wax job. He also says dirt washes off with the rain. Trouble is, he now has bought a new car, and the dealer wants $500 for an an application of the stuff. Sounds really expensive. I also know that another paint protection company is offering product to the wholesale market that they say costs $5.00 per car, and can be sold for $100 (including the labor of 1.5 hours to put it on. So -- is my Dad being ripped off, or is this worthwhile?
  • newwestdnewwestd Member Posts: 157
    I just discovered this site - It is refreshing to see that there are other car care maniacs like me around (If I have been out in the rain, I wash my car in the rain before putting it in the garage, and then dry it so it won't spot). I am really tempted to try the Zaino stuff after all the raves, but I have an entire shelf full of other "miracle waxes" I've tried over the years, and can't help being skeptical. I have a new Solara with a beautiful Pearl White metallic paint job that has responded well to Eagle One glaze and Wax Shop Carnuba wax. Perhaps in a couple of months we'll see what the Z stuff can do!
    By the way, a really good cleaner for VERY oxidized paint is Soft Scrub liquid cleanser without the bleach. Do a small part at a time with a wet sponge, and rinse really well. It has amazingly restored really bad paint. Then a cleaner-wax afterwards.
    I also have used Lemon Pledge on car interiors for many many years with great results. It gives a nice shine to wood, plastic, vinyl, leather and chrome. Lexol 2-3 x per year. I will try Vinlylex and let you know how it works.
    Thanks for all the great posts - I'll be watching for further enlightenment!
  • ssonnetssonnet Member Posts: 27
    The interior glass on the front and especially the rear windshield has a hazing problem. I can wash the interiors with Windex, or simply wipe the haze off, but it will reappear a few days later. It is especially irritating in the sun,obstructing my visibility.
    Does anyone know what causes this and any ways to stop it?
  • kewldudekewldude Member Posts: 20
    One thing that I find very cheesy about the Zaino web site is that they don't accept credit cards! I'd try it if they did. Come on Sal! It can't be that expensive to set your self up to accept CC's.
    It's too much of a pain in the [non-permissible content removed] to print that form out, write a check, and mail it in plus if for some reason they screwed me by saying "it must have got lost in the mail" I'd have no way to re-coup the loss.
    That haze is often reffered to as "vinyl fog" and is caused by gasses given off by the plastics in your interior. I have been cleaning it off my windows about once a week. I use Eagle one 50/50 window cleaner with a pint of iso-alcohol added to it. This seams to work well, but usually leaves a few streaks no matter how careful I am.
    There is a foam window cleaner out there, but I don't know the name of it. It is supposed to work well.
    The film is inevitable, so just use a good alcohol based window cleaner as frequently as you can stand.
    Hi:
    For windows I like the Eagle One 20/20 glass cleaner too. I don't add extra alcohol though. Regular Windex just isn't strong enough for the oily film inside a car window.
    If the Eagle One fails, I have had success with The Wax Shop's Oily Film Remover and Window Cleaner. I purchase mine locally but it can also be purchased from the Wax Depot at www.waxdepot.com.
  • anne4anne4 Member Posts: 35
    To avoid hazing, don't use window cleaners that contain ammonia. One brand that seems to work pretty well is Sprayways. Do a final wipe down with wadded up newspaper. For some reason the newspaper ink takes care of streaks. Also, Zaino's glass cleaner works very well, especially if there is a build-up of dirt, vinyl outgasses, etc.
    The haze that has accummulated on your interior windows is the result of "curring" (aging, drying out, etc.) of plastic interior parts. It happens in all cars and is easily seen in brand new cars. There are a number of products which will remove this haze layer and some were mentioned in the above posts. The best stuff I've found is Zaino's Glass Polish. OK, I'm a Zaino fan, but wow, I applied it and then wiped it off. And the haze was gone. I also use Zaino's Z6 as an every day glass cleaner. But real Glass Polish has a very light amount of glass abrasive which cuts through the plastic related haze like a knife through butter.
    FYI - The technical term is "outgassing", the vapors that the plastics, vinyl and other materials give off as they age. Fortunately, it is worst when the car is new, and will ease up as the car get a little older. It is tough to get off!
    A good window cleaner, especially for water spots, and even paint overspray is chrome polish. It is slightly abrasive and takes all the crud right off. I makes a white haze that easily wipes off (remember "Glass Wax"?) My grandparents also have always used newpaper, I am not sure if it is the ink or the rough paper, but it works great!
    Thank you all for the cleaning tips. I was hoping there was a product I could use on the windows which would not require me to clean them weekly. Sounds like there is no panacea for weekly cleaning.
    ann4 - The product I was using does contain ammonia. Why is this bad?
    newwestd - Is chrome polish the equivalent of glass polish at a cheaper price?
    To all-
    Maybe someone can invent an INSIDE windshield wiper and washer! LOL.......
    I ONLY wash the windows on my 300M when I can't see anymore! ;-)) With Chrysler's "cab forward" design, you have to be a contortionist to clean the front windshield.
    fastdriver
  • jwolffjwolff Member Posts: 19
    German car owners-- Avoid any silicon or polymer based waxes as they will cloud the paint. The best combo is PS 21 paint gloss pre wax cleaner (glaze) and the follow with One Grand Blitz carnuba wax. Great combo. I am going to try Surluster on my 911 to see if its hype or fact.
    WRONG! Zaino will NOT hurt the clearcoat on BMWs, etc. In the past, several "natural" polymers contained impurities which resulted in yellowing due to residue buildup. But Zaino is in a different category, synthetically produced, and will not cloud the paint.
