Visitor Agreement.
Thanks for the feedback...I've asked Q if anything showed up on auction. I think the E55 was discontinued in....2006?...so they probably didn't make all that many of them.
Yes, last model year for the E55 was 2006, it became with the E63 with a normally aspirated engine for model year 2007.
Other options would be parktronic, , keyless-go, special wood, Designo packages, P1 (nav, CD changer, heated/cooled seats - this will be on virtually every car), along with pano and distronic.
First year (2003) W211 E55 can more often be found without nav.
http://www.ridelust.com/superbird-gone-wrong/
I woke up in the middle of the night, to catch the tail end of an episode of "Mannix", where Joe was in a '69 Fury being chased around by a couple Ford trucks, and got roughed up. One thing I noticed that was a bit disturbing...the episode was from 1973...yet the Fury's dash padding was already cracked!
Now, that stuff was actually designed to work on a 1970 Roadrunner, so it probably didn't have nearly the same effect on a Fury. But, i imagine there was some improvement?
make no differencehurt) and that nose cone would turn that lumpy Mopar into a world beater, Cd-wise.In any case, the Euro version maxed out at 150 mph—fast, but certainly not out of the range of Boxers and good-running 930 Porsches. Unbolting the optional (at $5500) wing from the rear increased speed to 160 mph with only a very minor loss in directional stability. Not ordering the wing has to be the cheapest speed secret in the world.
‘80s
not sure what year it was, but the classy style with a normal trunk that they had in 1975 (IOW a glorified Nova).
In a way, couldn't that help with cutting through the air, as well? It might not show up in a wind tunnel if a stationary car just has a stream of air forced over it, but out in real world driving, the car would hunker down more, which might help. And the added traction would help it slice through the wind better, I would think.
Traction doesn't help with aerodynamics (I flunked Physics twice, but I remember a little bit)
https://jalopnik.com/the-1981-lotus-esprit-turbo-has-a-hidden-second-spoiler-1825751291
I asked my sister what color? Unfortunately, greyish green, not brown.
Usually paired with Chestnut interior, which is sort of a drab brown.
must be a really rare bird.
and at different times, a 57ish T Bird then a 64 T bird.
