Visitor Agreement.
Well, that's a relief!
Be quiet.
Traditional or outcome-based learning puts all students through the same program for a fixed period of time, no matter if they learn or can apply the knowledge or skills. A competency-based program is where students work on a concept and are supported until they learn and can apply it in context with their career. Once mastered, they move to the next step. Traditional education focuses on tasks or skills on systems students are studying, while competency programs focus on core skills, not the specifics of the system. For example, in current education programs a student might learn to test and diagnose a particular Ford system that contains certain core technologies, followed by learning to test and diagnose a Toyota system that contains some of the same technologies. The student has now learned the Ford way and the Toyota way, but when faced with an Audi, how do they react? In most cases they’ll say they need Audi training. In a competency-based model, the student learns how to test and diagnose the technology no matter the badge on the fender. As Koen so brilliantly put it, “Specific system knowledge cannot be a learning objective. Being able to follow diagnostic procedures is the learning objective.”
Fast-forward to today and we see the most complex data networks on the planet come into our shops, rolling on four tires that carry over 100 million lines of code in order to operate. Yet, we still only invest the same two years in our young technicians and expect the outcome to be the same. I think that is insane! So, what’s the answer? A four-year program? While that would be a good start, it is not the complete answer. Using our current outcome-based model of education, it could possibly take eight or more years to achieve the levels of post-vocational competency that we once had. I believe the answer is to modernize education by focusing on competency and the mastery of skills rather than basing our education on outcomes.
This next section reminds me of some of my career choices back in the eighties.
I recall as a young technician working for Datsun being asked to go to work at the Toyota store; I was scared to death. I knew Datsuns like the back of my hand but had never worked on a Toyota. It took me less than a day to realize this one truth that I preach daily: a car is a car is a car; the engineers who designed them all went to the same schools and belong to the same club (SAE). The laws of physics and chemistry are in play no matter the brand, and the suppliers for the OEMs are shared. In other words, become competent in testing and diagnosing the technology, not the nameplate. Koen uses the history of the rear window heater to make the point. In the eighties, the rear window heater circuit was very simple. You had a control circuit with power, ground, and a switch that controlled a high-current circuit that completed the heater resister circuit and warmed the rear glass. Simple foundation electrical diagnosis was needed. In the nineties the circuit was controlled by a control unit that took the input from the switch ‘pull down’ or ‘pull up’ circuit to know when to complete the control relay circuit, which in turn activated the heater resister circuit. Today, we have complex networks that contain simple wiring or data busses with many nodes on the network that require a different set of skills both in the way we test, and in the logic we use to solve problems. To apply the outcome model to these systems creates so many variables that if a technician hasn’t mastered the competencies, the amount of time needed to solve the problem negatively impacts the shop’s bottom line and is not fair to the motorist.
The closing of the article.
As Koen said, today’s students and technicians need to focus on generic skills independent of the OEM specifics. This does not mean you should not learn the OEM strategies and process; it means if you’ve mastered the competencies for each technology, when you approach OEM service information that asks you to pick up a tool or points you to a test, you’ll know exactly why and will have a clear expectation of the expected test results. A big Thank You to Koen Berends, principal at Electude, for clarifying what we need to do!
The article I linked and quoted from describes exactly where top techs really are with their careers and why most of us can work on anything. Specific nameplate stuff can be looked up and ultilized if the tech is truly competent. Today's students have to learn the base strategies, not specific operations.
Do you remember RB calling a tech a moron because he misdiagnosed an oil leak on a BMW? The story went that when looking at the car, the leak would appear to be coming from the oil pan so the techs would advise that repair. The problem was the oil leak could actually be coming from the oil filter adapter but due to the fact that the actual leak area is obstructed they get it wrong. Specific knowledge has it's place but what the techs really needed is to know how to test and prove where the leak is coming from and the easiest way to do that is to pressurize the crankcase to about 3psi with shop air cut down with a presssure regulator. Doing it this way, the tech can find any leak on any car the first time, everytime. The moronic way to approach vehicle problems is in thinking that someone can just know what is wrong becase they have seen it (heard about it) before because there will always be more things that someone hasn't seen than they have no matter who they are and what they have done.
