2019 Honda Ridgeline Lease Deals and Prices
kyfdxkyfdx Moderator Posts: 275,219
edited March 2018 in Honda
Ask your 2019 Ridgeline lease questions here! Get info about prices, money factor, deals, incentives, and payments.
Check out the 2019 Honda Ridgeline here.
«1345
  • Zoo Ropa82Zoo Ropa82 Member Posts: 122
    Can I have the Residual % and MF for a 2019 Ridgeline Sport 4WD and Ridgeline RTL 4WD for 24/36mo. 12k in PA 18641?
  • MichaellMichaell Moderator Posts: 270,453
    .00220 and 73% / 67% for Sport.
    Subtract 1% for RTL
    WOW, those are great numbers for the Ridgeline! ^
  • swoonhoundswoonhound Member Posts: 18
    Could I have numbers for the various models of '19 for 24/15 in Maryland, Tier 1+
    Thank you very much for always pulling the numbers!
  • kyfdxkyfdx Moderator Posts: 275,219
    .00220 MF and 70%-72% residual, depending on trim.
    Again, 24 month leases will be expensive, especially in Maryland.
    Thank you. Would Black have a 70% rv?
    71%
  • alexfrnchalexfrnch Member Posts: 82
    May have numbers MF, RV, incentives for 2019 Ridgeline RTLE in AZ.
    36/15K
    36/15K
    65% and .00220
  • jfilbertojfilberto Member Posts: 2
    Can I have the Residual % and MF for a 2019 Ridgeline RTL-E 4WD for 36mo. 10k and 12k in NY 10570
    .00220 and 67% for 36/12
    If 36/10 is available, add 1%
  • piggmundpiggmund Member Posts: 30
    Hello. Would you please post the residual percentage and money factor for a 2019 Ridgeline RTL-E in Colorado (80922)? 36/12
    .00220 MF and 67% residual
  • rayrayr26rayrayr26 Member Posts: 7
    Hello, can I please have the residual and mf for a 2019 ridgeline rtl 36/10 or 36/12 in nj. 07206 thank you
    Assuming AWD
    .00220 MF and 66% residual for 36/12
  • ridge__ridge__ Member Posts: 29
    Hi.  Could you provide the MF, residual for all wheel drive RTL and Black Edition— 36/15. Any incentives?
    Minneapolis area on last post.
    .00220 MF and 64% residual
    Either trim
    No incentives
  • akendraakendra Member Posts: 10
    Could I get the RV and MF for a RTL-E on a 36/12 lease, please? Portland Oregon area, zip 97015.
    .00220 and 67%
    .00220 and 67%
    Thank you so much!!
    Is a 39mo lease available from Honda on the Ridgeline? And if so, how much does that affect the RV and MF? Same criteria - RTL-E in zip 97015
    akendra said:
    .00220 and 67%
    Thank you so much!!
    MF goes up, and residual goes down.
    Best to stick with 36 months - that is the sweet spot for Honda.
  • cheapdad0000cheapdad0000 Member Posts: 173
    Please post RV/MF for 2019 Ridgeline RT and RTL AWD and FWD in 27519. 24/12, 36/12. Thanks.
    No RT AWD trim
    24/12 - .00320 and 70% (RT/RTL FWD) or 71% (RTL AWD)
    36/12 - .00220 and 63% (RT/RTL FWD) or 64% (RTL AWD)
  • ausabe73ausabe73 Member Posts: 15
    edited June 2018
    Can you please give me the MF and residual for 2019 Ridgeline RTL-E on 36/12 in Northern VA, zip 22305?
  • dandijon1dandijon1 Member Posts: 2
    MF & RV for 2019 Honda Ridgeline RTL-E 4dr Crew Cab AWD (3.5L 6cyl 6A)
    in Houston .
    in Houston .
    .00220 MF and 67%/65% residual
    Thanks, here in NOVA I have an offer of $508/36mos (12k miles) with $0 down. Then retained a lease broker to find the best deal and he returned $474/36mos with $3K down. Neither of these seem decent given the MF and residual you provided, or do you think these are reasonable offers?
    If you amortize the $3K over the lease, that broker offer goes to over $550/mo. Broker has to make money somewhere.
    If you can give us the MSRP and selling price and/or adjusted cap cost, we can model the payment for you.
    VA is going to be expensive to lease, given the tax situation.
    Thanks for your help. The MSRP is $42.5K and selling price is $38.5k.
    The VA tax is bad, but I could try to look at dealers in nearby areas (MD/DE/PA/WV) if their tax structure would significantly lower costs.
    If you live in VA, I don't think there is any way around the taxes.
    With those prices, I get $426/mo.
    Ask the dealer what the cap cost is for their quote, with taxes and fees added in - and make sure you get an itemized breakdown of them.
  • shetland001shetland001 Member Posts: 1
    Can I have a quote the Residual % and MF for a 2019 Ridgeline RTL-T 4WD for 36mo. 12k in PA 15017?
    Dealer offered .0023, 65% and invoice of $36,551 . . . so I'm not sure if this is a good deal or not.
    Those are the correct numbers if the security deposit is waived.
    What is the MSRP?
  • sanpaulsanpaul Member Posts: 3
    Would you be able to tell me the money factor for a tier 4 lease on a rtl-e here in Connecticut
    .00265 for 36 months
    Now as long as I am a tier 4 that can’t change depending if my score is on the lower end correct?
    That is a "standard" money factor, and Honda dealers can mark it up for extra profit. It's rare for a Honda dealer to do that.
    But, if you are tier 4, you are tier 4. Doesn't matter where you fall in the tier.
  • the13thjurorthe13thjuror Member Posts: 2
    Can I have a quote the Residual % and MF for a 2019 Ridgeline Black Edition 4WD for 36mo. 12k in NE 68022?
    .00220 and 66%
  • timg125timg125 Member Posts: 4
    Will Honda allow higher mileage leases? If so, could you provide the residual and MF for a 19 black edition, 36 month 25k/yr in CT?
    Same for an RTL-E?
    Same for an RTL-E?
    Sorry... the highest mileage allowances we have numbers for is 15K/yr
    .00220 MF
    65%/64% residual for RTL-E/Black
    No problem, I appreciate the information. Do you know if Honda won't go that high on the Ridgeline or could it potentially be done?
    They may have an upper limit... for most makes, it is 99K miles total.
    But, I don't know Honda's max number.
    They may have an upper limit... for most makes, it is 99K miles total. But, I don't know Honda's max number.
  • momo9394momo9394 Member Posts: 4
    May I have residual and money factor for a 2019 Honda Ridgeline Black Edition, 24 and 36 months at 10k for tier 1 in zip 98039?
    10K/yr is not offered
    72%/66% residual for 24/36 mo, 12K/yr
    .00220 MF
  • jausankajausanka Member Posts: 27
    Anybody negotiate a good deal lately? I had started looking elsewhere earlier in the year since Honda didn't seem to be willing to offer anything worthwhile on the Ridgeline - but now my lease is coming up due in September so I need to start making some decisions.
    Read back through this thread to see if you can glean any pricing info.
    I did. And there is only one actual dollar figure mentioned, not from any time recent, or local to me, or a similar vehicle. Sorry for asking. :@
