Visitor Agreement.
So to me the oil on the markets (especially synthetic)today are like light years ahead!
On a good day I think we got 4 mpg!
Sometimes theories go off in search of select bits of data whereas all the available data should really form the theory.
Unless soccer mom is also delivering coal in Alaska as a sideline, I can't see any undue stress on her car's engine. If accumulated moisture from non-use is the fear, then any oil is susceptible to that.
Trust me, I would not use synthetic oil if longer interval changes were indeed more detrimental to the equipment than regular oil and oil changes at the 3-5 k mark! If there is even a hint of doubt, spring for the VOA and or UOA. for BOTH and/or either/or.
So for me, synthetic (even thought it cost the same as conventional oil to manufacture) but usually sells for up to three times more has 1. less environmental impact 2. less cost per mile lubricated 3. fulfills the long term goal of greatest # of miles with least wear and cost.
FWIW, the truck was in immaculate condition, has nearly every option that was offered that year and looked nearly brand new. Old people take care of their stuff.
I plan on keeping this car for 10 years, which
should be around 145,000 miles.
I plan on doing my first oil change when I
hit 1000 miles, what would be the very best oil
and filter to use and what intervals to change??
I've used Amsoil oil and filter with success. My 92 Grand Prix 3.1 had 110,000 miles when I traded and ran like new and burned no oil. My 99 Grand Prix 3800 has 101,000 miles and runs like new and burns no oil. I change my amsoil oil and filter every 10,000 miles. If it were me I would run regular oil until about 15,000 mile and switch to Amsoil oil and filter and change every 5,000 to 7,000 miles after that. However, you may want to check with the dealer since they have a 100,000 mile powertrain warranty. Maybe they would use your oil and filter but still honor your warranty. Make sure you keep your warranty and good luck. I am shooting for 150,000 miles with my Prix.
I am at 110k miles on my 2001 Echo now and plan on keeping the car at least until it reaches 500k miles or more.
So far no oil consumption between oil changes. I could not be happier with this result.
It all comes down to how expensive and or new the car is and how long you want to keep it.
The longer you keep the car the more sense it makes to treat it with the good stuff and, of course, be very methodical (read anal) with your maintenance.
Merry Christmas to everybody
The pre oilers and bypass filters would also structually allow you to at least double the oil and filter change intervals. So a normal 10,000 mile oil and filter change would now be 20,000 miles. For me that would be up to 40,000 miles btw OCI's!!
My mileage goal for a 2003 VW Jetta TDI is the above mileage goal! After careful research I have also concluded that while both a preoiler and bypass oil filter would nice, it is marginally cost effective, even at the 500 dollar level and 500,000- 1,000,000 miles!
Short trips in cold climate is brutal on oil, long highway trips very easy and can extend the drain. If you drive the car at least 10 miles 90% of the time that you start it you should be able to go the max per your owners manual. Stick to the weight/viscosityed in the manual as well.
Filters, I like flow over filtering ability, thus I use K&M but Purolators, Pure Ones, NAPA old, OEM filters are good. Never ever use a Fram filter!!!!!!!!!!!!
The concept of "extended" drain is actually changing!! This to me is a good thing. I read somewhere (oil industry rag) that the Qwiky lubes fight hard to push back the "average" person's (OCI) oil change interval of 5,000 miles. So obviously they define "extended" as 3,000 miles
On separate oem vehicles that I have (Honda, Chevrolet, VW,), one 2004 has a 10,000 miles OCI with 20,000 mile oil FILTER change with CONVENTIONAL OIL!!. Another 2001 has a max of 15,000 miles OCI. Still another has one of 10,000 miles OCI. All the manufacturer's WILL honor the engine warranty given their above intervals.
When my Toyota Landcruiser's were under warranty, I asked my local dealership if they would honor the engine warranty (36,000 miles)given 15,00 mile OCI's. They said NOT a problem. My 94/96 Toyota Landcruisers are now FAR out of warranty (36,000 miles) At 120,000 and 60,000 miles and I have been doing 15,000 miles OCI's since all of them (5) were new (app 660,000 miles total)! Not to "tug on superman's cape" but I ran a 87 TLC with 15,000 mile oil change intervals and FRAM oil filters (PH 8A)for app 250,000 miles and 14 years.
Your dealers said that they would honor the warranty with your extended OCIs? Great, however, in the real world I hope you got that in writing. Saying one thing and living up to it, expecially a dealer having to rebuild an engine, are two different animals, expecially when he knows you were outside the manual in your service.
Your comments are greatly appreciated.
