2020 Volvo V60 Lease Deals and Prices
kyfdxkyfdx Moderator Posts: 275,130
edited August 2019 in Volvo
Ask your 2020 V60 lease questions here! Get info about prices, money factor, deals, incentives, and payments.
«13456716
  • indiesindies Member Posts: 14
    Hi there! I'd like the MF and RV, incentives, etc. for a 2020 Volvo V60 Cross Country in 72207 if available please.
    36/12 and 36/15 please. The Volvo V60 CC for 2020 only has one trim.
    Dealer has quoted me .00087 and 56% for the 36/12 term. Just wanted to see what you guys were showing on your end. Much appreciated and thanks in advance.
  • kyfdxkyfdx Moderator Posts: 275,130
    .00047 MF and 56% residual
    Looks like a money factor markup
    Thank you so much, really appreciate it.
  • agpopeagpope Member Posts: 2
    edited August 2019
    Hello, could you please let me know the money factor and residual for a 2020 T5 momentum in zip code 29223? 36/12
    Thank you for your help
  • autoboy19autoboy19 Member Posts: 182
    Could you provide the 36/10 lease rates for the following trims in 30313?
    T-5 Momentum
    T-5 Inscription
    .00076 MF and 55% residual
    T-5 Momentum
    T-5 Inscription
    .00076 MF and 56% residual
    .00065 MF and 58% residual
    Thank You!
  • bmathias619bmathias619 Member Posts: 25
    Could you provide the 36/10 lease rates for the following trims for ZIP 06830?
    T5 R-Design
    T8 Polestar
  • MichaellMichaell Moderator Posts: 270,427
    T5 R-Design
    T8 Polestar
    T5 RDES - .00065 and 58%
    I don't see any T8 trims for the 2020 V60
  • IcyJIcyJ Member Posts: 54
    Hi Michaell, good day!
    Can you please post details for:
    36/12, T5 Momentum FWD, 76051
    .00076 and 55%
    No incentives
  • jtmav51jtmav51 Member Posts: 30
    Sept numbers
    Looking to lease a 2020 v60 CC 36 months 15k/yr. would appreciate any updated numbers you may have. I was quoted .00077 mf and 54% residual for August here in the greater Boston area. Thanks for your guidance
    JTMav
    jtmav51 said:
    Sept numbers
    JTMav
    New programs released tomorrow.
    Any update on Sept Numbers my zip is 02053
  • jiholl1621jiholl1621 Member Posts: 9
    edited September 2019
    When you have the Sept Numbers, may I please have the MF, Residual, Incentives, for 36/12 for 2020 V60 Cross Country. Zip Code 07081. Thanks
    .00051 MF and 54% residual
    .00051 MF and 56% residual
    Thanks very much
    jtmav51
    Thnak you!
  • volvohnovolvohno Member Posts: 40
    May I please have the MF, Residual, and Incentives, for 36/15 for 2020 V60 Cross Country. Zip Code 45215. Thanks!
    .00051 and 54%
    No incentives
  • WSOLA572WSOLA572 Member Posts: 1
    Can I please have Residual and MF for T5 MOM FWD 36/10 - 78745- and for the CC 36/10. Thanks.
    T5 MOM - .00082 and 56%
    T5 CC - .00051 and 57%
    No incentives
    I had a general question, is it common for dealers to mark up the money factor or mark down the residual or is it an uncommon practice? I have dealt with a couple of dealers and one was definitely marking up and the other was inline with what you offer monthly. Sorry for the naive question
    JTMav
    JTMav
    The dealer can't alter the residual.
    Yes, it's somewhat common for luxury make dealers to markup the money factor.
    Good thing you know the base rate!
  • dfennigdfennig Member Posts: 21
    What is the MF and RV on a 36mo/12k yr lease?
    And what is the MF if I were to do a single pay lease?
    The dealer is quoting me .00041 if I put down the max security deposits allowed (he says 10) but if I do the single pay it's .0007.
    This is for the 80202 zip code.
    This is for the 2020 V60 Cross Country?
    Looks like they are taking a big markup, before applying the money factor reductions.
    Pretty sure that max MSDs drop the rate by .00045 (.00011 result).
    Not positive about single pay reduction amount, but it likely would take .00051 down to the minimum, which is .00005.
    Correct, this is for a 2020 V60 CC. The MSRP is $54,400 and I'm buying it for $51,400 which seems to be a pretty good offer, even with the rate bump, wouldn't you agree?
    Nah, I'd tell the dealer that I won't sign anything unless I get the base MF.
    edited October 2019
    Thanks for the info but after talking it over with my wife we decided to put down 50% and finance it for 48 months.
    That works, too.
  • dps06dps06 Member Posts: 91
    Could you provide the lease rates for 36/10 for the following trims in 30022?
    T-5 Momentum
    T-5 R-design
    T-5 Momentum
    T-5 R-design
    .00082 MF and 56% residual
    .00069 MF and 58% residual
    No incentives
    edited October 2019
    Oct numbers for 2020 v60 cc zip code 02053 36 and 15k/yr, please. Thanks for this very helpful resource.
    JTMav
    JTMav
    No incentives
  • mhpdx111mhpdx111 Member Posts: 44
    Is there any difference based on zip code? 97005 if it matters.
    Can I get MF/RV and incentives for a 2020 T5 R-Design V60 (non-CC)?
    thanks very much.
    thanks very much.
    .00069 and 58%
    No incentives
  • cea20008cea20008 Member Posts: 14
    Can you please confirm the MF and the residual for a 2020 V60 CC, zip is 20015.
    36mons/7500 miles
    Also - how much can the MF be reduced using MSDs?
    36mons/7500 miles
    .00051 MF and 58% residual
    9 MSDs X .00005 = .00045 reduction
  • MxwlBishMxwlBish Member Posts: 9
    Can someone please provide me with the MF & RV for a 2020 V60 T5 Momentum. Zip 75009?
    36mos/15k miles
    36mos/15k miles
    .00082 and 53%
    No incentives
  • terryalterryal Member Posts: 5
    Can you please provide me with the MF and RV for a 2020 V60 cross country. 36 months/12k miles. Zip 07901.
    .00051 and 56%
    No incentives
  • Aeg18Aeg18 Member Posts: 1
    Are you able to provide numbers for 2020 v60 polestar and v60 rdesign 36m/7.5k miles? Zip 19130
    RDES - .00069 and 59%; no incentives
    No Polestar numbers, this month
  • ms02113ms02113 Member Posts: 11
    May I please have Residual and MF for '20 T5 MOM FWD 36/10 - 02129. Many thanks!
    .00082 and 56%
    No incentives
    edited November 2019
    I take delivery of a custom ordered 2020 V60 CC this month sometime. The terms of my lease will be either the Sept numbers which for a 36 month 15k/yr were .00051 and 54% or if the Nov terms are better then they would apply. I would appreciate the Nov numbers for a 36 month 15k lease. I am using the “pull ahead” program to turn my 2017 Volvo 6 months early and slightly under miles, unsure if there are any incentives if they would still apply while using the early termination.
    As always thanks for your help and advice
    JTMav
