Synthetic motor oil
1114115117119120175
  • quockieoquockieo Member Posts: 2
    If you are thinking about switching to synthetics and know some of the benefits of using synthetic motor oil for your engine, then the real question to ask is when to switch from using conventional to synthetic oil. Some believe that it's okay to switch after 1,000 or even 10,000 miles of using conventional oil. Since you have about 53,000 miles on your engine, i think it's ok to switch. Would someone in here know exactly when to switch?
    The bars have been significantly raised and will continue to be raised when it comes to conventional oils. I would have no qualms if I decided to stay with conventional oil using oem Honda 5w20 or Exxon Mobil Superflo 5w20 for the oem recommended normal oil change interval of 10,000 miles. I switched from Honda 5w20 (made by Exxon Mobil to Honda and Fords specifications) at 10,000 miles for the owners manual made a special point of saying the factory fill should be used for the whole interval. This oil is really hard to beat in that the Exxon Mobil Superflo 5w20 is an excellent oil and at app 1 per quart offers excellent value.
  • shekharshekhar Member Posts: 23
    micweb,
    What a fanatastic reply. You have cleared many of my doubts. We are a 3 car home, the 16 yr old puppy just got her wheels. So every penny saved in preventives adds up. I am told that oil change is the most recommended service (Click and Clack on NPR) for the car.
    My Wal Mart lists only 3 types of services, but as per your suggestions I will ask fore Penzoil + Supertech filter w/o inspection. I think that would be the best deal for our cars (2005 Corolla, 2000 Odyssey and 1994 Altima).
    Thanks again
  • joss1joss1 Member Posts: 2
    I checked the VW website and they list compatable oils for their Gasoline Engines, but can't find one for their Diesel Engines in North America. I see a few people running some Diesel Trucking type motor oils for their VW's but they don't state VW approved. Is there a a problem using them? I'm a fan of synthetic oils as I have had great experience in the past dealing with - 40 degress in Canada.
  • tamu2002tamu2002 Member Posts: 758
    I started using fully synthetic oil not too long ago in my 91 Geo Storm with 100K miles. Lately I noticed the engine has started to leak oil--puddles of oil on driveway. I heard synthetic might cause engine leak in high mileage cars but didn't imagine it could actually happen to me. Could this be the reason? If I switch back to regular oil will the leak stop? Thanks!
  • micwebmicweb Member Posts: 1,617
    If you have an older VW, I believe Mobil 1 5-40 Truck and SUV works; it is full diesel rated and the proper viscoscity (but check your owner's manual!). If you have the newer PD (pumpen dusen) diesel you need to buy a special specification diesel oil which is easiest to find at the VW parts counter. Be careful - not all VW parts counter people know the difference themselves. Make sure it satisfies the PD spec, on the bottle, which I believe is 505.x or something like that. Keep googling until you get a definite spec if you have the PD engine.
    The PD has special high pressure injectors which will clog if you use regular diesel oil, that is the reason for the difference.
  • blueiedgodblueiedgod Member Posts: 2,798
    I use synthetics currently because it's the summer time here in Texas. So far, the average temperature is about 97 degrees. We have had about (4) 100 degrees+ days over here.
    Synthetic is better for winter use. You need all the lubricity you can get at 0°F out of oil. Most conventional oils start gelling at that temp and your start ups are oil starved. High heat has nothing to do with the oil. The engine with fully functional cooling system operates at a very narrow range of temps. So, whether is -20°F or 100°F engine, once warmed up, is at the same temprature. So, if you are just using synth for th summer because of the heat, you are wasting your money, or doing it for the erroneous reasons. I use Mobil 0W-20 year around, because it gets to -20°F in the winter and cold start ups are better with low winter number oils. Summer heat has nothing to do with the oil.
    Could you be right? :surprise: You said, in part, that the cooling system limits the range of engine temperature variation even when the prevailing climate is hotter. I agree.
    Synthetic oil is praised for its high flash point - resistance to high temperature. But of course if the temperature is very high, viscoscity - thinning of the oil - becomes a problem much sooner than oxidation.
