https://www.amazon.com/gp/product/B07C8L7Z7X/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
From the dash this morning after arriving at work....
@explorerx4 Yeah, but most of the time its the other way around. I thought it was nice that the car could be set to use either measurement system (for many items, all can be set independently), so I figured it would be a good way to become more fluent with the Celsius scale.
I was running around all day in low 20s F and thought I was going to die.
Now that you mention it, it was that wet cold that you get just before a snow event (tonight).
I've spent some miserable winters in Minnesota but nothing near that cold. Yikes!
I have a circulating block heater, an oil pan heater, and a transmission oil pan heater on it. CBH is fantastic.... at more moderate temps (like -10F and warmer), it can heat the engine to operating temp. I do not have auto-starts on my cars (I am the only person I know in Fairbanks without one!), so I appreciate the instant heat out of the vents when I start it up. At these temps, it does not get to operating, but it still provides perceptibly warm air out of the vents.
I have a timer that turns it on about three hours before I leave in the morning, and it starts up just fine. If I did not have it heated, it would NOT (not even close) start. For the big 3.0L diesel engine, I think the practical non-heated cut-off is about zero degrees F (-18C). I tend to plug it in if it is around ten degrees or less. At work, we have "headbolt" heaters (e.g., power outlets spaced around the parking lot), so I plug it in when I get to work and leave it that way. If it is warmer, like around or above zero, I usually do not plug in when I arrive, but go down an hour or two before I leave to do that.
I run my tires at 40 PSI on this vehicle, and 35 PSI on my Subarus. I set the pressure when I do the seasonal tire change outs, so ambient pressure is lower during this time of year, but it comes right back up as the temperature does. You have to be careful about setting pressure during cold snaps (or, at least, too high of pressure), as it can actually cause blowouts when the temperature jumps back up. Back in 2009, we had a cold snap of -50F that turned into +50F one day later, and there were multiple reports of blowouts! Too funny, yet dangerous.
And, coolant mixture: I tend to run between 60/40 and 70/30. Freeze protection is about -66F.
https://www.autonews.com/executives/gaunt-graying-ghosn-protests-his-innocence-court
You mentioned work: how do you keep the car operable while parked there?. Inside parking? Electrical connectors for plugin heaters?
We forget how fortunate we are to be able to jump into our car, press a button or turn a key, and go.....oh yeh, down here I have to put on my sunglasses.
This would make a nice addition to any car:
Ever worry about dreaded wheel ants:
2. Ever heard of riding shotgun?
3. Also helps with wheel termites, wheel centipedes and wheel praying mantis.
On the oil disposal idea, I’ve driven cars that did the same thing a drop at a time.
Here is one more I liked, I think these were like feather things you attached to your exhaust pipe to give it that real flaring look.
1. Change oil and filter
2. Replace brake shoes
3. Replace brake socks
4. Treat for wheel ants
TOTAL: $842. 40.
Each of the posts are electric outlets at the top, so we can plug in as needed.
Now I know where the saying, "shooting yourself in the foot" came from.
