1169416951697169917003236
  • qbrozenqbrozen Member Posts: 33,805
    Was just poking around looking at some deals... Fusion Energi has over 9k in rebates. MSRPs In the high 30s netting out to 300ish/month. If I wasn’t buried in the Elantra I would have to check one out.
    $4,500 DAS is steep.
    If I had seen it a few weeks earlier, I would probably be driving a Fusion hybrid instead of the TLX. Well, the wife would be driving it daily to work. Had a couple on Honcker. sticker was close to $29k. Pretty loaded, even had a moonroof. Was really low DAS (about $1,200) and monthly payment about $204-$212. 36 months, and even better, for 15,000 miles/year. That was a cheap car to roll up miles on, for not much gas. Would have been perfect to take the commuter miles too. Alas, as always, a day late (if not dollar short).
  • tjc78tjc78 Member Posts: 17,357
    That $4500 DAS is without any dealer discount, so it would go way down
    Honcker deal looks even better... shame it’s not October yet!
    run it through carvana and Vroom. Might get surprised!
    edited January 2019
    I did Carvana....almost $3000 back of book.
    ouch. cheaper to turn it in early and make the payments instead.
    Yep that would only be $1600 or so!
  • nyccarguynyccarguy Member Posts: 17,735
    My Infiniti is starting to show signs of weirdness.  Since the weather has gotten cold over the past few months, the power steering belt (I assume) makes a really loud whine at low speeds.  It is especially pronounced when I’m turning left.  Second, when I accelerate while merging, the BRAKE light on the dashboard illuminates (as if the parking brake is set, trust me it isn’t) and the stability control light stays on.  Not sure if I want to bring this to my mechanic or the dealer.  I just hit 42,000 miles and my next oil change isn’t due until 45K.
    it gets warmer next week. So ignore it until them and see if it goes away!
    or, check the brake fluid level. if that gets low (close to the min line) you can get intermittent brake light warning. That usually means you need pads of course, unless there is a leak. The PS issue is probably not the belt, but could be the pump. Really cold temps can cause stuff like this, but you will know soon enough.
    My gut says to start with the mechanic (guy in the Bronx near work, right?) and get the baseline. And go from there. Where do you get the oil changes done? Might be worth just doing that early for convenience.
    or of course, the obvious solution. Trade the sucker in!
  • corvettecorvette Member Posts: 11,622
    I suspected a low brake fluid level, as well. The Yukon will randomly disable the rear parking sensors at low temperatures. The front suspension also creaks over bumps when it's cold out--there's a TSB on it, not really a huge problem, just an annoying noise coming from a bushing, and would probably be a few hundred bucks to fix.
    our RDX had the light flash occasionally when the fluid was low. And our TL had some weird combo of lights at one point, stuff like TCS, and it turned out to be a weak battery. So sometimes the light you see, is not the root cause problem.
    If the Infiniti sits outside, will probably know in the AM if the battery is going. If it can crank when it is 2 degrees, it still has life.
    As for the steering whine, check fluid level on that, too.
    when it gets really cold it makes me whine, so why not a car?
  • xwesxxwesx Member Posts: 17,920
    If it is really cold, then the whining is likely due to thickening of the fluid. At about -20F (ambient, not wind chill) or lower, there is a possibility of blowing a power steering hose. You can swap out with 5606A hydraulic fluid, but, for this short period of time, it probably is not worth the effort. It is very likely that the noise will continue until things warm up.
  • sdasda Member Posts: 7,707
    Isn't it still under warranty?
    Since it has been under warranty, I have brought it to the dealer. It might warrant a look see at my mechanic's here in The Bronx.
    I'll check the brake fluid. Good suggestion.
    Also a good idea. Makes sense. Thank-you!
    It's not THAT cold here. Today was (+4F) in the AM. But this has been happening at 40 degrees & below.
    Powertrain yes, but not Bumper to Bumper. Since my car had less than 15,000 miles, the CPO warranty basically just extends the power train warranty to 75K. If the car had more than 15K miles, I'd have a BtoB extension for 6/100K from the original in service date.
  • au1994au1994 Member Posts: 3,767
    edited January 2019
    Could be the cold weather causing some unusual squeaking and groans. But yes, 40 is not an abnormal temp and if it’s happened then, it might warrant a check and fluid top off.
    Even the Subaru had a few creaks the past 2 days as we’ve had some teens and 20’s in the morning. MPG has also been kinda crap which I’m attributing to the cold and short trips. Went to the office once this week but other than that its been 2-5 mile trips to the gym and other errands. Not ideal since it never really hits a good operating temp.
    Can’t remember if we discussed this one here...
    https://bringatrailer.com/listing/1997-honda-prelude-2/
    It hasn't bid to anywhere near what he paid for it 7 months ago. But...there are 3 hours left.
    https://bringatrailer.com/listing/1970-chevrolet-camaro-12/
    Great. You got me down the rabbit hole.
    I love this one. Including the color. Just need to replace the steering wheel! I could do without the S/C but not throwing it out of bed for that.
