Visitor Agreement.
One daughter is in London, England for a week long conference. I just hope she can break away without having to entertain, to places she wants to go. On the other hand, learning using the food bill as theater & having fun can be very important.
However last time I spent any amount of time in Iowa (i.e. not passing through) it snowed. And that was in June.
Indeed, beers, wines, spirits, spaghetti, pizza, sushi, sashimi, egg rolls, chow mein, fried rice, pastrami sandwiches, wraps, tacos, curries, BBQ meats...etc., etc., etc., Then there are FUSIONS.
(vice versa for other than organic.)😱
Yesterday I had to enter the highway and the cars on the highway were really moving, so I stomped it. The yellow check engine light came on. When I got home I tried turning the car off and then on...it was still on. I checked the manual and it said to unscrew the gas cap and put it on tight....which I did. When we went out this morning for groceries it was on, but just when we came out of the second store it was off, and didn't come on again when we went out.
So I checked up about this light, and I will pass this on in case you come across this;
What problems can trigger the Check Engine Light?
Ranging from minor to major, a slew of things can trigger the check engine light to come on in your Mercedes-Benz, including (but not limited to):
Loose gas cap
Faulty fuel injector
Blown gasket heads
Faulty oxygen sensors
Cracked and loose hoses
Faulty mass air flow sensor
Worn out spark plugs and wiring
Emission control system malfunction
I was going to call and make an appointment on Monday if it didn't clear up. From what I read on some cars it should be looked at as soon as possible, but urgent if flashing....also urgent if it is associated with low oil or radiator overheating.
I think in my case I stomped it and it overwhelmed the air flow sensor or the fuel injector but after driving for awhile it corrected itself. Usually, only the garage can read the code, and reset the light. That was a close one...glad I don't have to take it in.
I don't trust organic food. Organic apples could have worms in them...or even worse if you bite into it half a worm. I like sprayed crops more....perfectly shaped apples with no worm holes, and the sprays help build immunity
There are very strict requirements for anything labeled organic. “Natural” on the other hand, has no requirements whatsoever. https://www.ams.usda.gov/rules-regulations/organic/labeling
For example, the Clubman would set a code once the car went closed-loop; my scanner revealed that the fault was multiple misfires. I checked the service history and noted that the PO had not changed the plugs at 100k miles as required, so I suspected the issue was the plugs as opposed to the coil packs. I replaced the plugs in less than 30 minutes and the problem was solved. Without a scanner your best guess is-at best-a shot in the dark.
If the CEL (aka "the money light") ever blinks rapidly, shut the car down! This means your catalytic is being unduly stressed and could get damaged if you keep rollin'.
Even with a code reader, the actual problem can be elusive. Code readers only tell you the system or circuit that is non-conforming. It doesn't tell you what to replace. Even a $10,000 scanner can't tell you that, without doing a deeper diagnosis.
Without any codes, you are indeed, just guessing---and guessing is expensive.
Exactly, but being a water guy I do know what's in pool water and, well, most people would prefer not to know. In most cases, as long as the chlorine levels are maintained, people will be fine. The world around us and our own bodies are not nearly as sterile as we'd all like to think.
LOL. My list comes from two assumptions: first, non-bottled water is contaminated including what is used to grow crops and prepare food, and second, people don't wash their hands after using the restroom (if there is a restroom). From those two points you can see why each rule I follow exists. Same can be said in a lot of developing countries and even parts of developed ones. The list works and kept me healthy for many months in-country while the folks around me had rather...hmmm..."unpleasant" experiences. One of my employees disappeared over the weekend and then resurfaced Sunday with an emergency call asking me to drop of more toilet paper to his apartment.
Honestly, I felt very privileged to have running water for a shower each day, power about 80% of the time, my own apartment or hotel room, air conditioning, and access to food every day. Very few people around me where I worked had that kind of luxury. I do miss working with the wonderful people there who eventually treated me as one of their own and made me feel so welcome. I admire many parts of their culture and think we westerners could learn more than a few things from them.
Stay safe and healthy
One article said taking the gas cap off and putting it back on was about the only thing you could do on your own.
I know the light went on when I stomped it...the hardest I have ever stomped it.
It could be my imagination but it ran a little rougher after stomping it and the light going on.
I am glad I don't have to take it in, and yes, Mr S., if it is a catalytic problem could be expensive.
Like I say, I am not a mechanical genius, but my wild guess is the air/gas mixture was off, or fuel mixture not right. I guess they can check the codes when i go in for an oil change, maybe?
so, re-install the cap, and see if that works. It does take a few cycles to reset (the car runs tests on all the systems, and sets the light when certain conditions met, then after a defined # of cycles within spec, turns it off).
if the car really was running poorly after your romping, entirely possible it was something else, but also possible you won't cause the out of spec condition again anyway.
Advance auto parts
Oreilly/Checkers
Autozone
What you want is the exact number, PXXXX, such as P0303 in the standard meaning is a misfire on cylinder #3.
Do not let the person just say, "It's a misfire." Or "it's your catalytic converter." and so on...
If you post the code number or numbers here someone may be able to tell you it's the emissions equipment sensing the gas cap wasn't screwed on or there's a leak in the gasoline tank system that controls emissions (I think those are in the 400 series of numbers). Searching for the meaning on the internet will usually give links to the standardized results.
But those numbers point to the sensing device that detected something, and that something may be not directly related to the actual problem. Takes a little intuition and experience.
I submit the code on my leSabre about emissions and leak indicating it was a charcoal canister solenoid not working right that vents the gas tank through charcoal to capture hydrocarbons. That solenoid seals off when the computer does a vacuum test to look for leaks--small or gas cap size.
Changed solenoid under car, not easy. Same result. Turns out it was the little switch that turns the vacuum on to the tank system to suck air in through the canister and the tank to reclaim the captured hydrocarbons. That switch that sits on the top of the hot engine was sticking. That set off the sensor that said the vacuum levels in the tank indicated an air leak.
My son triggered his check engine light by driving around all day with a blown water pump. Engine got so hot he burned a valve. His current inspection is good until October at which point the car will be sold for parts rather than pay $3000 for a valve job.
Fortunately, by then it will have well over 100k miles and he’ll have gotten his use out of it. Unfortunately, he’ll have to inherit the PT. That’ll learn him.
I don’t know about a MB but on run of the mill domestics a $20 code reader can not only scan for codes but erase them too. Next time buy a Chevy.
While I enjoy traveling, the first time anywhere is always a hassle--need to find everything and figure out how things work, even in unfamiliar places in North America, though there aren't that many of them anymore. That's true in spades over here, but I'm pretty well adjusted now, in spite of the 12.5 hour time difference, and beginning to actually enjoy the place.
Having good internet and air conditioning goes a long way.
mechanictechnician resets it.2017 MB E400 , 2015 MB GLK350, 2014 MB C250
Let me second that too. If he likes consulting as much as I did, he'll be doing it till he's 73 like I did. As much fun as it was I finally decided to hang it up before the cleaning crew found me slumped over my keyboard one night.
+1
The way the workplace is these days you could do a lot worse!
Actually, a nice way to see another country...on the company expense account.