I came up with the idea of pressurizing a crankcase to test for leaks in '83 when we were doing a lot of the S-10 Blazers and Pick-ups with the 2.8l V6 that had rear main seal issues. We would have to pull the engine and lift the crankshaft from the block to install a one piece lip seal in place of the two piece that the engine originally came with. Occasionally the seal would pinch and not set down in the groove correctly and you would end up with a worse leak than before you tried to fix it. By testing it before putting the engine back in, you prevented a comeback that would take another ten hours to try to solve which we wouldn't get paid to do of course. BTW, my routine didn't use a regulator, I just burped the air in using a shop rag as filler so that I didn't over pressurize the engine, somebody else added that and re-shared their improvement on my idea.
The recent example of how long it takes to do a set of kingpins demonstrates how both core competency as well as specific knowledge mold together to create an end result. I even threw out a little clue that the way I approach that job is different from what is in the book, did you catch it? If you have done them, then you probably do them the same way most people who have been shown how to replace the bushings do them. Just about everyone does both of them at the same time, and then they ream them together. My routine which I started on my own, is to replace and ream one bushing at a time on each knuckle and then do the second one. The result is I get that part of the job completed in about fifteen minutes, roughly less time than I have seen others take to just replace the bushings. Pressing the old kingpins out with the right tool takes about five minutes, ten if I have to heat anything. Doing them way I was first taught can take an hour for each side to heat the axle and then drive them out. Then you have to wait for everything to cool off which adds another hour to the job. So I really do expect to complete that job in about one fifth of the time that you were thinking. If an extra challenge or two arrises, that's just the way the work is and that goes back to core competency skills.
All in all things have come a long way, you no longer see everyone shooting from the hip for every owner who writes in saying something like "My car shuts off when I am driving, what is wrong?" Today responses guide them to first try to discover what they are losing (aka spark, fuel, both) and then setting the stage to test and prove why. That routine works everytime, on any car. The specifics of each namplate only begin to apply later in the routine and again, that stuff can be looked up.
I am totally with Cardoc on this. I tell people the same about my work in IT. I work on a system. There is input, processing, and expected output. If I know what the processing is supposed to do then I should be able to peek into a system and identify the problem area. I have helped others with their failed processes not knowing anything about their software but just knowing what it was supposed to do and what it did not do. One problem is there are too many vested interests involved. Framing information that is based on general physics as proprietary knowledge generates profit based on salaries, textbooks, and schools. Look at the warning in Eisenhower's final speech: "The prospect of domination of the nation's scholars by Federal employment, project allocation, and the power of money is ever present and is gravely to be regarded." This touches every aspect of education in this country. Every time one goes to learn something, those with the resources to teach it design it for maximum profit, maximum time in the classroom, and not minimum time and maximum learning efficiency.
Doc, my conspiracy theory is that the outcome-based education that has proven to be a significant failure is intentional. Ad infinitum it begets more schooling, it is self-fulfilling. And the schools are in cahouts with the large corporations. Those looking for work know this. If one does not have the exact exposure listed in the job posting, they will not even make the initial automated filter. This attitude about, "You have to spend X years doing exactly THIS" is like a disease in management across the country. The problem is, the person who has spent all of their time doing exactly THIS, like the article above hinted at with the Datsun mechanic, they get completely flustered anytime they are presented with a problem outside of their little world.
In IT, some certifications like MCSE mirror OEM automotive certifications. There are in fact a lot of certified people who do not know good methods!
https://techinfo.ferrari.com/
https://techinfo.ferrari.com/tools;jsessionid=1E37DAB2F661F96917E239BB4B11407A
http://www.supercartools.com/index.php?option=com_content&view=article&id=280:ferrari-deis-tester-&catid=57:ferrari&Itemid=29
You;ll also need a complete special tool set of course. The flywheel alone has 30 parts if you're doing a clutch job along with that cam belt. Be sure to charge at least $7,000 (on up).