    Oh, I think the white lude was mentioned. Flipper likely losing money on that one!
    edited January 2019
    Well, from all the whine I see on the news and social media, I would think it is the apocalypse...! :)
    -19.5C on the car's readout this morning, which equates to what, about -3F? It felt pleasant to me, even if chillier than the past few days.
    edited January 2019
    deleted, wrong forum
    edited January 2019
    Interesting. Maybe they have their warehousing distributed so extensively now that they figure it is more efficient to not use the space on stocking the appliances. They do still stock them here in Alaska, but I imagine the reasoning behind that is fairly obvious! Even though they do not need to compete with the likes of Amazon since Amazon won't ship stuff like that to Alaska anyway.
    Happily, my $400 lightly-used set of Samsung W/D are still humming along contentedly. Hopefully no issues with them for at least five years, preferably fifteen!
    Edit: Whoops! Well, I'm not deleting mine since I think I know the thread on which you meant to post that, and I'm no longer participating in that one.
  • kyfdxkyfdx Moderator Posts: 270,757
    https://bringatrailer.com/listing/2002-bmw-m-coupe-11/
    These bring stupid money, but I still want one
    I think the clown shoe cars are cool too. I’m always one of probably 3 people that likes these.
    https://bringatrailer.com/listing/1974-jensen-healey-mark-2-roadster-2/
    This is wicked cool too.
    https://bringatrailer.com/listing/1966-austin-mini-cooper-s-3/
    edited January 2019
    Just a run of the mill Boxster to my eyes---it's not an S, and it has various little defects. Just a used car. Keep in mind that they cranked out gazillions of these cars over the years.
    Bid seems light at $7K so far but these cars are always for sale in plentiful numbers, so unless a person wants these exact colors/options and price, no reason to get all warm over it. I'd hit it at around $9,500 for average retail. Also don't be over 6 ft tall :)
    The Money Police should arrest that bidder and put his children in a foster home. That's just crazy.
    Jensen seems fair enough at $2,200 for a project car. I wouldn't bid too much more for it. They aren't worth a whole lot.
  • carnaughtcarnaught Member Posts: 3,598
    edited January 2019
    I can’t get past the (majorly ugly) looks of that BMW coupe.
  • ab348ab348 Member Posts: 20,593
    The steering wheel is about the only original thing on the car! But it does look out of place on that.
    Nice enough for sure, but the exhaust will scrape driving over a gum wrapper and you better pray all the work was done properly.
    I saw that one and am curious to see where it lands, I remember seeing the original auction back in April. My guess is some last minute bids will get it to between $7K-$7,500.
    Seller hit a home run at $11,900. However, he put a chunk of change into it, so he probably broke even. Still, strong price regardless.
    Well that certainly took off in the last 10 minutes. $11,500....seller did quite well for himself.
    Sorta...he did some engine work. Still, the bid makes no sense to me. It's about double book and I don't see anything special about the car personally.
    Maybe it's the old "Swedish Meatball Theory" in action? **
    ** That's when the Swedish meatballs at a reception sit untouched for hours in a chafing dish and then guys starting scooping them into a dish, and then everybody in the room suddenly wants some.
    There is no rhyme/reason to pricing on Preludes, people are all over the board. Mine is 1 year older and has 100,000 more miles but I don't see how that constitutes a price that is about double what I paid. The overall condition and is arguably very similar and mine was maintained just as well with records to back that up.
    edited January 2019
    anybody want to go fast around a corner in this?
    https://www.cars.com/vehicledetail/detail/761268070/overview/?aff=acqem52&emc=acqem52
    Must have been owned by an old Sidekick owner who missed the adrenaline rush of driving around so precariously
    I love the Swedish Meatball analogy and will shamelessly steal that.
    Heck of a number on the Prelude. Nice and clean but still
    A nice Supra Turbo sold for 15k today as well. Many lamenting the fact it was an automatic.
    Mk 3, which just doesn't get the bids.
    I don’t want it, but there’s something kind of charming about that SX4 as a winter vehicle. The lift would keep it from dragging in a heavy pile of snow.
  • marcogallo1986marcogallo1986 Member Posts: 1,164
     I like the cars hosted a dog about guns, from wearing a trailer.com. Have to go on that site more often I’m not around just cause I can, and I have more free time these days, keeping busy busy with the gym and applying for jobs. A doctors appointment today, lost 25 pounds from last year, so happy good news. I’m doing almost Friday and the couple of hours.
     New York car guy, bring it to your mechanic but since on the warranty I see the appeal of the dealer. Ha ha ha this cold has effects on pores and things I wouldn’t worry too much everyone. Glad to hear from you soon man I had to hear everything‘s going well. This coming up weekend probably Saturday can you go with the fairly new neighbors, we moved here in August, they want to lease a second car, some on the car if they asked him which one  I know a lady here at the Hyundai dealer was a great sales woman who we dealt with a number of years ago when can I bring them to. And some other folks wagon they wanna. Told him look around at all your options you get what you like. His neighbors moved in towards the middle of August I become very friendly with them around my age to in their 30s, had wine with them last Saturday night again this coming up Saturday night too. Just hang out.
    Definitely one of the fugliest vehicles built in the last twenty years. I saw one in person once. Definitely worse. :)
    SX4 cracks me up. Good little cars for what they are. I used to see them around here regularly. But, this one? lots of miles, parked in the middle of a large city, and the description says, "all highway miles." Yeah. Uh-huh.
     Good morning everyone, happy Friday to all in here. I know love these descriptions that people put sometimes hilarious west, anyone doing any car looking this weekend?