    So I agree that summer weather in Texas is probably not a conventional oil vs. synthetic oil issue. Still, you pointed out that cooling systems have a "range" of normal operating temperatures and thus the oil could well be running hotter in the summer, which leads me to think that thicker oil in summer might be a good idea. For example, 5-30 instead of 5-20. Also, a synthetic oil is better than a conventional oil because they need fewer, and sometimes no, viscoscity improvers, where as a 5-20 conventional oil could degrade to 5-15 etc by the middle of the oil change cycle.
    I also prefer synthetic because it doesn't form sludge nearly as easily as conventional oils.
    I agree that synthetic really shines when it gets cold and conventional oils get gummy; car manufacturers keep reminding us that more wear takes place during start up and warmup so this is an important issue.
    All in in I think I'd run 5-30 full synthetic in the summer in Texas and 5-20 full synthetic in the winter (in cars recommending 5-20).
    BTW, 0-20 Mobil 1 is replaced by 5-20. But of course we know its still 0-20, right? :)
    "Synthetic is better for winter use."
    For my 4 dollars per quart, the above quote is a little like the sound of one hand clapping. There is almost no other oil I would chose in a cross country 10 hr a day cruising speeds of 80 plus mph in 105 degrees ambient temperatures than a quality group IV synthetic. Will a group III or non synthetic work? Absolutely!
    I'd say stick to 5W-20 for all year use. I still use 0W-20, I bought a few cases when it was on sale. It cost me less than $1.20 per quart when I bought it.
    PepBoys have a calendar, there is a coupon inside for Mobil 1 "buy 3 get 3 free." I waited until it was on sale for $3.99 at PEpBoys. Bought 6 packs with coupon, ended up paying $12 for 6 quarts of Mobil 1. Then sent in receipts to Mobil 1 rewards for $5 super certificate for each six pack. Here is the math: $12-$5=$7, $7/6=$1.17 per quart.
    I have enough 0W-20 to last me 2-3 years with 5000 mile oil change intervals. I may even take Honda up on their 10,000 mile recommended intervals with dyno oil. But, I live in an area where it gets bellow 0°F in the winter and above 90°F in the summer, which puts me in the Severe schedule. I would hate to void the OEM warranty on such technicality. Plus, my daily commute is a lttle over 5 miles one way.
    I just bought Penzoil Synthetic 5W-30 for "free after rebate." I know they are just purified dyno oils, so that will serve well in the Lawnmower (Honda) and Snowblower (Ariens).
    Good haul on the Ow20 Mobil One! To take Honda up on the 10,000 OCI is almost a total no brainer for 0w20 Mobil One. Indeed it was a no brainer with conventional oil Honda OEM 5w20! After the warranty period of 3 years or 36,000 miles I would have no concerns in running the Mobil One 15,000 to 20,000 miles OCI's.
    As I posted a couple of posts above, my Geo Storm burned or leaks 2 quarts of oil in the last several months. So if I add 2 quarts of oil now, which accounts for 66% of the total oil capacity of the engine, would that be just like doing an oil change for all practical purposes? If I keep replenishing the oil, maybe I can forget about changing the oil ;) ? Of course I do understand the filter will keep getting dirtier.
    No because the oil that remains degrades over time. But good try.
    Yeah, but I'll have the new oil in there to do the job. Right?
    Nope, you'll have new oil, old oil and old sludge and deposits. This isn't a good idea that you are pursuing here :cry:
  • marsha7marsha7 Member Posts: 3,703
    Shiftright is right, and your logic is not even 10% correct...adding oil is not changing oil, and all the stuff that falls to the bottom of the oil pan is still there...change oil, change filter, and stop trying to find someone to justify the "cheap way out"... ;) :P :shades:
    Yes sir :P
    I did come across somewhat harsh, and I do apologize...I did mean what I said, but I sure said it poorly... :blush::blush: ...I will take a week's worth of diplomacy and tact lessons in the next semester... ;)
    No offense taken Marsha. Cheers. :)
  • djordandjordan Member Posts: 10
    Yes, you've heard right - petroleum oil quality is (completely) uncomparable to synthetic. But, regarding synthetic price it is really doubtful for you to switch. Especially if you try to beat those who create (synthetic) oils by drain period of (max.) 5000. Why do you think that you know things better than Amsoil scientists who (for over 32 years) recommend 25.000 and 35.000 (series 2000 oils) miles? Are you so much qualified to ignore them? Just think for a moment about it?