And if it's an 360 Spyder engine you're servicing, be sure to remove the convertible top mechanism. You can slso avoid that by cutting holes in the rear access panels.
As for the more modern cars, yes, you can buy access to certain data from Ferrari.
Your link says: "Please note that Ferrari Special Tools have been designed to be used by technicians who have been trained on Ferrari vehicles, systems and components."
Have you done all the training on various Ferrari models?
My training is in another area of expertise. Why would I train to be a line mechanic? I work on cars on my current skill level.
My belief is that you don't have to know everything. You just have to know where to look, or who to ask, or who to pay to do it for you.
This presumes, of course, that one is intelligent enough to follow through on those options.
If your question meant-- do I update my training in my particular career?---sure, all professionals should do that.
If you mean, was I smart enough to be a top line mechanic when I was starting out in life?----sure, with the right training. But I think we both agree, this is no longer the best of professions for the young man.
I'm sure each of us knows how to do things the other does not.
You can follow the rest of his video's from there. First I am semi-retired and don't earn a living primarily repairing cars anymore so if I take on anything at all I can charge as much or little as I want to. Second I checked with a shop owner that I know in Florida. I can borrow every tool anytime I want to, I just have to pay the shipping. Third I linked that video because if someone can do the job like that then it is well within the reach of any skilled technician.
The point was that the professional mechanic can't afford to get beaten up tackling jobs he has no business doing. If he wants a challenge, it should be on his own time.
When you say things like:
The suggestion is that you personally have performed these repairs and are speaking from first hand experience and not from just watching, maybe helping someone else who was actually doing the repair. Parroting what you have been told by someone else, or simply watched someone else do doesn't make you an authority on the subject. But you betray that when you wrote: I'll ask again, have you? You suggest that you have with the specific steps that you wrote and I quoted above.
At this stage in my career I am totally capable of deciding what work to take on and what work to recommend to someone else. Even work that I am familiar with I don't take on unless I have all of the proper tools and information at hand. Now what you won't like is that I can take on engines and transmissions that I haven't done before if I choose to, without having to attend specific training on that assembly first. Natural talent, plus experience and core competency skills combined with just in time information allows me to be very proficient even on the first time with a given assembly. I would never say otherwise, I always expect others to have seen and done things that I have not becaue there is just too much out there for anyone to have done it all. But one person knowing what amounts to a piece of trivia whether a second person is aware of that same information is not a measure of either person's skill or knowledge. However while your experience is in deciding what a car should be worth and is decidedly not in how to do full line repairs mine is exactly the opposite. The difference is I would never search for and try to exploit any holes in your knowledge and experience to try to call into question your abilitites but that is exactly what you are trying to do with the Ferrari stuff.
If your premise were true, why would I believe anything you have posted, not having done it myself?
If you answer by saying you are a reservoir of learned experience, then I would say I know plenty of "docs" like you upon whom I can draw knowledge.
You, Doc, are like the doctor in the ER room--you see people with spikes driven through their heads, or 4 fingers removed by a table saw.
I don't have to deal with things like that. I can fix most of the things that come up with my cars.
@roadburner -- exactly. I have zero motivation for learning about a certain car if it doesn't interest me. I'd rather spend time working on my Triumph motorcycle, which I do know a lot about, then on my Mini Cooper or truck, which I like but not so much that I don't hand off most repairs and maintenance to others.
I'd have to be out of my mind to take on replacing a clutch in a Mini Cooper. Shoot me now.
As for diagnostics, It's amazing what you can learn just fishing around for information. Even if you ultimately cannot repair the problem, you've learned a good deal more about how to interact with the mechanic who will do the job.
As for my Jeep, worst case scenario is I upgrade to a JK; it's a bit more complex than my TJ, but it's a known quantity on the Jeep forums.
