1160116021604160616073236
  • corvettecorvette Member Posts: 11,954
    edited October 2018
    It still couldn't use it, since I park in the garage.
    If it's an attached garage, you probably don't need it. If it's a detached garage with no living quarters and no pets living inside it, well, I've opened the door and used it in that instance before. ;)
    Definitely looking forward to your review of the remote start installation.  I had the dealer add the OEM remote starter to my Subaru.  It’s one thing I actually miss about the car.
    I'll add details later. Basically, the Nissan/Infiniti wiring is extremely similar from what I can tell. You will need a test light to find the door pin wire to attach to prevent the auto headlamps from staying on and draining the battery in the event the remote start times out and the headlights are activated. The only new part, for me, is the Crimestopper (I think) module that adds the ability to start via a cellular connection. The old part, which I had on the Murano and will still have on the G37, you press the lock button on the OEM keyfob three times, and the car will start and run for 30 minutes. That part is a Fortin bypass module, and you can order them preprogrammed so they just plug and play. I had the same thing on both the Murano and the Mustang and left them both installed, so the remote starter people have gotten hundreds of $$$ from me over the past few years.
    The weather has been remarkably warm here. Not sure whether I should be glad of this or not! It rained heavily yesterday (would have likely been >12" of snow in years past), and I expected it to be icy this morning, but low temp bottomed out a couple degrees above freezing.
    I feel a little bad for the hares. They are all fully decked out in their winter-white coats, and there has yet to be appreciable snow! I imagine the raptors are enjoying it, though.
    As for auto-start, like with cell phones, mine is the only family I know that doesn't have this feature on our cars. I don't pre-heat mine, and my wife prefers to go start hers before she gets moving. I do use it on the one car I have that came with the feature, but usually just as I'm walking up to it!
    The wabbits might as well put targets on their backs!
  • nyccarguynyccarguy Member Posts: 18,017
    Hey @boomchek!  Welcome back!  Glad to hear from you that all is going well.  What vehicles are in your fleet now?  Have you punched your CCBA card at all in 2018?
     Well those are having warm weather awesome, we’re having a cold spell here in the north east, but hey it is what it is. Do we have to do regardless. Corvette yes put the snow on the remote start insulation on the G 37, have a good day all, think covered everything in here welcome back remember above.
    Well the Prelude needs a few things to pass state inspection. Right front caliper is bad, tie rod ends, ball joints have some play, rear way bar bushings. Brakes pass but would need done sometime next year so while they are in there I'm having pads/rotors done. Not thrilled but not really sure much of this would be known without throwing the car on a lift beforehand. Lesson learned. The bad caliper surprised me because it seemed to brake fine and straight.
    Didn't you just recently buy this, with something like 180k miles on it? Or is my memory playing tricks on me again? If you did just recently buy it, another good lesson on why it's worthwhile paying for a PPI, Especially on a well used older model with a lot of miles.
  • stickguystickguy Member Posts: 54,889
    As long as it’s a keeper, you will get a car that drives like new, so all good! Of course, it’s not my money.
    edited October 2018
    You are correct. As far as a PPI, fully agree but logistics prevented that from happening and I felt the gamble on something like a Honda is not the same as a Porsche, BMW, MB, etc. The seller scanned and emailed me all receipts for numerous and even more expensive maintainence items such as tires, misc OEM replacement parts, tune up, timing belt,valve adjustment, etc so I made a calculated decision it was worth the risk. Unfortunately it didn't completely pan out but with 182K those type of things are bound to fail at some point so if this gets me through the next few years with only needing stateinspections and oil changes I'll take it.
    Thanks, no stamps yet this year. The only thing recent that we bought that we have now is my wife's 2014 Mercedes B250 that we bought last fall. We got rid of an older Lexus RX300 we had for a year and our 2007 BMW 328i we had for a good 8 years after it hit 200,000kms (120k miles) as it was starting to have minor electrical annoyances.
    I was a manager at a used car lot for 2 yeara so we had no need to buy anything for a while as I just took cars home that suited me.
  • tjc78tjc78 Member Posts: 17,845
    I'm impressed they checked all that. In Jersey as long as the computer isn't throwing any codes, you pass.