    Uhhh, say what?
    Don't know what statement from my post triggered your response but I'll try to make additional explains. Nothing was personal (to anyone) in my post. I've just tried to point to fact that we (mostly) very easily accept OEM and (petroleum) oil manufacturer recommendations about change @ 3000 miles and stick with them from day one till infinite relying to their knowledge and experience. On the other way lot of users change synthetic oil @ 7000, 5000 or even 3000 miles despite recommendations of 10.000, 15.000 (Mobil) and 25.000, 35.000 (Amsoil). They can do whatever they want with their money but is it normal to take just seventh part of your earnings for instance (represents relation between 5.000 and 35.000 miles) or just to take a few sips from every glass of water and throw the rest of it.
    So, these users are (true) believers in first case and (most than) suspicious in other one. Is it really necessary to suspicious in synthetic oil manufacturer's recommendations (Amsoil for instance) and to their knowledge and experience if they are (very successfully) doing it for 32 years? A number of OEM's have a much shorter history and mentioned users readily believe their recommendations. Strange?
    It's completely OK to have own approach and to stick with "old school" and a little bit older rules.
    But, on the other side you use computer, newer cars, modern appliances,... You accepted these things easily and don't want to give a (little bit) chance to modern chemistry, research, ...How it comes?... :confuse:
  • davids1davids1 Member Posts: 411
    Cool!!! What manufacturer makes that West Virginia Jetta?
  • beernutbeernut Member Posts: 329
    That's the one that says "Objects in Mirror are Behind You" on the right side mirror.
    By your reaction I'd say that you are unmistakable. Am I having conversation with Good? Your sarcasm more speaks about you than me.
    You asked (some time ago) and I tried to answer. If you reply to all answers similarly,,,
    Please try to avoid bickering or personal attacks of any kind. We are here to enjoy ourselves, not win battles.
    If we can't move on to other subjects or maintain a civil attitude, I'm going to start removing posts, regrettably. So don't waste time writing in invisible ink. Have fun and keep the subject moving if you please.
    Thank you for your consideration
    MrShiftright
  • sandman46sandman46 Member Posts: 1,798
    What are you trying to say? I really don't understand. I would think the manufacturer of any "oil product" would know the proper way to use their product. Am I offbase on this assumption? I will take the recommendations of companies that develop a product over people who aren't really qualified and just spout their "opinions" if I can call them that.
    Any help in answering this question for me will be helpful!
    The Sandman :confuse:
    I'm thinking that we need to cut DJordan a little slack, English is obviously not his first language.
    Best Regards,
    Shipo
    You're completely right. We should be here because of helping each other through exchange of knowledge and experience not because of keeping eye on grammatical or typing mistakes.
    Let me explain by other words and examples. I hope that my non-native English will be clear enough.
    Is it strange to you that car manufacturers kept customers for decades misinformed about synthetic lubricants? Why? Because of profit! More oil exchanges - more money. Petroleum oil companies just perfectly supported that concept because of same thing. They spent huge amounts of money to bunk and disqualify "synthetic idea". Result of that approach is 3000 miles oil drain rule (recommendation, habit,...). Wanted they it or not customers accepted that concept and stuck with it years.
    Today all of "petroleum oil companies" have their synthetic oil products. For all of them, synthetic oil “suddenly” became top quality product and so important that some of them even mark hydrocracked petroleum oil as "full synthetic" and invested a lot of money to fight for that.
    One of the most known and emphasized synthetic oil advantages is longer drain interval. Resulting benefit is cheaper maintenance in the long run. All the manufacturers and great part of customers already are familiar with that. But, great part of manufacturers for their (lets say) $5/l products still recommend 3000 miles change interval! Wouldn’t be it notorious puling a money out of customer’s wallet? They want sell to customer more expensive product and keep him stuck with old habits. The most common question in this situation would be: why that product is more expensive?