This is a ten-year-old car. You have to expect unusual types of failures.
Do some research about the target systems required to align the ADAS cameras etc on the vehicles, and then make sure you catch some of the innovative work arounds where techs are printing out minature versions of the targets and simply placing them closer to the cameras. One camp says that's a pretty smart thing to do saving the tech/shop tens of thousands of dollars in targeting systems. The other camp asks a simple question about that practice. "What If"" there is an accident someday and the investigators come back and find out that the system wasn't set up exactly as described by the O.E.? Even if by all logic what they did worked does that keep them out of court when you have an attorney or law enforcement who needs to find someone to blame? How do you think the businesse's insurance company is going to feel about the practice?
If you haven't looked at that question and the responses take a moment and do that right now.
One of the standard answers to try to assist someone with an electrical problem is to say to check the grounds. When someone says that what exactly do they expect the person asking for help to do? I often wonder if they really understand what that means when they give that advice. Attached are the schematics for the high beams and the low beams which takes two pages because of the way the low beam circuit is drawn. Should any time actually be spent physically investigating the ground circuits?
Besides that's an OLD CAR--it might have been a bad idea, but it's way down the highway now.
RE: Accidents with ADAS -- I would think that the errors/omissions insurance would defend the shop. As for not following factory testing methods, that depends on how far you bend the rules. Anybody can sue anybody for anything. You can't prevent frivolous law suits. If you aren't comfortable fixing a system, send it to a specialist. Shops do this all the time.
RE: Grounds--well if they don't have a bazillion dollar tool chest and 10 years of training, then yeah, they should waste the time tracing the grounds. Or they can probe at the headlights. They can run a hot wire to each headlight plug and see if it was some kind of connector/junction issue. Or if they are motivated, they can test for voltage drop. You have to remember that it's crazy to give online DIY advice about electrical systems that is too specific. " OOPS! Your car burned down? So sorry".
Give 'em a hint, give 'em some encouragement. We aren't a repair shop here. That's what other online websites do with videos and message boards and back and forth with other owners.
If you are a persistent rookie, you can often figure these things out by trial and error. I could figure out the dim headlights problem. It would take me way longer than you, and it might not be methodical, but I'd get it done. Just this year I've tracked down an engine miss, a bad speed sensor, non-functioning door locks, dim fog lights, bad trailer hitch wiring on my two vehicles. No scan tool, no diagrams. Just persistence.
The ADAS example is about the setup and training of the system not diagnostics. About the only thing we can be sure of is that if something goes wrong down the road is there is usually more effort put into who to blame than what went wrong. They will ask the question, "What if the fact that the system wasn't trained exactly as designed by the manufacturer introduced a fault that it couldn't compensate for?"
The hindsight is always 20/20 stuff only happens after someone else has provided the answer. That was and still is used as a common bullying tactic by managers to try and control the technicians as the techs experience and educations advance beyond the management's comprehension. Just like what you tried to do above, and have been doing since you found out that kingpins shouldn't take a whole weekend is to try and put the tech back into his place. They can't control the tech if they have to admitt that they aren't capable of handling the work so they do exactly what you tried to do with the Ferrari stuff as well as the park assist buzzer. They preach "Everybody knows that" while they have no idea at all.
The schematics show that both the non HID high and low beam headlights share the same ground circuits. If the ground was bad it would affect both, the OP hasn't responded to say which system the car is equipped with. The HID's share part of the same ground circuit but not the whole circuit, with them a portion might need to be tested. But that doesn't mean take things apart look at them and try to clean things. It simply means measure the voltage drop on the circuit to see if it is excessive, then address that if it is. If the voltage drop isn't excessive, the problem isn't on the ground side.
Informative video, and a good chuckle to boot.
And I learned as I went. A lot of time sifting through manuals, that were only half there.
It was a short stint in my career and I learned a lot of how to do it right, cause when a part is thousands of dollars, a mistake has to come out of someone's pocket.
Nasty. Locate and repair the damaged wiring and the car was running again
