2017 Land Rover Range Rover Lease Deals and Prices
12467
  • hsaeed001hsaeed001 Member Posts: 65
    Hello! Can you please provide the residual and MF for the following cars and terms:
    2017 Range Rover HSE V6
    33/10K 36/10k and 42/10K
    2017 Range Rover V8
    Really appreciate your help and the wealth of information you put in the forum!
  • MichaellMichaell Moderator Posts: 266,158
    2017 Range Rover V8
    What is the trim name for the V8? Is that the SC?
    HSE V6
    63% and .00121
    59% and .00125
    56% and .00217
    2017 Range Rover V8
    HSE V6
    63% and .00121
    59% and .00125
    56% and .00217
    Yes SC please! Not an autobiography
    2017 Range Rover V8
    HSE V6
    63% and .00121
    59% and .00125
    56% and .00217
    SC
    63% and .00186
    59% and .00188
    56% and .00222
  • chrisj7845chrisj7845 Member Posts: 41
    Do you have 24 month and 36 month numbers for long wheelbase Autobiography with 10k miles?
  • kyfdxkyfdx Moderator Posts: 269,168
    SC Autobiography?
    .00332 MF and 64% residual
    .00183 MF and 54% residual
    edited October 2017
    SC Autobiography?
    Wow seriously? Not only is the Autobiography about $30k more it also has about a 10% residual difference?
    Does the longwheel SC non autobiography have different numbers compared to the short wheelbase SC?
    SC Autobiography?
    1% lower residuals.
  • mikaveleemikavelee Member Posts: 7
    Could you please provide the residual and MF for a base engine model 2017 Range Rover?
    33/10k 36/10k 42/10k
    .00210 MF and 66% residual
    .00210 MF and 62% residual
    .00222 MF and 59% residual
  • ROBRTM5ROBRTM5 Member Posts: 81
    Hello Kyfdx - Can you please share the lease numbers for a 2017 Range Rover HSE V6 and for a 2017 SC V8 - Looking for 36/10 on both vehicles.
    Thanks - RM
    Thanks - RM
    HSE - 58% and .00123
    SC - 58% and .00197
    Why are you cross shopping a RR and a GT-R? :smile:
  • rdformula1rdformula1 Member Posts: 6
    Hi, do you have November MF & Residual for 2017 HSEv6 and SCv8 for 33mo/15k yr
  • dccdmd11dccdmd11 Member Posts: 8
    Hi. Working on a lease deal Range Rover V8, 114k MSRP.  Dealer says buy rate is 0.00197 for a 39 mo lease, 10k miles/yr. Does this sound right? Seems it went up a bit in the last couple months. Residual?
    .00117 MF and 59% residual
    .00194 MF and 59% residual
    LWB is .00197, SWB is .00199
    Thank you for the great information on this site. It makes the negotations so much easier. Could you please provide the November RV and MF for a Range Rover SE and HSE. 10k. 33mo/36mo/39mo/42mo
    Where do you think the sweet spot is as far as lease terms? Thanks again!
    The sweet spot is definitely 39 months
    Base(SE?) .00211 MF and 61% residual
    HSE: .00129 MF and 58% residual
  • cargeek22cargeek22 Member Posts: 21
    Hi, do you have November MF & Residual for 2017 HSEv6, SCv8, and Td6 for 24/33/36/39 mo/10k yr. Thank you so much!
    What trim level of Td6?
    39 months is the sweet spot for November
    HSE - 58% and .00129
    SC - 58% and .00199
    HSE Td6. Thank you!
    cargeek22 said:
    HSE Td6. Thank you!
    33/10: .00098 MF and 62% residual
    36/10: .00105 MF and 59% residual
    39/10: .00113 MF and 58% residual
    Thank you! What would the values be on a 24/10 lease for an HSEtd6?
    Not good enough to publish ... :wink:
  • kindabobbykindabobby Member Posts: 16
    Good morning,
    Could you share the following lease numbers:
    2017 Range Rover HSE V6 and for a 2017 SC V8 in 07645 NJ
    33/12, 36/12, 39/12
    thank you!
    Good morning,
    33/12, 36/12, 39/12
    thank you!
    HSE
    61% and .00117
    57% and .00123
    57% and .00129
    SC
    61% and .00194
    58% and .00197
    57% and .00199
    wonderful thank you ^
    Hi, do you have the RV and MF for 7500k, 36 and 39 month? For both Range Rover base SE and HSE. Thanks!
    SE
    62% and .00209 (36) or .00211 (39)
    HSE
    59% and .00123 (36) or .00129 (39)
    How would you expect the 2018 Range Rover MF to be when it’s first released? Higher than 2017s?
    Will the ‘17s come down?
    Absolutely no idea where the numbers will be in relation to each other.
    Whatever LR thinks will move inventory, I suspect. And, how much 2017 inventory exists on the dealer lots.
  • harveydentharveydent Member Posts: 17
    2017 Range Rover HSE V6, non v6 HSE, and diesel HSE.
    33/12, 36/12, 39/12
    Thank you. And what would sweet spot be?
    Dealer offering $6k off diesel but only $2k off gas
    33/12, 36/12, 39/12
    I don't see a "non V6 HSE" - just the V6 and the diesel
    HSE
    61% and .00117
    57% and .00123
    57% and .00129
    HSE Td6
    61% and .00098
    58% and .00105
    57% and .00113
    33/12, 36/12, 39/12
    HSE
    61% and .00117
    57% and .00123
    57% and .00129
    HSE Td6
    61% and .00098
    58% and .00105
    57% and .00113
    Thank you. Sorry I meant non hse
    33/12, 36/12, 39/12
    HSE
    61% and .00117
    57% and .00123
    57% and .00129
    HSE Td6
    61% and .00098
    58% and .00105
    57% and .00113
    Base model
    39/12: .00211 MF and 60% residual (best term)
    for those interested in picking up a 2017, was able to get $6500 off msrp on a HSE Td6
  • smartajsmartaj Member Posts: 3
    Lease #s for 2017 HSE 39/15?
    Any idea Dec program?
    Thnx
    Thnx
    .00129 MF and 55% residual.
    No info on December
  • rjg96rjg96 Member Posts: 65
    Hi- I'm looking for December numbers for:
    39/10
    Gas-engine:
    HSE
    HSE Dynamic
    Supercharged
    Supercharged Dynamic
    39/10
    Gas-engine:
    HSE
    HSE Dynamic
    Supercharged
    I don't show any Dynamic models.
    Is this for the full-sized Range Rover?
    Any Dec #s yet? HSE 39/15
    Thnx!
    Thnx!
    55% and .00129
  • mcho3mcho3 Member Posts: 37
    could I get numbers for 2017 RR SC Long wheel Base model
    33/15k 33/12k
    27/15k 27/12k
    33/15k 33/12k
    27/15k 27/12k
    No 27 month numbers
    33/15 - 58% and .00192
    Add 2% for 12K
    could I get #s for HSE 39/12?
    57% and .00129
    Hello Kyfdx - Can you please share the December lease numbers for a 2017 Range Rover HSE V6 and for a 2017 SC V8 - Looking for 36/10 on both vehicles.
    RM
    RM
    39 months is the best term
    39/10:
    SC: .00199 MF and 58% residual
  • hightrajectoryhightrajectory Member Posts: 52
    Looking for MF and residual for a 2018 Evoque SE in zip 01776
    MS
    MS
    The 2018 Evoque lease thread can be found here:
    https://forums.edmunds.com/discussion/49657/land-rover/range-rover-evoque/2018-range-rover-evoque-lease-deals-and-prices/p1?new=1
