Visitor Agreement.
It has houdini's vertical rear window though.....that's what helped to ruined it.
But, the wagon looks pretty nice;
I thought this was the 4 door version but then I see on the link it is an amc Cavalier...this would have made a nice 4 door version:
Polarized roof panel and light bar sound really nice.
http://s.hswstatic.com/gif/1960s-studebaker-concept-cars-1.jpg.jpg
When GM did its sliding-roof Envoy some time back, they actually requested Wagonaire blueprints from the Studebaker National Museum archives. I thought that was interesting.
You could get those Studebaker 'sliders' with supercharger, disc brakes, 4-speed, Twin Traction (think Positraction), bucket seats, in-dash tach, and other performance stuff.
BTW, mentioned earlier, but here's an Avanti production order showing the "Silent Muffler" option, LOL:
http://billstudepage.homestead.com/files/pjavantipo.jpg
Anyway almost 10 years old and I still love to drive it!
Happy Monday!
However, for me, the pre '12 or is it ('13 when they improved?) C-class interiors didn't do anything for me.
Something I've done is leave the lights on while I'm waiting for someone for the ten minutes or so. Then listen to whether the cranking strength of the starter sounds weaker or slower. Most batteries I've had died during the summer. Another technique is to measure the amperage supply at Walmart or another big box store. That measures the reserve ability of the plates in the battery which is what I was doing by leaving the lights on to drain the battery slightly.
Now I have to treat batteries like I do tires: getting that last 10% of life out of them can be problematic. A high percentage of punctures occur in the last 10% or so of life. Replacing tires at about 75% worn saves hydroplanning on water or worse here on slush at the wrong time due to shallow tread grooves. The only way I'd wear tires lower is if I'm selling the car and the low tread won't hurt the value.
A second question is whether it can be replaced by just anyone or does it have to be replaced by a place with the right software tools to reset the charge and drain software?
I changed the battery in that car 4 times - 14-18 months is all I ever got out of a battery. I was using Interstate Batteries as replacement - one of the best on the market at the time. In the summers, the desert floor would hit 110-114 degrees F. We had hot temps from April through November, but June, July, August and September were the worst months. Invariably these batteries would go bad during the summer months. I would get in the car, turn the ignition key, and nothing - not even a dome light would work.
Tires didn't last very long either with those hot asphalt roads with sand all over the place.
Did I mind having to change tires and batteries frequently - of course - but if I wanted to continue living in the desert I had to "go with the flow" so to speak. It "was what it was!"
I like those 2008 C350s, and an old Mercedes always drives well.....and is enjoyable to drive.
I got a warning that the battery power in my key is low...replace battery. That warning gives you time, but a dead battery just when you need it isn't nice...for the cost, better to do it while you can.
one problem is that sometimes it is not a gradual fade out that gets you (so you get warning). Rather, something just lets go internally (I guess a cell failing) and you go from good to dead like flipping a switch. No real way to predict that.
I always get concerned about the wheels getting scraped like they did on one of my E400's - but those wheels stuck out more than the wheels I have on this car. I just have to find a guy who comes to your house to wash the car and do the interior - but they have to do it in the guest parking lot - not allowed to wash your car in our parking lot in front of the building.
2012 was also the year for the C-class interior upgrade, with a dash style similar to the E.
Re: batteries - My E55 was 11 years old when I sold it, still on its original battery. The fintail, which has a generator rather than alternator, seems to average about 7 years on a battery - the last one was still OK at 7 years old, but lots of cranking due to a failed cold start solenoid pushed it over the edge. Current battery is from 2014 and cranks like new.
Now my story: (@driver100, this may be beyond your patience for post reading so now is a good time to scroll)
After work one day, in the summer of 2011, Mrs. j's 2005 XG350 (yes, the one that blew an engine) would not start (no sounds at all). She calls me at work and I tell her to call AAA. The guy runs a test and says, "you have a bad cell (more about this later. I'm telling you @driver100 now is the time to scroll, don't say I didn't warn you). I can sell you a battery if you want". Mrs. j calls me about this pitch and I told her to get it jumped and drive directly home. Don't go shopping.
When I get home the car is in the driveway. I get in and expect nothing. Wrong, the car starts right up, no problem whatsoever. I go to Advance Auto Parts and the guy runs a test and says, "there is nothing wrong with this battery but it is getting a little old". FWIW his printout is the same as the guy's from AAA. Same format exactly and I show it to the guy at Advance. All he can say is his test says the battery in not bad. Which is what I expected him to say.