  • kyfdxkyfdx Moderator Posts: 276,941
    I was wondering if all of that was caught on inspection, or if your mechanic said you needed the repairs to pass?
    PA is pretty thorough with its safety inspections. Interestingly there were a few posts in Tales from Under the Hood referencing NY state inspections in light of the tragic limo accident. Ironically my car came from NY.
    @kyfdx I didn't ask but I guess it could be from either. It's my first experience with this shop since they only handle Honda/Acura. They have a sterling reputation though.
  • suydamsuydam Member Posts: 5,258
    Of course in Ohio, right next door, what inspections? If you can drag your heap onto the highway you’re good to go.
    Wow good thing  was only that  found  rong. With the car.  Crazy on the variation. On what the states  do when it comes to inspecting.   Cars
    Not super encouraging on the remote start. I thought I had ordered from this place before, but now it looks like I bought the previous two through Amazon. Anyway, this place charged my card but didn't send any order confirmation or shipping confirmation, nor do they answer their phone. If it's not here in a week, I'm filing a chargeback with my credit card. Looks like it may be a while before I have remote start in the G37!
     Wow Corvette, what a mess with this company that you were dealing with for the remote start, yes sounds like a plan we week and then finally charged back with your credit card company. Happy Friday everybody have a good weekend all, will be back in here later on.
    They’re still not answering their phone and haven’t sent me an order confirmation or tracking number. I went ahead and disputed the charge with my credit card.
     Very nice Corvette, glad disputed the charge from now instead of waiting a week. You just have to order it from another company on Amazon now.
    have to take the RDX in tomorrow to have the tires rotated, and brake check (the low fluid light is on). While we are out, might drag the wife off to look at a few things.
    I have been semi-incapacitated the last week with (apparently) Sciatica. Quite painful. Seems to be getting better, slowly. But I have discovered that when you have back/leg issues, a little bit higher seat, with power adjustments, and comfy design, is really nice. Probably the excuse I needed to swap out of the lower, firmer riding sporty car. Though the ride is OK, the bigger issue is not being able to tilt the seat up (plus it is on the firmer side).
    still want to test sit a Volvo and TLX. Though at this point, want to wait for the new V60. Also will look at a few small/midsized CUV/hatch types. Maybe an X2. and a CX5. CRV is out now.
    probably not actually doing anything soon. But, never know when you will be in the right place at the right time, and some dealer makes an offer you can't refuse!
  • DrivingfoolDrivingfool Member Posts: 227
    Have had sciatica for years now, since the 2005 accident, and can be quite debilitating at times. The one good thing about that Tucson I had was I was able to slide in and out with no drop whatsoever. Think that's what blinded me to every other negative there was. And funny, I still hear about it to this day about that expensive mistake I made once upon a time! And for some insane reason, I like the new Kia Sportage, I really do! And saw the rear ends of the new 2019 Kia Forte lined up and ready for their pdi's and tags. Nice looking from the rear and something we almost ended up with in our garage. Before I mentioned the A3, the wife was about to sign for a new Forte. Came down to the new Mazda3 or the new Forte at that time. Once I mentioned the Audi, I knew eventually she'd buy one. Takes her awhile to finally purchase anything and I know it's just silly to rush her. After multiple test drives and questions that can take weeks, she finally decides whereas I know within a pretty short duration what vehicles have made my short list and then choose a final one somewhat quickly. Sometimes too much is just too much!
  • benjaminhbenjaminh Member Posts: 6,962
    edited October 2018
    Sorry you're still having back trouble. Hate to say it, but the TLX might not be such a good choice if you're needing a higher seating position. It's a little higher than an Elantra Sport, but probably not much. On the other hand, the TLX's seats are quite comfortable. Might be a mistake to write off the CR-V, which at the EX trim level is an impressive package for c.$26k. Difficult to say about the seemingly small number of people who have engine oil issues with the 1.5 in the CRV, but I'm confident Honda will take care of any engine issues. In terms of looking for a bargain, what about the current Volvo S60 and V60? My local dealer is really dealing on those. A lease on one of those wouldn't lock you in too long, and then you could get the next generation when it's also a good deal and full debugged. Finally, it looks like Acura is having a rare "loyalty lease" on the RDX. Even with that the new RDX is expensive, but really an amazing vehicle that perhaps you should consider going for at your age? As someone just turned 54 myself that definitely factored into leasing a "dream car" for me. I wondered was I ever actually going to drive a nice car before I kicked the bucket? Rather grim way to put it, I realize, but there it is. Anyway, as you know I'm glad I did. It's just my 2 cents, but I feel like at this point in life, esp. with your back trouble, that it would be good to try for something nicer than an Elantra....
