I would suggest that you consider NOT using the Castrol Syntec 5W50. The "5W" means that this oil quite thin at startup (especially being a quasi-synthetic oil) The "50" means that it may be too thick to properly lubricate some parts of the engine properly. (look at the oil-specs for this engine!)
I would recommend the opposite. When you add a visocity index improver such as STP or equivalent, it "improves" the viscosity over the whole temperature range -- and you do not know what is the viscosity of the resulting oil mixture. In many cases it can be thicker than the 5w50 you are not recommending!!!
At least using, 5w50, you know it has the 5-weight properties during startup
"How long do you want to hold on to this vehicle?"
More specifically, a viscosity improver also contains a lot of extra detergents. These 2 items combined do two things for an engine in this conditon.
1) Reduce bleed-off of oil from the hydrolic adjusters during non-running. (quieter startups)
2) Removes gunk from inside the hydrolic adjusters which allows them to work better.
In the case of the Golf I was discussing, after a SINGLE treatment with STP oil treatment, the engine exibited quieter startups over the next several oil changes (NO STP IN THE OIL!)
In other words.
*)Cheep quick fix... pour somthing in the oil.
*)Proper fix... remove head and rework it.
Personally, a $1500 head job was not the right decesion when the vehicle only needs to last another year or so.
1) Tells you when coolant is low in the resivour bottle.
2) Tells you when engine is overheating
I suspect that #2 above is not the case so I will talk about #1.
There is an electrical plug on the side of the resivour bottle. Those 2 connections are connected to 2 prongs which dip into the antifreeze. If the antifreexe does not touch the 2 prongs, it will light the "engine coolant light".
A common issue is that the antifreeze is just a bit too low which causes the "engine coolant light" to come on. To fix this, add up to a 1/2 cup of distilled water to the resivour bottle. The coolant should be at least to the center "seam" of the bottle when stone cold.
Please let us know if that does not help the problem.
As for the door, there is a magnetic sensor in the door that may need to be replaced. This is not an uncommon failure.
Thanks- Pat
Low coolant light
New Coolant resevoir $130
New Coolant temp sensor $250
Drivers side door not recognized as open
New door control module $320
Please help - I know nothing about cars.
It is unlikely that your reseviour bottle is bad unless it is leakling. I am not sure what sensor they are thinking of (the sensor is IN the resivour bottle and is part of the bottle.)
I suppose they *may* be refering to the overtemp sensor that screws into the engine. Is your temperture gauge working OK?
I sounds to me as if they are just "shotgunning" the problem at your expense.
shotgunning = replace lots of stuff in the hopes of fixing a problem because they dont have a clue.
Any advice?
I'll probably try the DMV consumer protection dept.
i have roadside coming to get me.
RedJetta
If the coil has any cracks, replace it (or have it replaced). Once water or any moisture gets into any crack on the ignition coil, it will stop your engine dead in its tracks.
Once your Jetta is out of warranty, run as fast as you can out of the dealership and find a good, independent VW mechanic. That's what I plan to do once my 2003 1.8T Jetta's warranty expires. I know 3 good VW mechanics in my area (that I've dealt with at least 10 years or more)...
Unfortunately, mine only occurs when the temperature is below freezing, and I know if I bring it to the dealer they will tell me those infamous words - "We can't seem to replicate the problem."
From what I have read it is most always caused by the reservoir tank itself - not the probes or the sensor. If not under warranty, you can probably pick up a new reservoir for under $30 and replace it yourself. I read a DIY on vwvortex that describes this process.
I'm still under warranty, so I'll probably drop it off one night after I receive notification of the latest recall which none of the local dealers want to confirm - Faulty Hazard light switch replacement.
Good luck!
When the antifreeze level is right on the cusp of being too low, it contracts when it is cold and uncovers the probes in the resevour tank. This makes the light come on. After the antifreeze warms up, it expands and touches the probes causing the light will go out.
To correct this issue, simply add some G12 antifreeze (or distilled water) to the resivour.