I now go to Autozone for another test hoping they have a different tester and they do. The Autozone test also says my battery is good. Now what do I do?. I went home and cleaned the battery terminals although they were not corroded in the least.
Fast forward about 2 weeks and the same thing happens to Mrs. j's car. She again gets it jumped and goes directly home, no shopping. When I get home, again it starts right up but now I'm a little smarter. I go to Advance and buy a new battery and I bought their best one. It had a 6 year warranty with a full replacement for the first 3 years then pro-rated after that. A lot of good that did me, the car blew up in November of 2011. :@
Now about the dead cell thingy: (this is for everybody except @driver100 because he is long gone by now).
It is IMPOSSIBLE to do a terminal to terminal test of a battery and say, "a cell is bad". If a battery tests bad with a terminal to terminal test, all the tester can truthfully say is the battery is bad. It cannot say a cell is bad because batteries today do not have the individual cell connecting straps accessible to check each cell individually. I guess the battery tester feels it has to say something so it says, "bad cell", when in truth, ALL of the cells are probably degrading due to age. Batteries for many years now have sealed tops with only the positive and negative terminals accessible. I'll bet @Mr_Shiftright, @imidazol97, @isellhondas and some other old coots in here, remember the old style heavy lead individual cell connecting straps that were visible on the tops of batteries many years ago.
So, where am I going with all of this? Just what @isellhondas said. When batteries get up in years maybe around 6 years old, and this is just a little experience talking here, they should be replaced before they fail at the worst possible time.
Just an interesting comment, I don't why the newer batteries don't seem to give a warning like the old batteries did when they got old but mine have not. Mine just QUIT. I even loaded down a battery like @imidazol97 suggested and that still has not helped me.
Like I said, a battery test is not foolproof and I learned that the hard way.
I tried to keep this post short. Didn't use big words, kept to the point (could have gotten deeper about this), but even I can only do so much.
EDIT: As I was typing this post, Mrs. j wanted me to do something and when I got back to the keyboard I just continued with my post. I didn't look at all the subsequent posts that pretty much I agree with what I just said. Nice to know misery loves company. Should have known we are all peas in the same pod.
Sorry for the disappointing finish. Now look at my EDIT, that makes it even worser
Each cell produces 2.1 v. So if one cell shorts, the voltage drops from 12.6 nominal voltage to 10.5 e.g.. A single cell can short via sulfation which is bridging of the two types of plates by a whisker or crystal of material built up as the battery recharges. That whisker can break and the cell act perfectly normal again. However, the sulfation results in a 10.5 volt battery minus any drop in voltage from the other 5 cells due to age or undercharge. It should not give a totally dead battery. The interior light should glow for example. But some computers won't operate below a certain voltage so the control that allows the starter motor relay to operate may not work because the battery voltage is low. Hence no sounds. But there should be some things that operate.
You like to talk to your car, ask it if that is true or an unban legend. Better listen to what it says.
Reminded me of a battle I'm facing right now. I just purchased, about 2 weeks ago, a used 2016 Chrysler Town and Country. And I only received one key. So I do some reading in various places, the dealer wants about $300 for a new key with programming. So I look on yelp for "auto locksmith". One wants $260, another one won't give me a quote until he comes out to my house for $20 service charge, and the third one never returns my call.
Next step, look on ebay and amazon. Keys (complete programmable key fob) costs $10 out of China, or about $40 from here in the USA, reputable seller, with 99% + favorable feedback. Back to the forums, more reading, one person says they bought a key on Ebay, the dealer programmed it for $50. Another person with same experience, dealer charged him $75.
Good enough, I order the key, comes in, looks good, start calling dealerships. The 3 closest Mopar dealers all want exactly the same amount, $165. I'm assuming the book shows one hour, and they are all charging $165 per flat rate hour.
I would expect that it takes about 60 seconds to program the key, and maybe 5 minutes total by the time you get out the "tool" and set it up.
In order to get 12 volts, the 6 cells have to be connected in series. And the internal connectors seem to be what fails. Going back a number of years, the chemicals in the battery would go bad or wear out or "get sulfated" or whatever. But these days, batteries die when the internal connectors between cells give out. Which is why they tend to die suddenly, without giving any warning.
At least that's what I have read. Don't we have any electrical engineers in here who can give us the skinny? Or is it all lawyers and retired judges and CPA's and book sellers and car salesmen?
When I went to Virginia to get my '15 Genny, one of the first things the dealer said when I got there is, "I hope you brought your second set of keys, otherwise your trade is worth $350 less (they had already given me a price over the phone for my '09). If you have them at home and mail them to us we will send you a check for $350".
Fortunately I had them so I didn't have to go through that.
