1168916901692169416953236
    A member poses a very interesting question here. What's your opinion? Go visit him if you have time and share your ideas!
    https://forums.edmunds.com/discussion/54071/volvo/s60/general-question-on-volvo-s60#latest
  • xwesxxwesx Member Posts: 18,220
    Wow, look at that interior - kind of pushes my buttons. If this was a full LED gauges car on one of their cheap leases, I'd almost be tempted.
    Ugh. That thing is practically used up. Ten miles.... you better pass if you don't want a whole lot of troubles on your horizon! :p
  • 28firefighter28firefighter Member Posts: 9,974
  • corvettecorvette Member Posts: 11,910
    I knew it would be yellow before I even clicked on it.  :p
    You'd want to see all service and repair receipts. 125K miles is a danger zone for a used E36 BMW IMO. Things like cam cover leaks, rough idle, water pump failure, radiators cracking open, defective clutch fans, manual gearbox shifting problems (be aware if the transmission wants to pop out of 1st or 2nd gear), Guibo couplings, transmission mounts, rear shock mount failure----these are a few of the more likely problems you'll encounter at this mileage. The newer the model year of the E36, the better off you are. They improved over time.
  • stickguystickguy Member Posts: 54,800
    I like that one a lot. But not a car I would buy without a PPI by an expert! But I would be happy to have it to drive. I even like yellow. I think over the years I had 2 yellows (Gremlin and Duster) unless I am forgetting one.
    I can't do Yellow. I've only seen a handful of cars ever that I liked it - one was a Speed Yellow Porsche 968. This one, not so much.
  • au1994au1994 Member Posts: 3,855
    I love the yellow. But like Shifty said a nice, thick binder of receipts would be nice. Without it, start deducting. It would be a fun warm weather ride though. Very analog driving experience on the E36.
    One reason I bought my Volvo was the folder of receipts---when I saw all the new parts, + the recent timing belt change, that gave me lots of reassurance. I mean, think about it---if an otherwise nice looking car needed 4 tires + a timing belt, that could be $2,000 bucks!
    Volvo R pulled off yellow.
  • kyfdxkyfdx Moderator Posts: 276,029
    I'd take a pass on an E36 convertible. As bad as the interior bits deteriorate, I can't imagine how much worse that would be with a ragtop.
    Never tug on the upper radiator hose on one of those. Ask me how I know. :'(
  • MichaellMichaell Moderator Posts: 270,923
  • ab348ab348 Member Posts: 20,962
    That one is so sad it’s hilarious.
     :p
    i have bin injoying reading all in hear the past few days!Type your comment
    oh boy.
  • sb55sb55 Member Posts: 670
    We are visiting in Florida. Compared to Vermont, there are a lot more high end cars (and people).
    First stop in Vero Beach. A quite high end enclave with conservative fancy cars. Think Rolls and Bentleys (and even a Fisker Karma. Do they still make those?). Then off to visit friends in Ft. Myers. Probably not as upscale, but we did see a very yellow new Lamborghini SUV and several other nice autos. Not many beaters down here.
    Horrible snowy, salty Vermont roads would probably eat those nice cars up!
    here is a great example of what I was talking about, in terms of taking a classic car, and giving it modern upgrades while keeping the look as original as possible. I still consider this a classic:
    https://bringatrailer.com/listing/1968-pontiac-firebird-9/
    interesting comment in the comment section that pretty well explains what I was going for:
    "I’m in the process of the same resto-mid with my first classic car purchase, a ‘70 GTO… have had it for 20 years in good OE shape and just didn’t enjoy driving it. Not overly fast with the 400, didn’t handle well, braked funky with the front disc and rear drums. It just looked & sounded better than it drove…
    So a GM crate LS3, Welwood brakes, Hochkis suspension and new trans all added similarly to this build, and it has made Ana amazing difference to the ride and handling. Now it is beyond fun and exciting to drive"
    Well, doing what the guy said he did is probably $25K. That’s not including what you paid for the car. You’d still need to deal with the fuel system, cooling, AC/heat, and wiring. Don’t forget wheels and tires. Oh, and steering box. Don’t forget the endless fiddling to get all that stuff to work together properly. Then unless it has recently been done there is body/paint and chrome. Interior can be done cheap and wrong or correct and more pricey or “custom” and really pricey. If you go with the first two you get only basic 2-way adjustable seats. Crank window and non-power seats and locks are almost universal on a ‘60s car remember, so could you live with that? The mitaswells can add up really quickly and once you’ve had it for a while you give up trying to do things on the cheap because things drive you nuts and it seems justified to pay someone whatever it takes to fix. $50-60K for all that is probable.
    IMO you would be far better off both financially and satisfaction-wise buying a late model fun car. Anything from a Mustang or Camaro convertible or a Boxster or a BMW of some sort. Performs better in every way, no headaches and far cheaper. Take it to Cars and Coffee and knock yourself out.
    Kind of my thinking these days. Gotta get the Coronet put together and sold first, though.
    So, along these lines, I've been perusing a couple of the car apps. I'm definitely leaning towards a v8 coupe of some kind. I really should focus on something with a back seat, but a C6 vette is definitely tempting. Here are some I have run across that strike me as interesting possibilities.
    2005+ M6
    2005+ CL55
    Challenger
    Camaro
    2009+ Jag XK
    2007+ Quattroporte (yeah, I know, not a coupe)
  • graphicguygraphicguy Member Posts: 14,245
    2005+ M6
    2005+ CL55
    Challenger
    Camaro
    2009+ Jag XK
    I was tempted by a used Maserati a few months ago. Y’all talked me out of it. Beautiful cars, though.
    I vote for the Challenger.
    oh boy. I’m more likely to get a newer car too. Though could be from the 80s, but really depends how on if it is to be my real car, or purely a spare toy.
