Synthetic motor oil
1161162164166167175
  • wtd44wtd44 Member Posts: 1,208
    Check the prices at Walmart and you will see why. Perhaps Amzoil was the pioneer that brought diester based synlube to the public. As I recall the story, military aviation lubricants inspired the development of those early synthetics for the civilian mass market. Soon, Amzoil became Amsoil due to a demand from the owner of the letter Z: Pennzoil. Well, some version of that!
    Wouldn't Scamsoil be the proper derogatory term for Am(way)soil.
    Is scamsoil set up as multilevel marketing like tupperware and many other MLM's? It seems like all the "independent" sellers are out pimping their websites trying to drive business to their site, which often appears to be a boxed site on scamsoil's own servers. They also seem to work trying to keep an image up for the tired old synthetic they sell that's not needed nor much different, if any, from other synthetics available over-the-counter even at my local Walmart. All I can tell is it may meet an European requirement from some German cars. I believe my nephew-in-law usees it in my TDI Passat. Of course he doesn't change oil very often so paying 2-3 times more for it isn't much of an extra cost.
    It appears to me buying Scamsoil is like buying bottled water instead of the water from the tap in our quality water city.
  • xwesxxwesx Member Posts: 17,928
    That is exactly it. If you're paying $35.00 a gallon for oil and changing it every 7500 miles, it does not make sense. But, if you are changing the oil every 20,000 - 25,000 miles, versus every 7500 miles for oil that is half the price, you save money using the Amsoil. Not only must you consider the cost of the oil, but also the filters and time involved. I put 23K on my minivan last year on a single oil change, and I had to add about 2 quarts additional during that time frame; not bad for a van with over 200,000 miles on it. If I only put 7500 miles a year on it, though, it would be silly to spend the extra money on the product.
    For me, it is all about the total cost.
    My two questions are:
    is there something that actually makes that oil better than one of the synthetics I can now buy at Walmart for my car?
    is there a reason to change the oil before 25000 miles due to contaminants in the oil from cold starts and driving especially in cold weather?
    Make that three...
    is it multilevel marketing?
    1. Better? For me, only the standard 25,000 / 1 year OCI vs. the more typical 7500 OCI of other oils. Amsoil also has an oil with a 7500 mile OCI. You could probably look up research that indicates larger or smaller wear rings, etc., for different brands, but you always have to take those with a grain of salt because inevitably the tests are sponsored by one brand or another. From what I have seen, Amsoil and Royal Purple always score very high (or low, depending on the test!) in tests with comparable oils, but not always the best on any given test. All of the synthetics score better than conventional.
    2. No, I change my oil annually simply because a UOA is, for me, cost prohibitive and the oil's manufacturer recommends annual OCIs. The oil is actually rated for 35,000 miles or 17,500 under "severe" conditions, but the filter is only rated for 25,000. I typically put around 17,000 a year on my vehicles using synthetic, but last year we had a long trip to Pennsylvania and back that put a lot of miles on the van.
    3. I don't have a clue about the multilevel marketing. I know they have all of these titles for various dealers, such as "jobbers," "direct jobbers," "dealers," etc., but I don't get into all that mumbo jumbo. I buy all my oil using Amsoil's website, then pick up the product at the regional distribution center when I make a trip to the Palmer area. As I always drive through there at least once a year, it works out pretty well.
    Cost-wise, I save about $100 a year compared to conventional oil that I used to use; I spend about $60 per vehicle, which includes the filter and oil for the initial fill, and an allowance for additional oil added during the year (usually about a quart).
    It is no oil analysis, but I like that the oil drains (after a whole year) golden brown, only slightly darker than when I installed it, versus the tar black of conventional oil. I have not used other brands of synthetic, but I have quite a few friends who use Mobil 1 and they say theirs looks similar (brown, not black!) when they change the oil, but none of them use longer than 7500-mile OCIs.
    I would like to do a UOA, but there is no place local to do it, so it is pretty expensive between the shipping and cost of analysis.
    "All I can tell is it may meet an European requirement from some German cars."
    The thing is, it doesn't meet even a single oil specification for any European vehicle manufacturer, not one. If you read the fine print on the Scamzoil web site, you'll see con-man style terms that say things like, "Our oil was designed to meet the stringent VW 502.00 (et.al.) oil specification." Uh-huh, designed to meet but not certified to meet. If you look at the Mobil 1 0W-40 oil that you can find at Napa, Walmart and Autozone, and the Castrol Syntech 0W-30 and 5W-40 that you can find at Autozone and some other retail outlets, you'll see language that says, "Certified to meet...", you'll also find those oils on the VW/Audi list of approved oils, but you will not find even a single Amsoil offering on said list.