Like with all machines, this and all other issues can be easilly corrected when the underlying root cause is realized. I make a living troubleshooting and fixing complex systems. An automobile is far simpler than the systems I usually work on.
The problem doil is talking about does not match the "only when cold" failure signiture and most likely has some other root cause.
The resivour tank is just a plastic bottle, it cannot POSSIBLY cause any issues with the indicator. However, the electric connector or probes that are molded into the tank have some known possible problems. (All of which can be easilly isolated with an ohmmeter and basic troubleshooting skills.)
Find a mechanic with some troubleshooting skills! Not one that just hooks your car up to a diagnostic computer and blindly pushes the buttons. Remember, their job is to SELL PARTS... not necessarrly to fix your car.
As an engineer, That's my favorite example of using a simple test to solve a complex problem...:-)
The piston needs to rotate as well as push. You can get one from Metalnerds for ~ $40.
The oem recommended special tool is the best, but there are much cheaper ones at you local auto parts store (10-12). Ask for a rear brake caliper windback tool. Here is a more expensive visual
http://www.thetoolwarehouse.net/shop/AP-7860.html
http://www.lislecorp.com/tool_detail.cfm?detail=399
1. what years will interchange with mine
2. what is the biggest motor that will go into the 89 jetta.
3. where is the best place to find performance parts for the 89 jetta
I own a 2000 VW Jetta, 4 cylinder, manual transmission. Recently the temperature sensor
(Coolant light?) has been going on only when first started cold. Now, today, the check engine light in on and is staying on.
In response to the above post, could the antifreeze level be an issue? If so, would low levels of antifreeze eventually effect the check engine sensor?
Thanks in advance for your time!
Kashi
It is if the caliper slides aren't free and well lubricated with silicone grease or brake lube.
I have a 2001 model jetta, and a 2000 little girl...
Does any one know how to take apart the passenger side air vent, she pushed one of the air horizontal bars and snapped it out of place, I took it to the dealer to have it fixed, but the dealer wants to replace the whole unit $90 worth...
I can see the bar is not broken on either side but I cannot take it out.
Thanks...
To fix it, you may add up to a cup of distilled water. If it needs more than that, use ONLY G12 antifreeze. No other antifreeze is acceptable.
For the CEL (Check Engine Light), it could be almost anything. Many auto parts stores will "pull the code" for free and tell you what code has made the CEL come on.
Once you know what code made the light come on, post it here an we may be able help out.
The trick is that it is designed (German enginering) to snap TOGETHER and is not very easy to take apart. One trick is to make sure it is WARM so soften it up a bit so it is more flexable.
Running the heater on high for 20 minutes should warm it up nicely. Then carefully pry it out. If you can identify where the snaps are, you should concentrate on them. (I beleive 2 on top and 2 on bottom) I would start on the bottom so if I mar the plastic, it will be less obvious.
If you break it, or cannot fix it once it is removed. Any salvage yard will have a large supply of VWs with vents you can procure for cheep.
When I go to a salvage yard, I often have a list of items I am looking for. I take my own tools and ask them where the VWs are. Once I locate the row of VWs, I select the best parts and fill a bag with them. Once back to the front desk of the salvage yard with my bag of parts, the cost is always VERY reasonable. (like $10 for a bag full of stuff.)
My current list (Still waiting for the the snow to melt by June ;-) includes a latch for the center-console for my daughters VW and some other various items. (headlight bulbs are a good item to grab too)
You could ask the AutoZone guy to show you what the O2 sensor for your car looks like.
The exhaust manifold on a VW is on the firewall side of the engine. This makes access to the O2 sensor more difficult.
Asian vehicles, on the other hand, usually have the exhaust twards the FRONT of the vehicle and the O2 sensor is sticking up right in front of you when you open the hood. (between the engine and the radiator)
Consider yourself lucky that you have ony ONE O2 sensor... my Dodge truck with the semi-Hemi V8 has 4 O2 sensors and 3 catalytic converters.