Key Benefits
- SYNTEC provides superior protection against deposits. Corrosive particles such as acid, soot and oxidized fuel fragments can cause costly damage to critical engine parts.
- SYNTEC contains a Powerful Additive Package that neutralizes corrosive particles, preventing them from grouping together and forming sludge.
- Neutralizes acids in your engine that can cause rust and corrosion on vital engine parts such as cylinders, bearings and hydraulic valve lifters.
- SYNTEC meets the world's toughest gasoline engine protection requirements.
- SYNTEC provides Stability & Endurance under extreme conditions (heat, load, speed) that can cause conventional oils to break down.
- SYNTEC delivers the ultimate performance under high-temperature conditions: unsurpassed protection against volatility burn-off and viscosity increase.
- SYNTEC can be used with confidence in every gasoline engine passenger car, new or old, regardless of oil previously used.
- SYNTEC is fully compatible with all conventional and synthetic oils.
- SYNTEC offers a level of protection that Outperforms All Leading Conventional Oils, passing severe industry torture tests.
jlg
The latest information that I have is that the Castrol SYNTEC that is generally available here in North America is a "Hydro-Cracked" petroleum based oil, not a true synthetic oil. As such, I prefer Mobil 1 0W-40 in my car. They are able to call it a "Synthetic Oil" because of a legal technicality, unlike Mobil 1, Amsoil, German Castrol SYNTEC and a few others.
Best Regards,
Shipo
For me, I am a user of Mobil One 5w30 (app 694,000 miles) Mobil One Truck and Suv 5w40 aka Delvac One 5w40 (47,000 miles) and upon vehicle break in 0w20.
Hydrocracked product is being sold for far less money per quart than are the synthesized products. I contend that the hydrocracked product is the far better purchase, all things considered. There are some marketers selling hydrocracked product at high prices. I suggest passing those oils by, and purchasing the competitively priced brands.
However, the cost to process the synthetic and hydrocracked products are almost identical. So the cost differential between say PAO group IV products like Mobil One at $4-5. vs say a hydrocracked product group III like Castrol Syntech at 1.92 to 3.50 can be due to a plethora of unseen factors. i.e. less volume, higher marketing costs, higher profit, etc.
I read a factoid, (oil industry study) that most folks change their oil at app 5,000 miles. This would of course spell doom and gloom to the qwiky lube industry!
(MAX 3,000 miles between oil changes or your motor coach will turn into a pumpkin mentality)
On the other hand, the motor oil manufacturer's continue to raise the bar substantially. I read several UOA's that put Exxon Mobil 5w20 Superflo (SL standard) good to go for 9,100 miles in a Honda Civic and or Ford Focus!!! With still a lot of chemical UMP PAH left! Honda Civic has normal OCI's recommendations of 10,000 miles with every other oil change to change the filter (20,000 miles)
This oil is app .75-1.5 per quart. To boot, this is no where near a "synthetic" oil!!! Don't forget the new GF standard is now out!? WOO HOO!
I'd say run the oil as far as your own personal judgment dictates.
But for a lot of people, and you know the car abusers I am talking about, the ONLY time their tire pressure gets checked is at a lube joint, the ONLY time anyone looks at the undercarriage is at a lube joint, and ALMOST the only time anyone changes their air filter is at a lube joint - because they are dealer-phobic and in denial about the need to any car maintenance whatsoever. These are the people who don't read the manuals of their Hondas and Toyotas, the manuals that politely ask the driver to make five or six checks regularly - oil level, other fluid levels, tire pressure.
IMHO, the 3K oil change is useless as an oil change, but invaluable as a recurring safety check.
The only thing I'd add, is that nowadays, with a small investment of extra time, it's better to do it at a dealer's fast lane or express lane etc., where the prices are the same as lube joints, but once you go there you get coupons for free "17 point" etc. inspections - by a mechanic who knows your brand of car.
Also, they run your car through their computer for announced recalls, TSB's, and "secret" recalls (or adjustments), something a quickie lube can't do.
When synthetics first arrived on the market, I couldn't afford gas, let alone fancy oils. I'm now thinking about switching everything to synthetic.
I have a new, 2005 Corolla, my wife's daily driver - lots of short trips, with less than 2000 miles on it. Is it too early to start synthetics? Is is useful to do so?
I have a 1988 Town Car with 57,000 on it that is rarely driven. Is it too late to start and is it worth it?
I have a 1997 Windstar with a Ford reman. engine, 50,000 on it. Its my daily driver and does about 15 miles a day Monday through Friday and summer weekend, it pulls a 2000# camper trailer. Is it too late to start and is it a good idea?