    I am considering a lease. For a Volvo now, would either be that or a couple of year old CPO (not like they changed much the last few years). good point about being a nice transition to the new model in a couple of years, doing a lease now. Supply though is getting pretty thin, especially with a non-black interior. I do need to find some time to stop over there, just in case.
    The TLX is high enough for me. I just don't want something like a Miata where you pretty much fall in/climb out of it! The seats are more important than the height.
    My wife loved the new RDX. She would not complain, but that is going to be real pricey. The "splurge on a luxury car because you might never get another chance" move, was that RDX (I told her she had to commit to keeping it 10 years, and she is willing). At least that is paid off.
    edited October 2018
    What’s the RDX top out at? 44k or so. I would think a low 400s lease payment would be doable with zero out of pocket.
    Not a chance. No incentives.
    Mid-$500s, most likely
    Wow, many other choices at that payment.
     Go for it stick guy, you know you want to enroll in here to encourage you.
    Yes...
    Seeing all of the Honcker prices can spoil you for the real world. Once you start looking for a specific model, rather than just a low price, you see that the "1% rule" is definitely not the norm.
    No it’s not. My Enclave is a touch above the 1% rule. 50K MSRP not a penny out of pocket at signing (not even 1st payment ) and 515 /month.
    edited October 2018
    Acura's "loyalty/conquest" lease on the base RDX is $380 a month + taxes etc.—but that's with $3k down. So that probably means that with taxes and if you aren't putting much at all down you'd probably be looking at almost $500 a month. It's an awesome vehicle, but that's a lot of money. Acura is known for good levels of standard equipment, and so the base model has a panoramic roof, heated memory seats, good sound system, etc., but that is still a FWD model that doesn't have blind spot monitoring.
    https://www.acura.com/
    "2019 RDX 10 Speed Automatic Featured Special Loyalty/Conquest Lease
    $379 Per month for 36 months.$2,999 Total due at signing.Closed-end lease for 2019 RDX 10 Speed Automatic vehicles (TC1H3KJW) available from September 5, 2018 through October 31, 2018, available to well-qualified lessees approved by Acura Financial Services. Not all lessees will qualify. Higher lease rates apply for lessees with lower credit ratings. Lease offers vary based on MSRP. MSRP $38,295.00 (includes destination, excludes tax, license, title fee, registration, documentation fee, options, insurance and the like). Actual net capitalized cost $34,982.23. Net capitalized cost includes $595 acquisition fee. Dealer contribution may vary and could affect actual lease payment. Total monthly payments $13,644.00. Option to purchase at lease end $24,125.85."
    Prestige Volvo in NJ has this lease offer....
    "2018 VOLVO S60
    T5 Inscription
    MSRP: $39,290
    2018 Volvo S60 T5 AWD Inscription shown
    LEASE FOR
    $275/mo.
    $3,180 Down"
    https://www.prestigevolvo.com/
    $100 less a month for a vehicle that has a slightly higher msrp than a base Acura RDX.
    And for a money saver they have a certified 2013 S60 with 47k miles for $14k. Might get them down to 12, and I bet it has better seats than an Elantra Sport.
  • graphicguygraphicguy Member Posts: 14,259
    I’m surprised at those lease prices/terms on the RDX. I would think that their residual would mitigate some of the purchase price.
    What is the residual percentage on an RDX after 36/36K?
    One of the best lease deals on a luxury car still seems to be at my local Volvo dealer for a loaded 2018 V60 AWD wagon with an msrp of $47k.....