    Best regards,
    Shipo
    Is it possible that Amsoil is good enough for the job, but just has not been put through the testing? I got the idea in the past that Amsoil chose not to spent the large sums required to get the official sanction of certification.
    Is it good enough? Until their oil has been independently tested and "Certified", there's absolutely no way to know. That said, the Amsoil Euro formula does NOT show up on any "Approved: list from any European manufacturer, and if you use the oil and have an engine failure, you will most likely be denied any warranty coverage.
    In the Grand scheme of things, the certification testing doesn't really cost all that much, and given the potential increase in sales they'd see if they were approved, I have to believe that they'd easily recover the cost of the certification testing in relatively short order. Said another way, they know the oil doesn't meet the specifications in one or more areas, and they're hiding behind a smoke screen by claiming they don't feel it is necessary to spend that money. I mean come on already, they have some oils tested and certified, why not others?
    Best regards,
    Shipo
  • ingvaringvar Member Posts: 205
    It does if you care about your car. I do care about my uber-auto:-)
    Depends on the car. I wouldn't put it in BMW or Audi, but see no problem to use it with Japanese or US cars.
    No, it does not; not if you can spend $20 a gallon on oil that will protect your engine just as well over that same span. As with anything else, I always recommend the right tool for the job (even if you have to make it yourself!). :P
    Best bang for the buck, I say! I am most recently into Mobil 1 due to the pricing at Walmart in my area. :P
    Absolutely. For me, the value of not having to change oil during the winter months cannot be over estimated. :D
    "is it multilevel marketing?"
    On the chance that you really don't know, the answer is yes!
    http://www.performanceoiltechnology.com/al_amatuzio_interview.htm
    Interview with Al Amatuzio, President and CEO of AMSOIL INC.
    Action News: Back to the Dealers. Occasionally you hear concern that AMSOIL will abandon multi-level marketing and move to a traditional marketing program. Any truth to that?
    Al Amatuzio: Absolutely none.
    I didn't. I saw lots of individual "dealers" selling and advertising anywhere they can stick in a link to their site even in Edmunds discussions. I saw those sites looking like the "Mothership" site Amzoil and all containing information from there. Reminded me of all the MLMs.
  • beancountantbeancountant Member Posts: 34
    I'm about to have my car's cooling system back flushed. What is the better way to use, The regular Antifreeze, color Green or the newer Antifreeze Long Life (color green) but the manufacturer, say last for 100,000 miles, brand name is "Service Pro"
    Does the long life protect the cooling system just as good as the regular antifreeze??
    Any thoughts?
    There are typically three different types of coolant used in factory applications, the good old green stuff (IAT), OAT, and HOAT. Most folks in the know advise that you stick with whatever came in your car in the first place. The only problem with that is availability. Coolant makers are trying to help out retailers by creating a "One type fits all" coolant, however, that actually turns out to be "one type fits none". If you have a GM car, use Dexicool (sp?), if you have a Mercedes, Chrysler, or Ford, use HOAT (i.e. Zerex G-05), and if you have an older car, use good old fashioned "Green Stuff".
    As an alternative to the old IAT green stuff for older cars, some folks (myself included) opt for a more environmentally friendly Propylene-Glycol coolant. It costs a bit more, however, it is far less toxic to the environment, and if you have a slow coolant leak into the oil, it is far less destructive to engine bearings.
    Best regards,
    Shipo
    Please let me know if you ever see an ad in an Edmunds forums post and I'll track it down. That is not allowed here.
    Both of our cars, 09 Scion XB and 02 Honda Accord 4 cyl. takes 5W-20. I happen to buy a Mobil1 Advanced Fuel Economy 5W-30. Can I use this oil for Winter or any other season or is this motor oil too thick for our car's engine?
  • mcdawggmcdawgg Member Posts: 1,722
    You'll void the warranty IF anything ever happened to the engines during the warranty period.
    To Mr. Shiftright: Both of our cars, 09 Scion XB and 02 Honda Accord 4 cyl.is required to take 5W-20. I happen to buy a Mobil1 Advanced Fuel Economy 5W-30. Can I use this oil for Winter or any other season or is this motor oil too thick for our car's engine?