    On the other side some of synthetic oil manufacturers (Amsoil and Exxon, for instance) are honest with customers and recommend oil drain intervals from 7.500 miles to indefinite. Wouldn’t it be much financially better for them to recommend 3000 mi? Certainly would! But, that would put them in bunch of greedy, dishonest and common companies what is completely opposite of their policy and (32 years, for Amsoil) reputation.
    Let me, once more, elaborate customers with synthetic oil drain concept of 3000 miles. Despite written (bottles and other literature) recommendations of (lets say) 25.000 miles they, because of old habit mainly, decide to change oil @ 3000 miles! Is it OK? Do they assume themselves as more qualified than whole researching teams with years of experience? If manufacturer (Amsoil) stands behind product for over 32 years with same or improved recommendation why should I rather have my own idea based on old habit than believe to longer drain interval?
    I think the problem is that you are citing two extremes of oil changes. Whenever one dwells on the extremes of a problem, one will find stronger dissent on both ends than in a middle position
    I am a typical example. On the one hand, I personally find changing out synthetic oil at 3,000 miles rather wasteful to say the least; but would I wait 25,000 miles to change oil in my $12,000 engine? I don't think so, I don't see the point of going to that level of "economy".
    As for "science", we all know that there is good science and not so good science. In fact, "science" constantly re-invents and corrects itself. The builders of the Titanic relied on science, after all. And commercial / industrial science should always be approached with a bit of skepticism, as it is not quite the same as pure clinical scientific research with no motive except knowledge.
    Last of all, the science we get in an advertisement is a condensation of a rather elaborate test procedure, which may have all kinds of caveats and exceptions which are not quoted in the sales literature. It's hard to say if the average consumer really digests all the "science" behind a product.
    Mr. Shiftright, could you try to explain me why I understand your opinion as a pure defiance of (lets say Amsoil's) research teams, results, hardly obtained reputation and all corrections implemented through 32 years. According to that standpoint European car manufacturers (BMW, Mercedes Benz,...) just deceive customers with synthetic oil and longer drain intervals. Aren't their engines also expensive?
    Going to "point of economy" of 25.000 (or even 35.000) miles is not any kind of extreme. Driving an 18-wheeler for 409.000 miles without oil change could be considered as it! For me all of this is not (cheap) economy. It is just optimal usage of available resources! If, for instance I were in some mountain spa I wouldn't breathe just with half of lungs.
    You're right about average customer's knowledge and approach. Rather than explore little bit through (easily available) documentation about some product they comply by ample advertising campaigns. Regarding that, for instance, it happened that some of my friends tried to convince me that Castrol Syntec is "full synthetic oil" like it is marked on the bottles.
    It happens that I understand this forum as supposed place where those who know a little bit more about some problems, products, technologies,... are available to common customers for all their questions and concerns. Why Mr/Mrs X have to spent hours in reading different documents about some problem while Mr. Shiftright or Mr. Y already spent (lets say) half of life in solving same or similar problems. That is one of the ways how to educate common ("non-digestible") customer. Isn't it?
    If I were going to extend oil changes to 25,000, I would not personally do so without periodic oil analysis, probably every 6 months. That way I have data I can rely upon, about my car, my oil, my situation, my climate, my traffic conditions. I seriously doubt that if my high mileage engine on my Porsche blows up, that Amsoil scientists are going to pay for it. I'm a skeptic, not a gambler. Oil analysis takes out the guess work and the hyperbole.
    While the Mercedes is under warranty, I have no problem with their oil intervals as they are paying the bills. When I myself have to pay the bills, I have a problem with it unless I use oil analysis. You can't tell the condition of oil by just looking at it.
  • yurakmyurakm Member Posts: 1,345
    There are two limits for oil usually: mileage and age. As well as I remember, even Amsoil it used to recommend to change its oil every 25,000 miles or 12 months, what happens earlier. Few people drives more than 20,000 miles per year; personally, I know only four persons.
    I believe that the 25,000 miles oil life is good only for driving on highways, in light traffic.
    I have two cars in my family, 2000 and 2004 Buick Regals. The both have oil monitors. The manual for the older car recommends changing oil after 7,500 miles maximum; with the newer car the maximum increased to 12,000 miles. The both numbers are for natural oil, for the ideal driving conditions.