    "2018 VOLVOV60Cross Country T5 AWD
    Lease For$399/MO. $0 Down
    INCLUDED PACKAGES
    Manufacturer's Suggested Retail Price (MSRP) ($41,850)
    Convenience Package ($1,500)
    Keyless Entry & Drive
    Electric Power Steering Personalization
    Rear Park Assist Camera
    HomeLink® Integrated Garage Door Opener
    Blind Spot Information System Package ($925)
    Blind Spot Information System (BLIS)
    Cross Traffic Alert
    Front Park Assist
    Lane Change Merge Aid
    Heated Front Seats & Heated Steering Whe ($750)
    Metallic Paint ($595)
    Net Pocket Kit* ($160)
    Protection Package* ($270)
    Off-Black Leather ($500)
    Destination Charge ($995)
    Total Manufacturer's Suggested Retail Price (MSRP) ($47,545)"
    https://www.volvooflouisville.com/specials/new.htm
  • ab348ab348 Member Posts: 21,013
    Astounds me what Volvo charges extra for - keyless entry? Rear view camera? Heated seats (on a vehicle from Sweden)?
    62% base
    60% all other trims.
    And, the ad car is only $38K MSRP.
    I wouldn't say it's high, just typical.
    edited October 2018
    Although the new Cadillac XT4 also charges extra for heated seats.
    We're enjoying the standard heated cloth seats in our 2018 AWD CRV EX that we paid c.$27k for.
  • breldbreld Member Posts: 7,005
    Tempting...
    530i manual
    2025 BMW i5 - 2017 911 C4S - 2024 VW GTI - 2026 MB GLE450 - 2024 Genesis GV60 - 2019 Cayman
    breld said:
    Tempting...
    530i manual
    Nice... those do look like M5 wheels, but I didn't think they fit the stock 530i?
    For $6500 or so, it would be nice. I like it a lot.
  • 28firefighter28firefighter Member Posts: 9,981
    Me like that 530.
    My local Cadillac dealer has this lease deal on a new 2018 XT5....
    "2018 CADILLAC XT5 Base
    Lease For $289 $0 DOWN
    2018 Cadillac XT5 Base - Disclaimer: MSRP $40,990 must qualify for all incentives including Loyalty / Conquest. $0 due at signing. 10,000 miles a year. 39-month lease term. Plus taxes, dealer fees, and dealer added options. "
    https://www.courtesycadillac.net/MonthlySpecials
    https://www.youtube.com/watch?v=3NBbSbya3PU
    Heated seats? What are those for? (smile) I think I already told my story about heated seats, so I'll spare all of you the retelling.
    That sounds like a very good deal on the 2018 XT5. Well under the 1% rule, and a car I wouldn't mind owning. One of the local Caddy dealers has a base 2018 XT5 for $10k off sticker, about $31k. Tempting.
    Probably about $360-$365 with fees and taxes rolled in. I assume FWD?
    breld said:
    Tempting... 530i manual
    No mention of cooling system or valley pan.
    edited October 2018
    A lot more here in Texas, thanks to 6.25% sales tax up front on the entire amount. That will add about $2k right there, spread over 39 months (the length of the lease), another $51 per month. But I wouldn't be leasing anyway.
    And yes, the Base XT5 is FWD.
     QP, you know you want to do it go for you all in a bowl you in here. Ha ha sounds like a nice deal on the Cadillac, think I said in one of those earlier this year at the auto show seemed nice.
    Huh. They're standard on all trims of it up here.
    In Canada it seems like you get heated everything for free lol!++
  • Looks like Carmax sent my old C30 to auction and it's now for sale down in Colorado Springs at a much lower price, but still not low enough.
    I still miss this car.
    https://www.carsforsale.com/vehicle/details/48014407
    breld said:
    Tempting...
    530i manual
    I do look back fondly on the 2002 530i I had - I drove that for about a year as my daily, and we all know that's saying a lot.
    Those are definitely M5 wheels - I'd prefer the stock sport package wheels, but the M5 ones certainly look nice, and not necessarily out of place.
    I don't know much about that "M-sport" package they refer to - not sure if that was actually available from the factory or is more of an aftermarket add-on. Either way, as long as it was installed professionally, it looks nice. The dual tailpipe setup is attractive.
    Given the price point, if it received good grades on a PPI, I'd consider it.
  • roadburnerroadburner Member Posts: 18,764
    breld said:
    Tempting...
    530i manual
    A perfect work hack for me!!!