    Hmmm, you say that you bought Mobil 1 "Advanced Fuel Economy" oil in the 5W-30 grade? You might want to check again because as far as I know, those two are mutually exclusive. Said another way, the "Advanced Fuel Economy" oil only comes in 0W-20 and 0W-30, while the regular Mobil 1 is available as a 5W-30.
    Regarding your cars, if you have 0W-30 you're probably good to go even for the winter, however, if you have 5W-30 I would probably wait until summer to use that oil, errr, unless you have mild winters where you live.
    Best regards,
    Shipo
    I have a choice of Castrol EDGE full synthetic and Quaker Horsepower full synthetic in 10-30 for my 03 leSabre. Which one is the choice for a first synthetic oil change at 90K miles?
    I'm sorry. It's Mobil1 0W-30 Advanced Fuel Economy. The manufacturers required Viscosity is 5W-20. Is this O.K. to use since the oil is higher than 20 Weight?
    Yes, 0W-30 should do perfectly well, in fact, my Mazda3 calls for 5W-20 and I'm using the Mobil 1 0W-30 in it as well. The car runs great, starts well down to twenty below (the coldest I've had a chance to start it so far), and still gets great fuel economy. There's no need to worry about the oil being "too thick" as 0W-30 NEVER gets as thick as cold 5W-20 (even when it's just as cold). Said another way, cold 5W-20 is thicker than cold 0W-30 and way-WAY-WAY thicker than warm 0W-30.
    Best regards,
    Shipo
    Heck, 0w-30, at least the stuff I use, is very fluid even at -40. It makes all the difference in the world when starting the car in those temperatures; especially when I forget to plug in the car for a couple hours ahead of time. :blush:
  • the_big_althe_big_al Member Posts: 1,079
    And I would also wager to bet that in your owner's manual it will say that if 5w20 isn't available, then 0w30 or 5w30 is okay to use.
  • timvipondtimvipond Member Posts: 84
    Vehicle warranties only cover parts failure due to faulty parts, design or assembly. They do not cover oil failure. Only the vehicle manufacturer can refuse to cover a warranty repair due to oil failure, and has to be documented in writing, not a dealership.
    The only way an oil will void a warranty, is if the oil fails. Easily proven with parts and used oil analysis. If the oil fails, then the manufacturer of the oil is responsible. The burden of proof of oil failure is on the vehicle manufacturer.
    AMSOIL has never voided a warranty in 37 years because the oil never failed and caused a parts failure when used as directed. And if it ever does fail, AMSOIL covers all expenses with their own warranty promptly.
    If a dealership or repair shop says using AMSOIL will void a warranty, ask them to put it in writing on company letterhead. At this point, they usually back down from their claim if they know the law. If they will put it in writing, send it to AMSOIL who will firmly tell them they are in violation of the law and will press charges if they continue to tell customers this.
    All of the oil companies can claim this under the Magnusson Moss Act. So what's your point?
    "AMSOIL has never voided a warranty in 37 years because the oil never failed and caused a parts failure when used as directed. And if it ever does fail, AMSOIL covers all expenses with their own warranty promptly."
    Uh-huh, tell that to the guy that showed up on the VW-Vortex site a year or so ago. He had been using the Amsoil "European" oil that is NOT VW 502.00 certified (although Amsoil's language on the bottle is cleverly written to imply that it meets that spec), and suffered an engine failure. VW denied warranty coverage, and Amsoil did nothing to help him out. In the end it cost him something like $4,500 to have his 1.8T replaced.
    "All of the oil companies can claim this under the Magnusson Moss Act. So what's your point?"
    The point is that some posters here feel using AMSOIL will void their warranty and it won't and never has. If it does, AMSOIL pays for repairs.
    "Uh-huh, tell that to the guy that showed up on the VW-Vortex site a year or so ago. He had been using the Amsoil "European" oil that is NOT VW 502.00 certified (although Amsoil's language on the bottle is cleverly written to imply that it meets that spec), and suffered an engine failure. VW denied warranty coverage, and Amsoil did nothing to help him out. In the end it cost him something like $4,500 to have his 1.8T replaced"
    I'll gladly tell that to "the guy". Give me his name and contact info. The BBB shows no consumer warranty complaints against AMSOIL for the past 3 years And they didn't list any for 5 years before that when I checked. Pretty good for the million or so vehicle AMSOIL oil changes during that time. Sounds like an unsubstantiated "urban legend" or someone with an axe to grind. If AMSOIL recommends the oil for an application, they will warranty it. And your proof is an anonymous post on the internet?