  • I used Zaino on a 1999 BMW 323. The color was Titanium Silver, and it looked great. No clouding.
  • huantshuants Member Posts: 6
    Can someone show me where I can purchase the necessary material to clay my cars. I was told to clay first then polish. I went to local auto parts store and could find anything like that. And if possible please tell me how to clay. Thanks.
    haunts-
    Try this site for the clay material- http://www.erazer.com/toc.htm and this site for the tips-
    http://www.geocities.com/MotorCity/Flats/6021/zainofaq.html
    fastdriver
    Seems to be! Also - Mother's makes a glass cleaner that is ALSO a chrome polish!
    I honestly don't know why ammonia causes streaks, but it does consistently. I used to try cleaning the inside of my windshield with Windex, then be totally torqued off by all the streaks it left. Sometimes it looked worse than before i cleaned it! Finally went to a ammonia-less cleaner (Sprayways), which doesn't leave streaks most of the time. If it does leave a few streaks, newspaper will take care of them.
    Thank you very much for the quickest info.
    You know, it is interesting/surprise that three local auto parts stores have no clay material/kit nor do they know what clay is.
    Thank you again.
    I have always used a chamois to dry my car. I did this for years. It was actually much more work to dry the car than to wash it. After reading advise I found here, I used bath towels yesterday. Man! What a difference. I dried it off in a few minutes. It is probably easier on the finish, too.
    I am interested/curious about the drying tip you mentioned above. I went back 40 posts and could find it. Would you show me. Thank you.
  • tp4unctp4unc Member Posts: 437
  • bogey9bogey9 Member Posts: 1
    Huants:
    I'm in the St. Louis area so I don't know if you have these stores where you are. We have Grandpa Pigeon (discount store) that carry Mother's clay. It was about $11.00. I haven't check Wal-Mart, but give that place a try.
  • charlesfcharlesf Member Posts: 28
    What is the correct way to pronounce "Zaino"?
  • GischpelGischpel Member Posts: 133
    I assume it is Zay-no.
    Speaking of Zaino, I just clayed my father's new Town & Country LX (Clay Magic - Blue) and then gave it a coat of Z1 and Z2 followed by a Z6 wipedown. Since then, the neighbors have been stopping every time we are out in the driveway to comment on the shine. He, too, was pretty surprised by the end result over his previously used products. Needless to say, his order for his own Z-products will be forthcoming.
    Happy Labor Day to those in the U.S.
    Terry
    OK - Is anyone willing to do a patch test - say one part of a fender with one wax, and another part with Zaino for a one-on-one comparison?
    Check out 127.
  • doickledoickle Member Posts: 12
    You fellows may love your Zaino but it's Nu Finish for me. I've got a dulley pickup so I'm using Nu Finish, get the job done ASAP and don't worry about it again for six months. I'm not married to the pickup and don't want to spend a whole weekend
    polishing it, have better things to do with my time. Bet some of you fellows even carry a cover for your little cars so they dont even get dusty when you park them.
    I have a 79 VW camper van and a 99 Honda Odyssey. I'd already Zaino-d the Honda and liked the results a lot. When getting ready to sell the VW, I decided to be a cheapskate and just try Nufinish on it instead of Zaino. I did one of the side door panels first. After the application and removal, I could see NO DIFFERENCE in appearance between the Nufinished panel and the adjacent panel that hadn't been waxed yet. Both looked dull. The panel that had been treated with Nufinished made water bead up better, but it still didn't look good. I then Zainoed the previously untreated panel, and it looked much shinier than the Nufinished panel. Just one person's experience.
    Thank both of you for your quick response.
  • jonahdark1jonahdark1 Member Posts: 6
    Has anyone here used Liqui-Tech? I was cruzing the web and I found their website. (www.liquitech.com). Any comparisons to Zaino? Response would be appreciated. Thanks
    I also like the idea of using a bath towel. Someone recommended driving a quick mile after washing and rinsing to dry most of the car. Wrong! Actually it depends on where you live and or wash the car. I did it just to see the result. And my result was dusty little water spots. Even with Zaino car wash. Its just in the atmosphere. So I rinsed again and dried with a towel.
    On the Nu-Finish vs Zaino subject, since both products are polymer based they'll probably have a similiar wearing ability. I put a coat of Zaino on my car on July 4th, and it has lasted all this time. This weekend I put another coat of Z2 on the car and it increased the shine, etc. But even before, my previous coat of Z2 was still beading water in a beautiful fashion. That's after 2 months without a wash due to this drought. From my experience, Zaino really lasts a long time.
    Hi:
    The website is www.liqui-tech.com.
    They market Finish First which is a polymer product or sealant. I have used it and do not find the durability problems that others have posted about.
    They have a pre-cleaner that removes surface wax and grease. This step is similar to the Dawn wash used by the Zaino users. It contains physical abrasives.
    After prepping you apply a light blue liquid, let it cure, and wipe off the haze. I prefer to let it sit overnight in the garage prior to removing. Let it cure for 24 hours and you can add another coat to build upon the first.
    Do not let it dry on the trim or you will have a white splotch (not unlike carnauba wax). I have ordered from Liqui-Tech and they delivered as promised.
    Don't forget that you can use this (like many other waxes and sealants) on your wheels to make cleaning easier.
  • ruskiruski Member Posts: 1,566
    why do you think that it takes a long time to apply Zaino? I think you should read all the previous posts about Zaino first, before you make statements like that.
    AND Zaino lasts a long time too, probably just as long as NuFinish, if not longer.