    However, in the real conditions - hilly terrains, city traffic, and 25 traffic lights on my 7.5 mile commute to work - I have to change oil every 6,000 miles. This is according to the oil monitors. I am using Mobil 1, and change the oil every 6 months. As a rule, it is also close to the mileage limit.
    That is completely OK! Even Amsoil recommends: 25.000 miles or one year, whichever comes first. So, with (recommended) oil analysis it is safely possible to extent drain interval to even 35.000 (Series 2000 oils). And I would do it just in the beginning while I am getting confidence.
    Are your "serious doubts" based on any other particular reason (or known case) other than "being skeptic not gambler"? Am I missing some (well known probably) info?
    For a difference I do not personally know any person who drives so much per year. But, all the cabs, police cars, rent-a-cars, 18-wheelers, ... are driven much more than that. So, longer drain intervals obtained through synthetic oil (and other lubricants) usage would be their perfect match. Why they do not use it (widely)? I do not have exact answer.
    Without any personal offence could you tell me do you have any stronger reason than believing that 25.000 miles oil is “good just for light traffic on highways”? For me, as technically inclined person, believing is not an argument (at all).
    The most interesting part of your post for me is: you drive Mobil 1 for 6.000 miles without any Exxon’s written recommendation like that. Your decision in this case is based just on personal suppositions about its quality. On the other way you quickly reject Amsoil's recommendation despite they support that claim for over 32 years. Do you think that they could survive harsh N.American market just with unsupported claims and weak (comparing with Exxon, Castrol,…) advertising.
    ican market with advertising and unsupported claims?
    I am currently on the road and 4000 miles away from a 25,000 mile OCI. The oil is Mobil One Truck & SUV aka Delvac One 5w40 in a VW Jetta TDI.
    Do you use oil analysis (forgive me if you told me this already :P ) and is your VW under warranty at the moment?
    No and no. As you know the stated oil is formulated to withstand, among a myriad of other things, the rigors of diesel operation; specifically soot %'s. This oil is really some robust stuff.
    How much are you folks paying for an oil analysis? Blackstone Labs charges $20.00 for a basic analysis. A little bit more if you want more information. For $20.00 I can change the oil (conventional) and filter and not bother with the analysis. For just a little bit more than $20.00 I can change 5 quarts of Mobil1 with filter and again, not bother with the analysis.
    Appears to me to be six of one thing, half a dozen of another. Something to think about.
    Analysis can serve as the basis for hard fact based trend and maintenance analysis. Most folks that get into it do it as an informational source, dare I say hobby. I think it is useful when one is unsure, or the particular vehicle is part of a fleet.
    Insofar as being a tool for changing attitudes, I don't think the hard facts have changed many minds, both percentage and volume. In fact, the qwiky lube oil change industry surveys have indicated most average oil change intervals are app 5k instead of the much marketed 3k interval. They of course see this as an ominous trend. For informational purposes, I really think that in all fairness, oil analysis should be done for both conventional and synthetic. As a practical matter, the cost is not justified.
    Given how my vehicles are driven, I have no concerns at all for my average of 15,000 mile OCI's. I have been both amazed and impressed with how far conventional oil has come. On the Honda Civic VP (used as a commuter) they recommend 10,000 mile OCI's on conventional oil!! In this case 20,000 miles on Mobil One 0W20/5W20 presents no concerns to me at all.
  • phastphil1phastphil1 Member Posts: 24
    The quick lube companies do want you to spend extra $. While it doesn't hurt to change a little more often, they are ignoring the fact that most engines are burning so cleanly,that it has become the industry norm for longer intervals with no ill effects for the engine. ;)
  • pulgopulgo Member Posts: 400
    I have had no problems with my 2001 Toyota Echo doing oil changes every 20k miles. Present mileage is 118k and I am on my eight oil change. Initially I changed the oil more often because the warranty was still in effect.
    I have done oil analysis 6 times and the results are outstanding, oil is suitable for continued use every time.
    The oil used is Amsoil ASL 5W-30. I am pretty sure that the new Mobil 1 for extended service would perform similarly.
    50% of my commute of 40 miles each way is stop and go so I would call this severe service.