I have a 1994 Murray mulching mower with a 4 HP Briggs and Stratton ... oh, never mind that...
What are your opinions on the rest?
If the Corolla were kept outdoors in severe winter climate, I might also go with that one after 5,000 miles or so on the engine, but only if those two conditions were in place.
I use the (synthetic) Mobil One products in all of mine. (3)5w30, (1)5w40, (1)0w20. I also do 15,000 mile OCI's and as soon as the warranty is up on a TDI, I will probably do 20,000 mile OCI's.
In regard to the 2005 Corolla, I have its competitor Civic. The Civic as I have found out uses a 5w20 and it happens to be an oil that has hgher doses of moly. So the owner's manual says to leave the oem fill (Honda oil 5w20, made to Honda specs by ExxonMobil, aka ExxonMobil Superflo 5w20) for the full recommended term; i.e., 5k severe/10k normal, for the new engine needs the properties of the oem fill oil. I am thinking that the Corolla's owner's manual will say something similar?
After the break in time for the Civic, 5k/10k I will be going to the Mobil One 0w20., which coincidently is specifically made for Honda and FORD that require 5w20.
50k on the Ford is not too late and I could benefit from it. Correct?
The Lincoln - with its low use - is just not worth the investment. Yes?
The Toyota - which is operated in northern Virginia's mild climate and is garage kept is only a "maybe"?
Some folks have recommendedd changing the new Corolla's oil by 1K or 2K because of factory goo in the engine, blah, blah. I don't agree and am leaning toward sticking with the 5K but going to synthetic.
My goal for any of this is engine longevity, not mpg. If all works out, I'd like to get 250 out of the Corolla - and maybe even that old Ford.
BTW, thanks for the speedy responses.
Yes, it is probably true that the oem fill will probably have some assembly lubrication. I am swagging it a bit here, but I am guessing that since assembly lube is a controlable consumeable item it might be app 1 oz-2 oz max.
I am also targeting the Honda Civic to go 250,000 miles and above! :)Another interesting thing is the normal oil change recommendation is 10,000 with conventional oil!!! Another anomoly is the recommendation for oil filter change is every other oil change. (10 severe/20 normal)
In the "good old days" I can remember when 1500 miles might be pushing it. 3,000 miles was like running a mental marathon!!
Actually for me there are a host of reasons. Since the average yearly mileage for most drivers is 12-15k, changing once a year is far preferable to changing up to 5 times and for me if you multiply it by 5 vehicles I do prefer yearly total of 5 times vs 25 times!!! Lower cost per mile lubricated, superior oil, less waste stream, 5x less or 5x more? (29.15 quarts per year vs 145.75 quarts) , slightly better mpg, lower sludge build up potential,
Lastly, I ran a 87 Toyota Landcruiser on Mobil 5w30 for 14 years and app 250,000 miles on 15,000 mile OCI's. Since this model had a requirement for 15,000 mile valve adjustments, the dealer mechanics tore the engine down a bit and did the valve adjustments app 16-17 times. So not only did they say it was ULTRA clean 17 times, they actually could do the physical measurements of those exposed components subject to wear. Even at app 230,000 miles they said they micro'd out almost NO wear and was not much different from the NEW specifications!! Of course, a periodic oil analysis was a helpful snap shot.
So... I'll take the plunge - its synthetic for the Corolla and the van.
OEM filters are OK for this, right?
I would also be remiss if I didnt say that the conventional oils are getting FAR better than before! I read on Bobstheoilguy, that folks using the Honda oem 5w20 and also the ExxonMobil 5w20 Superflo (Honda engine products) have actually done UOA's with 9,100 miles and the numbers not only looked good, but there was actually a fair amount of TBN left!!
Again using Honda as an example, Honda's oem 5w20 oil is made to Honda specifications by ExxonMobil and the dealers sell over the counter for app 4-6 dollars per qt. ExxonMobil (surprised?) markets its own label Superflo 5w20 and this is available "aftermarket" in almost any auto chains store for a usual 1.44 and with rebate coupons app 1.00-1.09. So does this mean that because of the price differential that one product is 4 x's up to 6x's better than the other? Another might be: how many people actually believe Honda's (normal) 10,000 miles OCI's (with conventional oils?)
Needless to say the cost per mile lubricated can be ALL OVER THE PLACE.
Best example of that is the 78 Dodge van, lasted 19.5 years, only rebuilt the carb, never ever had the valve covers off. Went nearly 300K, through 3 teens learning to drive. Don't think that would have happened on conventional.
Is it really that good?
