With the discussion on braking vs downshifting on downhill grades, I was wondering if CVT's did downshifting going downhill like conventional auto transmissions. Can you put a CVT in low? Anyone know? Thanks.
I only drove it home from the dealer (25 miles), but first impressions are that it's not for me. Rear visibility isn't very good through the odd shaped rear window, and no back up camera! It rides OK, but it is small and the short, flat seats didn't feel as nice as I would have hoped for in a BMW.
I think that my wife may return it (if my car is ready today) so I don't know if I'll get more seat time.
Maybe the question should be:
Do I really need shifter paddles and when would the common man ever feel inclined to use them?
I don't know what that car is but it's definitely not a PT Cruiser.
It your CVT really downshifting since there are no gears? I know some CVTs have computer programs that mimic gear shift "bump" but isn't it all just a computer artifact?
Gee, a free car and you aren't out flogging it, or at least enjoying it? I'm sure the lòt boy at the dealership is enjoying your 5.
Late to this discussion but echo driver100, what advantages would the paddles give you over sport mode? Is it just the ability to rev higher or keep it in the same gear?
In my previous 135, sport mode locked out 6th gear. I found that annoying and silly, so I always used the paddles in that car. I didn't use it much in my V sport because that worked very well in sport mode. The one annoying habit it had, however, was holding a low gear after a strong braking event. So, for example, someone stops short in front of you. You brake hard and then when you go to move again, the car thinks you are racing and holds the low gear. So I got into the habit of manually upshifting in those cases.
A new 3 model year old Honda that will never sell at that price....
https://www.performancehondastore.com/new/Honda/2015-Honda-Accord-78c269450a0a00e05e818beaf0b3b039.htm
But you get the badge.
I notice all the effort made on construction projects to control the runoff and prevent dirt from being washed into the runoff. He likely has similar responsibility. Did his work require and did he get a permit from your municipality?
Or, as in my case- I just didn't want a rear camera.
They must use the strippers for rentals and to advertise a low price.
Why would you not want one of the greatest inventions of all time? Do you know little kids get run over every year....because you can't see directly behind you.
I can't see why anyone would shun a backup cam, unless they are making some kind of stripped down track rat (a mommyish X1 certainly isn't one of those - with the sight lines in modern cars of that type, a cam would be handy indeed).
I'm not following your regarding performing normal after hard breaking. That is exactly what that car did NOT do.
Sport mode speeds up kick down, which I find very useful on the highway. So full auto in the 135i was only accomplished in "regular mode" and I did not like regular mode, hence being in manual mode almost exclusively in that car. My Caddy would go up to 8th gear in sport mode. I always drove that car in sport mode because it also firmed up the suspension.
When coming to a ridiculously slow or stopped speed on the freeway, especially when sudden, or one particular lane with others moving normally (at much higher speeds), be advised to look in your rear-view mirror, be situationally aware, and prepared to dodge a potential rear-ender. While it may be a semi's fault for rear-ending you (almost always the rear-ending car's fault), you won't collect the money because you'll be dead.
Even an inattentive driver should notice a BIG RIG bearing down at them at full speed from behind. Inattentive is not as bad as oblivious.
I recall years before that the pickup truck driver on his way to work in the morning who was squeezed (pancaked) between two semi trucks where the rear one didn't feel it necessary to stay attentive and slow down.
I stay behind a semi rather than moving up and getting between two semis on our local interstates for that reason.
It's all marketing.
Recently Mercedes was able to hit the $29,995 price point with their CLA as long as you didn't get it with any options, including forgoing metallic paint. The luxury makes are trying to hit these price goals with their great cars, but most know it'll cost much more to get the whole deal.
Now with cheap cars, you could be sold a pile of crap, but they market that it has 24 cameras, with 13 speakers, 5 drive modes, 9 speeds, and 24 standard "options," but you still have a pile of crap moving it along the roadway.
Wow!
I wonder how many people are STILL ran over from drivers backing up, because they don't "LOOK" behind them before reversing. Also, throw in people that don't bother to look at the screen and do have a back up cam (similar to not looking at all). Also, sometimes I've noticed I'm ready to back up 2 seconds before the car's computer has finished booting up, or the monitor is ready to show me what's going on.
Then again I've seen some crazy prices on used Hondas.
Your time is worth something.
Could be lots of reasons for that rear ending that don't fault the Honda. Break down or slowing on a ramp come to mind. My niece was rear ended at the stop at the bottom of a highway ramp. Garbage truck driver was probably doing the same thing.
A CDL driver bears a greater responsibility just because of the potential carnage he can do.
They charged that truck driver in NY with manslaughter.
What's involved in an invasive MRI? Curious because I just came back from an MRI on the wife because of a possible small stroke.
Boy getting old sucks. That's why I decided to get younger every day instead.
Must be working because my wife calls me childish all the time.
Damn! That looks sweet.
OK, I got rushed so it is in sport mode and if you brake hard and then you start up again the car goes to a lower gear and stays there.
I find similar irregularities, like I use sport mode to enter a highway, I get ahead of upcoming traffic but car in front isn't going to fast, I slow down and the transmission does some heavy duty shifting...probably to find the correct gear.
I just think nothing is perfect, the sport mode and the horsepower are great and get me onto the highway, they are powerful tools though, and they just react to the conditions. I would rather have SM and suffer the consequences.
That may be what we are talking about or I may have missed the point.
Note: I have had to read posts quickly, my older brother should go into a retirement home but me and my younger brother have gone to hell and back trying to convince him to leave his apartment and go to a retirement home. We have had meetings and emails....he says he is ready to do it and then backs out....several times now.
People like their dignity, even if it isn't the easiest thing for you.
I guess I have to change the picture to the Grand Coupe and the bottom note, too.
2018 430i Gran Coupe
