Can I please get the MF, RV and any current incentives on both the 2019 Grand Cherokee Summit (AWD) and SRT in the 12866 zip with 15k miles?
Thank you very much
EDIT: I found this on the last page, guessing it's the same for me.
SUM: .00039 MF and 46% residual. $5000 incentive
SRT: .00077 MF and 49% residual. $500 incentive
$3500 incentive
$4500 incentive
Thank you in advance.
Limited X same program as Limited
Summit numbers are different (and worse)
2WD: .00015 MF and 47% residual
4WD: .00018 MF and 48% residual
SUM: .00039 MF and 48% residual
$3500 incentive
$4500 incentive
$4500 incentive
Can I have the MF, Residual, and incentives for a
Grand Cherokee Limited X 4x4? Zip code 11577.
39/10
RWD or AWD?
$3500 incentive
.00003 MF and 49% residual
$5000 incentive
39 month term is not supported
.00018 MF and 46% residual
$5000 incentive
For all Laredo trims, except base model. Base model has no support.
$5000 incentive
HA: .00017 MF and 51% residual
SUM: .00039 MF and 49% residual
TH: .00004 MF and 50% residual
$3500 incentive on all
OVL: .00017 MF and 50% residual. $3500 incentive
.00003 and 50%
$5000 incentives
LTD 4x2 - .00014 and 48%; $4500 incentives
(hint: stick with the Limited trim)
$3500 incentives
$4500 incentives
$5000 incentives
HA: .00017 MF and 50% residual
$3500 incentive