    I have no means of contacting the guy over on the VW Vortex site so that won't work. That said, given Amsoil's business practices that are abhorrent to many (me included), any and all claims regarding fitness of use will be immediately discarded as so much marketing bilge.
    Long story short, until Amsoil stops using business practices that are replusive to many, and until they step up to the plate and have their oil certified to meet manufacturer requirements (as do almost all other suppliers of high end oil), regardless of the amount of marketing noise, and regardless of the number of internet drones they have, they're not going to convince the vast majority of folks to try their products.
    Since there's no response does that mean each of these is equally capable as a synthetic oil to put in a first time synthetic fill for a 90K mile motor?
    At least find the post, and I'll contact him. VW and AMSOIL would both have sent him written correspondence why the repair was not to be performed under warranty. Unless it is BS, and it sure sounds like it at this point, as many on that site use AMSOIL and one said it was their VW dealership that recommended it.
    What abhorrent and repulsive business practices are you referring to? AMSOIL Inc., has been a highly respected company in the industry by it's customers, peers, API, consumer groups and oil associations for 37 years. They were the first oil to gain API certification for synthetic oil.
    AMSOIL does offer 5w20, 5w30, 10w30, 10w40 and 15w40 oils certified by API. How many more do you want? No vehicle manufacturer requires oil certification in the US and Canada. AMSOIL has grown on the average of 20% a year for the past 20 years, while the majors have lost market share.
    AMSOIL was and is "The First in Synthetics". AMSOIL leads, the others follow.
    I took a quick look and was not able to find it amongst the tens of thousands of posts over there, pretty much a needle in a haystack. As for VW dealerships recommending Amsoil, hey, if they want to warrant the engines themselves, then they're certainly welcome to use and recommend that oil, however, VW does not and will not warrant any engine that has used oil that has not been certified. Here's the most recent version of the published list of certified oils; Amsoil is not on the list: http://www.audiusa.com/etc/medialib/cms4imp/audi2/aoa/company/aoa-specific.Par.0- 023.File.pdf
    In short, I find all companies that operate as MLMs abhorrent, add to that their highly questionable (and grossly misleading) marketing and advertising practices, and you couldn't pay me to use their products.
    Who cares how many API oils they have, API specifications were completely insufficient for three of my last six cars.
    Did you type that with a straight face? The following is a very short list of manufacturer oil specifications for cars sold in North America that are absolutely required to maintain warranty compliance (which spec pertains to which engine/model is a much longer list):
    VW: 502.00, 503.01, 505.00, 505.01, 506.00, 507.00
    BMW: LL-01, LL-04
    Mercedes-Benz: MB 229.5
    So? Who cares? They sell an overpriced product that based upon independent studies perform as well as (but not better than) products a third to a half cheaper (I assume the cost of maintaining the MLM accounts for the extra cost).
    So you can't even find the post. Maybe it doesn't exist or was pulled due to it being BS.
    AMSOIL is not on the list because they wish not to pay to be on every list that comes along. It simply is not required to be on any list in the US and Canada. It is in some other countries, but AMSOIL does not market there.
    MLM's have thoroughly been investigated. If AMSOIL was shady or fraudulent in anyway, they would have been taken off the market. AMSOIL is an American Company and has been in business for 37 years and provides income for tens of thousands Americans and will provide many more US jobs in the future. Sound better than sending our money overseas to me.
    Again I ask for proof of AMSOIL, Inc. " highly questionable (and grossly misleading) marketing and advertising practices".
    "Did you type that with a straight face?" Yes, certification and being on a list is not required in the US and Canada. No vehicle manufacturer requires oil certification in the US and Canada. "
    BMW: LL-01, LL-04
    Mercedes-Benz: MB 229.5 " Oil manufacturers only have to list that they meet those specifications, which AMSOIL does and has never voided a single VW, BMW, or MB warranty and even offers their own free warranty.
  • altair4altair4 Member Posts: 1,469
    I could have guessed before I googled timvipond, but he appears to be an Amsoil dealer in Houston, TX. Looks like I'll remove this from my forum list for awhile.
    Is Amsoil dealer in Houston on the Amsoil mother side
    "AMSOIL is not on the list because they wish not to pay to be on every list that comes along"
    That is a hoot for someone to say that. I looked for the GM 6094X certifications. Guess they wouldn't want to be on that list.
