Saw a black TT convertible today owned by a guy who's obviously into his car. I noticed as it turned that the black rims had a flash of metallic blue next to the tires and may have had a stripe of blue on the black spokes that added a little color as the wheel rotated.
Then I was behind this beautiful convertible at the stoplight and saw the metallic blue in the two "Ts" instead of chrome. Next stoplight I was beside him and saw the metallic blue on the circle around a gauge in front of him. I almost expected the seats to be metallic blue. I suspect there was more blue in other places.
Oh, second thing I had noticed was the blue lenses on his sunglasses in the rear view mirror that exactly matched the blue on the wheels and in the TT emblem. Car really looked nice with it. Tastefully done.
True, probably similar to Chicago. Casa Loma is cool. I haven't seen too many newer things, aquarium etc. Are you going to try the Edge Walk at the CN Tower? I think it is only about $200!
I like something like this way more. A 1968 Chrysler New Yorker, large windows, square, balanced look;
Those are good things to do. If you came through Port Huron/Sarnia you were on 402. If you came through Windsor/Detroit, you came on 401. Around London Ontario 402 joins 401 and that gets you to Toronto. One of the busiest highways in North America, and I believe the part that crosses Toronto, is the busiest highway in North America.
Have fun, the rest of the week should be pleasant, but 96F on Saturday.
I'm not sure what post he was not pleased with me about but I think it was about doing oil changes on my '09 Genny. I don't know why he thinks you have to be a professional mechanic to do an oil change properly but he does. But then he thinks you have to be a pro to do anything on a car. Maybe even adding air to your tires. He'd probably even try to tell me how to wax a car. I'm sure the guy is a good mechanic, and he better be since he does it for a living, but there are some things that don't have to be done by a pro.
As I have said in here numerous times, I have found too many mistakes that were done to my cars by pros. Which is why I started to work on cars myself. I can screw it up just as well as a pro and its cheaper when I screw up. Nor do I have to convince myself that I didn't screw up when I did. Got tired of the lies about why it was done right when it wasn't.
Plus the cost of getting your skivvies cleaned.
WOW, that is some Malibu you have.
First you see the TT from the side. Then you're behind it at a light, then at the next light you're side by side, then it's in your rear view mirror.
You either have your Malibu on steroids or you never mentioned you got the Premium Performance Package on that beast. In any case it's a real sleeper.
Things went downhill from there.
My Generation 8 is a little higher seating position than Gen 9 and weighs slightly more than a Gen 9, but it is so nice traveling any distance in it. It's as comfortable as the loaded leSabre seats and soundproofing I used to have. Car gives good performance from an engine for normal people. Gave 36 mph going to Columbus last week to setup a rehearsal dinner for son's upcoming wedding.
My next shopping likely will include high end Optimas and I'll even venture into a distant, safe Camry store to look at Avalon and Camry. I might even drive a Civic and Accord but since they are so related, I don't know I could see an Accord as a good choice. It was not a high speed area. This was in Moraine next to the Fuyao Glass plant nee Moraine Assembly for S10 then Suv's. He made a right turn onto an eastbound street as I waited from the opposite direction to turn left. I got the full flash of the blue on the wheels. Pretty, I thought. Then 1000 ft later in a 40 mph zone, he was at the light and I was behind. I saw his sunglasses' blue in his review mirror after I saw the blue TT emblem. Then 800 ft later I was beside him at the stoplight. I should have looked at the wheels, but I saw part of the cockpit with blue metallic trim on some.
Fellow was probably in his 30s. Careful driver.
I suspect aftermarket trim pieces are available in this blue are readily available to match the outside blue color.
Just look at an Impala if you want something bigger, it is the logical next step, and the current model has received positive reviews even from sources who conspire to bring down the big 2.5
I have no idea what my actual account balance is, what tolls have been charged to my account via my transponder, and a whole host of other data and information I used to be able to access.
So I called the Sun Pass Operations Center and after a 20 minute wait on the phone, a woman answered. She told me that she had no idea what my actual balance is because the entire system has been down for 4 weeks due to technical issues. I asked her how long before this new system will be operational and the response was, "...we have no idea at tis point in time..."! She said that no tolls have been charged against any transponder account for the past 4 weeks. Can you imagine the hundreds of millions of dollars the State Toll Road Authority is losing every month? It's not just the Florida Tunrpike System - it also includes other toll roads thorughout the State of Florida.
Remember, the same thing happened to the Obama Care Portal - it was not Beta tested and, it is quite obvious this new system was not properly Beta Tested. But without tolls being processed and paid, the Toll Road Authority sill have some severe finanacial problems since Tolls pay for maintenance, not the State of Florida. I wonder how many heads are going to roll as a result of this calamity. Good Grief!
I looked back and it was in the smaller print...is that how?
1968 Chrysler New Yorker Values | Hagerty Valuation Tool®
Hagerty
1965 Chrysler New Yorker Sedan
I still say it looks better than the Imperial,,,,and that makes it closer in age.
The key has a transponder, not a chip. I just checked. When I first read that,
I thought Park Avenue had gone to transponder keys while leSabre had chip keys until 1999.
https://forums.edmunds.com/discussion/comment/5521928/#Comment_5521928
The '68 Imperial is rather distinctive from the front so I knew it wasn't one of those.
Didn't last long though. He screwed up, several times, and they fired him.
One of the reasons I did my own oil changes, for years (decades). These days, owning mostly new cars under warranty, I often get free oil changes from the dealer, so I take advantage of that. But I'm like you with checking the lug nuts, I always check that the oil is at the right level, and nothing is pouring out the bottom. Which doesn't mean they used the right oil (very important these days), but I check what I can.
My nephew bought a 2017 Civic and then got a job in New York City where a car wasn't practical. I was in the process of helping the family sell it when his kid sister appropriated it for herself. If we had gone to sale it would have been a legit "moving, can't take it with me".
That TT is really sharp. They've improved the looks since I last looked.
https://www.motorists.org/issues/speed-limits/langlotz/
Great study on how the IIHS can post studies with more holes than the Titantic in 2018.
There is something wrong with your recent posts, we don't have to translate them into something we can figure out.
And yes, your new Enigma machine is better than your old one. Only took me two reads of your post above to get it. Keep up the good work.
Glad to see you're back posting with a machine that is working better for you.
When I started teaching I was assigned to a second grade classroom. It was a scary experience. The first day I walked into the room and the kids started to file in from the playground, four of them started crying almost immediately once they saw who their teacher was. Remember, I was 6’2” tall and weighed 217 lbs. I was at a loss as to what I could do to stop their crying.
Out of the blue, I started singing the Beatles song, “...If I Fell In Love With You, I would Promise to be true...”! The crying stopped immediately. That was my first success in my teaching career - I knew how to stop 7-year olds from crying. Teaching them how to read, write and compute was not as easy!
Enjoy the book. Glad you got it. There was no tracking available, so I was kind of worried about it getting to you.
It's kind of funny, I thought this month was going to end up on a down note, but a lot of things turned out good.
It is almost Saturday...happy Saturday too!
And yes, the writing is greatly improved.
