Visitor Agreement.
Strangely for me, having looked at the pics, I like what I see. It appears to be nicely done.
Putting the inside unit on my '72 Duster was the EASY part!
And thanks, shifty, for the reality check.
http://www.ebay.com/itm/272605505601?ul_noapp=true
http://www.ebay.com/itm/1968-Pontiac-CUSTOM-/222452719315?_trksid=p2141725.m3641.l6368
The yellow one, aside from needing a new trunk seal - which is no money at all, makes me wonder why they didn't install one - and the messed up rear lights, is actually not bad if you removed all the GTO and Judge decals. Hopefully they are just stuck on and not clearcoated over. And when I see a dash mat I wonder what evil lurks underneath. But most other interior pieces for one of these are easy to get.
wonderknow what evil lurks underneath."There, I fixed it!
So the inspector finally called. Well, not the inspector but a dude who looks over the report and gives an assessment. I did not look over the report yet but, in summation, he thinks it is rather poor and worth $5k-$7k. Ouch. Another one bites the dust.
Inspector called, is that the Blue one?
Not what you are looking for, but looks pretty good.
https://hartford.craigslist.org/cto/6062664998.html
Yes, that was the blue Lemans.
$35k is WAY over budget.
Just trying to show you what is out there and it seems like your limit is creeping up a bit.
Here is another Pontiac for sale local to me.
http://www.34motorco.com/ProdDetails.aspx?type=Classic Cars&id=123&pid=139
My limit hasn't necessarily increased. I've capped myself at $20k but don't want to go there if I don't have to. But for the right car...
It's also a matter of where the money goes. If I spend $20k, I'm not going to want to do much to it. If I spend $16k and need to add AC, PB, or what have you, that's OK.
Let's see if this works.
I also like the AMX, but I have always been a sucker for a nice AMC. Owned 2 back in the old days (a gremlin and a Hornet hatch. Both 6 cyl 3 speed sticks)
If you could find me a nice clean V8 Gremlin, that would be tempting!
http://www.34motorco.com/ProdDetails.aspx?type=Classic Cars&id=123&pid=138
A friend of mine bought a very nice, stock, repainted once but not-otherwise-restored, '63 Riviera a thousand miles away. He dealt with an inspector, who to me appeared to miss some pretty basic things. Took a ton of pics and included close-ups of each (radial) tire, but didn't bother to identify the age of the tires, which to me is important and easily-done online. I mean, come on! And this guy was the better of the two my friend had hired (another had looked at a different car, elsewhere). I bought a '64 Studebaker several years back online, and when it got here, I could see that the radial tires were 18 years old! Some people just shouldn't be in the car business, LOL.
So the inspector has to work efficiently. He isn't supposed to be an "authenticator" who date codes---for that you pay someone like Galen Govier, and lots more $$$.
What would you rather have the inspector do with the 2 hours he has? Take a 1/2 test drive or date code the tires and check for the correct part number on the water pump? Pick one, you can't have both.
Personally, I wouldn't drive a car with radials over ten years old. But then, I've always driven my cars.
Based on his experiences, I decided I would not buy a car using an inspector I don't know personally--which basically means my one particular buddy.
From my point of view, date-coding tires is not a good use of the inspector's time. You can put him to better use. Old nasty tires are pretty easy to spot. But sure, if a clients specifically asks to date code tires, I'll do it and charge accordingly.
Generally, though, for clients who want to get into that level of detail---date coding, pulling wheels, compression testing, etc--I refer them to either an authenticator (for the date coding) or a repair facility that can tear the car apart if that's what they want. These are more about mechanical inspections. What I do is pre-purchase, which only involved lots of photos, detailed notes and a good road test. I do however, check important things like engine #s and data plates, because so much of the car's value is tied to those items.
I like to work in complete isolation. I don't want anyone talking to me or distracting me. I've got a large agenda in an inspection, a lot of liability, and a limited amount of time.
Friends and club members can spend all day on a car. I can't. Gotta move along and work smart.
So far, I've only had satisfied clients. I try to look at each car as if I were personally going to spend the money on it.
Unfortunately, there's no such thing as an inspector's license. There are highly competent people doing it, and real rubes. A lot of inspection services are brokered and those are the hit or miss ones.
So that black tie was OK but not great. The brown GS was gone already. The green Cutlass was in the showroom. At first glance, it is a WOW car, but then the details are not there. Rust bubbles on the bottom of both doors and paint peeling off both rockers. Owner asked me what I thought of car and when I mentioned those things, he was pretty offended that I took exception to paint issues on a 45-yr-old car. Hmmmm...that rubbed me the wrong way to be sure.
Anyway, moving on, he had a pretty darned nice white over red Coronet with fresh 440 and AC. He offered it right off the bat for $25k. I probably would have bit but my son vetoed it. What my son did like was a blue and white Ford Victoria. I was very surprised by this choice. It was $18k and not too bad off. Paint was good, no rot to speak of, all chrome was very good. Flathead 8 was not pretty and leaking quite badly. I just couldn't see myself in it in the end.
I checked out the green Dart. What a nightmare. Someone actually hacked a hole in the hood under that massive hood scoop.
I also wound up in that place in Lakewood. That Challenger turned out to be super nice, but it was already sold. In their showroom, they had an absolutely gorgeous and freshly restored 442. It looked simply amazing. And at $32.9k, I think VERY reasonably priced. Possibly even a bargain. Out if my reach though.
on our way home, I called about the '74 black Dart. It just sold 2 days ago. I shed a tear.
http://www.ebay.com/itm/262909731406?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
Edit: ended at $16,400. Pretty cheap, I think.
Usually, if the bid is *close* to the reserve, BAT will kick in the difference---so the reserve must not be too realistic.
http://bringatrailer.com/listing/1971-dodge-charger/
http://www.gatewayclassiccars.com/milwaukee/1964/ford/galaxie-S36.html
I would have popped over (I literally am within walking distance) to kibitz, but sadly was up in NY all day for a funeral type activity. I would much rather have been looking at ratty "classics".
This looks pretty decent.
https://charlotte.craigslist.org/cto/6044764787.html
https://www.hemmings.com/classifieds/cars-for-sale/studebaker/unspecified/1744977.html
The color is my favorite aspect. I thought those things were supposed to be the mirrors. Huh. Big car not to be able to see what is around you.
A "little rust" is like a "little cancer". Rust never sleeps. There is a thing called "flash rust" but that is quickly eradicated with some sanding. There is no penetration of the metal.
I'm typically not a fan of these cars, but geez I like 'original' and this certainly looks the part:
https://www.hemmings.com/classifieds/dealer/plymouth/valiant/1925074.html?refer=blog#&gid=1&pid=1
I personally wouldn't pay the asking price, but what an interesting car.