    Off top of my head, mustang, a Z350/370, wrangler, Z3/z4. Older cars, a classic GTI maybe?
    What about a 2005/2006 GTO?
    Big car. Good for QB, too big for me.
    Prelude or RSX would be good though!
  • fintailfintail Member Posts: 59,099
    Regarding the M and AMG cars, do you feel lucky? Those particular years are not the zenith of quality for those brands. As I have little patience for real wrenching or buying a mechanic a new boat, I personally would hold off for a 2010+ (I think) big coupe if I wanted a bruiser MB - the C215 has a host of potential issues, and the earlier C216 6.2 cars have the head bolt shenanigans.
    2005+ M6
    2005+ CL55
    Challenger
    Camaro
    2009+ Jag XK
    I came across a couple, but it is hard to fall in love with what looks like a Cavalier.
    edited January 2019
    Fair point but if it's not my daily driver I could probably live with it. Hard to argue with 400 HP :D
    You could go with the slightly newer Holden based Pontiac G8 GT?
    edited January 2019
    I like for my toy to be a convertible. The Wrangler is a ton of fun and I’ve always been a fan of the Z3/4. The Z350/70 convertible never did it for me personally but its probably pretty fun. Can’t go wrong with a Mustang either and like the Jeep the aftermarket is there for you to personalize it and have a little fun making it perform and look a little better.
  • breldbreld Member Posts: 6,995
    My fun car thoughts these days are leaning toward something along the lines of a Civic Si. Maybe a Veloster N when they're available for deeply discounted used prices. Something more like my departed Type R, but at least a bit more subtle.
    I'd certainly like something more usable than the Miata, which I knew would be the case sooner than later.
    Given the pending house purchase and move, I will likely unload the Miata and wait 'til the dust settles to find a replacement. I have a nice purchase quote from Carvana, which would make it easy.
    2025 BMW i5 - 2017 911 C4S - 2024 VW GTI - 2025 MB GLE450e - 2024 Genesis GV60 - 2019 Cayman
    I would love a circa 1990 era CRX si. But those are rare and expensive. A nice civic Si from that era would be nice though. I had a 1984 (probably around 1990) but was just an S, with a carb. Still fun!
    In 1991, I was looking at a Civic Si. Asked my insurance agent about it, and was told they were expensive to insure.
    So I got a Nissan Sentra SE instead.
    Maybe a Fiat Abarth AND Polaris Slingshot. I think I could fit both in the one garage bay currently occupied by the Dodge. ;)
    The fiat might fit in the trunk.
    That slingshot really does look like fun.
    edited January 2019
    Maserati gives you very little for your money IMO. They SOUND great, but content, at least on the new ones, is vastly overpriced.
    I drove the Abarth for an entire morning. Fun for what it is, but it really feels like a toy someone built in their backyard.
    RE: Polaris----my mantra is---"Never own anything with three wheels".
    Well, now that I've destroyed everyone's hopes and dreams, I guess I'll shut up for a while. :p
    Well it's not like I'm alone in opinions about Fiat and Maserati. As for 3-wheelers, my main objection is that you get to hit every pothole imaginable no matter which way you steer. But sure, on a nice flat road on a warm day, a Polaris would be fun. Remember you're talkin' to a man who runs around part of the year on an old Triumph motorcycle.
    edited January 2019
    Maser may be overpriced when new, but that is certainly not what I’m talking about. You can get an 07-08 With very low miles at this point for less than $20k.
    I am sure I would tire of a Fiat mighty quick.
    I'd take my chances on a miled up Cayman (though, you may not fit), at that price.
    Interesting thought.
    There are 911s out there with replaced IMS that could call my name. Couple on BAT right now.
    But, how much older than '07-'08?
    Here is a Cayman S. But that is one funny looking shifter, and someone must have broken off a pedal.
    http://atcm.co/S2PVDP/1df0ce0a
    Love the colors, but I'd have to put in some black floor mats. No idea why Porsche can't get away from the monochromatic interior.
    But, no stick = no sale.
    Nice Audi. But still short a pedal.
    Pretty sure Audi doesn’t know manual trans’ still exist. ;b
    So, stick, somebody posted elsewhere the following:
    ok, so as promised I would give feedback on my attempt to lease a car from the Honcker app. I called them to tell them what vehicle I wanted to lease and make sure all pricing was correct and included…before they did a hard credit check…and surprise surprise they told me that the pricing was ‘off’…that ‘unfortunately’ the pricing listed was from some time in December and hasn’t been updated…and it would be about $40 more/month now. I asked if this was just for this car or all Jeeps or ALL cars on the site and I was told…ALL cars on the site currently show the wrong prices. (obviously this means they have been showing the wrong prices for all the cars for at least 3 - 4 weeks!). But, if I want to pay the higher price, they would be higher to process my order (for about $40 more a month for 39 months, lol). Of course I told them to get bent, asked why they even have the appp up and running until they fix pricing? or say on the front page…please note prices are estimated not exact at this time’…and i didn’t get a very good answer obviously, In summary…I guess my advice would be to steer clear of this app! Far far away…
    Interesting. Thanks. Right now, I just use it for amusement purposes. Price was as presented back in December though!
    My account at Ally finally shows closed. Whew!
    Yes, though if you can drive more than a few miles without it overheating... you already won! :)
    edited January 2019
    Maserati brand was part of a WarrantyDirect survey. Score? 36th place out of.........36!
    The various Maserati boards are rather fascinating to read. Owners seem to be really in a love/hate thing with them.
    One guy said his 2009 has been "dead reliable" and then proceeded to list about 11 things that went wrong with it.
    Another post was classic: "NO PROBLEMS WHATSOEVER in the last 3 months, 3000 miles".
