But who copied Bentley first? Was it Mini, or Genesis (of those two it was probably the Mini). I'm not going to even put the poor copy that Chrysler did in this discussion.
Bentley should sue "hyundai". Mercedes should sue for plagiarism on the back end and Aston Martin for the front end.
I've always said, "if you're going to copy, do it well".
It's like inventions. It's not who did it first...it's who improved on it the best.
Think Japanese car manufactures.
2024 Ram 1500 Longhorn, 2019 Jeep Wrangler Rubicon, 2019 Ford Mustang GT Premium, 2016 Kia Optima SX, 2000 Pontiac Trans Am WS6
It has the '90s era MACH stereo that was Ford's top unit at the time. Not going to blow today's in-car stereos away. But, I treated it to a new FM modulation unit which will stream from my iPhone my calls and tunes. Plugs right into the cigarette lighter (not a power port, but a real cigarette lighter). And, I always have the cassette deck and CD player to use. Yes, I still have some cassettes.
Doesn't sound bad!
How thick were his glasses?
Curb weight (lbs)
3,853
That's about previous generation S4 territory, and this is from the RWD unit; I'd imagine the AWD is at least 100 lbs more then that; actually; it's worse:
Curb weight (lbs)
4,005
At these weights you'll need the 400 HP and 350 lb/ft. of torque. The regular 3.0TT is actually a bit lighter; smaller brakes and tires is probably a chunk of that.
Also, did you Infinity fans say you hated the steering in certain versions? Is that the standard steering, or the optional higher priced (I'm guessing) optional "direct adaptive steering?" that you hated, and the other you liked?
If you want the minimum bell or whistle with your ride, you have to get the moonroof! 0.7" penalty front and rear for headroom.
http://www.nxtbook.com/nxtbooks/crain/an1441850607BCEKP_supp/index.php#/2
It would be easy to mistake that for a Bentley:
Also for the one I linked, Atlanta is probably the largest and richest nearby market aside from Miami, and also one not known for subtle refined taste.
Hertz and Thrifty to pay $1.25M fine following advertising probe
Competition Bureau said companies were promoting prices that were unattainable because of mandatory fees systematically added to a customer’s bill.
The law enforcement agency said Hertz and Dollar Thrifty were advertising prices that were unattainable because of mandatory fees that were systematically added to a customer’s bill.
The bureau said the additional fees could increase the final price by as much as 10 to 57 per cent. The agency also said some of the fees were described in a way that implied that they were mandatory taxes or surcharges imposed by various governments when they were not.
Last year Avis and Budget got caught and paid almost 3X as much.
Wonder if this goes on elsewhere?
I have had the impression that Canada is much better at ferreting this stuff out than is the USA. Watching "Holmes on Homes" talking about requirements for home building and repairing was enlightening as well.
There has been quite a few comments about GM and Cadillac during the time with the problems about the wiring harness loosening on the 4-cyl Turbo engine. I've watched as the temperature of the comments increased to how awful this is. The impression I have now is that there were 3 known cases of the heat affecting the mechanical fasteners and letting the bundle of wiring move, possibly touching the CV axle.
It appears that this was being checked for using a silent recall technique, allegedly widely used by some foreign car makers in the 80s and 90s because it keeps the information, negative, out of the news cycle, and helps keep the public impression of the reliability higher than deserved.
The end fix for this, after what I assume to have been engineering looking at the cable design, was a change in the exhaust system location or sheathing. At first a reattachment technique was used for the cable bundles, which failed gloriously on GG's leaving the dealership. Second, the exhaust system was changed. All this redesign takes time. But Cadillac should not have made the time the problem it was for GG with his car sitting, unusable, in the shop.
For those that are critical of the time this takes, just recall the Monday morning quarterbacking on how the ignition switch spring pressure change occured for the ignition switch used in several of GM's vehicles, most notably the Cobalt. If GM rushed the change on the cable bundles without the proper signoffs and there was a problem, I'm sure the Monday guys would be kvetching about how they should have taken time. But they should have just traded or refunded GG out of the vehicle. Much like Honda was rumored to have done in 2003 or around that date, with vehicles that were exhibiting popping noises on body flexing.
I compared the commenting on this problem with the lack of interest in a vehicle with Shraeder valves that were leaking from the factory. AC systems are essentially transferable between car models so this was not a system with unique valves: the system could have been put on most of VW's models with changes only in capacity of the pump and other parts. Add to that the news still that VW's various models, and MB's as well, may not be meeting pollution requirements, intentionally or unintentionally. The diesel cheating was met with lukewarm indignation by many. Since VW was able to give back cash for fumes to make owners feel better about having polluters, that seemed to salve many minds. But that money was from the high profits some car makers have gleaned from the buyers of their products. GM has been saddled with higher US build costs in the UAW settlement from 2008-9.
Same comments about the sludging and the runaway acceleration of that other brand. The money was profits.