    I think in the end, the real reason (only reason?) many people avoid AMSOIL products is that they find the advertising and testimonials rather uncomfortably "cult-like".
    So in a sense, some of the franchisees/dealers often don't do the product's image a good turn, IMO.
    I have nothing to prove against the product but the merchandising of it drives me up a wall.
    "AMSOIL was and is "The First in Synthetics". AMSOIL leads, the others follow."
    Dude, you've been drinking way too much of their Kool-Aid. The thing is, it's zealots like you that makes the Amsoil name synonymous with Scamzoil in most people's minds.
    As a suggestion; why don't you go away for a couple of years, gain some perspective, and then come back and discuss this with us. :P
    Let's not get personal about this please. Everyone has a right to an opinion here.
    Oh, I don't know, I find conversations like these to be quite a hoot. :shades:
    "That is a hoot for someone to say that. I looked for the GM 6094X certifications. Guess they wouldn't want to be on that list."
    You are correct. AMSOIL doesn't want to pay to be on that list. There is no reason to be on that list for GM products sold in the US and Canada. It is not required by GM to be on the list, only to meet GM's specs, and AMSOIL meets GM specs. Why pay to be on some obscure list that only a gullible, ill informed consumer thinks is important? It would only raise the price of AMSOIL.
    "Dude, you've been drinking way too much of their Kool-Aid. The thing is, it's zealots like you that makes the Amsoil name synonymous with Scamzoil in most people's minds.
    As a suggestion; why don't you go away for a couple of years, gain some perspective, and then come back and discuss this with us."
    Sorry, I don't drink Kool-Aid. I prefer to read technical information, used oil analyses, product specifications, independent testing, and tribology books.
    As far as perspective, I've done my own oil changes for the past 36 years, have a chemistry minor, retired from Shell/Pennzoil/QuakerState after 28 years, most of which as a technologist where Shell formulates, tests motor oil, and engine tear downs, and been an independent AMSOIL/NGK/WIX/Donaldson/Mann Direct Jobber for 5 years. I consult to over 330 accounts, including municipalities, retailers, commercial fleets and individuals, providing AMSOIL for over 5,000 oil changes a year with no problems. If anyone here can top that for perspective, please speak up.
    You forgot to mention that you're a Scamzoil reseller who is bordering on hawking your products on this web forum. Kind of a conflict of interest don't you think?
    I am not a Scamzoil reseller. I did say that I am an independent AMSOIL Direct Jobber who also sells NGK/WIX/Donaldson and other fine products. I am free to sell other motor oils, just can't find one that is equal to or better than AMSOIL, so why bother?
    I am just clearing up misconceptions stated here that AMSOIL will void a warranty, when the facts are that it never has in 37 years.
    Why do you think AMSOIL, Inc. is a scam? Any specific examples? Or is this just another internet forum wives tale....
    I guess I've just been insulted as one of those gullible, ill-informed consumers.
  • rgould22rgould22 Member Posts: 21
    When people have to resort to name calling you know they are losing the argument. It's a good way for those of us that don't know the details to be able to tell which story should be believed.
    "Why do you think AMSOIL, Inc. is a scam?"
    When Scamzoil representatives say stuff like the following (something that happens all too frequently):
    "I am just clearing up misconceptions stated here that AMSOIL will void a warranty, when the facts are that it never has in 37 years."
    Going back to the VW example, Amsoil is NOT on the VW/Audi list of approved oil (at least I don't see it on that list and I'm pretty sure you didn't either), however, Amsoil and it's minions keep insisting that the oil can be used with no fear of voiding the engine portion of a new vehicle warranty.
    Fact; if the oil isn't on the list of approved and certified oils and an engine fails during the warranty period, VW and Audi (in this specific case), can, will, and more importantly has voided the engine portion of the warranty. Furthermore, until Amsoil gets off their butts and has the oil certified, that situation will not change. As for your assertion that having their oil certified will increase the price, I say, "horse hockey". Why? Two reasons actually, 1) manufacturers all over the world, some smaller than Amsoil, have their oils on the list and said oil is considerably less expensive than Amsoil, and 2) by having their oil certified, they would significantly increase their potential client base, and as a result, sell more oil (which would spread the cost of the certification to the point of it being an irrelevant amount per unit of oil).
    So, why doesn't Amsoil step up to the plate and have their oil certified? My guess is that it is incapable of meeting the requirements in one or more areas and it will not pass the tests. Said another way, they'd rather say their oil is 502.00 capable instead of proving that it's 502.00 capable. :P
