Visitor Agreement.
The oils available in 1969-1978 were absolute crap compared to today's brews. I estimate I changed the oil 84-90 times in 250k. With the new TDI engine at 550k, I am on target to change it 37 times!!! For the same mileage 250k, I am on target to change it 17 times. Needless to say I have less waste stream.
Have they gotten that coil pack problem solved ??
Bosch is hurting lots of owners like you....
Go gettum !!!
Best Regards,
Shipo
I have to change 2 rubber bands at 100k and recalibrate!
MAF's are a known problem area but fed emissions law is good for 100k or 10 years.
Nowadays with modern precision machinery you'd best be careful what you put into an engine, transmission or a fuel tank.
My e-mail is:
mr_shiftright@edmunds.com
Please continue your talk. I'll take care of any "problems" with the board! Thanks for your support and cooperation.
Shifty the Host
on the MMO....I have been using it for years...but do not know if it is actually working, or just extra stuff to burn ? I like it and still am working on another bottle ... :-)
maybe it is just their proprietary blend of petroleum distillates...
I used to work for an independent petroleum consultant co.....and we tested all sorts of gas and gas products....
did you know that we import a light yellow colored gas with 50 octane from China ? And all the gas companies would blend it with toluene and benzene and others to bring up the octane. They all had their own type iof injector cleaner.....and all the gas companies do transfer gasoline between their refineries....and the injector cleaners are added at the last step before delivery to end consumers.....
so it may be possible that MMO is useful , as much as any other companies' product....
BTW, all gas is traded between gas companies, and each batch is different, like any other mass produced but heterogenous product....
IMO, the engines can take a lot, as long as the residues, octane numbers, and other parameters are close.....
lets give the prize to armtdm .. 1 dozen Krispy Kreme ..... :-)
OK, so lets use it ...the term...CPB
Not a new planet but it will do at my age.
I plan on using it in a high mileage jeep (215k miles!). I've always used synthetic oils, but I'm hoping not to 'find' the leaks in this engine...... we'll see.
Maybe the oil is cleaning up some black gunk in your engine, and it is suspended in the oil. Also what is the temp? Oil can look honey colered when hot, but near black when cold.
Jon
If you go with the other so called synthetics you get a good product but will not be able to go to extended drains (more than 5k miles).
I use Amsoil most of the time (12 to 15K between changes) or Mobil 1 (10k miles). Oil analysis has shown, depending on the tipe of vehicle, climate, driving style, sump volume, filtering, etc, that up to 25k miles is possible between changes. The most I have gone is 18k with no problem and excellent analysis results.
Best Regards,
Shipo
Mazda said their engines were not tested in synthetic oils.
The Mazda email reply even warns that synthetic oil may void bumper-2-bumper warranty.
Click on the Mag-1 logo on the top of the page and you can get to the spec sheets. SuperTech and Sears Spectrum are identical to these. Although a tech at Warren indicated to a caller on bobistheoilguy that it was group IV, most thinking is that it's group III.
Pre-SL oils were made by Specialty Petroleum, a company that was acquired by Quaker State before that company was acquired by Pennzoil to Shell, etcetc. Although some Wally World employees believe differently since there was QS labeling on these bottles, the product was never identical to Quaker State.
2. All additives (even big companies) come from a handful of companies.
3. I think they do blend their own oils, at least they have chemists, etc. on staff. In other words they're not just taking a bunch of bulk oil that doesn't sell and packaging it.
4. You're right, I doubt if they're the paragon of consistancy. In the case of Warren, their 5w30 includes moly, I don't think their 10w30 does-- or maybe it does now but didn't used to. If that bothers you I'd look elsewhere.
Wal-Mart owns the brand name, not the blending plant so the SM oil might be from a different source entirely. Again, I choose ST because I get a bottled oil changed (sort of) by people who unlike Jiffy Lube don't try to sell me a battery. There is a small chance that the bulk, name brand oil is actually old SA rated crap that the manager's brother is bootlegging. Not going to happen with Warren.
They provide the oil, and sometimes additive packages, in bulk, the blenders package and ship it.
What most people don't know is that gasoline is pretty much the same way...according to the NY Times it is all "bulk" but with different additive packages depending on the reseller (Mobil, Chevron, Rotten Robbie etc.). There are minimum Federal standards for "cleanliness" i.e. the ability to keep injectors clean, but Chevron is supposed to be well above the minimum. Me, I use cheaper Arco but run Supertech gas cleaner through every oil change ($1.78 for the stronger stuff in the black bottle from Wally World).
The big deal right now on bobistheoilguy is differentiating regular Castrol Syntec from German Castrol Syntec-- so consistancy isn't always there with any supplier.
I have uysed both synthetic gear oils and the ATF and IMO, they outperform the petroleum based lubricants.
One disadvantage can be the higher up front cost.
http://www.valvoline.com/pages/rebates/rebate_details.asp?rebatei- d=18
Some of other filters with good reputation are Mobil 1, and premium brand of Delphi.
Champion Labs (Supertech at Walmart, STP and Bosch at Autozone) are considered well made.
Purolator, AC Delco, some Motoraft, WIX, Napa Gold, and Mobil 1 are considered better than average.
Generally, the manufacturer's oil filter line should be good for the manufacturer's maximum stated drain interval (5,000 for Ford, 6,000 for Chrysler/Dodge, 10,000 for VW, Honda, and Acura) but my suspicion is they are no better than the parts store oil filters. However, I believe you would be protected under the filter or car manufacturer's warranty if a car maker's oil filter failed within the maximum stated drain interval.
Keep in mind that stated drain intervals have a time component, usually one year or less, so if you aren't hitting your miles, you need a change based on time instead. I don't think time is that critical, but it does affect your warranty.
Don't go beyond the manufacturer's stated drain interval on the oil, or you lose your warranty or potential "good will" fix. Possibly Amsoil might back you up if you have a claim and are within an Amsoil extended change period, but I'd check around on the 'net before relying on that. I don't know whether the Amsoil warranty is limited to parts replacement (the bad filter) or covers damage to your engine; or even if Amsoil makes filters...