    Mr. Shiftright: In Germany Porsche recommends an OCI of 30000 Kms (18645 miles) for some of their cars (like the Cayenne). As you know, cars there are driven at MUCH higher speeds than in the USA and the engines survive that type of use without any problems.
    Synthetic oils are mandatory for those long intervals.
    djordan: Show me ONE case (please document it) where Amsoil has had to replace an engine under their warranty. It does not exist. Engines will fail for many reasons but it is pretty much impossible to prove that oil is the cause for the failure.
    I believe that to go to 25k or 35k oil change intervals oil analysis is indispensable.
    I really do not know why you asked for my answer. I am "synthetics believer" for more than 20 years and have no any doubts about quality, advantages, benefits and (substitution) necessity. You're right that it is almost impossible to prove oil as cause of failure. Only oil analysis perhaps. If results show critical viscosity change or missing additives or non-adequate quality or… there are chances for reimbursement. In the long run, though. I do not think that after 32 years of making “clean record” Amsoil will let that unfortunate incidence occur.
    Yes, I have a computer and have moved into the modern age (I hope... ;) )...but I still see those measly 6-7 quarts of oil as the only item inside that I can control, and it helps to clean and cool the engine, in addition to lubricate it...Altho oil filters are designed to remove microscopic dirt, acids and chemical are not removed by filters, they are removed by draining the fluid with contaminants in suspension (that is why oil should always be drained when the engine is warm/hot, never when it is cold)...regardless of the type of oil, the contaminants are there, contaminating the oil...so, I have accepted the additional longevity of syn oil, I now wait 5K miles instead of 3K...I just feel, without any scientific evidence, that the engine will be cleaner and healthier (?) if I do NOT wait for 20K or 30K miles between changes, my gut just says that my engine deserves better than that to, hopefully, maintain its longevity...but, as we say, YMMV...
    5K oil change = 8 quarts oil @ $2.50 per + fact. oil filter $10 = $30 X3times= $90
    15K oil change = 8 quarts synthetic @ $5 + fact. oil filter $10 = $50 X 1time = $50
    Annual miles = 12,000
    Savings per year (time to go 12K) by using synthetic + 15K interval = $32
  • richardsonrichardson Member Posts: 92
    Question is: Does synthetic actually save gas? On another forum they say 1 to 3 miles per gallon. I don't know. I'm going to try it on my gas eating Sedona van. If it really does, it is well worth doing.
    That's a tricky question. I personally do not believe 3 mpg. I'd even be skeptical at 1 mpg....BUT...I do think it is possible under certain conditions. For instance, synthetic can give you faster warm ups in really cold weather....so....less time running a rich fuel mixture...that will save some gas, definitely. And you don't have the crankshaft plowing through thick dino oil. But once an engine is warmed up, I mean, what can be more slippery than regular oil after all?
    3 mpg on a truck getting 15 mpg is a 20% increase in fuel economy. Any engineer would tell you he'd sell his grandmother into slavery for such a massive gain in economy. It sounds way too good to be true, and so simple a solution for manufacturers to optimize their fleet CAFE standards. Why would Toyota spend all that $$ on hybrid technology when all they needed was Amsoil in their crankcases?
    See what I mean?
    Besides, I've tested gas mileage extensively and thoroughly on my own cars, and synthetic didn't change it over the long haul, or the variation was so slim that it could have been due to statistical variations.
    But if someone wants me to give a .5 to 1 mpg gain, I'd say "sure, that's plausible".
  • rhiebertrhiebert Member Posts: 10
    Replying to: "... Why would Toyota spend all that $$ on hybrid technology when all they needed was Amsoil in their crankcases?"
    > Toyota and others have to meet the EPA deadlines. Then, as is the case now in some states and Canadian provinces, it's annual emission tests that car & truck owners will need to have done that will make people use a superior engine oil option.
    The real issue for me is why is it acceptable for MobilOne to offer a longer oil change option, ie. 15,000 kms(?) maybe miles, and not Amsoil?
    On the topic of improved milage, I'm inclined to think that also using, ie. Donaldson air & oil filters and superior synthetic transmission lubricants would accumulate noticeable fuel reduction in larger vehicles.