Agree or disagree on the Cadillac problem, I would not worry about buying a CTS with 4-cyl turbo today. I have yet to see a CTS, ATS, XTS on a flatbed being taken in for work. I have seen many other brands on flatbeds or being towed. My problem is the handling by Cadillac to make this not the consumers financial and time load. They didn't do that. Luckily GG had a second vehicle and bought a third which sounds like a joy to drive. But Cadillac did give a loaner(s) during that time. At the 3rd week, the Cadillac rep, who had talked so positively early on about a trade or buyback, should have said something to the effect "Here's our offer to end this for you, Mr. Guy." Perhaps putting the Nissan CEO in charge of Cadillac wasn't the best solution and perhaps keeping the headquarters in the down-to-earth Midwest in Detroit would have been a better solution that moving it to New York.
Lets put a positive spin on this.
It looks like Hertz and Thrifty having to pay only a $1.25M fine shows that they learned something from what happened to Avis and Budget, right.
For the rental car subject, I think it happens in Murka too. I've seen screamer ads for $9.99/day rentals - after taxes and fees, you aren't paying anything near that, although I think those are all government-mandated fees and not ones a corporation is pretending are from someone else. That's one thing I like about shopping in Europe - taxes are figured into the price. Pick something off the shelf or menu, and the price you see at choosing is the price you pay when the bill is due. Seems kind of deceptive to do it the other way.
Haven't seen any credible data about MB cheating emissions regulations, either. I have to imagine if it was true, a well-compensated and egoistic regulator would have announced it by now - that kind of thing is their meal ticket.
With VW owning Bentley, and BMW owning Rolls-Royce and Mini, maybe the winged Mini badge is just a way to show how things have changed in this new world.
This is all after the fact musings, but just to add, I do business with GM Corporate in Warren, MI. I told one of the people I work with there (Director level) in their Technology depts about my Cadillac woes several weeks ago. He said if the arbitration hearing did not come out positively, he'd be able to help cut through the red tape internally to replace (not refund) my car.
He did some digging on his own for me. You're right about wiring harness not being properly "bound" causing the chafing with the half shaft, resulting in arcing and the burning of a limited area in the engine bay. They first tried to just replace the fasteners with new wiring. As you pointed out, that failed. Then, they ran a re-route (actually computer designed in Warren Tech area) of the wiring. That meant new and different wiring, fasteners and associated parts. It also meant they had to pull the drivetrain to re-route and reinstall the wiring and the parts, which included replacing the entire exhaust system. My understanding, that's what took the longest.
If that was explained to me, and I was offered a resonable and timely solution, this might have gone differently. But, where Cadillac failed, they kept me mostly in the dark, and were at different times, appologetic one week and then arrogant the next. The times I contacted the dealership for an update, all I got was "we don't have the parts and the engine is out of your car and undriveable". Only when the arbitration date was closing in did they do their botch job, with the exhaust system installed hastily and incorrectly (I didn't even take it back for that faux pas).
It's difficult for me to accept that only 3 cars were affected. I have no way of proving or disproving this. And, Cadillac certainly had plenty of reasons to state it was only 3 cars. Maybe it was. But, I'm thinking maybe it was only 3 cars affected in the Cincinnati region. Nationally? Who knows? I'm not motivated to dig into it any more, though.
The other question...why did the other two CTS's in my area only take a couple of weeks to fix, where mine took months?
No matter.....it was very aggravating....and at times stressful. I knew I was right, so that kept me pressing on. But, if it weren't for you guys encouraging me to fight the good fight, I might have taken it to Carfax and let them write me a check. I figured I would have lost at least $20,000 going that route, probably more. In the end, it cost Cadillac a customer, a refund of what I consider well over what they sold it to the dealership for, and an extra few thousand for all my time and energy expended to fight them.
Not a good business decision on their part.
https://tampa.craigslist.org/hdo/cto/6083537215.html
This is so quirky and they made so few of them that this might be collectable in another 40 years.
I have plenty of other cards so I don't need this one. I was thinking of just calling the bank to close it out. But it has a credit limit of $15K. I read somewhere that the credit rating agencies don't like to see your credit capacity decrease and will drop your rating score if they see cards being cancelled. Any insights?
But, if no fee, does not really matter if you keep it. I have a few of those I never bother with.
2013 LX 570 2016 LS 460
https://en.wikipedia.org/wiki/Corinthian_leather
After a review they told me they wouldn't take on my case because it could cost them $million and it wasn't worth it, they actually said if it was beer or an oil company then it would be worth it for them to get involved.
Our competition bureau is pretty toothless. In the US if a supplier sells a customer goods, they can't cut them off because another company request it. That is only fair. If Sony sells TV sets to Smith TV store, then Best Buy should not be able to say to Sony you better stop selling to those guys.
I think when all this happened Cadillac could have offered another car.......fixed GGs and sold it. If the car came from the factory and there was no dealer or commissions it wouldn't have been a big loss.
Makes no sense from a business standpoint. GG may even have bought another Caddie one day.
